In the help page for invlaplace we find the statement
"If the option opt is set to 'NO_INT', then the program will not resort to integration of the original problem if all other methods fail.  This will increase the speed at which the transform will run."
This statement is found in Maple 2017 and in Maple 8 and I believe in all versions in between.
Can anyone provide an example of a function F(s), where
invlaplace( F(s) ,s, t, NO_INT);
gives a different result (or works faster) than
invlaplace( F(s) ,s, t);
## It should be added that an identical statement is made in the help page for laplace itself.
Hello!
I have a problem with calculations. I have a worksheet and it calculated on some computer but on another i have an error after each equation. I dont have any idea why. When i click on error i see "Sorry, we do not have specific information about your error. " What can i doo with this?
salute ! all Maplesoft managers and employee programers ...
Is there any fortune in near future to have some kind of machin based "Proof Assistant" as built in part of Maple IDE ?
it can be better than COQ ?
also there is a great lack of user interactivity by Geometry and Geometry3d packages of maple !!!
for example most of the time it is nessesary (and more facilated) to define geometrical primitive shapes manually or making simple transformations and dissectings attaching ... rather than doing them programaticaly or by commands ?
even having traditional tools like compass ruler ... in pallettes of Geometry window ?
BEST WISHES FOR MAPLESOFT
I'm trying to solve Laplace's equation in Maple in 2-D domain. But while writing the last line "pdsolve(pdef)" (to get the final solution) and after that hitting enter, it doesn't shows anything. Please help me regaring this.
f := -ln(-1-ln(exp(x)))+ln(-ln(exp(x)))-Ei(1, -1-ln(exp(x)))+Ei(1, -ln(exp(x)))
solve(limit(diff((subs(x=q, f)-f),h), h=0) = f, q);
limit(diff((subs(x=x*h, f)-f),h), h=0);
Error, (in limit/dosubs) invalid input: `limit/dosubs` uses a 3rd argument, newx, which is missing
guess an operator called Lee, Lee(f, x) = f
suspect q = x*h or q=x*f
limit(diff((subs(x=f*h, f)-f),h), h=0);
Error, (in depends/internal) invalid input: `depends/internal` uses a 2nd argument, x, which is missing
A few days ago I was browsing through some books in my collection, that by Gradshteyn and Ryzhik in particular. What fraction of the intregrals, series and products therein can Maple handle correctly?  Besides special functions these properties are valuable components of symbolic mathematical software.  If the answer to this question is not nearly everything in that printed compilation, this inclusion in Maple is a worthy objective.
I am trying to solve the particular system of partial differential equation. But I get the following error.pdsolve.mw
"restart;  f(x,y):=x*y:  yy:={diff(f(x,y),x)=0,diff(f(x,y),y)=0}:  ee:=pdsolve(yy,numeric);"
Error, (in pdsolve/numeric) invalid subscript selector
Download pdsolve.mw
Hi, i encountered this, error, and the link to the help page was broken.
Error, (in RootOf) expression independent of _S000100
Hi every body :
I want to slove this below PDE with conditions 1&2, can every body help me, tnx.
PDE := diff(u(x, t), t)+6*u(x, t)*(diff(u(x, t), x))+diff(u(x, t), x, x, x) = 0;
1.x=0
2.assume t is step function(Heaviside).
with regards....
See Wiki and the description  in flame_draves.pdf for info and an example below.
I am writing a matrix to file where each matrix element is placed on a new line. An example of such code:
HH:=Matrix([[x**2,x**z,z**12],[2*x,5**y,6**1]]):
filenameHH:=fopen("test.txt",WRITE,TEXT):
nRow,nCol :=LinearAlgebra[Dimension](HH);
for i from 1 to nRow do
   for j from 1 to nCol do
      fprintf(filenameHH,"%a\n",HH[i,j]):
fclose(filenameHH):
When this is printed to file, it will print as the power sign ^ regardless of the input it is given. This particular output file will be read in by another language, and due to this the power symbol "^" is not desired, but instead " ** ". By converting the matrix into a string format and applying string operations, this can be done; but is there a simpler way to do it?
-Yeti
Hey friends
I want to solve this relation with respect to "M"analytically but maple answer me: "Warning, solutions may have been lost"
How I can solve this problem and get to an analytical solution. It must be noted -1<w<-1/3. we can fix "w" with any value inn this interval. It be accepted any solution for any fixed "w".
