I have .mla. package and I would like to create the source code associated to this package.
In the past, you have also help me to obtain the source code of procedure of the module.
Here the post where Carl Love has helped me :
http://www.mapleprimes.com/questions/203676-Open-A-Maple-Package
How can I do to create the complete source code of package directly ?
Is there a direct way enabling to not have to read one procedure by one procedure but to obtain the code source for all the package ?
Thank you for your help
Environment: Maple2015, MATLAB_R2014b(MacOSX10.8.5), 2015b(MacOSX10.11.4)
MapleToolbox2015.1MacInstaller.app was successfully completed (log tells us), but when MATLAB were booted, following error messages appeared and symbolic operations of maple failed.
This would be closely related to maple installation on MATLAB as such errors never occur for clean install of MATLABs and looks independent on OSX versions. Now javaforosx.dmg in use by instruction of Maplesoft.  Something wrong is in Maple2015. Note maple-MATLAB link works normally.
Please provide us with direction of how to fix it hopefully by Maplesoft professionals.
(Quote of MATLAB command window display)
Exception in thread "Startup Class Loader" java.lang.UnsatisfiedLinkError: jogamp.common.os.MachineDescriptionRuntime.getPointerSizeInBytesImpl()I
at jogamp.common.os.MachineDescriptionRuntime.getPointerSizeInBytesImpl(Native Method)
at jogamp.common.os.MachineDescriptionRuntime.getRuntimeImpl(MachineDescriptionRuntime.java:138)
at jogamp.common.os.MachineDescriptionRuntime.getRuntime(MachineDescriptionRuntime.java:124)
at com.jogamp.common.os.Platform.<clinit>(Platform.java:228)
at javax.media.opengl.GLProfile.<clinit>(GLProfile.java:83)
at com.mathworks.hg.peer.JavaSceneServerPeer.initializeJOGL(JavaSceneServerPeer.java:114)
at com.mathworks.hg.peer.JavaSceneServerPeer.<clinit>(JavaSceneServerPeer.java:100)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:190)
at com.mathworks.mde.desk.StartupClassLoader.loadClass(StartupClassLoader.java:258)
at com.mathworks.mde.desk.StartupClassLoader.access$900(StartupClassLoader.java:25)
at com.mathworks.mde.desk.StartupClassLoader$2.run(StartupClassLoader.java:244)
at java.lang.Thread.run(Thread.java:745)
>> maple();
error: maple (line 178)
Invalid MEX-file '/Applications/MATLAB_R2014b.app/toolbox/maple/maplemex.mexmaci64':
dlopen(/Applications/MATLAB_R2014b.app/toolbox/maple/maplemex.mexmaci64, 6): Symbol not found: ___sincos_stret
  Referenced from: /Library/Frameworks/Maple.framework/Versions/2015/bin.APPLE_UNIVERSAL_OSX/libhf.dylib
  Expected in: /usr/lib/libSystem.B.dylib
 in /Library/Frameworks/Maple.framework/Versions/2015/bin.APPLE_UNIVERSAL_OSX/libhf.dylib
>> syms x  y
error: sym (line 186)
 error: sym (line 56)
           assignin('caller',varargin{i},sym(varargin{i}));
(Unquote)
I've got the following:
Integral_over_region.mw
M_Iwaniuk
For the last 24hrs or so I have found it almost impossible to upload worksheet files in response to questions.
My usual approach is
Big green up-arrow:
(uploader pop-up appears)
Browse files
(this still works)
Upload file
This is the problem step - I generally just get "waiting for Mapleprimes" in my browser's annunciator box: and I wait, and wait, (as in >5 minutes) and still this step does not complete. Just to be annoying, every once in a while the file will upload as normal, such but success is now the exception
I'm seeing the same issue in Firefox 45.0.2 and Chrome 50.0.2661.75mon Win 7, 64-bit.
Anyone else seeing the same issue?
