Hi, currently im using maple 15
the coding did work but it is not the same with the answer
here, i attach the coding with the answer
coding:
derivation := proc (A, n)
local i, j, k, t, s1, s2, m, D, sols, eqns, Andre;
eqns := {};
D := matrix(n, n);
Andre := matrix(n, n);
for i to n-1 do
for j from i+1 to n do
for m to n do
s1 := sum(A[i, j, k]*D[m, k], k = 1 .. n);
s2 := sum(A[k, j, m]*D[k, i]+A[i, k, m]*D[k, j], k = 1 .. n);
eqns := `union`(eqns, {s1 = s2})
end do end do end do;
sols := [solve(eqns)];
t := nops(sols);
for i to t do
for j to n do
for k to n do
Andre[k, j] := subs(sols[i], D[k, j])
end do end do;
print(Andre)
end do end proc
the maple result showing:
> AS1 := array(sparse, 1 .. 2, 1 .. 2, 1 .. 2, [(1, 1, 2) = 1]);
> derivation(AS1, 2);
[D11 0]
[D21 D22]
> AS2 := array(sparse, 1 .. 2, 1 .. 2, 1 .. 2, [(1, 1, 1) = 1, (1, 2, 2) = 1]);
> derivation(AS2, 2);
[0 D12]
[D21 D22]
the maple should showing
> derivation(AS1, 2);
[D11 0]
[D21 2D11]
> derivation(AS2, 2);
[0 0]
[D21 D22]
please help., thank you
how to field plot this system?
with(Physics[Vectors]);
with(DEtools);
with(VectorCalculus);
eq2 := ...;
eq3 := ...;
eq4 := ...;
with(DynamicSystems);
sys := DiffEquation([eq2 = t, eq3 = t], inputvariable = [b(t)], outputvariable = [a(t), c(t)]);
ts := .1;
in_t := t;
sol := Simulate(sys, [in_t]);
with(DEtools):
dfieldplot([...],[a(t),b(t),c(t)],t=−2..2,a=−1..2,b=−1..2,c=−1..2,arrows=SLIM,color=black,dirfield=[10,10]);
Hello, I have a question.  I don't know why, but results of my calculations can't be saved in raschet document. This document excists, but there is no information in it! And I have an error with floating point format. How to solve that problems?
> restart;
> Digits := 5;
> NULL;
> NULL;
> NULL;
> NULL;
> NULL;
> ScS0 := P/(phi*f*kc*k0*deltad*Bm*etat);
> NULL;
> NULL;
> Sc := sqrt(ScS0);
> A := sqrt(Sc);
> B := A;
> NULL;
> mue := mu0*mur/(1+mur*dzet/lm);
> lm := 2*(LCA-A+(LC0+A))+dzet;
> NULL;
> LC0 := 3*A; LCA := .4*LC0; LD := .9*LC0;
> NULL;
> NULL;
> w1 := EE/(2*Pi*f*Bm*Sc);
> Lm := mue*w1^2*Sc/lm;
> I11 := sqrt((w2*Id/w1)^2+I0^2);
> NULL;
> h1 := sqrt(RAT*I11/deltad);
> h2 := sqrt(RAT*Id/deltad);
> NULL;
> A := .6;
> Ud := 35000;
> R := Ud^2/P;
> P := Ud*Id;
> P1 := P/eta;
> R1 := EE/I11;
> EE := 110000;
> I0 := EE/(2*Pi*f*Lm);
> w2 := w1*sqrt(P*R)/EE;
> mu0 := 4*Pi*10^(-7);
> mur := 1000;
> f := 50;
> k0 := .25;
> kc := .98;
> deltad := 0.3e7;
> Bm := 1.45;
> etat := .98;
> eta := .95;
> RAT := 1;
> dzet := 0.1e-3;
> phi := .5;
> W1 := evalf(w1);
324.55
> LLm := evalf(Lm);
13.407
> W2 := evalf(w2);
103.26
> evalf(lm);
7.2457
> evalf(LC0);
2.5877
> evalf(LCA);
1.0351
> Imax := evalf(I0);
26.117
> P1;
7
1.5215 10
> Rd := evalf(R);
84.746
> Bmm := evalf(mue*w1*I0/lm);
1.4500
> hâ := (.9*LC0*1000)/(w2+1)-4;
> evalf(hâ);
h¬
> Pred := Id/deltad;
> evalf(Pred);
0.00013767
> NULL;
> NULL;
> ll := hâ*(w2+1)+4*w2;
> NULL;
> a := am*nâ/nx;
> NULL;
> Pol := Vit*nâ;
> am := 5.1;
> am := 5.1;
> nâ := 4;
> evalf(a);
20.4
nx
> Vit := 35.19;
> evalf(Pol);
140.76
> plotnToka := Id/Pol;
> evalf(Id/Pol);
2.9341
> NULL;
> I1 := evalf(I11);
133.98
> NULL;
> evalf(mue);
0.0012395
> NULL;
> evalf(EE/I11);
821.02
> NULL;
> pr := "%";
