I have a system of 4 nonlinear equations in 4 lambda variables. I cannot obtain a solution using solve():
4_nonlinear_equations.mw
I can sometimes simplify similar systems by rescaling equations to reduce parameters. With only 3 parameters (sigma_v, sigma_d, sigma_d3) in this case, complexity arises from the interactions of the 4 lambdas in the 4 equations. Upon examining the equations (highlighted in yellow), I suspect hidden symmetries. Is it possible to solve the system by rewriting the equations in terms of each other to find an equivalent system? I am exploring if a smarter and simpler reformulation could lead to a solution. Thank you.
I can do that for a cylinder (in green below) but not for a box geometry.
Box_geometry_and_pendulum.msim
i want to factoring the (m+G'/G) in my long equation but i use some trick but still i can't get the exactly system and still G will remain in my system what should i factoring for remove this G(xi) from my system is all about factoring , my system of equation are wrong contain G(xi) How i can remove it by taking a factoring or any other technique,
not parameter is arbitrary except V and sigma''
with(PDEtools)
with(LinearAlgebra)
with(Physics)
with(SolveTools)
undeclare(prime)
_local(gamma)
Warning, A new binding for the name `gamma` has been created. The global instance of this name is still accessible using the :- prefix, :-`gamma`.  See ?protect for details.
declare(Omega(x, t)); declare(U(xi)); declare(u(x, y, z, t)); declare(Q(xi)); declare(V(xi))
Omega(x, t)*`will now be displayed as`*Omega
U(xi)*`will now be displayed as`*U
u(x, y, z, t)*`will now be displayed as`*u
Q(xi)*`will now be displayed as`*Q
V(xi)*`will now be displayed as`*V
ode := (-V*a[2]+a[1])*(diff(diff(U(xi), xi), xi))+U(xi)*(((-gamma+sigma)*k+b)*U(xi)^2-a[1]*k^2+(w*a[2]-alpha)*k-w) = 0
F := sum(e[i]*(m+(diff(G(xi), xi))/G(xi))^i, i = -1 .. 1)
e[-1]/(m+(diff(G(xi), xi))/G(xi))+e[0]+e[1]*(m+(diff(G(xi), xi))/G(xi))
D1 := diff(F, xi)
-e[-1]*((diff(diff(G(xi), xi), xi))/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*((diff(diff(G(xi), xi), xi))/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)
S := diff(G(xi), `$`(xi, 2)) = -(2*m*mu+lambda)*(diff(G(xi), xi))-mu
diff(diff(G(xi), xi), xi) = -(2*m*mu+lambda)*(diff(G(xi), xi))-mu
E1 := subs(S, D1)
-e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)
D2 := diff(E1, xi)
2*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)*((diff(diff(G(xi), xi), xi))/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)/(m+(diff(G(xi), xi))/G(xi))^3-e[-1]*(-(2*m*mu+lambda)*(diff(diff(G(xi), xi), xi))/G(xi)-(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2-2*(diff(G(xi), xi))*(diff(diff(G(xi), xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*(-(2*m*mu+lambda)*(diff(diff(G(xi), xi), xi))/G(xi)-(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2-2*(diff(G(xi), xi))*(diff(diff(G(xi), xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)
E2 := subs(S, D2)
2*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)^2/(m+(diff(G(xi), xi))/G(xi))^3-e[-1]*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)
D3 := diff(E2, xi)
