hi,
i'am beginers in  the maple programmation, i want to solve the einstien equation in the spherical coordinate,
I have a nested for loop that iterates through a range of values for x and y coordinates to create a 3d surface for illustration of my research. after the x loop there is a y loop, and inside of that y loop is a series of commands to find some eigenvalues of a matrix (which become the z coordinates) and sort them into already open files. This isn't bad when the precision i require is more than .02, but some of my matrices require up to 0.005 or less. The latter precision costs hours of computation time on just one processor. However my laptop has an i7, so I want to see if i can get the for loop to send its next iteration to the next processor in line while it has the previous ones still calculating. Have any tips?
how to design antenna with maple i am looking for designing patch antenna using graphene
Searching for "typeset but do not execute" in MaplePrimes returns several hits.  The following looks primising:
acer - Replies
... Note that Maple doesn't do so much with this computationally, since it's interpreted
just as a ... But if the 2D Input is only used as typeset math without ...
Clicking on that link, however, leads to a page which has nothing to do with the searched item.  How does one navigate to the correct page?
I was posting some code on a forum tonight. I specificially added # comments to the code. I used Ctrl_c ,Crtl_v. All the # comments were removed including the 2016 grey boxes which appeared as NULL.
Is there away around this. The comments were very important to help in understanding. The pasted code did look readable though.
I also experimented with exporting the code as .txt and opening it in Word. Required loads of editing to make it look presentable, which really opend the door to introuucing errors, also all # coments were removed too.
The forum just has the normal type comments box. Nothing fancy. Actually it is a WordPress Blog. It does accept latex but that is ok for one or two lines. Could be a real mess if 30--40 lines of code go wrong and latex as far as I know can't be copy/pasted back in to Maple.
How Maple knows free and dummy index?
In Maple18.02:
Hso := Matrix(8, {(1, 4) = -x, (1, 6) = I*x, (2, 3) = x, (2, 5) = I*x, (3, 2) = x, (3, 5) = -I*z, (3, 8) = y, (4, 1) = -x, (4, 6) = I*z, (4, 7) = -y, (5, 2) = -I*x, (5, 3) = I*z, (5, 8) = -I*y, (6, 1) = -I*x, (6, 4) = -I*z, (6, 7) = -I*y, (7, 4) = -y, (7, 6) = I*y, (8, 3) = y, (8, 5) = I*y})
av, AV := LinearAlgebra[Eigenvectors](Hso)
Error, (in Polynomial:-Quadratic) type `truefalseFAIL` does not exist
This does not happen in Maple17.
Hi there,
I'm new here. My first question:
Is there a way to make Maple output display explicit multiplcations signs in 2D-math?
Example:
When you enter 5*2^x Maple will output 5*2^x. Is there a way to make Maple display the multiplications signs in output in stead just implicit multiplication signs (i.e. whitepaces)? (I would settle for Maple display all multiplication signs in output - not just the ones which are made explicit in the input.)
I searched this site. No luck. I looked into "Typesetting Rule Assistant", but I couldn't find a way to alter the output of multiplication sign (*).
Can you guys help me?
Kind Regards,
Jens
P.S.: I'm a teacher from Denmark. We use Maple before college/university for a lot of pupils. Some less competent pupils have a tendency to overlook the whitespace.
How we can construct conservation laws of fractional differential equation with Maple?
Respected member!
Please help me to find the solution of attached problem,  I am a new user so please forgive any mistakes.maple.mwmaple.mw
Can anyone solve,
eqn := diff(x(t), t, t)+omega^2*x(t)-epsilon*mu*(diff(x(t), t))+epsilon*alpha*x(t)^2*(diff(x(t), t))+epsilon*Zeta*cos(Omega*t)*x(t)=0;
This equation using MMS (Method of Multiple Scales) in maple.
Pls use Polar transformation function as (1/2)*a(t)*exp(-I*beta(t))
Please reply.
I am trying to see the solution to a PDE that I am coding with initial and boundary conditions. I know with the ODE, it shows the solution, but with the PDE I cannot seem to see it. Any suggestions?
Hi, i try resolve this equations numerical for the boundary between the spinglass and ferromagnetic phases:
how?
Regards.
Hi Dears,
I studied the concept of Grobner bases and some algorithm for computing them. I understood that the computation of grobner bases is related to the term ordering. Also, I knew that LEX ordering is very expensive. So, it is good idea to use the Grobner basis conversion algorithms such as FGLM and Grobner walk algorithm. Now, I want to know concerning the complexity of these algorithm (Buchbergers algorithm, F4 and F5 algorithm, FGLM algorithm and Grobner walk). I hope my question be appropriate in this site,
Thank you in advance.
I am looking forward to hearing from you.
Any help will be appreciated
I have a continuous time dynamical system
x in R ( set of real number)
t  a positive real time
and the function f_t(x)=x-t
How can we plot or sketch their behaviour in the phase space and in the extended phase space
Many thanks
First 176 177 178 179 180 181 182 Last Page 178 of 371