> fd := fopen("C:\\Users\\Ñåìåí\\Desktop\\ÍÈÐ\\raschet4.ms", WRITE); fprintf(fd, "E=%g;Ud=%g;Imax=%g;P=%g;FR=%g;A=%g;B=%g;LC0=%g;LD=%g;LCA=%g;R=%g;BM=%g;", EE, Ud, Imax, P, f, A, B, LC0, LD, LCA, Rd, Bm); fprintf(fd, "\n %s P=%g;Id = %g;Bm=%g;I1=%g;Bmm=%g", pr, P, Id, Bm, I1, Bmm);
Error, (in fprintf) number expected for floating point format
> fprintf(fd, "\n %s W1 = %g; W2 = %g; Lm=%g; Sc=%g; dzet=%g", pr, W1, W2, LLm, Sc, dzet);
Error, (in fprintf) file descriptor not in use
> fclose(fd);
Error, (in fclose) file descriptor not in use
I have a system of PDEs with 3 dependent variables (U, V, W) and 3 independent variables (x, y, t).
I need an explicit numerical solution, i.e., a table with the values of U, V and W, corresponding to several values of x, y and t.
Can anybody help me?
How can Maple solve that problem for me?
Given: a summation of one equation with its limits, equaling another summation with given limits, but NOt the equation. How do Maple be programmed to find that out?
fx     [sum(x^(n)*y^(1-n), n=0..10, = sum(unknownequation),n=1..11)]   , find the unknown equation by maple?
Appreciating in advance,
Hi, I have defined two functions:
ex1 := (x,t,z) -> -1.132*10^(11)* exp(9.9*10^(6)*x)*exp(sqrt(-1)*(1.95*10^6*z-2.98*10^15*t))
ex2 := (x,t,z) -> -2.82*10^(12)* exp(2*10^(6)*sqrt(-1)*x)*exp(sqrt(-1)*(1.95e*10^(6)*z-2.98*10^(15)*t));
And then tried the command:
implicitplot3d( ex1, x = -10..0, t = 0..10, z = 0..10, axes = boxed, style = patchcontour, scaling = constrained, shading =z);
But the boxes are entirely blank! What is the problem here?? It should be some kind of sine curve
Maple 2016.
Why does
int(sqrt(c+d*tan(e+f*x))*(a+b*tan(e+f*x))^(5/2),x);
Causes mserver.exe to hang into a loop at full CPU and maple hangs?
Windows 7, 64 bit.  Even using timelimit() on it, it still hangs exceeding the time limit and never return. I have to kill mserver.exe or exit Maple to recover.
I have posted long time ago a patch for Shadebetween and you have transformed it into a hot fix:
http://www.mapleprimes.com/questions/205956-Error-In-Shadebetween
In the last Maple 2015 update, the problem was not fixed.
Just curious: is it fixed in Maple 2016? Because I feel that the Maplesoft team is not "impressed" by such patches.
Edit. This was a comment related to acer's patch for NLPSolve, but it was transformed (I don't know why) into a separate question.
I am trying to find the interpolation of a 3D function.
I have the vector x, the vector y and a matrix M at my disposition.
I know how to do the pointplot3d , but I can not find the function: f(x,y)
any suggestion?
Thank you for help
I am trying to slve the second order differential equation with initial conditions  t0=0.dy/dt=0,y0=10000
-(diff(y, t, t))-9.81+0.563e-3*(0.1832e-2*abs(diff(y, t))+0.51702e-1*abs(diff(y, t))^(3/2)+.4*(diff(y, t))^2) = 0
using 4th order runge kutta.do i need to declare a step parameter like (D(y))(t) = u or is a command that can be applied automatically?
 rk4.mw
Hello everyone, I recently learned how to plot vector fields using maple. So far, I know of two ways using VectorField(output = plot) and fieldplot3d(some_vectorfunction). My problem is that, it seems these two functions yield slightly different plots, fieldplot3d seems to give a more accurate depiction of the actual vector field, whereas the other function gives a similar ouput but in a more 'sloppy' form. Is this normal? Or am I doing something wrong?
