Dear Maple  users,
I am facing the memory allocation problem while calculating the inverse Laplace transformation of a big expression. I have many such terms (401) and I am importing them from a text file.
For an individual term itself, Maple consumes huge memory but at the end, it is able to calculate it in about an hour. I want to automate the process of reading and writing the terms one by one from the different text files. While doing so, maple eats a lot of memory and I see the error msg
"Error, (in expand/bigprod) Maple was unable to allocate enough memory to complete this computation.
Please see ?alloc "
Is there a way to do so? The maple file is attached.
InvLaplace_ex.mw
I´m new to Maple and I´m trying to find the minimum distance of an ECC from its parity check matrix or the generator matrix. Is this possible?
A fact that seems to be not documented. Probably it should be obvious.
Digits := d0
evalf[d](expr);
The toplevel float sub-expressions in expr  are computed with Digits=d0 but in procedures Digits is set to d.
Notice that the actual float parameters of the toplevel procedures are evalf-ed with Digits=d0.
g:=proc() convert(1/3., string) end:
h:=proc() 1/3. end:
Digits:=3;
evalf[10]([
  1/3. = h(),
  convert(1/3.,string) = g(),
  fsolve(3*x=1) = add([1/3]),
  fsolve(x/3=1/9.) # 1/9. being at top level is evalf-ed with Digits=3
[.333 = .3333333333, ".333" = ".3333333333", .3333333333 = .3333333333, .3330000000]
k:=proc(x) convert(x,string) end:
kernelopts(floatPi);
4.+Pi;
7.14
evalf(k(1/3.+Pi));
# floatPi seems to be ignored inside actual parameters
".333+Pi"
evalf(k(4+evalf(Pi)));
"7.14"
evalf(k(4+Pi));
# 4 not being float (or "infected" by a float) is not evalf-ed
"4+Pi"
### (this is documented)
`evalf/h` := proc() 7.777 end:
evalf(h(1/3));
.333
evalf('h'(1/3));
7.777
Download digits.mw
(edited)
collect((sqrt(x)+y)^2, [x, y], distributed);
                                       (sqrt(x)+y)^2
I think this is wrong. Documentation says that collect supports fractional powers of the variables, so in this case collect should return x+2*sqrt(x)*y+y^2.
After waiting about six hours for the worksheet to be executed, I finally lost hope and stopped it. (My CPU usage was stuck on 100% the whole time and I almost ran out of memory) Is this evaluation time normal and should I have waited longer, or is there a problem with my worksheet? (I'm uploading it here) Or is it possible that the equation cannot be solved by Maple at all?
parasitic.mw
help me on thispde_solutionalpha.mw
M := 1; S := .78; K := .5; Sh := .2; alpha := .7; R := .3; N := .6; k := .5
pde1 := diff(u(y, t), t)+S.(diff(u(y, t), y))-2*k^2*u(y, t) = diff(u(y, t), y, y)+theta(y, t)+N.C(y, t)+M.u(y, t)+u(y, t)/K
                pde2 := theta(y, t)+t*(diff(theta(y, t), t))+S*(diff(theta(y, t), y)) = (diff(theta(y, t), y, y))/Pr-alpha.theta(y, t)
pde3 := C(y, t)+t*(diff(C(y, t), t))+S*(diff(C(y, t), y)) = (diff(C(y, t), y, y))/Sh-R.C(y, t)
PDE := unapply({pde || (1 .. 3)}, Pr)
proc (Pr) options operator, arrow; {C(y, t)+t*(diff(C(y, t), t))+.78*(diff(C(y, t), y)) = 5.000000000*(diff(diff(C(y, t), y), y))-.3*C(y, t), diff(u(y, t), t)+.78*(diff(u(y, t), y))-.50*u(y, t) = diff(diff(u(y, t), y), y)+theta(y, t)+.6*C(y, t)+3.000000000*u(y, t), theta(y, t)+t*(diff(theta(y, t), t))+.78*(diff(theta(y, t), y)) = (diff(diff(theta(y, t), y), y))/Pr-.7*theta(y, t)} end proc