Dear Maple researchers
I have a problem in solving a system of odes that resulted from discretizing, in space variable, method of lines (MOL).
The basic idea of this code is constructed from the following paper:
http://www.sciencedirect.com/science/article/pii/S0096300313008060
If kindly is possible, please tell me whas the solution of this problem.
With kin dregards,
Emran Tohidi.
My codes is here:
> restart;
> with(orthopoly);
print(`output redirected...`); # input placeholder
> N := 4; Digits := 20;
> A := -1; B := 1; rho := 3/4;
> g1 := proc (t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(A-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc; g2 := proc (t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(B-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc;
> f := proc (x) options operator, arrow; 1/2+(1/2)*tanh((1/2)*x/sqrt(2)) end proc;
> uexact := proc (x, t) options operator, arrow; 1/2+(1/2)*tanh((1/2)*(x-(2*rho-1)*t/sqrt(2))/sqrt(2)) end proc;
> basiceq := simplify(diff(uexact(x, t), `$`(t, 1))-(diff(uexact(x, t), `$`(x, 2)))+uexact(x, t)*(1-uexact(x, t))*(rho-uexact(x, t)));
> alpha := 0; beta := 0; pol := P(N-1, alpha+1, beta+1, x); pol := unapply(pol, x); dpol := simplify(diff(pol(x), x)); dpol := unapply(dpol, x);
> nodes := fsolve(P(N-1, alpha+1, beta+1, x));
> xx[0] := -1;
> for i to N-1 do xx[i] := nodes[i] end do;
> xx[N] := 1;
> for k from 0 to N do h[k] := 2^(alpha+beta+1)*GAMMA(k+alpha+1)*GAMMA(k+beta+1)/((2*k+alpha+beta+1)*GAMMA(k+1)*GAMMA(k+alpha+beta+1)) end do;
> w[0] := 2^(alpha+beta+1)*(beta+1)*GAMMA(beta+1)^2*GAMMA(N)*GAMMA(N+alpha+1)/(GAMMA(N+beta+1)*GAMMA(N+alpha+beta+2));
> for jj to N-1 do w[jj] := 2^(alpha+beta+3)*GAMMA(N+alpha+1)*GAMMA(N+beta+1)/((1-xx[jj]^2)^2*dpol(xx[jj])^2*factorial(N-1)*GAMMA(N+alpha+beta+2)) end do;
> w[N] := 2^(alpha+beta+1)*(alpha+1)*GAMMA(alpha+1)^2*GAMMA(N)*GAMMA(N+beta+1)/(GAMMA(N+alpha+1)*GAMMA(N+alpha+beta+2));
> for j from 0 to N do dpoly1[j] := simplify(diff(P(j, alpha, beta, x), `$`(x, 1))); dpoly1[j] := unapply(dpoly1[j], x); dpoly2[j] := simplify(diff(P(j, alpha, beta, x), `$`(x, 2))); dpoly2[j] := unapply(dpoly2[j], x) end do;
print(??); # input placeholder
> for n to N-1 do for i from 0 to N do BB[n, i] := sum(P(jjj, alpha, beta, xx[jjj])*dpoly2[jjj](xx[n])*w[i]/h[jjj], jjj = 0 .. N) end do end do;
> for n to N-1 do d[n] := BB[n, 0]*g1(t)+BB[n, N]*g2(t); d[n] := unapply(d[n], t) end do;
> for nn to N-1 do F[nn] := simplify(sum(BB[nn, ii]*u[ii](t), ii = 1 .. N-1)+u[nn](t)*(1-u[nn](t))*(rho-u[nn](t))+d[nn](t)); F[nn] := unapply(F[nn], t) end do;
> sys1 := [seq(d*u[q](t)/dt = F[q](t), q = 1 .. N-1)];
[d u[1](t)
[--------- = 40.708333333333333334 u[1](t) + 52.190476190476190476 u[2](t)
[   dt
        2          3
   + 39.958333333333333334 u[3](t) - 1.7500000000000000000 u[1](t)  + u[1](t)
   + 7.3392857142857142858
   - 3.6696428571428571429 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) - 3.6696428571428571429 tanh(
                                                     d u[2](t)
-0.35355339059327376220 + 0.12500000000000000000 t), --------- =
                                                        dt
-20.416666666666666667 u[1](t) - 25.916666666666666667 u[2](t)