Here are the two plots done by each function:
fieldplot3d:
Plot done by 'fieldplot3d' function.
VectorField(output = plot):
Plot done by 'VectorField(output = plot)' function.
I would like to symbolically determine the rank of a jacobian matrix. In the help, I have seen that the Rank function of the LinearAlgebra can be used for this purpose. However, when I use this function, the function doesn't allow to find the different singularities that can occur on my jacobian matrix.
Here a exemple of a jacobian matrix that I obtain on a slidercrank mechanism:
Phi := Matrix(2, 3, {(1, 1) = -l1*sin(theta(t)), (1, 2) = -1, (1, 3) = l2*cos(beta(t)), (2, 1) = l1*cos(theta(t)), (2, 2) = 0, (2, 3) = l2*sin(beta(t))})
The rank of this jaobian (Phi) gives 2 whatever the values of theta(t) and beta(t). However, if the values of  theta(t) and beta(t) are :theta(t)=Pi/2,beta(t)=0. The rank shouldn't be 2 but 1.
Is a way to obtain the symbolic calculation of the rank of a jacobian matrix which can distinguish different cases following the values of the parameters ? In others words, my dream will be to have a Rank function (or another algorithm) which can gives :
the rank is 2 if theta(t) different of Pi/2 [Pi] and beta(t)=0 [Pi]
and otherwise 1 if ...
and perhaps 0 if ...
Thanks a lot for your help.
I let a piece of code with an example of calculation of the rank
RankMatrix.mw
I am trying to solve the folowing ODE with initial conditions t0=0,v0=0 and tf =80 with step 0.01 but the matrix that appears is not having the values!please help
f := proc (t, V) options operator, arrow; -9.81+0.563e-3*(0.1832e-2*abs(V)+0.51702e-1*(abs(V)^(3/2))+.4*V^2) end proc
V0 := 0:
t0 := 0:
tf := 80:
n := 1000
h := evalf((tf-t0)/n):
t := t0:
V := V0:
rk := proc (x0, tf, V0, n) local t, V, h, i, k1, k2, k3, k4, k, R; t := t0; V := V0; R := t, V; h := evalf((tf-t0)/n); for i to n do k1 := f(t, V); k2 := f(t+(1/2)*h, V+(1/2)*h*k1); k3 := f(t+(1/2)*h, V+(1/2)*h*k2); k4 := f(t+h, V+h*k3); k := (1/6)*k1+(1/3)*k2+(1/3)*k3+(1/6)*k4; V := V+h*k; t := t+h; R := R, t, V end do end proc:
R := rk(0, 80, 0, 300):
0, 0
.2666666667, -2.615998110
.5333333334, -5.231986045
.8000000001, -7.847954569
1.066666667, -10.46389463
1.333333334, -13.07979725
1.600000001, -15.69565351
1.866666668, -18.31145452
2.133333335, -20.92719143
2.400000002, -23.54285541
2.666666669, -26.15843764
2.933333336, -28.77392932
3.200000003, -31.38932166
3.466666670, -34.00460588
3.733333337, -36.61977321
4.000000004, -39.23481490
4.266666671, -41.84972219
4.533333338, -44.46448634
4.800000005, -47.07909861
5.066666672, -49.69355027
5.333333339, -52.30783259
5.600000006, -54.92193685
5.866666673, -57.53585433
6.133333340, -60.14957632
6.400000007, -62.76309410
6.666666674, -65.37639897
6.933333341, -67.98948223
7.200000008, -70.60233518
7.466666675, -73.21494912
7.733333342, -75.82731536
8.000000009, -78.43942520
8.266666676, -81.05126996
8.533333343, -83.66284095
8.800000010, -86.27412949
9.066666677, -88.88512689
9.333333344, -91.49582448
9.600000011, -94.10621358
9.866666678, -96.71628551
10.13333334, -99.32603160
10.40000001, -101.9354432
10.66666668, -104.5445116
10.93333335, -107.1532281
11.20000002, -109.7615841
11.46666669, -112.3695709
11.73333336, -114.9771799
12.00000003, -117.5844024
12.26666670, -120.1912297
12.53333337, -122.7976532
12.80000004, -125.4036642
13.06666671, -128.0092541
13.33333338, -130.6144142
13.60000005, -133.2191358
