How to pdeplot Curl(A(x,y,z))=0 in maple
it has A1(x,y,z) , A2(x,y,z) and A3(x,y,z)
I have a partial differential equation similar to the following:
Equation: f_x(x,y) + f_y(x,y) = f(x,y) + f(x,0),
Boundary value conditions: f(x,10) = f(10,y) = 0.
The solution is that f is identically equal to 0.
However, I am having trouble solving this equation in Maple. I type the following:
pde := diff(f(x, y), x)+diff(f(x, y), y) = f(x, y)+f(x, 0);
bv1 := f(x, 10) = 0;
bv2 := f(10, y) = 0;
solution := pdsolve(pde, {bv1, bv2}, numeric, time = x, range = 0 .. 10);
When Maple tries to evaluate the last expression, I get the error
Error, (in pdsolve/numeric/process_PDEs) PDEs can only contain dependent variables with direct dependence on the independent variables of the problem, got {f(x, 0)}
It seems to have difficulties with the expression "f(x,0)". Is there some trick to typing this in a way that makes Maple interpret it correctly?
Edit: I encounter the same problem, when I try to solve the ODE f'(x) = f(x) + f(0), where f(10) = 0.
Best regards.
Is there a method to relate groebner bases with monomials ideals
For some reason, the rising edge block is not working how it is supposed to.
The component decription is as follows: "
The Rising Edge component triggers a Boolean expression, true, in the output, y, when a rising edge is detected at the input, u.
I am applying a step signal. (red waveform)
and this is the probe's measurement:
Why is it not detecting the rising edge?
John.
I attempt to understand is it possible whether to calculate the next expression by means of mathematica:
where
{,}- anti-communicator;
 a=0,1,2,3;
\tau^{0}-unity matrix; \tau^{i} - Pauli matrix;
and:
finally - Levi-Civita symbol; -Hermitian conjugation.
Thank you for your kind replies .
Hi ,
I have recently got to know this software and its capabilities and was wondering if I can use it to start an initial systems design for an E-scooter as a first step (virtual validation). then feed this data to a designer which will design and cooperate with an engineer to realise the design again on this platform.
SO i have the range of my scooter , the weight it carries , the enviroment's average topography which i will be simplifying it at the first step to a 15% hill climb , and finally some dynamic/static restrictions... which i hope ican build upon . like adding chasis loads and analysis to data.
I want it to give me the cell number of the batteries , verify the loads and give me a electric-motor description .
this was the road map.
Is there a way to change the numeric formatting of 'Scientific' to use a cdot instead of a cross to represent multiplication?
Is there a problem with MaplePrime web site?   All my questions for the last 4 years, and answers are no longer available. All gone. I posted a question early today about sin(x) calling. one hr after that, I noticed all my questions and answers gone.
When I go to my user profile, it says I have zero questions, zero answer and zero post for the last 4 years. All the answers to my questions also got deleted, which is a shame if this happened. They have many useful information.
Any one else affected by this?
I have a need to calculate base 2 math as would be done in an integrated circuit. Math will be done using 15 bit 2's complement mantissa and 8 bit exponent. (the exponent is always assumed to be negative) We need to perform multiplication and addition, where each internal operation is represented by such a number.
The goal is to best represent the errors associated with such calculations and export the resulting code to a hardware description language for implementation on an integrated circuit.
Is there a package in Maple that can do that? Any advice on how te proceed?
for the simple ODE:
dsolve(26*(diff(y(x), x$4))-50*(diff(y(x),x$2))-2*y(x) = 0)
dsolve produces strange solution as below:
in this solution the forth function is wrong and it would be as below:
_C4*exp((1/26*I)*sqrt(26*sqrt(677)-650)*x)
can you explain this problem???
please help me :((((
I am using Maple 2016.
I have defined 5 polynomials: f1, f2, f3, f4 and f5 with 5 unknowns q1,q2 ,q3, q4 and lamda.
After this, I generated the Gröbner basis. But when I try to find the normal set I got an error.