Analytically_solution.mw
the following code results in an error message: Error, (in forget) lexically scoped parameter out of context
If I click on this error message, it brings me to a page which I visited too often.
if I uncomment the irrelevant minimize command, the error message disappears.
How can I prevent this error without giving irrelevant commands?
kind regards,
Harry Garst
I solve a mechanical exercise but i had a problem.
I know M (mass) and K (stifness) matrices (4x4).
I want to solve the (λ2M+K)v=0  eigenvalue problem, where λ are the eigenvalues and v eigenvectors.
How can i solve this problem.  I tried with the Eigenvectors() command but it didn't give the right solution.
The Eigenvalues are okay, but the eigenvectors not
K := Matrix([[4*10^7,-1.50*10^7,2*10^7,0],[-1.50*10^7,1.50*10^7,0,1.50*10^7],[2*10^7,0,8*10^7,2*10^7],[0,1.50*10^7,2*10^7,4*10^7]]);
M:=Matrix([[121.90,99.048,-91.429,0],[99.048,594.29,0,-99.048],[-91.429,0,243.81,-91.429],[0,-99.048,-91.429,121.90]]);
w1,w2:=Eigenvectors(K,M);
Acoording with the book the right eigenvectors(shape mode) are:
[0.013 991,  0.034 233,  0.073 683,  0.090 573]
[0.035 637, 0, -0.032 213, 0]
[0 ,-0.034 233, 0, 0.090 573]
[-0.013 991, 0.034 233, -0.073 683, 0.090 573]
hello...how i can remove this error?
33.mw
restart; Digits := 15
15
sys3 := {-.233333333333333*(diff(g5(y), y, y))+0.5e-1*g3(y)-.820000000000000*g5(y)*omega2-0.150000000000000e-1*g4(y)*omega2+0.500000000000000e-4*(diff(g1(y), y))*omega2-0.999999999999999e-4*(diff(g2(y), y))*omega2-1.44142830009497*(diff(g2(y), y, y, y, y, y))+864.856980056984*(diff(g5(y), y, y, y, y)), 2.61572184429325*10^(-10)*(diff(g3(y), y, y, y, y, y, y, y, y))+3.32396399331216*10^(-7)*(diff(g3(y), y, y, y, y, y, y))-0.193818732289211e-2*(diff(g3(y), y, y, y, y))+0.199166451610413e-1*(diff(g1(y), y, y, y, y, y))+0.598690451303844e-1*(diff(g2(y), y, y, y, y, y))-5.40849801271536*(diff(g1(y), y, y, y))-5.40846938859685*(diff(g2(y), y, y, y))-.101409302553410*(diff(g3(y), y, y))+0.240924444444445e-5*(diff(g4(y), y, y, y, y)), -.233333333333333*(diff(g4(y), y, y))-0.5e-1*g3(y)-.820000000000000*g4(y)*omega2-0.150000000000000e-1*g5(y)*omega2+0.999999999999999e-4*(diff(g1(y), y))*omega2-0.500000000000000e-4*(diff(g2(y), y))*omega2-0.225354497440541e-3*(diff(g3(y), y, y, y, y, y, y))-76.1509512630580*(diff(g1(y), y, y, y, y, y))-11.7785283950617*(diff(g2(y), y, y, y, y, y))+1874.44512820514*(diff(g4(y), y, y, y, y))+6.88355555555557*10^(-7)*(diff(g3(y), y, y, y, y))-8413.23456790121*(diff(g2(y), y, y, y))+8413.23456790121*(diff(g1(y), y, y, y)), 7118.49071746442*(diff(g2(y), y, y, y, y))+0.266666666666666e-2*(diff(g3(y), y))-93.3333333333333*g2(y)+93.3333333333333*g1(y)+.820000000000000*g2(y)*omega2-0.999999999999999e-4*(diff(g5(y), y))*omega2+1.66666666666666*10^(-7)*(diff(g1(y), y, y))*omega2-0.500000000000000e-4*(diff(g4(y), y))*omega2-3.33333333333333*10^(-7)*(diff(g2(y), y, y))*omega2+0.150000000000000e-1*g1(y)*omega2+980.282047736626*(diff(g1(y), y, y, y, y))+0.987816663816580e-2*(diff(g3(y), y, y, y, y, y))-2.84647769547324*(diff(g1(y), y, y, y, y, y, y))-1.77181281840245*(diff(g2(y), y, y, y, y, y, y))+5.40846577473014*(diff(g3(y), y, y, y))+5.07598485596708*10^5*(diff(g1(y), y, y))-5.07598485596708*10^5*(diff(g2(y), y, y))-16826.4691358025*(diff(g4(y), y, y, y))-0.210330864197531e-4*(diff(g3(y), y, y, y, y, y, y, y)), 