13.86666672, -135.8234103
14.13333339, -138.4272290
14.40000006, -141.0305833
14.66666673, -143.6334645
14.93333340, -146.2358640
15.20000007, -148.8377732
15.46666674, -151.4391834
15.73333341, -154.0400859
16.26666675, -159.2403334
16.53333342, -161.8396611
16.80000009, -164.4384465
17.06666676, -167.0366810
17.33333343, -169.6343560
17.60000010, -172.2314629
17.86666677, -174.8279930
18.13333344, -177.4239376
18.40000011, -180.0192882
18.66666678, -182.6140360
18.93333345, -185.2081725
19.20000012, -187.8016890
19.46666679, -190.3945769
19.73333346, -192.9868275
20.00000013, -195.5784322
20.26666680, -198.1693824
20.53333347, -200.7596694
20.80000014, -203.3492846
21.06666681, -205.9382194
21.33333348, -208.5264652
21.60000015, -211.1140133
21.86666682, -213.7008550
22.13333349, -216.2869818
22.40000016, -218.8723850
22.66666683, -221.4570560
22.93333350, -224.0409862
23.20000017, -226.6241669
23.46666684, -229.2065895
23.73333351, -231.7882454
24.00000018, -234.3691260
24.26666685, -236.9492226
24.53333352, -239.5285266
24.80000019, -242.1070294
25.06666686, -244.6847224
25.33333353, -247.2615969
25.60000020, -249.8376443
25.86666687, -252.4128560
26.13333354, -254.9872234
26.40000021, -257.5607378
26.66666688, -260.1333906
26.93333355, -262.7051732
27.20000022, -265.2760770
27.46666689, -267.8460934
27.73333356, -270.4152137
28.00000023, -272.9834293
28.26666690, -275.5507316
28.53333357, -278.1171120
28.80000024, -280.6825619
29.06666691, -283.2470726
29.33333358, -285.8106356
29.60000025, -288.3732422
29.86666692, -290.9348838
30.13333359, -293.4955517
30.40000026, -296.0552374
30.66666693, -298.6139322
30.93333360, -301.1716276
31.20000027, -303.7283149
31.46666694, -306.2839855
31.73333361, -308.8386307
32.00000028, -311.3922420
32.26666695, -313.9448108
32.53333362, -316.4963284
32.80000029, -319.0467862
33.06666696, -321.5961756
33.33333363, -324.1444880
33.60000030, -326.6917148
33.86666697, -329.2378474
34.13333364, -331.7828772
34.40000031, -334.3267955
34.66666698, -336.8695937
34.93333365, -339.4112633
35.20000032, -341.9517956
35.46666699, -344.4911820
35.73333366, -347.0294139
36.00000033, -349.5664827
36.26666700, -352.1023797
36.53333367, -354.6370964
36.80000034, -357.1706242
37.06666701, -359.7029544
37.33333368, -362.2340784
37.60000035, -364.7639877
37.86666702, -367.2926736
38.13333369, -369.8201275
38.40000036, -372.3463408
38.66666703, -374.8713049
38.93333370, -377.3950112
39.20000037, -379.9174511
39.46666704, -382.4386159
39.73333371, -384.9584971
40.00000038, -387.4770861
40.26666705, -389.9943742
40.53333372, -392.5103529
40.80000039, -395.0250135
41.06666706, -397.5383474
41.33333373, -400.0503461
41.60000040, -402.5610009
41.86666707, -405.0703032
42.13333374, -407.5782444
42.40000041, -410.0848159
42.66666708, -412.5900091
42.93333375, -415.0938154
43.20000042, -417.5962262
43.46666709, -420.0972329
43.73333376, -422.5968269
44.00000043, -425.0949996
44.26666710, -427.5917424
44.53333377, -430.0870466
44.80000044, -432.5809037
45.06666711, -435.0733051
45.33333378, -437.5642421
45.60000045, -440.0537062
45.86666712, -442.5416888
46.13333379, -445.0281812
46.40000046, -447.5131749
46.66666713, -449.9966612
46.93333380, -452.4786316
47.20000047, -454.9590775
47.46666714, -457.4379902
47.73333381, -459.9153612
48.00000048, -462.3911818
48.26666715, -464.8654435
48.53333382, -467.3381376
48.80000049, -469.8092556
49.06666716, -472.2787888
49.33333383, -474.7467287