with(Groebner);
f1 := lamda*q1-(3380075947548081*q1*(1/140737488355328)-259050600068343*q2*(1/140737488355328)-1826834460600733*q3*(1/1125899906842624)+4414049272733425*q4*(1/9007199254740992))*(q2*(8289619202186977*q1*(1/9007199254740992)+3380075947548081*q2*(1/281474976710656)-4414049272733425*q3*(1/18014398509481984)-1826834460600733*q4*(1/2251799813685248))+q3*(1826834460600733*q1*(1/2251799813685248)-4414049272733425*q2*(1/18014398509481984)+843667886835955*q3*(1/70368744177664)-215663898201129*q4*(1/9007199254740992))-q4*(4414049272733425*q1*(1/18014398509481984)+1826834460600733*q2*(1/2251799813685248)+431327796402257*q3*(1/18014398509481984)+843667886835955*q4*(1/70368744177664))-q1*(3380075947548081*q1*(1/281474976710656)-259050600068343*q2*(1/281474976710656)-1826834460600733*q3*(1/2251799813685248)+4414049272733425*q4*(1/18014398509481984)));
f2 := lamda*q2+(259050600068343*q1*(1/140737488355328)+3380075947548081*q2*(1/140737488355328)-4414049272733425*q3*(1/9007199254740992)-1826834460600733*q4*(1/1125899906842624))*(q2*(8289619202186977*q1*(1/9007199254740992)+3380075947548081*q2*(1/281474976710656)-4414049272733425*q3*(1/18014398509481984)-1826834460600733*q4*(1/2251799813685248))+q3*(1826834460600733*q1*(1/2251799813685248)-4414049272733425*q2*(1/18014398509481984)+843667886835955*q3*(1/70368744177664)-215663898201129*q4*(1/9007199254740992))-q4*(4414049272733425*q1*(1/18014398509481984)+1826834460600733*q2*(1/2251799813685248)+431327796402257*q3*(1/18014398509481984)+843667886835955*q4*(1/70368744177664))-q1*(3380075947548081*q1*(1/281474976710656)-259050600068343*q2*(1/281474976710656)-1826834460600733*q3*(1/2251799813685248)+4414049272733425*q4*(1/18014398509481984)));
f3 := (1826834460600733*q1*(1/1125899906842624)-4414049272733425*q2*(1/9007199254740992)+843667886835955*q3*(1/35184372088832)-862655592804515*q4*(1/18014398509481984))*(q2*(8289619202186977*q1*(1/9007199254740992)+3380075947548081*q2*(1/281474976710656)-4414049272733425*q3*(1/18014398509481984)-1826834460600733*q4*(1/2251799813685248))+q3*(1826834460600733*q1*(1/2251799813685248)-4414049272733425*q2*(1/18014398509481984)+843667886835955*q3*(1/70368744177664)-215663898201129*q4*(1/9007199254740992))-q4*(4414049272733425*q1*(1/18014398509481984)+1826834460600733*q2*(1/2251799813685248)+431327796402257*q3*(1/18014398509481984)+843667886835955*q4*(1/70368744177664))-q1*(3380075947548081*q1*(1/281474976710656)-259050600068343*q2*(1/281474976710656)-1826834460600733*q3*(1/2251799813685248)+4414049272733425*q4*(1/18014398509481984)))+lamda*q3;
f4 := lamda*q4-(4414049272733425*q1*(1/9007199254740992)+1826834460600733*q2*(1/1125899906842624)+862655592804515*q3*(1/18014398509481984)+843667886835955*q4*(1/35184372088832))*(q2*(8289619202186977*q1*(1/9007199254740992)+3380075947548081*q2*(1/281474976710656)-4414049272733425*q3*(1/18014398509481984)-1826834460600733*q4*(1/2251799813685248))+q3*(1826834460600733*q1*(1/2251799813685248)-4414049272733425*q2*(1/18014398509481984)+843667886835955*q3*(1/70368744177664)-215663898201129*q4*(1/9007199254740992))-q4*(4414049272733425*q1*(1/18014398509481984)+1826834460600733*q2*(1/2251799813685248)+431327796402257*q3*(1/18014398509481984)+843667886835955*q4*(1/70368744177664))-q1*(3380075947548081*q1*(1/281474976710656)-259050600068343*q2*(1/281474976710656)-1826834460600733*q3*(1/2251799813685248)+4414049272733425*q4*(1/18014398509481984)));
f5 := q1^2+q2^2+q3^2+q4^2-1;
ord := tdeg(q1, q2, q3, q4, lamda);
G := Basis([f1, f2, f3, f4, f5], ord);
IsZeroDimensional(G);
                             false
ns, rv := NormalSet(G, ord);
Error, (in Groebner:-NormalSet) The case of non-zero-dimensional varieties is not handled.
Any help please ?
I was wondering if it is possible to use units in Maple so I can always check if the result I have at the end of calculation is the meter.  For example:
>c:=3e8m/s
>Ec:=1J
>Ec*c
The answer is of course 3.10^8 m^3*kg/s^3
I try to do something with the units but I am unable to crreate something that will simplify the m/s ffactor to 1.
Any idea?
