I have gotten an expression:
eq21 := collect(eq20, [exp(-sqrt(s)*x/sqrt(Dp)), exp(sqrt(s)*(-lh+x)/sqrt(Dp)), exp((-2*lh+x)*sqrt(s)/sqrt(Dp)), exp((lh-x)*sqrt(s+thetac)/sqrt(Dc))], simplify);
q(x, s) = exp(-sqrt(s)*x/sqrt(Dp))*_F1(s)+sqrt(Dp)*(-Dp*sqrt(s+thetac)*alpha1*pinf*s^2-2*Dp*sqrt(s+thetac)*alpha1*pinf*s*thetac-Dp*sqrt(s+thetac)*alpha1*pinf*thetac^2+A2*Dp*sqrt(s+thetac)*alpha1*s+A2*Dp*sqrt(s+thetac)*alpha1*thetac+Dc*sqrt(s+thetac)*alpha1*pinf*s^2+Dc*sqrt(s+thetac)*alpha1*pinf*s*thetac+A1*Dc*alpha1*s^2+A1*Dc*alpha1*s*thetac+A1*sqrt(Dc)*sqrt(s+thetac)*s^2+A1*sqrt(Dc)*sqrt(s+thetac)*s*thetac-A2*Dc*sqrt(s+thetac)*alpha1*s)*exp(sqrt(s)*(-lh+x)/sqrt(Dp))/((s+thetac)^(3/2)*(-sqrt(Dp)*alpha1+sqrt(s))*s*(Dc*s-Dp*s-Dp*thetac))+(sqrt(Dp)*alpha1+sqrt(s))*_F1(s)*exp((-2*lh+x)*sqrt(s)/sqrt(Dp))/(-sqrt(Dp)*alpha1+sqrt(s))+Dc*A1*exp((lh-x)*sqrt(s+thetac)/sqrt(Dc))/((Dc*s-Dp*s-Dp*thetac)*sqrt(s+thetac))-(-pinf*s-pinf*thetac+A2)/((s+thetac)*s)
I need to further simplify the coefficient of
Would you like to give some tips?
how to calculate potential energy in terms of gauss curvature?
how to find back a patch in maple from Pi+GaussCurvature*Area(triangle) = Pi
EFG := proc(X)
local Xu, Xv, E, F, G;
Xu := <diff(X[1],u), diff(X[2],u), diff(X[3],u)>;
Xv := <diff(X[1],v), diff(X[2],v), diff(X[3],v)>;
E := DotProduct(Xu, Xu, conjugate=false);
F := DotProduct(Xu, Xv, conjugate=false);
G := DotProduct(Xv, Xv, conjugate=false);
simplify([E,F,G]);
UN := proc(X)
local Xu,Xv,Z,s;
Z := CrossProduct(Xu,Xv);
s := VectorNorm(Z, Euclidean, conjugate=false);
simplify(<Z[1]/s|Z[2]/s|Z[3]/s>,sqrt,trig,symbolic);
end:
lmn := proc(X)
local Xu,Xv,Xuu,Xuv,Xvv,U,l,m,n;
Xuu := <diff(Xu[1],u), diff(Xu[2],u), diff(Xu[3],u)>;
Xuv := <diff(Xu[1],v), diff(Xu[2],v), diff(Xu[3],v)>;
Xvv := <diff(Xv[1],v), diff(Xv[2],v), diff(Xv[3],v)>;
U := UN(X);
l := DotProduct(U, Xuu, conjugate=false);
m := DotProduct(U, Xuv, conjugate=false);
n := DotProduct(U, Xvv, conjugate=false);
simplify([l,m,n],sqrt,trig,symbolic);
GK := proc(X)
local E,F,G,l,m,n,S,T;
S := EFG(X);
T := lmn(X);
E := S[1];
F := S[2];
G := S[3];
l := T[1];
m := T[2];
n := T[3];
simplify((l*n-m^2)/(E*G-F^2),sqrt,trig,symbolic);
sph := <f(u,v)|g(u,v)|h(u,v)>;
cur := GK(sph);
X := sph;
AreaTriangle := int(int(Z[1]^2+Z[2]^2+Z[3]^2,v=-Pi/2..Pi/2),u=0..2*Pi);
dsolve(Pi+cur*AreaTriangle = Pi, [f(u,v),g(u,v),h(u,v)]);
I have a package of routines meant to help Danish highschool students use Maple. I would like to use MapleCloud to distribute this but have run into a major stumbling block:
While Maple is perfectly happy to use non-latin letters such as the Scandinavian letters æ, ø and å it seems that MapleCloud can't handle that. Specifically, strings containing such letters is displayed in garbled form (the non-latin letters are shows as squares), and symbolic names containing such characters seems not to be recognized. The latter problem in particular makes MapleCloud quite useless to me.