1.66666666666666*10^(-7)*(diff(g2(y), y, y))*omega2+0.500000000000000e-4*(diff(g5(y), y))*omega2-3.33333333333333*10^(-7)*(diff(g1(y), y, y))*omega2+0.999999999999999e-4*(diff(g4(y), y))*omega2+0.150000000000000e-1*g2(y)*omega2+.820000000000000*g1(y)*omega2-5.53911151967922*(diff(g1(y), y, y, y, y, y, y))-2.55201448559671*10^5*(diff(g4(y), y, y, y))-0.355523547493069e-4*(diff(g3(y), y, y, y, y, y, y, y))+0.266666666666666e-2*(diff(g3(y), y))-4.05637062704760*(diff(g3(y), y, y))-11.4677117829418*(diff(g3(y), y, y, y))-0.338031746031747e-2*(diff(g3(y), y, y, y, y))-0.890132662315342e-2*(diff(g3(y), y, y, y, y, y))-378.595555555555*(diff(g2(y), y, y, y))-482.358781893005*(diff(g2(y), y, y, y, y))-2.84647769547324*(diff(g2(y), y, y, y, y, y, y))-93.3333333333333*g1(y)-4.35805550617285*10^5*(diff(g1(y), y, y))-378.595555555555*(diff(g1(y), y, y, y))+45299.9927158183*(diff(g1(y), y, y, y, y))+93.3333333333333*g2(y)+5.07598485596708*10^5*(diff(g2(y), y, y))}:
bcs3 := {-0.350267076923078e-2*((D@@3)(g2))(0)+7.00534153846156*((D@@2)(g5))(0) = 0, -0.350267076923078e-2*((D@@3)(g2))(1)+7.00534153846156*((D@@2)(g5))(1) = 0, -0.2100e-1*(D(g5))(0)+0.350267076923078e-2*((D@@5)(g2))(0)-7.00534153846156*((D@@4)(g5))(0) = 0, -0.2100e-1*(D(g5))(1)+0.350267076923078e-2*((D@@5)(g2))(1)-7.00534153846156*((D@@4)(g5))(1) = 0, 1.71617510204081*10^(-14)*((D@@4)(g3))(0)+2.93357776746121*10^(-11)*((D@@2)(g3))(0)+0.912685714285722e-5*(D(g1))(0)-0.912685714285712e-5*(D(g2))(0)-5.09278628571429*10^(-7)*((D@@2)(g4))(0)+8.04988799999997*10^(-9)*((D@@3)(g1))(0)+4.59993600000001*10^(-9)*((D@@3)(g2))(0) = 0, 1.71617510204081*10^(-14)*((D@@4)(g3))(1)+2.93357776746121*10^(-11)*((D@@2)(g3))(1)+0.912685714285722e-5*(D(g1))(1)-0.912685714285712e-5*(D(g2))(1)-5.09278628571429*10^(-7)*((D@@2)(g4))(1)+8.04988799999997*10^(-9)*((D@@3)(g1))(1)+4.59993600000001*10^(-9)*((D@@3)(g2))(1) = 0, -1.64283428634155*10^(-7)*((D@@4)(g3))(0)-.133295923200000*((D@@3)(g1))(0)-0.286218240000000e-1*((D@@3)(g2))(0)+15.1830055384616*((D@@2)(g4))(0)+5.57568000000000*10^(-9)*((D@@2)(g3))(0)-227.157333333333*(D(g2))(0)+227.157333333333*(D(g1))(0) = 0, -1.64283428634155*10^(-7)*((D@@4)(g3))(1)-.133295923200000*((D@@3)(g1))(1)-0.286218240000000e-1*((D@@3)(g2))(1)+15.1830055384616*((D@@2)(g4))(1)+5.57568000000000*10^(-9)*((D@@2)(g3))(1)-227.157333333333*(D(g2))(1)+227.157333333333*(D(g1))(1) = 0, -1.71617510204081*10^(-14)*((D@@5)(g3))(0)-2.12981181756245*10^(-10)*((D@@3)(g3))(0)+0.813595871901550e-5*(D(g3))(0)-0.393365900022856e-4*((D@@2)(g1))(0)-0.136355081430858e-3*((D@@2)(g2))(0)+5.09278628571429*10^(-7)*((D@@3)(g4))(0)-8.04988799999997*10^(-9)*((D@@4)(g1))(0)-4.59993600000001*10^(-9)*((D@@4)(g2))(0) = 0, -1.71617510204081*10^(-14)*((D@@5)(g3))(1)-2.12981181756245*10^(-10)*((D@@3)(g3))(1)+0.813595871901550e-5*(D(g3))(1)-0.393365900022856e-4*((D@@2)(g1))(1)-0.136355081430858e-3*((D@@2)(g2))(1)+5.09278628571429*10^(-7)*((D@@3)(g4))(1)-8.04988799999997*10^(-9)*((D@@4)(g1))(1)-4.59993600000001*10^(-9)*((D@@4)(g2))(1) = 0, -0.2100e-1*(D(g4))(0)+1.64283428634155*10^(-7)*((D@@6)(g3))(0)+.185046811569231*((D@@5)(g1))(0)+0.286218240000000e-1*((D@@5)(g2))(0)-15.1830055384616*((D@@4)(g4))(0)-5.57568000000000*10^(-9)*((D@@4)(g3))(0)+227.157333333333*((D@@3)(g2))(0)-227.157333333333*((D@@3)(g1))(0) = 0, -0.2100e-1*(D(g4))(1)+1.64283428634155*10^(-7)*((D@@6)(g3))(1)+.185046811569231*((D@@5)(g1))(1)+0.286218240000000e-1*((D@@5)(g2))(1)-15.1830055384616*((D@@4)(g4))(1)-5.57568000000000*10^(-9)*((D@@4)(g3))(1)+227.157333333333*((D@@3)(g2))(1)-227.157333333333*((D@@3)(g1))(1) = 0, 