Thank you in advance for your help.
how to convert a nested for loop to iterative version with stack
#my testing for wildcard to one
#after testing, it loop a very long time and not stop
ppp := [[0,0,0,x],[0,0,1,0],[0,1,0,0],[1,0,0,0]]:
check1 := [seq(0,ii=1..nops(ppp))];
ttt1 := [[0,0,0,1],[0,0,1,0],[0,1,0,0],[1,0,0,0]]:
mmmeaght1 := [seq(0,ii=1..nops(ppp[1]))]:
bbb1 := [seq(0,ii=1..nops(ppp[1]))]:
emap := [(xx) -> if [xx < 0 assuming x > 0] then 0 else 1 end if, (xx) -> evalf(1/(1+exp(xx)))]:
#trace(perceptronrule1);
MM(ppp, ttt1, mmmeaght1, bbb1, check1, emap);
when test wildcard variable for input, would like to assume x > 0 then
i try assuming x > 0 , got error
I have expression h1 as below:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received shareman
"`u__1`(`xi__1`,`xi__2`,Zeta,t):=`u__0`(`xi__1`,`xi__2`,Zeta,t)+Zeta*`phi__1`(`xi__1`,`xi__2`,t):"
"`u__2`(`xi__1`,`xi__2`,Zeta,t):=`v__0`(`xi__1`,`xi__2`,Zeta,t)+Zeta*`phi__2`(`xi__1`,`xi__2`,t):"
"`u__3`(`xi__1`,`xi__2`,Zeta,t):=`w__0`(`xi__1`,`xi__2`,Zeta,t):"
`&phi;__n` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)-(diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)))/(2*a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*a__2(`&xi;__1`, `&xi;__2`, Zeta, t))
`&varepsilon;0__1` := (diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)+v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*w__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__1)/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__2` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)+u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)+a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*w__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__2)/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__4` := (diff(w__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)+a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*`&phi;__2`(`&xi;__1`, `&xi;__2`, t)-a__2(`&xi;__1`, `&xi;__2`, Zeta, t)*v__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__2)/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;0__5` := (diff(w__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)+a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*`&phi;__1`(`&xi;__1`, `&xi;__2`, t)-a__1(`&xi;__1`, `&xi;__2`, Zeta, t)*u__0(`&xi;__1`, `&xi;__2`, Zeta, t)/R__1)/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&omega;0__1` := (diff(v__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`)-u__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)-`&phi;__n`
`&omega;0__2` := (diff(u__0(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`)-v__0(`&xi;__1`, `&xi;__2`, Zeta, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+`&phi;__n`
`&varepsilon;1__1` := (diff(`&phi;__1`(`&xi;__1`, `&xi;__2`, t), `&xi;__1`)+`&phi;__2`(`&xi;__1`, `&xi;__2`, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)
`&varepsilon;1__2` := (diff(`&phi;__2`(`&xi;__1`, `&xi;__2`, t), `&xi;__2`)+`&phi;__1`(`&xi;__1`, `&xi;__2`, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)
`&omega;1__1` := (diff(`&phi;__2`(`&xi;__1`, `&xi;__2`, t), `&xi;__1`)+`&phi;__1`(`&xi;__1`, `&xi;__2`, t)*(diff(a__1(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__2`))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t)-`&phi;__n`/R
`&omega;1__2` := (diff(`&phi;__1`(`&xi;__1`, `&xi;__2`, t), `&xi;__2`)+`&phi;__2`(`&xi;__1`, `&xi;__2`, t)*(diff(a__2(`&xi;__1`, `&xi;__2`, Zeta, t), `&xi;__1`))/a__1(`&xi;__1`, `&xi;__2`, Zeta, t))/a__2(`&xi;__1`, `&xi;__2`, Zeta, t)+`&phi;__n`/R
