Dear All
I have downloaded second version of DGApplications to work with abstract Lie algebra. The file is actually .mla file and it is executale(as when we open it, a prompt ask, "do you want to execute this file"), but when I press ok for execution, a file open with command like as
"march('open',"C:\\Users\\Manjit\\Downloads\\DGApplications.mla");",
what should I do after this, is it a some sort installation procedure. I keep all my Maple file in E drive with following path:
E:\Maple work\General Maple Workout
Please guide me in simple way, as I failed to install Maple package many times.
I am currently working on FDM ,i have 2 coupled nonlinear pde ,i need help in solving these equation using maple code.
> restart:
> alias(f=f(tau,eta), theta=theta(tau,eta));
> PDE1:=S*diff(f,tau,eta)=eta^2*diff(f,eta)^2+(6*eta^2-2*f*eta)*diff(f,eta)+(6*eta^3-f*eta)*diff(f,eta,eta)-eta^4*diff(f,eta,eta,eta);
> PDE2:=eta^4*diff(theta,eta,eta)+2*eta^3*diff(theta,eta)-Pr*(f*eta^2*diff(theta,eta)+S*diff(theta,tau))=0;
i need this equation solve by maple
eql := alap*[(la(a)^4+6*la(a)+1+alap*(la(a)^4-1)/difl1)*la(a)*j(a)-((la(a)^2+1)*(1+2/difl)+la(a)^2-1)*intdj/a^4+[(4*(la(a)^4-1))/difl-8*la(a)^2]*intdj/a^2]-(4*(la(a)^2+1))*intdj/a^4+(4*(la(a)^4-1))*intdj1/a^2 = 0;
Hello all,
I have a hash structure with arrays in a YAML file that I would like to read in Maple.
Does there exist a module, so I can read it?
I'm trying to implement the QR algorithm to find the Eigenvalues of the input matrix which will be forwarded to another implementation (of the SVD alg.) to find the singular values. My implementation goes as follows:
1. feeding input: A::Matrix(datatype=float) # a bidiagonal matrix
2. construct input matrix for the QR alg. of matrix A and Z (zeros of size A): C := Matrix([[Z,Transpose(A)],[A,Z]], datatype=float); # therefore C should be symmetric
3. find the eigenvalues of matrix C with an implementation of the QR alg.:
for k from 1 to 400 do
Q, R := QRDecomposition(C);
C:=R.Q;
At this point, the eigenvalues of C should be placed in the diagonal of the matrix, but they're randomly placed around the diagonal, with only ~0 elements (like 2,xxx * 10^(-13)) in the diagonal.
If anyone knows how to resolve this, let the knowledge flow through. Any help will be appriciated, thanks in advance.
Please check why Maple is not returning location of Minima in following case:
-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x)
plot(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = -3.2 .. 3.2)
readlib(extrema):
{-0.6447467154e-1, 0.6447467152e-1}
Minima := op(1, {-0.6447467154e-1, 0.6447467152e-1}); 1; Maxima := op(2, {-0.6447467154e-1, 0.6447467152e-1})
-0.6447467154e-1
0.6447467152e-1
minimize(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = 0 .. 3.5, location)
minimize(-0.6159648936e-1*sin(.9960622471*x)+0.1077739351e-1*sin(1.992124494*x)-0.6872829504e-3*sin(2.988186741*x)+0.3984248988e-4*sin(3.984248988*x), x = 0 .. 3.5, location), {}
Why Maple is not returning location of minima?
Download Location_for_Max_Min.mw
ANALYSIS AND DESIGN OF MACHINE FOUNDATION
Loading Optimization
Loading LinearAlgebra
Loading plots
with(ScientificConstants):
Loading DynamicSystems
with(Units:-Standard)
with(Units:-Natural)
with(StringTools)
FormatTime("%m-%d-%Y, %H:%M")
Introduction
This document deals with vibration analysis and design of machine foundations subjected to dynamic load.
GetConstant(g);
standard_acceleration_of_gravity, symbol = g, value = 9.80665, uncertainty = 0, units = m/s^2
g__SI := evalf(Constant(g, system = SI, units))
9.80665*Units:-Unit(('m')/('s')^2)
Richart and Lysmer's Model
Richart et al. (1970) idealised the foundation as a lumped mass supported on soil which is idealised as frequency independent springs which he described in term of soil parameter
dynamic shear modulus or shear wave velocity of the soil for circular footing when footings having equivalent circular radius. The Tables below shows the different values of spring and damping vlaues as per Richart and Lysmer.