371.200498864795*((D@@2)(g1))(0)-0.125033665514056e-4*((D@@3)(g3))(0)-0.454911629784616e-2*((D@@4)(g1))(0)-0.207508224000000e-2*((D@@4)(g2))(0)-.90862933333333*((D@@2)(g2))(0)-.219044470756571*(D(g3))(0)+.317542124307693*((D@@3)(g4))(0)-7.77529998367344*10^(-9)*((D@@5)(g3))(0) = 0, 371.200498864795*((D@@2)(g1))(1)-0.125033665514056e-4*((D@@3)(g3))(1)-0.454911629784616e-2*((D@@4)(g1))(1)-0.207508224000000e-2*((D@@4)(g2))(1)-.90862933333333*((D@@2)(g2))(1)-.219044470756571*(D(g3))(1)+.317542124307693*((D@@3)(g4))(1)-7.77529998367344*10^(-9)*((D@@5)(g3))(1) = 0, -1.71617510204081*10^(-14)*((D@@8)(g3))(0)-2.42316975112457*10^(-10)*((D@@6)(g3))(0)+0.156993173154261e-4*((D@@4)(g3))(0)-0.483974477413303e-4*((D@@5)(g1))(0)-0.145481779666834e-3*((D@@5)(g2))(0)+.146029446343315*((D@@3)(g1))(0)+.146028673492115*((D@@3)(g2))(0)+0.912683722980687e-2*((D@@2)(g3))(0)-1.95148800000000*10^(-8)*((D@@4)(g4))(0) = 0, -1.71617510204081*10^(-14)*((D@@8)(g3))(1)-2.42316975112457*10^(-10)*((D@@6)(g3))(1)+0.156993173154261e-4*((D@@4)(g3))(1)-0.483974477413303e-4*((D@@5)(g1))(1)-0.145481779666834e-3*((D@@5)(g2))(1)+.146029446343315*((D@@3)(g1))(1)+.146028673492115*((D@@3)(g2))(1)+0.912683722980687e-2*((D@@2)(g3))(1)-1.95148800000000*10^(-8)*((D@@4)(g4))(1) = 0, 54.7703335314617*((D@@2)(g2))(0)+5.87769600000000*((D@@2)(g1))(0)+0.148770877878858e-4*((D@@3)(g3))(0)-0.207508224000000e-2*((D@@4)(g1))(0)-0.129031719384616e-2*((D@@4)(g2))(0)+.146028885677714*(D(g3))(0)+.143109120000000*((D@@3)(g4))(0)+0.350267076923078e-2*((D@@3)(g5))(0)-4.59993600000001*10^(-9)*((D@@5)(g3))(0) = 0, 54.7703335314617*((D@@2)(g2))(1)+5.87769600000000*((D@@2)(g1))(1)+0.148770877878858e-4*((D@@3)(g3))(1)-0.207508224000000e-2*((D@@4)(g1))(1)-0.129031719384616e-2*((D@@4)(g2))(1)+.146028885677714*(D(g3))(1)+.143109120000000*((D@@3)(g4))(1)+0.350267076923078e-2*((D@@3)(g5))(1)-4.59993600000001*10^(-9)*((D@@5)(g3))(1) = 0, 1.71617510204081*10^(-14)*((D@@6)(g3))(0)+2.42316975112457*10^(-10)*((D@@4)(g3))(0)-0.715265022412607e-5*((D@@2)(g3))(0)+0.483974477413303e-4*((D@@3)(g1))(0)+0.145481779666834e-3*((D@@3)(g2))(0)-3.28345600000000*10^(-7)*(D(g1))(0)+3.28345600000000*10^(-7)*(D(g2))(0)+2.11875840000000*10^(-8)*((D@@2)(g4))(0)-5.09278628571429*10^(-7)*((D@@4)(g4))(0)+8.04988799999997*10^(-9)*((D@@5)(g1))(0)+4.59993600000001*10^(-9)*((D@@5)(g2))(0) = 0, 1.71617510204081*10^(-14)*((D@@6)(g3))(1)+2.42316975112457*10^(-10)*((D@@4)(g3))(1)-0.715265022412607e-5*((D@@2)(g3))(1)+0.483974477413303e-4*((D@@3)(g1))(1)+0.145481779666834e-3*((D@@3)(g2))(1)-3.28345600000000*10^(-7)*(D(g1))(1)+3.28345600000000*10^(-7)*(D(g2))(1)+2.11875840000000*10^(-8)*((D@@2)(g4))(1)-5.09278628571429*10^(-7)*((D@@4)(g4))(1)+8.04988799999997*10^(-9)*((D@@5)(g1))(1)+4.59993600000001*10^(-9)*((D@@5)(g))(1) = 0, g1(0) = 0, g1(1) = 0, g2(0) = 0, g2(1) = 0, ((D@@2)(g1))(0) = 0, ((D@@2)(g1))(1) = 0, ((D@@2)(g2))(0) = 0, ((D@@2)(g2))(1) = 0}:
dsys4 := {bcs3, sys3}:
Typesetting:-mrow(Typesetting:-mo("for", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("in", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("extra_bcs", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("try", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mo("&uminus0;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mn("13", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("dsolve", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("newsys2", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("union", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mo("&uminus0;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mn("13", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), font_style_name = "2D Input", mathvariant = "normal", open = "{", close = "}"), Typesetting:-mo("union", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("bcs3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("numeric", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("method", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("bvp", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("middefer", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("output", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("listprocedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("initmesh", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("3024", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("approxsoln", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("omega3", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("0.0000000001", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g1", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "false", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g2", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g4", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("7", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("7", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g5", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("abserr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1e&minus;9", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("catch", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("lasterror", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("try", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("indices", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nolist", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("P", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("seq", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("subs", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("omega3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("for", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("from", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("by", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-mi("sqrt", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("^", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1111111em", rspace = "0.1111111em"), Typesetting:-mn("25", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("*", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("P", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal")), Typesetting:-mrow(Typesetting:-mn("2", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("Pi", italic = "false", font_style_name = "2D Input", mathvariant = "normal")), linethickness = "1", denomalign = "center", numalign = "center", bevelled = "false"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mi("plots", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(":-", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odeplot", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi(""), Typesetting:-mrow(Typesetting:-mi("seq", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("cat", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal")), Typesetting:-mi("")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("thickness", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""))
"unable to store %1 when datatype=%2", -HFloat(9.659865599999965e-7)+0.459993600000001e-8*((D@@5)(g))(1), float[8]
Download 33.mw
First 167 168 169 170 171 172 173 Last Page 169 of 371