I have attached a simple workbook demonstrating the problems to this message.
 i need a help on how to find the local truncation error of a hybird block method of three order IVP. here is the one of the discrete methods i need to find the local truncation error. please any solution should put here thanks
Please can someone help with maple comand to obtain Jacobian elliptic functions particularly in code editing region?
this equation is complicated
how to dsolve for this equation for function f ?
f(t,x,diff(x,t)) - f(t,x,p) - (diff(x,t)-p)*diff(f(t,x,p), p) = tan(t)
updated:
P := evalm(p2 + c*vector([cos(q1+q2+q3), sin(q1+q2+q3)]));
with(Groebner):
p1 := vector([a*cos(q1), a*sin(q1)]);
p2 := evalm(p1 + b*vector([cos(q1+q2), sin(q1+q2)]));
Pe := map(expand, P);
A := {cos(q1) = c1, sin(q1) =s1, cos(q2)=c2, sin(q2)=s2, cos(q3)=c3, sin(q3)=s3};
P := subs(A, op(Pe));
F1 := [x - P[1], y - P[2], s1^2+c1^2-1, s2^2+c2^2-1, s3^2+c3^2-1 ];
F2 := subs({a=1, b=1, c=1}, F1);
g2 := Basis(F2, plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[1], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[2], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[3], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[4], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[5], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[6], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[7], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[8], plex(c3, s3, c2, s2, c1, s1));
LeadingTerm(g2[9], plex(c3, s3, c2, s2, c1, s1));
                                   1, c1
                               2       2    2   2
                           16 y  + 16 x , s1  s2
                                 8 x, c1 s2
                                2      2    2
                             2 y  + 2 x , s1  c2
                                 2 x, c1 c2
                            3            2
                         2 x  - 2 x + 2 y  x, s2 c2
                                   1, c2
                                   2 x, s3
                                    2, c3
originally i think
g2[1], g2[7], g2[9] have single variables c1, c2, c3 respectively
can be used to solve system
but without x and y, these equations can not be used
if choose leading term has x and y , but there is no single variable s1 or c1.
originally expect solve as follows
g2spec := subs({x=1, y=1/2}, [g2[3],g2[5],g2[6]]);
S1 := [solve([g2spec[1]])];
q1a := evalf(arccos(S1[1]));
q1b := evalf(arccos(S1[2]));
S2 := [solve(subs(s1=S1[1], g2spec[2])), solve(subs(s1=S1[2], g2spec[2])) ];
q2a := evalf(arccos(S2[1]));
q2b := evalf(arccos(S2[2]));
S3 := [solve(subs(s1=S2[1], g2spec[2])), solve(subs(s1=S2[2], g2spec[2])) ];
q2a := evalf(arccos(S3[1]));
q2b := evalf(arccos(S3[2]));
 MaplePrimes member has sent you a message on MaplePrimes.