In which, G = dynamic shar modulus of he soil and is given G = `ρ__s`*V__s^2 ; ν = Piosson's ratio of the soil; ρs = mass density of the soil; Vs = shear wave velocity of the soil obtained
from soil testing; g = acceleration due to gravity; m = mass of the machine and foundation; J = mass moment of inertia of the machine and foundation about the appropriate axes; K = equivalent spring stiffness of the soil; C = damping value of the soil; B = interia factor contributing to the damping factor; D = damping ratio of the soil; r = equivalent radius of a circular foundation; L = length of foundation, and B = width of the foundation.
Sketch
nu := .25
Table : Values of soil springs as per Richart and Lysmer (1970) model
SI No.
Direction
Spring value
Equivalent radius
Remarks
Vertical
K__z = 4*G*r__z/(1-nu)"(->)"
r__z = sqrt(L*B/Pi)"(->)"
This is in vertical Z direction
Horizontal
K__x = (32*(1-nu))*G*r__x/(7-8*nu)
r__x = sqrt(L*B/Pi)"(->)"
This induce sliding in horizontal X
2.1
Horizontal
K__y = (32*(1-nu))*G*r__y/(7-8*nu)
r__y = sqrt(L*B/Pi)"(->)"
This induce sliding in horizontal Y
Rocking
`K__φx` = 8*G*`r__φx`^3/(3*(1-nu))"(->)"
`r__φx` = (L*B^3/(3*Pi))^(1/4)"(->)"
This produces roxking about Y axis
3.1
Rocking
`K__φy` = 8*G*`r__φy`^3/(3*(1-nu))"(->)"
`r__φy` = (L^3*B/(3*Pi))^(1/4)"(->)"
This produces roxking about X axis
4
Twisting
`K__ψ` = 16*G*`r__ψ`^3*(1/3)"(->)"
`r__ψ` = ((B^3*L+B*L^3)/(6*Pi))^(1/4)
This produces twisting about vertical Z axis
Table : Values of soil damping as per Richart and Lysmer (1970) model
SI No.
Direction
Mass ratio (B)
Damping ratio and Damping values
Remarks
Vertical
B__z = .25*m__U*(1-nu)*g__SI/(`ρ__s`*r__z^3)
`ζ__z` = .425/sqrt(B__z)"(->)"C__z = 2*`ζ__z`*sqrt(K__z*m__U)"(->)"
This damping value is in vertical Z direction
Horizontal
B__x = (7-8*nu)*m__U*g__SI/((32*(1-nu))*`ρ__s`*r__x^3)
`ζ__x` = .288/sqrt(B__x)"(->)"
C__x = 2*`ζ__x`*sqrt(K__x*m__U)"(->)"
This damping value is in lateral X direction
2.1
Horizontal
B__y = (7-8*nu)*m__U*g__SI/((32*(1-nu))*`ρ__s`*r__y^3)
`ζ__y` = .288/sqrt(B__y)"(->)"
`ζ__y` = .288/((2.145204688-2.451662500*nu)*m__U*Units:-Unit(('m')/('s')^2)/((1-nu)*`ρ__s`*(L*B/Pi)^(3/2)))^(1/2)
(5.1)
NULLError, invalid left hand side in assignmentError, invalid left hand side in assignment
`ζ__ψ` = .5/(1+117.6798000*`J__ψ`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`ρ__s`*((B^3*L+B*L^3)/Pi)^(5/4)))
(5.2)
C__y = 2*`ζ__y`*sqrt(K__y*m__U)"(->)"
This damping value is in lateral Y direction
Rocking
`B__φx` = (.375*(1-nu))*`J__φx`*g__SI/(`ρ__s`*`r__φx`^5)
`ζ__φx` = .15/((1+`B__φx`)*sqrt(`B__φx`))
`ζ__φx` = .15/((1+11.03248125*(1-nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))^(1/2))
(5.3)
Error, invalid left hand side in assignmentError, invalid left hand side in assignmentNULLError, invalid left hand side in assignment
.15/((1+11.03248125*(1-nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))^(1/2)) = .15/((1+11.03248125*(1-nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))*((11.03248125-11.03248125*nu)*`J__φx`*Units:-Unit(('m')/('s')^2)*3^(1/4)/(`ρ__s`*(L*B^3/Pi)^(5/4)))^(1/2))
(5.4)
`C__φx` = 2*`ζ__φx`*sqrt(`K__φx`*`J__φx`)"(->)"
This damping value is for rocking about Y direction
3.1
Rocking
`B__φy` = (.375*(1-nu))*`J__φy`*g__SI/(`ρ__s`*`r__φy`^5)
