For bonus in my one class, we are required to change the code in a program to have it produce another row when running Neville's Method. We need to, after it runs initially, have it ask "Run another time? Y/N" and type 'Y' or 'N' for Yes or No. If No, it ends the program. If yes, we need to have it input another x(i) and f(x(i)) without having to input all the other data points again. Here is what I have so far (this is just the additional part we have to add, not the whole code):
 print(`Do you want another point? Type Y or N.`):
  J := scanf(` %c`)[1]:print(`Entry = `):print(J):
  if J = "Y" or J="y" then
  AGAIN := "Y":
  AGAIN = "Y" or AGAIN = "y":
        OUP := default:
      fprintf(OUP, `NEVILLE'S METHOD\n `):
       fprintf(OUP, `Table for P evaluated at X = %12.8f , follows: \n`, X):
       fprintf(OUP, `Entries are XX(I), Q(I,0), ..., Q(I,I) `):
       fprintf(OUP, `for each I = 0, ..., N where N = %3d\n\n`, N):
       for I1 from 0 to N+1 do
         fprintf(OUP, `%11.8f `, XX[I1]):
         for J from 0 to I1 do
           fprintf(OUP, `%11.8f `, Q[I1,J]):
         fprintf(OUP, `\n`):
    if J="Y" or J="y" then
         AGAIN := Y:
             if AGAIN = Y or AGAIN = y then
                 #N=N+1:
                  if N > 0 then
                  OK := TRUE:
                 for I1 from N to N+1 do
                        print(`Input X(i) and F(X(i)) for i = `):print(I1):
                        print(`separated by a space `):
                       XX[I1] := scanf(`%f`)[1]:
                       Q[I1,0] := scanf(`%f`)[1]:print(`Entries are`):print(XX[I1],Q[I1,0]):
                  print(`Number must be a positive integer `):
               fi:
                AGAIN := No:
         fi:
         fi:
        print(`Ok thanks`):
 fi:
Not sure what I am doing wrong and any help is appreciated. Thanks.
Leading on from this post I made before:
http://www.mapleprimes.com/questions/210359-Integrating-Very-Large-Sums
I have a script that can now integrate larger sums thanks to the tips I was given. I now have a question regarding cpu usage when the calculation is run through a loop. I have attached two files. One contains the sum (large_sum.txt) which is then read in to the main Maple script (large_sum_int.mw).
When the loop is run, the first few points are calculated quite consistently with very similar cpu times. However, as the calculation progresses the cpu time suddenly increases (with larger sums than the one given it is a very severe increase) it then decreases again and returns to the time it took for the initial points to be calculated.
Is there a reason there is a sticking point in this calculation? is there a more efficient way to simplify it before it reaches the integration stage? When using simplify(...,size) the initial block takes a very long time to execute hence is not included here. This is not the largest sum that needs to be processed so I am looking for means to speed up calculation time/make it more consistent.
Any help is appreciated
large_sum.txt
large_sum_int.mw
-Yeti
I have to use the optimization package.
- The objective function is non linear,
- I have constrains and bounds,
- The constrains are not linear.
I have reading the help page on maplesoft.com
My question are:
Can you confirm me that the only algorithm I can use is : NLPSolve with method ''sqp''?
And if I would like to use the gradient method how can I do?
This is somehow an old problem which came back and I decided to post it. So, I have some code which runs in Grid framework locally. Each node saves data directly to hard disk and there is no need to return anything at the end to the node of ID 0. Nevertheless, I noticed that memory usage on one instance of the mserver is very huge.  Moreover, this instance is all the time in S state, namely sleeping. Below you can see dump from top. I deny this is caused by some particular procedures called in my code since in this case I should rather observe more uniform memory usage. I am not sure if for this moment I could share some code with you which demonstrate this behavior. I will try to write some toy example because my productive code cannot be posted here.