Member: faisal http://www.mapleprimes.com/users/faisal
E-Mail Address:
> restart; with(PDETools), with(plots);
> n := .3; Pr := 7; Da := 0.1e-4; Nb := .1; Nt := .1; tau := 5;
> Eq1 := (1-n)*(diff(f(x, y), `$`(y, 3)))+(1+x*cot(x))*f(x, y)*(diff(f(x, y), `$`(y, 2)))-(diff(f(x, y), y))/Da+(diff(f(x, y), y))^2+n*We*(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), `$`(y, 3)))+sin(x)*(theta(x, y)+phi(x, y))/x = x*((diff(f(x, y), y))*(diff(f(x, y), y, x))+(diff(f(x, y), `$`(y, 2)))*(diff(f(x, y), x)));
> Eq2 := (diff(theta(x, y), `$`(y, 2)))/Pr+Nt*(diff(theta(x, y), y))^2/Pr+Nb*(diff(phi(x, y), y))*(diff(theta(x, y), y))/Pr+(1+x*cot(x))*f(x, y)*(diff(theta(x, y), y)) = x*((diff(f(x, y), y))*(diff(theta(x, y), x))+(diff(theta(x, y), y))*(diff(f(x, y), x)));
> Eq3 := Nb*(diff(phi(x, y), `$`(y, 2)))/(tau*Pr)+Nt*(diff(theta(x, y), `$`(y, 2)))/(tau*Pr)+(1+x*cot(x))*f(x, y)*(diff(phi(x, y), y)) = x*((diff(f(x, y), y))*(diff(phi(x, y), x))+(diff(phi(x, y), y))*(diff(f(x, y), x)));
> ValWe := [0, 5, 10];
> bcs := {Nb*(D[2](phi))(x, 0)+Nt*(D[2](theta))(x, 0) = 0, f(0, y) = ((1/12)*y)^2*(6-8*((1/12)*y)+3*((1/12)*y)^2), f(x, 0) = 0, phi(0, y) = -.5*y, phi(x, 12) = 0, theta(0, y) = (1-(1/12)*y)^2, theta(x, 0) = 1, theta(x, 12) = 0, (D[2](f))(x, 0) = Da^(1/2)*(D[2, 2](f))(x, 0)+Da*(D[2, 2, 2](f))(x, 0), (D[2](f))(x, 12) = 0};
> pdsys := {Eq1, Eq2, Eq3}; for i to 3 do We := ValWe[i]; ans[i] := pdsolve(pdsys, bcs, numeric) end do;
> p1 := ans[1]:-plot(theta(x, y), x = 1, color = blue); p2 := ans[2]:-plot(theta(x, y), x = 1, color = green); p3 := ans[3]:-plot(theta(x, y), x = 1, color = black);
> plots[display]({p1, p2, p3});
please help me on check my schmitt2.msim schmitt's trigger
I would like to publish a technical paper about a renewable energy with you. I use Maple 2016. What i need?. Thanks!
im stuck here also still produces output but yeah  oh well :
with(Statistics):
`&Dopf;` := ["<","&",">","@"]; d[0] := `&Dopf;`[1]; d[1] := `&Dopf;`[2]; Y1 := {}; W1 := {}; W2 := {}; S[1] := proc (S, d) options operator, arrow; StringTools:-Split(S, d) end proc; S[2] := proc (S, d) options operator, arrow; StringTools:-Join(S, d) end proc; N := Count(FileTools[ListDirectory]("C:\\")); M := 0; while M <= N do M := M+1; S[0] := FileTools[ListDirectory]("C:\\")[M]; W1 := `union`({seq(seq(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. N)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = n .. m)}), n = 1 .. m), m = 1 .. N)}, W1); W2 := `union`(W2, {seq(Count(convert(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}), 'list')), n = 2 .. N)}) end do; Y1 := convert(ListTools['Flatten'](map(convert, convert(W1, 'list'), 'list')), 'set'); d[0] := "."; d[1] := "."; Y2 := {}; W3 := {}; W4 := {}; S[1] := proc (S, d) options operator, arrow; StringTools:-Split(S, d) end proc; S[2] := proc (S, d) options operator, arrow; StringTools:-Join(S, d) end proc; N := Count(FileTools[ListDirectory]("C:\\")); M := 0; while M <= N do M := M+1; S[0] := FileTools[ListDirectory]("C:\\")[M]; W3 := `union`({seq(seq(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. N)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = n .. m)}), n = 1 .. m), m = 1 .. N)}, W3); W4 := `union`(W4, {seq(Count(convert(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}), 'list')), n = 2 .. N)}) end do; Y2 := convert(ListTools['Flatten'](map(convert, convert(W3, 'list'), 'list')), 'set'); Y3 := `union`(Y2, Y1); `&Dopf;` := ["<","&",">","@"]; d[0] := `&Dopf;`[3]; d[1] := `&Dopf;`[4]; Y1 := {}; W1 := {}; W2 := {}; S[1] := proc (S, d) options operator, arrow; StringTools:-Split(S, d) end proc; S[2] := proc (S, d) options operator, arrow; StringTools:-Join(S, d) end proc; N := Count(FileTools[ListDirectory]("C:\\")); M := 0; while M <= N do M := M+1; S[0] := FileTools[ListDirectory]("C:\\")[M]; W1 := `union`({seq(seq(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. N)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = n .. m)}), n = 1 .. m), m = 1 .. N)}, W1); W2 := `union`(W2, {seq(Count(convert(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}), 'list')), n = 2 .. N)}) end do; Y1 := convert(ListTools['Flatten'](map(convert, convert(W1, 'list'), 'list')), 'set'); d[0] := "."; d[1] := "."; Y2 := {}; W3 := {}; W4 := {}; S[1] := proc (S, d) options operator, arrow; StringTools:-Split(S, d) end proc; S[2] := proc (S, d) options operator, arrow; StringTools:-Join(S, d) end proc; N := Count(FileTools[ListDirectory]("C:\\")); M := 0; while M <= N do M := M+1; S[0] := FileTools[ListDirectory]("C:\\")[M]; W3 := `union`({seq(seq(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. N)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = n .. m)}), n = 1 .. m), m = 1 .. N)}, W3); W4 := `union`(W4, {seq(Count(convert(`intersect`({seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}, {seq(Delete(S[2](S[1](S[0], d[0]), d[1]), i .. i), i = 1 .. n)}), 'list')), n = 2 .. N)}) end do; Y2 := convert(ListTools['Flatten'](map(convert, convert(W3, 'list'), 'list')), 'set'); `minus`(Y2, Y1); Y3 := `union`(Y2, Y1)
Error, invalid subscript selector
{"ARS.csv", "BOONXT", "BOOTNT", "BOOTNX", "BOOTNXT", "BOOTXT", "BOTNXT", "O", "OOTNXT", "OS", "OeDrive", "OnDrive", "OneDive", "OneDrie", "OneDriv", "OneDrve", "Onerive", "PefLogs", "PerLogs", "PerfLgs", "PerfLog", "PerfLos", "Perfogs", "PrfLogs", "Rcovery", "Recoery", "Recover", "Recovey", "Recovry", "Recvery", "Reovery", "S", "SSETUP", "SWETUP", "SWSETP", "SWSETU", "SWSETUP", "SWSEUP", "SWSTUP", "Uers", "User", "Users", "Uses", "Usrs", "VAR.csv", "VARS.cs", "VARS.cv", "VARS.sv", "VARScsv", "VAS.csv", "VRS.csv", "WSETUP", "Widows", "Windos", "Window", "Windows", "Windws", "Winows", "Wndows", "ecovery", "emp", "erfLogs", "h", "hp", "ietpub", "indows", "inepub", "inetpb", "inetpu", "inetpub", "inetub", "intpub", "neDrive", "netpub", "p", "sers", "tem", "temp", "tep", "tmp", "$ECYCLE.BIN", "$RCYCLE.BIN", "$RECCLE.BIN", "$RECYCE.BIN", "$RECYCL.BIN", "$RECYCLE.BI", "$RECYCLE.BIN", "$RECYCLE.BN", "$RECYCLE.IN", "$RECYCLEBIN", "$RECYLE.BIN", "$REYCLE.BIN", "Cnfig.Msi", "Cofig.Msi", "Confg.Msi", "Confi.Msi", "Config.Mi", "Config.Ms", "Config.Msi", "Config.si", "ConfigMsi", "Conig.Msi", "EEETREETRT.csv", "EEETREETRT.xls", "ETSTAT.csv", "Flders.csv", "Foders.csv", "Folder.csv", "Folders.cs", "Folders.csv", "Folders.cv", "Folders.sv", "Folderscsv", "Foldes.csv", "Foldrs.csv", "Folers.csv", "HddenFiles.csv", "HiddeFiles.csv", "HiddenFies.csv", "HiddenFile.csv", "HiddenFiles.cs", "HiddenFiles.csv", "HiddenFiles.cv", "HiddenFiles.sv", "HiddenFilescsv", "HiddenFils.csv", "HiddenFles.csv", "Hiddeniles.csv", "HiddnFiles.csv", "HidenFiles.csv", "MRescueDisk", "MaageEngine", "ManaeEngine", "ManagEngine", "ManageEgine", "ManageEngie", "ManageEngin", "ManageEngine", "ManageEngne", "ManageEnine", "Managengine", "MangeEngine", "MnageEngine", "NEEEREETRT.csv", "NEEEREETRT.xls", "NEEETEETRT.csv", "NEEETEETRT.xls", "NEEETREERT.csv", "NEEETREERT.xls", "NEEETREETR.csv", "NEEETREETR.xls", "NEEETREETRT.cs", "NEEETREETRT.csv", "NEEETREETRT.cv", "NEEETREETRT.ls", "NEEETREETRT.sv", "NEEETREETRT.xl", "NEEETREETRT.xls", "NEEETREETRT.xs", "NEEETREETRTcsv", "NEEETREETRTxls", "NEEETREETT.csv", "NEEETREETT.xls", "NEEETRETRT.csv", "NEEETRETRT.xls", "NEETREETRT.csv", "NEETREETRT.xls", "NESTAT.csv", "NETSAT.csv", "NETSTA.csv", "NETSTAT.cs", "NETSTAT.csv", "NETSTAT.cv", "NETSTAT.sv", "NETSTATcsv", "NETSTT.csv", "NETTAT.csv", "NTSTAT.csv", "NeStatReport", "NestatTable.csv", "NetSatReport", "NetStaReport", "NetStatReort", "NetStatRepor", "NetStatReport", "NetStatRepot", "NetStatReprt", "NetStatRport", "NetStateport", "NetSttReport", "NetsatTable.csv", "NetstaTable.csv", "NetstatTabe.csv", "NetstatTabl.csv", "NetstatTable.cs", "NetstatTable.cv", "NetstatTable.sv", "NetstatTablecsv", "NetstatTale.csv", "NetstatTble.csv", "Netstatable.csv", "NetsttTable.csv", "NettatReport", "NettatTable.csv", "NtStatReport", "NtstatTable.csv", "OneDrive", "PerfLogs", "Pogram Files", "PogramData", "Prgram Files", "PrgramData", "Progam Files", "ProgamData", "Progra Files", "PrograData", "Program Fies", "Program File", "Program Files", "Program Fils", "Program Fles", "Program iles", "ProgramDaa", "ProgramDat", "ProgramData", "ProgramDta", "ProgramFiles", "Programata", "Progrm Files", "ProgrmData", "Proram Files", "ProramData", "RECYCLE.BIN", "Recovery", "SSTEM.SAV", "SYSEM.SAV", "SYSTE.SAV", "SYSTEM.AV", "SYSTEM.SA", "SYSTEM.SAV", "SYSTEM.SV", "SYSTEMSAV", "SYSTM.SAV", "SYTEM.SAV", "TMRecueDisk", "TMResceDisk", "TMRescuDisk", "TMRescueDik", "TMRescueDis", "TMRescueDisk", "TMRescueDsk", "TMRescueisk", "TMResueDisk", "TMRscueDisk", "TMescueDisk", "TRescueDisk", "VARS.csv", "YSTEM.SAV", "_Argon__.tmp", "__Agon__.tmp", "__Argn__.tmp", "__Argo__.tmp", "__Argon_.tmp", "__Argon__.mp", "__Argon__.tm", "__Argon__.tmp", "__Argon__.tp", "__Argon__tmp", "__Aron__.tmp", "__rgon__.tmp", "agefile.sys", "anageEngine", "apleAUTO.txt", "etStatReport", "etstatTable.csv", "iddenFiles.csv", "maleAUTO.txt", "mapeAUTO.txt", "maplAUTO.txt", "mapleATO.txt", "mapleAUO.txt", "mapleAUT.txt", "mapleAUTO.tt", "mapleAUTO.tx", "mapleAUTO.txt", "mapleAUTO.xt", "mapleAUTOtxt", "mapleUTO.txt", "mpleAUTO.txt", "olders.csv", "onfig.Msi", "paefile.sys", "pagefie.sys", "pagefil.sys", "pagefile.ss", "pagefile.sy", "pagefile.sys", "pagefile.ys", "pagefilesys", "pagefle.sys", "pageile.sys", "pagfile.sys", "pgefile.sys", "rogram Files", "rogramData", "sapfile.sys", "swafile.sys", "swapfie.sys", "swapfil.sys", "swapfile.ss", "swapfile.sy", "swapfile.sys", "swapfile.ys", "swapfilesys", "swapfle.sys", "swapile.sys", "swpfile.sys", "wapfile.sys", "Dcuments and Settings", "Docments and Settings", "Docuents and Settings", "Documens and Settings", "Document and Settings", "Documents ad Settings", "Documents an Settings", "Documents and Setings", "Documents and Settigs", "Documents and Setting", "Documents and Settings", "Documents and Settins", "Documents and Settngs", "Documents and Sttings", "Documents and ettings", "Documents andSettings", "Documents nd Settings", "Documentsand Settings", "Documets and Settings", "Documnts and Settings", "Douments and Settings", "NetstatTable.csv", "Pogram Files (x86)", "Prgram Files (x86)", "Progam Files (x86)", "Progra Files (x86)", "Program Fies (x86)", "Program File (x86)", "Program Files (86)", "Program Files (x6)", "Program Files (x8)", "Program Files (x86", "Program Files (x86)", "Program Files