`ζ__φy` = .15/((1+`B__φy`)*sqrt(`B__φy`))
.15/((1+`B__φy`)*`B__φy`^(1/2)) = .15/((1+`B__φy`)*`B__φy`^(1/2))
(5.5)
`C__φy` = 2*`ζ__φy`*sqrt(`K__φy`*`J__φy`)"(->)"
This damping value is for rocking about X direction
4
Twisting
`B__ψ` = `J__ψ`*g__SI/(`ρ__s`*`r__ψ`^5)"(->)"
`ζ__ψ` = .5/(1+2*`B__ψ`)"(->)"NULLError, invalid left hand side in assignmentError, invalid left hand side in assignmentNULLError, invalid left hand side in assignmentNULLError, invalid left hand side in assignment
.5/(1+117.6798000*`J__ψ`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`ρ__s`*((B^3*L+B*L^3)/Pi)^(5/4))) = .5/(1+117.6798000*`J__ψ`*Units:-Unit(('m')/('s')^2)*6^(1/4)/(`ρ__s`*((B^3*L+B*L^3)/Pi)^(5/4)))
(5.6)
`C__ψ` = 2*`ζ__ψ`*sqrt(`K__ψ`*`J__ψ`)"(->)"NULL
This damping value is valid for twisting about vertical Z axis
NULLNULL
Vertical Motion Considering damping of the Soil
For vertical direction the equation becomes that of a lumped mass having single degree of freedom when
deq := m__U*(diff(z(t), t, t))+'C__z'*(diff(z(t), t))+'K__z'*`#mi("z")` = P__0*sin(`ω__m`*t)
m__U*(diff(diff(z(t), t), t))+C__z*(diff(z(t), t))+K__z*`#mi("z")` = P__0*sin(`ω__m`*t)
(6.1)
t1 := subs(P__0*sin(`ω__m`*t)/m__U = F, expand(deq/m__U));
diff(diff(z(t), t), t)+1.085721853*(G*(L*B/Pi)^(1/2)*m__U/(1-nu))^(1/2)*(diff(z(t), t))/(m__U*(m__U*Units:-Unit(('m')/('s')^2)/(`ρ__s`*(L*B/Pi)^(3/2))-m__U*Units:-Unit(('m')/('s')^2)*nu/(`ρ__s`*(L*B/Pi)^(3/2)))^(1/2))+4*G*(L*B/Pi)^(1/2)*`#mi("z")`/(m__U*(1-nu)) = F
(6.2)
By algebraically manipulating the expression, the form traditionally used by engineers is derived:
t2 := algsubs('C__z'/m__U = 2*zeta*omega, t1)
diff(diff(z(t), t), t)-(-1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))*nu+1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))+4.*G*(L*B/Pi)^(1/2)*`#mi("z")`*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`ρ__s`*(L*B/Pi)^(3/2)))^(1/2))/((nu-1.)*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`ρ__s`*(L*B/Pi)^(3/2)))^(1/2)*m__U) = F
(6.4)
t3 := algsubs('K__z'/m__U = omega^2, t2)
(6.5)
This form includes the damping ratio , the natural frequency , and the external forcing term .  Consider only free vibration by setting
gen3 := subs(F = 0, t3)
diff(diff(z(t), t), t)-(-1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))*nu+1.085721853*(-G*(L*B/Pi)^(1/2)*m__U/(nu-1))^(1/2)*(diff(z(t), t))+4.*G*(L*B/Pi)^(1/2)*`#mi("z")`*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`ρ__s`*(L*B/Pi)^(3/2)))^(1/2))/((nu-1.)*(-Units:-Unit(('m')/('s')^2)*(nu-1)*m__U/(`ρ__s`*(L*B/Pi)^(3/2)))^(1/2)*m__U) = 0
(6.6)
sol1 := dsolve({gen3, z(0) = P, (D(z))(0) = V}, z(t))
z(t) = -(1000000000/1178791942081753609)*Pi*m__U*exp(-(1085721853/1000000000)*Units:-Unit(('s')/('m')^(1/2))*t/(Pi*((nu-1)^2/(`ρ__s`*L^2*B^2*G))^(1/2)*m__U))*(1085721853*V*Units:-Unit(('s')/('m')^(1/2))*((nu-1)^2/(`ρ__s`*L^2*B^2*G))^(1/2)*`ρ__s`*L^2*B^2-4000000000*(L*B/Pi)^(1/2)*Pi*nu*`#mi("z")`+4000000000*`#mi("z")`*Pi*(L*B/Pi)^(1/2))/(Units:-Unit(('s')/('m')^(1/2))^2*B^2*L^2*`ρ__s`)+(4000000000/1085721853)*`#mi("z")`*G*Pi*(L*B/Pi)^(1/2)*((nu-1)^2/(`ρ__s`*L^2*B^2*G))^(1/2)*t/((nu-1)*Units:-Unit(('s')/('m')^(1/2)))+(1/1178791942081753609)*(1085721853000000000*V*Units:-Unit(('s')/('m')^(1/2))*Pi*((nu-1)^2/(`ρ__s`*L^2*B^2*G))^(1/2)*m__U*`ρ__s`*L^2*B^2+1178791942081753609*Units:-Unit(('s')/('m')^(1/2))^2*P*`ρ__s`*L^2*B^2-4000000000000000000*(L*B/Pi)^(1/2)*Pi^2*m__U*nu*`#mi("z")`+4000000000000000000*`#mi("z")`*Pi^2*(L*B/Pi)^(1/2)*m__U)/(B^2*L^2*`ρ__s`*Units:-Unit(('s')/('m')^(1/2))^2)