IBC := {C(0, t) = 1, C(1, t) = 0, C(y, 0) = 0, theta(0, t) = 1, theta(1, t) = 0, theta(y, 0) = 0, u(0, t) = 0, u(1, t) = 0, u(y, 0) = 0}
PrList := [.71, 7, 10, 100]; Colours := table(`~`[`=`](PrList, ["blue", "red", "green", "cyan"])); for Pr in PrList do pds := pdsolve(PDE(Pr), IBC, numeric); Plots[Pr] := pds:-plot[display](u(y, t), t = .5, linestyle = "solid", colour = Colours[Pr], legend = sprintf("Pr=%2.2f", Pr), title = "Velocity Profile", labels = ["y", "theta"]) end do; plots:-display([seq(Plots[Pr], `in`(Pr, PrList))])
Download pde_solutionalpha.mw
Exporting one plot in program works well:
       MapleEngine.EvalMapleStatement(kv, "Export(\"D:\\\\MyGraph.jpeg\",plot(sin(x)*cos(2*x)));");
But if I'm trying to export two plots, program stops working and prints no exception:
        MapleEngine.EvalMapleStatement(kv, "Export(\"D:\\\\MyGraph2.jpeg\",plot(sin(x)*cos(2*x)));");
What is the cause?
f := (s) -> -HankelH1(1, s)-2*I/Pi*BesselK(1, s);
evalf(Int(f(s), s = 0 .. 1));
                 -0.2348023134 + 0.3562894462 I
evalf(Int(Re(f(1.*s)), s = 0 .. 1)+I*Int(Im(f(1.*s)), s = 0 .. 1));
evalf(Int(f(1.*s), s = 0 .. 1));
               -0.2094198744 + Float(infinity) I
I don't know if the third one is really an issue, but given that the first two work fine, looks suspicious.
How can i export a plot using open maple in java?
engine.evaluate("Export(\"D:\\MyGraph.jpeg\", plot(sin(x)));");
engine.evaluate("exportplot(\"D:\\MyGraph.jpeg\", plot(sin(x)));");
doesn't work,
exception - com.maplesoft.externalcall.MapleException: Error, (in Export) exported file D:MyGraph.jpeg could not be createdError, plotting was not implemented by the application
How do i find the distance between the quasi cyclic codes in maple ?
how do i solve a system of PDE's with variable coeffiecients in Maple?
what package I need to add in order to use commands named "Drawmatrix, Translatemat and Transform" ? I add package named Lamp but it is not working. I have maple 15. Please try to respond as soon as possible because its urgent.
Hi everyone
I have a problem with differentiating an equation. I have the following code:
(sum((x(i)-M)^3, i = 1 .. n))/(n*((sum((x(i)-M)^2, i = 1 .. n))/(n-1))^(3/2));
The values of x(i) is available in Excel and I want to import that. For this case, I copy the column and paste in maple and it seems work fine. But, I want to calculate the differentiate of the summation with respect to x(i) and M and find the answer. I don't know how to write the code appropriately.
In other words, how could I differetiate the following function with respect to x(i) and put the values from excel into it.
Thank you so much for your kind attentions  in advance
"(a)(b"
"(a)(b"
Copy the string, paste into a new cell, delete and retype the opening quote.
""(a)(`b"`"
Error, unable to delimit strings/identifiers
""(a)(`b"`"
Copy the string from the first cell, add f() around it.
"f("(a)(`b"`)"
"f("(a)(`b"`)"
Download 2dstring.mw
Hope everything is fine with everything. I want to draw the graph of the u(x,0.5) and T(x,0.5) for different values of alpha like alpha =0.4,0.6,0.8 while keeping Gr, R and Pr are fixed. Please solve the following problem I shall be vary thankful to you. Thanks in advance
with the following BCs
First 161 162 163 164 165 166 167 Last Page 163 of 371