49.60000050, -477.2130666
49.86666717, -479.6777940
50.13333384, -482.1409022
50.40000051, -484.6023827
50.66666718, -487.0622268
50.93333385, -489.5204260
51.20000052, -491.9769716
51.46666719, -494.4318551
51.73333386, -496.8850678
52.00000053, -499.3366012
52.26666720, -501.7864466
52.53333387, -504.2345955
52.80000054, -506.6810393
53.06666721, -509.1257693
53.33333388, -511.5687770
53.60000055, -514.0100537
53.86666722, -516.4495909
54.13333389, -518.8873800
54.40000056, -521.3234124
54.66666723, -523.7576794
54.93333390, -526.1901725
55.20000057, -528.6208831
55.46666724, -531.0498026
55.73333391, -533.4769224
56.00000058, -535.9022339
56.26666725, -538.3257285
56.53333392, -540.7473976
56.80000059, -543.1672326
57.06666726, -545.5852249
57.33333393, -548.0013659
57.60000060, -550.4156470
57.86666727, -552.8280597
58.13333394, -555.2385953
58.40000061, -557.6472452
58.66666728, -560.0540009
58.93333395, -562.4588537
59.20000062, -564.8617951
59.46666729, -567.2628164
59.73333396, -569.6619091
60.00000063, -572.0590645
60.26666730, -574.4542741
60.53333397, -576.8475293
60.80000064, -579.2388215
61.06666731, -581.6281420
61.33333398, -584.0154823
61.60000065, -586.4008338
61.86666732, -588.7841879
62.13333399, -591.1655361
62.40000066, -593.5448697
62.66666733, -595.9221801
62.93333400, -598.2974587
63.20000067, -600.6706970
63.46666734, -603.0418863
63.73333401, -605.4110181
64.00000068, -607.7780837
64.26666735, -610.1430746
64.53333402, -612.5059822
64.80000069, -614.8667979
65.06666736, -617.2255130
65.33333403, -619.5821190
65.60000070, -621.9366073
65.86666737, -624.2889694
66.13333404, -626.6391966
66.40000071, -628.9872803
66.66666738, -631.3332119
66.93333405, -633.6769829
67.20000072, -636.0185846
67.46666739, -638.3580085
67.73333406, -640.6952460
68.00000073, -643.0302885
68.26666740, -645.3631274
68.53333407, -647.6937540
68.80000074, -650.0221599
69.06666741, -652.3483364
69.33333408, -654.6722749
69.60000075, -656.9939668
69.86666742, -659.3134036
70.13333409, -661.6305766
70.40000076, -663.9454773
70.66666743, -666.2580971
70.93333410, -668.5684273
71.20000077, -670.8764594
71.46666744, -673.1821848
71.73333411, -675.4855950
72.00000078, -677.7866813
72.26666745, -680.0854351
72.53333412, -682.3818479
72.80000079, -684.6759110
73.06666746, -686.9676159
73.33333413, -689.2569539
73.60000080, -691.5439165
73.86666747, -693.8284951
74.13333414, -696.1106811
74.40000081, -698.3904660
74.66666748, -700.6678411
74.93333415, -702.9427978
75.20000082, -705.2153276
75.46666749, -707.4854218
75.73333416, -709.7530719
76.00000083, -712.0182693
76.26666750, -714.2810054
76.53333417, -716.5412716
76.80000084, -718.7990593
77.06666751, -721.0543600
77.33333418, -723.3071650
77.60000085, -725.5574658
77.86666752, -727.8052537
78.13333419, -730.0505202
78.40000086, -732.2932567
78.66666753, -734.5334546
78.93333420, -736.7711053
79.73333421, -743.4686884
Download runge_kutta4.mw
Is this what is supposed to happen when linking Maple to Matlab?  I was hoping it would open the actual Matlab program and write variables to the current worksheet.  I'm I missing something?
Nothing even pops up on the Matlab Command window. What good is this?
I have 3 equations
eq1 := vs = (Rs+Z)*i1+Z*i3
eq2 := A*vi = Z*i1+(Z+Rf+ro)*i3
eq3:= vo = (Rf+Z)*i3+Z*i1
and I want to solve for vo/vs . How to do that ?
the expected solution is
First 203 204 205 206 207 208 209 Last Page 205 of 371