x86)", "Program Files(x86)", "Program Fils (x86)", "Program Fles (x86)", "Program iles (x86)", "ProgramFiles (x86)", "Progrm Files (x86)", "Proram Files (x86)", "ocuments and Settings", "rogram Files (x86)", "Sstem Volume Information", "Sysem Volume Information", "Syste Volume Information", "System Vlume Information", "System Volme Information", "System Volue Information", "System Volum Information", "System Volume Iformation", "System Volume Infomation", "System Volume Inforation", "System Volume Informaion", "System Volume Informatin", "System Volume Informatio", "System Volume Information", "System Volume Informaton", "System Volume Informtion", "System Volume Infrmation", "System Volume Inormation", "System Volume nformation", "System VolumeInformation", "System Voume Information", "System olume Information", "SystemVolume Information", "Systm Volume Information", "Sytem Volume Information", "ystem Volume Information", "CmpleteCurrentFileExtensionASSOClist.csv", "ComleteCurrentFileExtensionASSOClist.csv", "CompeteCurrentFileExtensionASSOClist.csv", "CompleeCurrentFileExtensionASSOClist.csv", "CompletCurrentFileExtensionASSOClist.csv", "CompleteCrrentFileExtensionASSOClist.csv", "CompleteCurentFileExtensionASSOClist.csv", "CompleteCurrenFileExtensionASSOClist.csv", "CompleteCurrentFieExtensionASSOClist.csv", "CompleteCurrentFilExtensionASSOClist.csv", "CompleteCurrentFileEtensionASSOClist.csv", "CompleteCurrentFileExensionASSOClist.csv", "CompleteCurrentFileExtenionASSOClist.csv", "CompleteCurrentFileExtensinASSOClist.csv", "CompleteCurrentFileExtensioASSOClist.csv", "CompleteCurrentFileExtensionASOClist.csv", "CompleteCurrentFileExtensionASSClist.csv", "CompleteCurrentFileExtensionASSOCist.csv", "CompleteCurrentFileExtensionASSOlist.csv", "CompleteCurrentFileExtensionSSOClist.csv", "CompleteCurrentFileExtensonASSOClist.csv", "CompleteCurrentFileExtesionASSOClist.csv", "CompleteCurrentFileExtnsionASSOClist.csv", "CompleteCurrentFilextensionASSOClist.csv", "CompleteCurrentFleExtensionASSOClist.csv", "CompleteCurrentileExtensionASSOClist.csv", "CompleteCurretFileExtensionASSOClist.csv", "CompleteCurrntFileExtensionASSOClist.csv", "CompleteurrentFileExtensionASSOClist.csv", "ComplteCurrentFileExtensionASSOClist.csv", "CopleteCurrentFileExtensionASSOClist.csv", "ompleteCurrentFileExtensionASSOClist.csv"}
Download MAPLE_BITTY.mw
I have a very large set of equations that calculates for a long time. Up until now, I have designated the second derivatives and copied the finished equation to another program to do the simulation. But with this file I can hardly do anything because the equations are too long. Even saving a file after computation is not easy. Export to PDF takes 20 minutes and the file has 120 MB and 1000 pages. Recording to .mw has not gone yet due to the occurrence of a write error message. I have 16 GB of RAM and after calculation is 14 GB in use.
5._Równanie_z_5_niewiadomymi.mw
Any suggestions?
I was wondering if it were possible to call only the mapping function used to grahically display using a particular plot command in general, but aside from that, this is the one in specific id really like, naturally, since thats a bit of a hole in the understanding of what you are looking at thats probably important in some way to something.
Sorry yes as the title suggests, id like to know how to execute keyboard and mouse pad actions in an automata of sorts.
First 166 167 168 169 170 171 172 Last Page 168 of 371