(6.7)
Download Analysis_and_Design_of_Machine_Foundations_1.mw
Good Morning Mapleprime Community,
Would anybody please help in the attached worksheet. I'm trying to use the new function in Maple that is the clicable method, but I was having problem in some of my output such as zeta_y and zeta_phi as this two equations are generating an error message.
Moses
I would like to add threads to this code that compiles cleanly:
RECTmatrixSEQ :=  (FD,m, n, xw, yw, tr, k, rho, dmax) ->
   [seq
     (seq
        # A return of 0 means there is no choice - no digit possible
        # result of a 4 means there is a choice of (-1 or 0)
        (add(RECTpred(m, n, i, j, iter1, k, rho)*(2*abs(iter1)+1), iter1 = -dmax .. dmax)
        + (2*dmax+1)*(RECTpredR(m, n, i, j, dmax, k, rho)+
        RECTpredL(m, n, i, j, -dmax, k, rho))+
        .5*RECTpredOR(m, n, i, j, dmax, k, rho)+
        .5*RECTpredOL(m, n, i, j, -dmax, k, rho),
      i = -ceil(2*dmax+2*rho)*2^m .. ceil(2*dmax+2*rho)*2^m-1),
    j = 0 .. 2^(n-yw)-1)]:
I've added thead calls like this, still no syntax errors:
   CodeTools:-Usage( Threads:-Wait(
   [seq (Threads:-Create
     (seq
        + (2*dmax+1)*(RECTpredR(m, n, i, j, dmax, k, rho) +
    j = 0 .. 2^(n-yw)-1)) ] )
I do get a runtime error:
                 "PROC:feasibilitycheckproONCE
Error, (in CodeTools:-Usage) invalid input: too many and/or wrong type of arguments passed to Threads:-Create; first unused argument is j = 0 .. 3
Any help spotting this problem would be appreciated. Thanks in advance.
Bonnie
The following code is part of my attempt to answer the recent Question about the bifurcation of the map f:= x-> exp(x^2*(a-x)). Two very weird things are happening. They can be seen by applying trace to f. The first is that the input argument to f seems to be changed to a very large integer. The second is that for some real values of a and x, I get imaginary results from this obviously real-valued function. Why are these things happening?
f:= x-> exp(x^2*(a-x)):
trace(f):
Iterate:= proc(a, x0:= 1., n:= 2000)
local A:= hfarray(1..n, [x0]), f:= subs(:-a= a, eval(:-f));
     #evalhf(
          proc(f, A, n)
          local k;
               for k from 2 to n do A[k]:= f(A[k-1]) end do
          (f, A, n);
     evalf[4]~(convert(A[1000..], set))
Iterate(1.05);
{--> enter f, args = 4607182418800017408
HFloat(1.0512710963760241)
<-- exit f (now in unknown) = 4607413323290551347}
{--> enter f, args = 4607413323290551347
HFloat(0.9985962074909431)
<-- exit f (now in unknown) = 4607169774561176020}
{--> enter f, args = 4607169774561176020
HFloat(1.0525960836530153)
Warning,  computation interrupted
Iterate(.75);
.754589752755861+.192678397202388*I
<-- exit f (now in unknown) = HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I}
Error, (in unknown) unable to store 'HFloat(0.7545897527558614)+HFloat(0.19267839720238844)*I' when datatype=float[8]
Download bifurcation.mw
hi.i am a problem for solving this non linear algebric equation.