        2          3
   - 20.416666666666666667 u[3](t) - 1.7500000000000000000 u[2](t)  + u[2](t)
   - 3.7500000000000000000
   + 1.8750000000000000000 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) + 1.8750000000000000000 tanh(
                                                     d u[3](t)
-0.35355339059327376220 + 0.12500000000000000000 t), --------- = 29.458333333\
                                                        dt
  333333333 u[1](t) + 38.476190476190476190 u[2](t)
        2          3
   + 30.208333333333333333 u[3](t) - 1.7500000000000000000 u[3](t)  + u[3](t)
   + 5.4107142857142857144
   - 2.7053571428571428572 tanh(0.35355339059327376220
   + 0.12500000000000000000 t) - 2.7053571428571428572 tanh(
-0.35355339059327376220 + 0.12500000000000000000 t)]
> ics := seq(u[qq](0) = evalf(f(xx[qq])), qq = 1 .. N-1);
    u[1](0) = 0.38629570659055483825, u[2](0) = 0.50000000000000000000,
      u[3](0) = 0.61370429340944516175
> dsolve([sys1, ics], numeic);
Error, (in dsolve) invalid input: `PDEtools/sdsolve` expects its 1st argument, SYS, to be of type {set({`<>`, `=`, algebraic}), list({`<>`, `=`, algebraic})}, but received [[d*u[1](t)/dt = (20354166666666666667/500000000000000000)*u[1](t)+(13047619047619047619/250000000000000000)*u[2](t)+(19979166666666666667/500000000000000000)*u[3](t)-(7/4)*u[1](t)^2+u[1](t)^3+36696428571428571429/5000000000000000000-(36696428571428571429/10000000000000000000)*tanh(1767766952966368811/5000000000000000000+(1/8)*t)-(36696428571428571429/10000000000000000000)*tanh(-1767766952966368811/5000000000000000000+(1/8)*t), d*u[2](t)/dt = -(20416666666666666667/1000000...
I am currently working on FDM ,i have 2 coupled nonlinear pde ,i need help in solving these equation using maple code.
> restart:
> alias(f=f(tau,eta), theta=theta(tau,eta));
> PDE1:=S*diff(f,tau,eta)=eta^2*diff(f,eta)^2+(6*eta^2-2*f*eta)*diff(f,eta)+(6*eta^3-f*eta)*diff(f,eta,eta)-eta^4*diff(f,eta,eta,eta);
> PDE2:=eta^4*diff(theta,eta,eta)+2*eta^3*diff(theta,eta)-Pr*(f*eta^2*diff(theta,eta)+S*diff(theta,tau))=0;
The code I write is properly indented.  The operation of pasting it here strips the white space and makes it hard for the reader to comprehend the structure. Manually restoring the appropriate indentation is doable but tedious, made more so because the characters we see here are in a variable width font.  The rationale might be that, given a variable width font the indentation is going to be inconsistent, but that isn't the case if the preformatted style is used, which I do, for code.
Is there any way to turn off the white space stripping?  Presumably this is some ridiculous xml-based processing feature.
I want to solve system of non linear odes numerically.
I encounter following error
Error, (in dsolve/numeric/bvp) cannot determine a suitable initial profile, please specify an approximate initial solution
how to correct it
regards
Is it possible to view maple workbook content in older versions?
I am trying to solve numerically int( f(t,z) , t=0..T ) = 0 , in z for a cumbersome f.
I tried z1=fsolve( int( f(t,z) , t=0..T ) = 0 , z). But then I tried int( f(t,z1) , t=0..T ) and the result is clearly not zero nor anything small.