-6*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)^2*((diff(diff(G(xi), xi), xi))/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)/(m+(diff(G(xi), xi))/G(xi))^4+4*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)*(-(2*m*mu+lambda)*(diff(diff(G(xi), xi), xi))/G(xi)-(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2-2*(diff(G(xi), xi))*(diff(diff(G(xi), xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)/(m+(diff(G(xi), xi))/G(xi))^3+2*e[-1]*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)*((diff(diff(G(xi), xi), xi))/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)/(m+(diff(G(xi), xi))/G(xi))^3-e[-1]*((2*m*mu+lambda)^2*(diff(diff(G(xi), xi), xi))/G(xi)+(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+3*(2*m*mu+lambda)*(diff(diff(G(xi), xi), xi))*(diff(G(xi), xi))/G(xi)^2+6*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))^2/G(xi)^3-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(diff(G(xi), xi), xi))/G(xi)^2+6*(diff(G(xi), xi))^2*(diff(diff(G(xi), xi), xi))/G(xi)^3-6*(diff(G(xi), xi))^4/G(xi)^4)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*((2*m*mu+lambda)^2*(diff(diff(G(xi), xi), xi))/G(xi)+(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+3*(2*m*mu+lambda)*(diff(diff(G(xi), xi), xi))*(diff(G(xi), xi))/G(xi)^2+6*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))^2/G(xi)^3-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(diff(G(xi), xi), xi))/G(xi)^2+6*(diff(G(xi), xi))^2*(diff(diff(G(xi), xi), xi))/G(xi)^3-6*(diff(G(xi), xi))^4/G(xi)^4)
E3 := subs(S, D3)
-6*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)^3/(m+(diff(G(xi), xi))/G(xi))^4+6*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)/(m+(diff(G(xi), xi))/G(xi))^3-e[-1]*((2*m*mu+lambda)^2*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)+4*(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+12*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))^2/G(xi)^3-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)^2/G(xi)^2-6*(diff(G(xi), xi))^4/G(xi)^4)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*((2*m*mu+lambda)^2*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)+4*(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+12*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))^2/G(xi)^3-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)^2/G(xi)^2-6*(diff(G(xi), xi))^4/G(xi)^4)
K := U(xi) = F
K1 := diff(U(xi), xi) = E1
K2 := diff(U(xi), `$`(xi, 2)) = E2
K3 := diff(U(xi), `$`(xi, 3)) = E3
L := eval(ode, {K, K1, K2, K3})
(-V*a[2]+a[1])*(2*e[-1]*((-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-(diff(G(xi), xi))^2/G(xi)^2)^2/(m+(diff(G(xi), xi))/G(xi))^3-e[-1]*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3)/(m+(diff(G(xi), xi))/G(xi))^2+e[1]*(-(2*m*mu+lambda)*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)/G(xi)-3*(-(2*m*mu+lambda)*(diff(G(xi), xi))-mu)*(diff(G(xi), xi))/G(xi)^2+2*(diff(G(xi), xi))^3/G(xi)^3))+(e[-1]/(m+(diff(G(xi), xi))/G(xi))+e[0]+e[1]*(m+(diff(G(xi), xi))/G(xi)))*(((-gamma+sigma)*k+b)*(e[-1]/(m+(diff(G(xi), xi))/G(xi))+e[0]+e[1]*(m+(diff(G(xi), xi))/G(xi)))^2-a[1]*k^2+(w*a[2]-alpha)*k-w) = 0
# rewritting rule
RR := isolate(m+diff(G(xi), xi)/(G(xi))=Phi, diff(G(xi), xi)/G(xi));
(diff(G(xi), xi))/G(xi) = Phi-m
# Apply RR and collect wrt Phi
subs(RR, L):
normal(%):