please help me...thanks
FSOLVE.mw
FSOLVE.mw
I have a complex set of non linear diff eqns in the form :
y1'' = f(y1',y1,y2'',y2',y2,y3'',y3',y3,y4'',....,y6'',y6',y6,u1,u2,u3,u4) ;
y2'' = f(y1'',y1',y1,y2',y2,y3'',y3',y3,y4'',....,y6'',y6',y6,u1,u2,u3,u4)
and so on ... y6''=(...)
As I want to resolve this coupled systeme in matlab using @ODE45... I wanted the equations in the form : y1''=f(y1',y1,y2',y2,....) and so on ... => X'[] = f(X[],U[])
How can I force maple to rearrange a system of coupled eqns with only the variables i want ?
I know this is possible beacause it is a nonlinear state space model but maple do not work with nonlinear state space model... It give me error when I tried to create statespace model with my non linear diff eqns.
Thanks a lot !
Wanting to edit a post of mine, I accidentally clicked the 'More'-button and chose 'Edit' on anothers post. I immediately saw that it was not my post, and did of course not alter it. But it left me somewhat shocked, for it would seem to imply that anyone can edit (and delete, as well, have just investigated that) anyones post(s). That I think is something that really needs to be remedied as soon as possible.
Hey
I have a very simple function and I need to plot it. The plot is however not smooth and there are annoying cuts and steps which don't go away no matter how I set the options. This problem has been puzzling me for a while and I really appreciate any help.
The followings are all the possible options I could find, none seems to work. You can take a look at this file: ploting_problem.mw
I saw yesterday evening (at home) a very elegant answer to my question "Intersection of real intervals" .
Unfortunately I can't retrieve it this morning (I'm in the office)
It was something like  coulitbe('_x' ...) ... but I don't remember it entirely
I think it came from Carl Love or maybe Mac Dude
 Could you please send me it again ?
Howdy all,
I am trying to create a solar system model by defining a force equation then using the sequence function to create a differential equation and then solving those differential equations using the initial conditions (in X,Y,Z coordinates). So far I have the code below.
m[1] = 1.989*10^30; m[2] = 3.301*10^23; m[3] = 4.867*10^24; m[4] = 5.972*10^24+7.346*10^22; m[5] = 6.417*10^23; m[6] = 1.899*10^27; m[7] = 5.685*10^26; m[8] = 8.682*10^25; m[9] = 1.024*10^26; m[10] = 1.471*10^22; m[11] = 9.3*10^20; m[12] = 2.6*10^20; m[13] = 2*10^20; m[14] = 8.67*10^19; m[15] = 3.9*10^19; mass := Matrix(15, 1, [1.989*10^30, 3.301*10^23, 4.867*10^24, 5.972*10^24+7.346*10^22, 6.417*10^23, 1.899*10^27, 5.685*10^26, 8.682*10^25, 1.024*10^26, 1.471*10^22, 9.3*10^20, 2.6*10^20, 2*10^20, 8.67*10^19, 3.9*10^19]); G := 6.67408*10^(-11)
mass := Vector(4, {(1) = ` 15 x 1 `*Matrix, (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
0.6674080000e-10
sqrt(sum(x[i](t)^2, i = 1 .. 3));
(x[1](t)^2+x[2](t)^2+x[3](t)^2)^(1/2)
proc (i, j) options operator, arrow; sqrt(sum((x[i, k](t)-x[j, k](t))^2, k = 1 .. 3)) end proc
((x[1, 1](t)-x[3, 1](t))^2+(x[1, 2](t)-x[3, 2](t))^2+(x[1, 3](t)-x[3, 3](t))^2)^(1/2)
proc (i, j) options operator, arrow; [x[j, 1](t)-x[i, 1](t), x[j, 2](t)-x[i, 2](t), x[j, 3](t)-x[i, 3](t)] end proc