It looks like Maple evaluates analytically the integral, and does it wrong (check this for more details) so fsolve uses the wrong equations.
Anyone knows how I can force Maple to evaluate numerically the integral at each step of the fsolve function?
Thank you!
hi,i am studying the maple most recent.But when calculating function integral,I ran into trouble.I hope to get your help.Here is the code I wrote, but it runs a very long time. How to effectively reduce the integration time?
with(student);
assume(n::integer);
Fourierf := proc (sigma, a, b, N) local A, A0, B, T, S, Ff; T := b-a; A0 := int(sigma, t = a .. b); A := int(sigma*sin(n*Pi*t/T), t = a .. b); B := int(sigma*cos(n*Pi*t/T), t = a .. b); S := sum(A*sin(n*Pi*t/T)+B*cos(n*Pi*t/T), n = 1 .. N)+(1/2)*A0; Ff := unapply(S, t) end proc;
f := proc (t) options operator, arrow; piecewise(t < .13*2.6 and 0 <= t, 100*t/(.13*2.6), .13*2.6 <= t and t < 2.6, 100, 2.6 <= t and t < 2.6*1.1, 0) end proc;
sigma := f(t);
a := 0;
b := 1.1*2.6;
s1 := unapply((Fourierf(sigma, a, b, 500))(t)/uw0, t);
s2 := unapply((Fourierf(sigma, a, b, 500))(t)/ua0, t);
A1 := (2*n+1)^2*Pi^2*(C3+1+sqrt(4*C1*C2*C3+C3^2-2*C3+1))/(8*C1*C2-8);
A2 := (2*n+1)^2*Pi^2*(C3+1-sqrt(4*C1*C2*C3+C3^2-2*C3+1))/(8*C1*C2-8);
g := -C2*Cww*(diff(s1(x), `$`(x, 2)))+Caa*(diff(s2(x), `$`(x, 2))+(n+1/2)^2*Pi^2*(diff(s2(x), x)));
f1 := -(1/2)*(n+1/2)^2*Pi^2*sqrt(4*C1*C2*C3+C3^2-2*C3+1)+C2*Cww*((D@@1)(s1))(0)-Caa*((D@@1)(s2))(0)+(n+1/2)^2*Pi^2*(C2-(1/2)*C3+1/2);
CN := ((2*(int(exp(-A1*x)*g, x = 0 .. t)-f1))*exp(A1*t)-(2*(int(exp(-A2*x)*g, x = 0 .. t)-f1))*exp(A2*t))/((n+1/2)^3*Pi^3*sqrt(4*C1*C2*C3+C3^2-2*C3+1));
ua := sum(CN*sin((n+1/2)*Pi*z), n = 0 .. 100);
Dear All
I have started exploring Lie Algebra package in Maple 18 and it wonderful experience for me. But as I am in learning stage so I feel little difficulty to understand even its basic enviroment.