%MEM     TIME+ COMMAND
49.1 17:00.19 mserver
0.1 12:43.70 mserver
0.1 12:32.15 mserver
0.1 13:54.02 mserver
0.1 14:45.45 mserver
0.1 12:35.22 mserver
0.1 13:50.77 mserver
0.1 14:14.85 mserver
0.1 8:58.82 mserver
0.1 12:58.48 mserver
0.1 8:51.00 mserver
0.1 10:35.92 mserver
0.1 12:58.13 mserver
0.1 9:34.39 mserver
0.1 10:10.13 mserver
0.1 12:07.77 mserver
0.0 8:21.17 mserver
0.0 11:41.42 mserver
0.0 5:07.27 mserver
0.0 8:31.88 mserver
0.0 6:30.12 mserver
What is the maximal independent set of monomial ideal$<c^4a^3b>$ in $K[a,b,c]$?
In the creation of a list, I would like to use the assume function twice.
Here it is a print screen of my issue.
The second part of the list is not taken into account.
Do you have ideas so that my list takes into account the second term ?
Thanks a lot for your feedback
not the same ordering every time of monomials after determinant and map sign positive and op in maple 15
sometimes i need to use Reverse or Rotate List to adjust.
why ordering is different in list of monomials?
is it caused by virus?
Hi there.
I have a equation following:
with letters {a,b,c,d,k} is missing all solutions ,but with {z,u,w,t} letters works fine.
Bug_maple.mw
I_Mariusz
Hi everyone, I got a problem. I'm a new user and I'm getting to know this beautiful software.
The problem is that when I enter a function in math mode (the easyest with simple inputs I guess), once I right click and plot only the cartesian plot is shown, without the actual function.
What should I try? Math without plots is boring... :)
Thank you!
I have the following question:
Illustrate how the sequence N->R de fined by n ->n^2/n^2 + 31n + 228 can be shown to be
within a given epsilon > 0 of its limiting value x0.
(a) use an appropriate conditional statement to find N such that abs (xn -􀀀 x0) < epsilon for every n>=N
and produce an appropriate list of the data points (n,xn) to illustrate
this
I found N but without using any CONDITIONAL STATEMENT.Can you help me find N using IF FOR WHILE?
Hello All,
I am running Maple 18 on Ubuntu 14.04.4 with x86_64 architecture. When running the xmaple command for a specific user, the java loading window takes about 5-10 minutes to appear. With other users, it takes around 15 seconds. All users are running the same xmaple script, I did not see and conflicting environment variables.
I was wondering if the community had any other ideas as to what could be causing this slow response?
Thank you in advance,
Michael
I receive this message when I try to store the package that I have created as a table
Do you have some ideas how I can correct my code so as to store efficiently my package ?
Thanks a lot for your help
I have an equation as shown below.  In this i need to get the value of 'a' for each 'omega'.  'omega' range from 0 to 2 with increment 0.01
And save all the values of 'a' as a column matrix named 'result'.
!!!  Please help  !!!
0.4e-3*a^2*omega^2+(-2.1739*a+a*omega^2+(1.495414012*(sqrt(a^2+.2916)*EllipticE(sqrt(a^2/(a^2+.2916)))-.2916*EllipticK(sqrt(a^2/(a^2+.2916)))/sqrt(a^2+.2916)))/a)^2-0.1e-3 = 0
Download problem_1.mw
In a worksheet, I have defined several long procedures. In order to simplify my worksheet, I would like define thes procedures in a package so as to call theses procedures from the package. It should enable to improve the readability of my worksheet.
However, i have never make a custom package. Can you detail me the main steps so as to create a custom package ?
Thanks a lot for your help.
I am interested in efficiently plotting a grid of squares where each square is coloured.
From what I understand I can do this using plotting primitives. For example,
P1 := Array( 1..4, 1..2, [[0,0],[1,0],[1,1],[0,1]],storage=rectangular, order=C_order, datatype=float[8] );
P2 := Array( 1..4, 1..2, [[1,1],[2,1],[2,2],[1,2]],storage=rectangular, order=C_order, datatype=float[8] );
PLOT( POLYGONS(P1,P2), COLOUR(RGB,1,0,0,0,1,0)  );
plots one red and one green unit sqaure.
I am interested however in plotting millions of squares.  Is there a way to efficiently store the sequence required for the POLYGONS and COLOUR primitive?  Ideally I want to store them as arrays.
First 204 205 206 207 208 209 210 Last Page 206 of 371