[x[3, 1](t)-x[1, 1](t), x[3, 2](t)-x[1, 2](t), x[3, 3](t)-x[1, 3](t)]
proc (i, j) options operator, arrow; [seq(x[j, k](t)-x[i, k](t), k = 1 .. 3)] end proc
diff(x[0, 1](t), t, t) = force(0)[1]:
initialPositions := Matrix([[0, 0, 0], [-0.210e8, 0.426e8, 0.541e7], [0.106e9, -0.244e8, -0.644e7], [-0.139e9, -0.569e8, 0.316e4], [-0.177e9, -0.155e9, 0.111e7], [-0.802e9, 0.131e9, 0.174e8], [-0.480e9, -0.142e10, 0.438e8], [0.280e10, 0.103e10, -0.324e8], [0.420e10, -0.157e10, -0.645e8], [0.132e10, -0.477e10, 0.127e9], [0.431e9, -0.690e8, -0.816e8], [0.228e9, 0.305e9, -0.368e8], [0.300e9, -0.351e9, 0.217e9], [-0.434e9, -0.841e7, -0.284e8], [-0.115e9, -0.466e9, -0.612e8]])
initialPositions := Vector(4, {(1) = ` 15 x 3 `*Matrix, (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
initialVelocities := Matrix([[0, 0, 0], [-0.462e7, -0.170e7, 0.285e6], [0.666e6, 0.293e7, 0.183e4], [0.936e6, -0.239e7, 83.3], [0.145e7, -0.140e7, -0.650e5], [-0.196e6, -0.106e7, 0.879e4], [0.745e6, -0.271e6, -0.250e5], [-0.208e6, 0.524e6, 0.467e4], [0.161e6, 0.442e6, -0.129e5], [0.463e6, 0.294e5, -0.137e6], [0.193e6, 0.143e7, 0.923e4], [-0.119e7, 0.974e6, 0.116e6], [0.978e6, 0.562e6, -0.470e6], [0.166e6, -0.156e7, -0.131e5], [0.132e7, -0.170e6, 0.395e6]])
initialVelocities := Vector(4, {(1) = ` 15 x 3 `*Matrix, (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
ic1 := seq(seq(x[i, k](0) = initialPositions[i+1, k], k = 1 .. 3), i = 0 .. N-1); ic2 := seq(seq((D(x[i, k]))(0) = initialVelocities[i+1, k], k = 1 .. 3), i = 0 .. N-1); equations := {ic1, ic2, ode}; sol := dsolve(equations, numeric)
Error, (in dsolve/numeric/process_input) invalid specification of initial conditions, got {x[0, 1](0) = 0, x[0, 2](0) = 0, x[0, 3](0) = 0, x[1, 1](0) = -0.210e8, x[1, 2](0) = 0.426e8, x[1, 3](0) = 0.541e7, x[2, 1](0) = 0.106e9, x[2, 2](0) = -0.244e8, x[2, 3](0) = -0.644e7, x[3, 1](0) = -0.139e9, x[3, 2](0) = -0.569e8, x[3, 3](0) = 0.316e4, x[4, 1](0) = -0.177e9, x[4, 2](0) = -0.155e9, x[4, 3](0) = 0.111e7, x[5, 1](0) = -0.802e9, x[5, 2](0) = 0.131e9, x[5, 3](0) = 0.174e8, x[6, 1](0) = -0.480e9, x[6, 2](0) = -0.142e10, x[6, 3](0) = 0.438e8, x[7, 1](0) = 0.280e10, x[7, 2](0) = 0.103e10, x[7, 3](0) = -0.324e8, x[8, 1](0) = 0.420e10, x[8, 2](0) ...
plots[odeplot](sol, [x[1, 1](t), x[1, 2](t), x[1, 3](t)], t = 0 .. 20, numpoints = 1000, axes = normal)
Error, (in plots/odeplot) input is not a valid dsolve/numeric solution
plots[odeplot](sol, [seq(x[1, k](t), k = 1 .. 3)], t = 0 .. 20, numpoints = 1000, axes = normal)
plots[odeplot](sol, [seq([seq(x[i, k](t), k = 1 .. 3)], i = 0 .. N-1)], t = 0 .. 20, numpoints = 1000, axes = normal)
Download ass4.mw
Everything works fine until I try to execute the last line. When I do that I get an error that says "Error, in dsolve/numeric/process_input. invalid specifications of initial conditions.
At this point I am not sure if the problem lies in how I have defined my initial conditions or the way i've defined the force equation but I am open to any suggestions or ideas on where I should go from here.
Thanks in advance!
Nick
First 199 200 201 202 203 204 205 Last Page 201 of 371