I am trying to fing quotient algebra for Normalizer of certain element W1 in Lie algebra and I don't how to do it. I have expected answer for quotient of Normlizer but don't know to obtain it. Please see following details:
with(DifferentialGeometry):with(LieAlgebras):``
L1 := _DG([["LieAlgebra", Alg1, [6]], [[[1, 3, 1], -1], [[1, 6, 2], -1], [[2, 3, 2], -1], [[2, 4, 1], 1], [[2, 5, 2], 1], [[4, 5, 4], -1], [[4, 6, 3], -1], [[4, 6, 5], -2], [[5, 6, 6], -1]]])
DGsetup(L1)
`Lie algebra: Alg1`
Alg1 >
MultiplicationTable("LieTable")
"[[[,`| `,e1,e2,e3,e4,e5,e6],[,-`---`,-`---`,-`---`,-`---`,-`---`,-`---`,-`---`],[e1,`| `,0,0,_DG([["vector",Alg1,[]],[[[1],-1]]]),0,0,_DG([["vector",Alg1,[]],[[[2],-1]]])],[e2,`| `,0,0,_DG([["vector",Alg1,[]],[[[2],-1]]]),_DG([["vector",Alg1,[]],[[[1],1]]]),_DG([["vector",Alg1,[]],[[[2],1]]]),0],[e3,`| `,_DG([["vector",Alg1,[]],[[[1],1]]]),_DG([["vector",Alg1,[]],[[[2],1]]]),0,0,0,0],[e4,`| `,0,_DG([["vector",Alg1,[]],[[[1],-1]]]),0,0,_DG([["vector",Alg1,[]],[[[4],-1]]]),_DG([["vector",Alg1,[]],[[[3],-1],[[5],-2]]])],[e5,`| `,0,_DG([["vector",Alg1,[]],[[[2],-1]]]),0,_DG([["vector",Alg1,[]],[[[4],1]]]),0,_DG([["vector",Alg1,[]],[[[6],-1]]])],[e6,`| `,_DG([["vector",Alg1,[]],[[[2],1]]]),0,0,_DG([["vector",Alg1,[]],[[[3],1],[[5],2]]]),_DG([["vector",Alg1,[]],[[[6],1]]]),0]]]"
Alg1 >
W1 := [a*e3+e5]
[a*_DG([["vector", Alg1, []], [[[3], 1]]])+_DG([["vector", Alg1, []], [[[5], 1]]])]
Alg1 >
Nor[W1] := SubalgebraNormalizer(W1)
[_DG([["vector", Alg1, []], [[[5], 1]]]), _DG([["vector", Alg1, []], [[[3], 1]]])]
How one can find Quotient alegebra "(Nor[W1])/(W1)....???`? ``The expected answer is {e3}.`"
I am trying verify 4th 2-dimensional subalgebra results given in research artcle by Coggeshall and Meyer-ter-Vehn (See pp. 3592 in article).
Download [670]_Normalizer_in_Abstract_Lie_Algebra.mw
I have tried to perform the examples given in the help section for DataSet retrival.  I cannot get Maple 2016 to access the internet available databases.  It does not return any outside of PC resources, like Maple 2015 did, on search items. Is there a setup item that I am missing or is there something amiss in Maple 2016.
This is the Error that I am getting: "Error, (in DataSets:-Search) invalid input: find_count expects its 1st argument, lst, to be of type list(nonnegint), but received [FAIL["total_count"], 0]. "
I was able to run this example in Maple 2105.  The example is the "Average Global Temperature"
Bill Tolrud
Hello everyone, Im now doing my fyp project in cryptography. I need to encrypt a message by using genetic operator, mutation and crossover and decrypt it after that.
For example:
message:=elgamal;
m:=convert(message,bytes);
with(Bits):
for i from 1 to l do
bit[i]:=Split(M[i]);
After that I will use genetic operator to change some bit for each character.
The output I might get will be something like this [1,1,1,1,1,1,1] , after that I need to convert it back to Ascii key value by join function, but sometime it might exceed 127 which out of the range of Ascii key value. Any command can solve this problem or any method can be used which will not affect the original message? Thank you.
I would like to start using maple workbook to manage my projects but i can't figure out the paths. suppose i have a workbook named: WorkBookTest.maple
and inside this i have a folder containing Data in which i have an excel workbook DataTest.xlsx
and also i have a folder containing Documents in which i have a maple worksheet Document.mw
and also i have a folder containing Code in which i have a mathematica notebook Code.nb
Now inside the maple worksheet, to import the excel data i use the command: Import("this:///Data/DataTest.xlsx")
and it works
Now inside the mathematica workbook, to import the excel data i use the command: Import["this:///Data//DataTest.xlsx"]
and it fails
so if i have other program like mathematica notebook inside maple workbook that wants to call a file with data, how should i define the path?
First 201 202 203 204 205 206 207 Last Page 203 of 371