`&varepsilon;__1` := (Zeta*`&varepsilon;1__1`+`&varepsilon;0__1`)/(1+Zeta/R__1)
`&varepsilon;__2` := (Zeta*`&varepsilon;1__2`+`&varepsilon;0__2`)/(1+Zeta/R__2)
`&varepsilon;__4` := `&varepsilon;0__4`/(1+Zeta/R__2)
`&varepsilon;__5` := `&varepsilon;0__5`/(1+Zeta/R__1)
`&varepsilon;__6` := (Zeta*`&omega;1__1`+`&omega;0__1`)/(1+Zeta/R__1)+(Zeta*`&omega;1__2`+`&omega;0__2`)/(1+Zeta/R__2)
epsilon := Matrix([[`&varepsilon;__1`], [`&varepsilon;__2`], [`&varepsilon;__4`], [`&varepsilon;__5`], [`&varepsilon;__6`]])
with(LinearAlgebra)
e__1 := Matrix([[0, 0, 0, e1__15, 0], [0, 0, e1__24, 0, 0], [e1__31, e1__31, 0, 0, 0]])
e__5 := Matrix([[0, 0, 0, e5__15, 0], [0, 0, e5__24, 0, 0], [e5__31, e5__31, 0, 0, 0]])
E__1 := -Matrix([[diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__1`)], [diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__2`)], [diff(`&varphi;1`(`&xi;__1`, `&xi;__2`, Zeta), Zeta)]])
E__5 := -Matrix([[diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__1`)], [diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), `&xi;__2`)], [diff(`&varphi;5`(`&xi;__1`, `&xi;__2`, Zeta), Zeta)]])
`&epsilon;__1` := Matrix([[`&epsilon;1__11`, 0, 0], [0, `&epsilon;1__22`, 0], [0, 0, `&epsilon;1__33`]])
`&epsilon;` := Matrix([[`&epsilon;5__11`, 0, 0], [0, `&epsilon;5__22`, 0], [0, 0, `&epsilon;5__33`]])
f := Matrix([[f1, f2, f3]])
D__1 := Multiply(e__1, epsilon)+Multiply(`&epsilon;__1`, E__1)
D__5 := Multiply(e__5, epsilon)+Multiply(`&epsilon;__5`, E__5)
h1 := simplify((Multiply(Transpose(E__1), D__1))(1))
(-R__1*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*e1__31*(R__2+Zeta)*(phi__2(xi__1, xi__2, t)*Zeta+v__0(xi__1, xi__2, Zeta, t))*(diff(a__1(xi__1, xi__2, Zeta, t), xi__2))-(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*R__2*e1__31*(R__1+Zeta)*(phi__1(xi__1, xi__2, t)*Zeta+u__0(xi__1, xi__2, Zeta, t))*(diff(a__2(xi__1, xi__2, Zeta, t), xi__1))-a__2(xi__1, xi__2, Zeta, t)*R__1*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*e1__31*(R__2+Zeta)*(diff(u__0(xi__1, xi__2, Zeta, t), xi__1))-a__1(xi__1, xi__2, Zeta, t)*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))*R__2*e1__31*(R__1+Zeta)*(diff(v__0(xi__1, xi__2, Zeta, t), xi__2))-a__2(xi__1, xi__2, Zeta, t)*R__1*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))*e1__15*(R__2+Zeta)*(diff(w__0(xi__1, xi__2, Zeta, t), xi__1))-a__1(xi__1, xi__2, Zeta, t)*R__2*(diff(varphi1(xi__1, xi__2, Zeta), xi__2))*e1__24*(R__1+Zeta)*(diff(w__0(xi__1, xi__2, Zeta, t), xi__2))+`&epsilon;1__33`*a__1(xi__1, xi__2, Zeta, t)*a__2(xi__1, xi__2, Zeta, t)*(R__2+Zeta)*(R__1+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))^2-e1__31*(a__2(xi__1, xi__2, Zeta, t)*R__1*Zeta*(R__2+Zeta)*(diff(phi__1(xi__1, xi__2, t), xi__1))+a__1(xi__1, xi__2, Zeta, t)*(R__2*Zeta*(R__1+Zeta)*(diff(phi__2(xi__1, xi__2, t), xi__2))+a__2(xi__1, xi__2, Zeta, t)*w__0(xi__1, xi__2, Zeta, t)*(R__1+R__2+2*Zeta)))*(diff(varphi1(xi__1, xi__2, Zeta), Zeta))+a__2(xi__1, xi__2, Zeta, t)*(`&epsilon;1__11`*(R__2+Zeta)*(R__1+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))^2-e1__15*(R__2+Zeta)*(phi__1(xi__1, xi__2, t)*R__1-u__0(xi__1, xi__2, Zeta, t))*(diff(varphi1(xi__1, xi__2, Zeta), xi__1))+(R__1+Zeta)*(`&epsilon;1__22`*(R__2+Zeta)*(diff(varphi1(xi__1, xi__2, Zeta), xi__2))-e1__24*(phi__2(xi__1, xi__2, t)*R__2-v__0(xi__1, xi__2, Zeta, t)))*(diff(varphi1(xi__1, xi__2, Zeta), xi__2)))*a__1(xi__1, xi__2, Zeta, t))/(a__1(xi__1, xi__2, Zeta, t)*a__2(xi__1, xi__2, Zeta, t)*(R__1+Zeta)*(R__2+Zeta))
Download simplifymore.mw
How can i simplify h1 more in Maple?
First 178 179 180 181 182 183 184 Last Page 180 of 371