PhiN := collect(numer(lhs(%)), phi):
PhiD := denom(lhs(%%));
Phi^3*G(xi)^4
with(LargeExpressions):
LLE := collect(PhiN, Phi, Veil[phi] ):
LLE / PhiD = 0;
(Phi^6*phi[1]+3*Phi^5*phi[2]-Phi^4*phi[3]-Phi^3*phi[4]-Phi^2*phi[5]+Phi*phi[6]-phi[7])/(Phi^3*G(xi)^4) = 0
(15)
# phi[i] coefficients
phis := [ seq( phi[i] = simplify(Unveil[phi](phi[i]), size), i=1..LastUsed[phi] ) ]:
print~( phis ):
phi[1] = G(xi)^4*e[1]^3*((-gamma+sigma)*k+b)
phi[2] = e[1]^2*G(xi)^4*e[0]*((-gamma+sigma)*k+b)
phi[3] = -3*e[1]*G(xi)^4*(-(1/3)*a[1]*k^2+(-e[-1]*(gamma-sigma)*e[1]+(-gamma+sigma)*e[0]^2+(1/3)*w*a[2]-(1/3)*alpha)*k+b*e[-1]*e[1]+b*e[0]^2-(1/3)*w)
phi[4] = (2*e[1]*(V*a[2]-a[1])*(diff(G(xi), xi))^3+3*e[1]*G(xi)*(2*m*mu+lambda)*(V*a[2]-a[1])*(diff(G(xi), xi))^2+e[1]*(V*a[2]-a[1])*G(xi)*((2*m*mu+lambda)^2*G(xi)+3*mu)*(diff(G(xi), xi))+G(xi)^2*(-(6*e[-1]*((-gamma+sigma)*k+b)*e[1]-a[1]*k^2+k*w*a[2]+((-gamma+sigma)*k+b)*e[0]^2-k*alpha-w)*e[0]*G(xi)+e[1]*mu*(2*m*mu+lambda)*(V*a[2]-a[1])))*G(xi)
phi[5] = -3*e[-1]*G(xi)^4*(-(1/3)*a[1]*k^2+(-e[-1]*(gamma-sigma)*e[1]+(-gamma+sigma)*e[0]^2+(1/3)*w*a[2]-(1/3)*alpha)*k+b*e[-1]*e[1]+b*e[0]^2-(1/3)*w)
phi[6] = 4*((1/2)*(V*a[2]-a[1])*(diff(G(xi), xi))^3+(3/2)*(V*a[2]-a[1])*(m*mu+(1/2)*lambda)*G(xi)*(diff(G(xi), xi))^2+(V*a[2]-a[1])*((m*mu+(1/2)*lambda)^2*G(xi)+(3/4)*mu)*G(xi)*(diff(G(xi), xi))+(1/2)*((3/2)*e[0]*((-gamma+sigma)*k+b)*e[-1]*G(xi)+(V*a[2]-a[1])*(m*mu+(1/2)*lambda)*mu)*G(xi)^2)*e[-1]*G(xi)
phi[7] = 8*e[-1]*((1/4)*(V*a[2]-a[1])*(diff(G(xi), xi))^4+(V*a[2]-a[1])*(m*mu+(1/2)*lambda)*G(xi)*(diff(G(xi), xi))^3+(V*a[2]-a[1])*((m*mu+(1/2)*lambda)^2*G(xi)+(1/2)*mu)*G(xi)*(diff(G(xi), xi))^2+(V*a[2]-a[1])*(m*mu+(1/2)*lambda)*mu*G(xi)^2*(diff(G(xi), xi))+(1/4)*(-(1/2)*((-gamma+sigma)*k+b)*e[-1]^2*G(xi)^2+mu^2*(V*a[2]-a[1]))*G(xi)^2)
(16)
# WATCHOUT: you have 9 coefficients and so its desirable to have the same number of unknowns
unknowns := indets(rhs~(phis), {e[-1],e[0],e[1],'identical'(mu),'identical'(lambda),'identical'(a[1]),'identical'(alpha)});
COEFFS := solve(rhs~(phis), unknowns)
{alpha, lambda, mu, a[1], e[-1], e[0], e[1]}
{alpha = alpha, lambda = lambda, mu = mu, a[1] = a[1], e[-1] = 0, e[0] = 0, e[1] = 0}, {alpha = alpha, lambda = lambda, mu = mu, a[1] = -(gamma*k*e[0]^2-k*sigma*e[0]^2-b*e[0]^2-k*w*a[2]+alpha*k+w)/k^2, e[-1] = 0, e[0] = e[0], e[1] = 0}, {alpha = (1/2)*(-G(xi)^4*gamma*k^3*e[-1]^2+G(xi)^4*k^3*sigma*e[-1]^2-4*G(xi)^2*(diff(G(xi), xi))*V*k^2*m*mu^2*a[2]+4*G(xi)*(diff(G(xi), xi))^3*V*k^2*m*mu*a[2]+G(xi)^4*b*k^2*e[-1]^2+4*G(xi)^2*(diff(G(xi), xi))*k*m*mu^2*w*a[2]-4*G(xi)*(diff(G(xi), xi))^3*k*m*mu*w*a[2]-2*G(xi)^2*V*k^2*mu^2*a[2]+2*G(xi)*(diff(G(xi), xi))^2*V*k^2*mu*a[2]-2*G(xi)*(diff(G(xi), xi))*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*V*k^2*mu*a[2]+2*(diff(G(xi), xi))^4*V*k^2*a[2]+2*(diff(G(xi), xi))^3*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*V*k^2*a[2]-4*G(xi)^2*(diff(G(xi), xi))*m*mu^2*w+2*G(xi)^2*k*mu^2*w*a[2]+4*G(xi)*(diff(G(xi), xi))^3*m*mu*w-2*G(xi)*(diff(G(xi), xi))^2*k*mu*w*a[2]+2*G(xi)*(diff(G(xi), xi))*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*k*mu*w*a[2]-2*(diff(G(xi), xi))^4*k*w*a[2]-2*(diff(G(xi), xi))^3*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*k*w*a[2]-2*G(xi)^2*mu^2*w+2*G(xi)*(diff(G(xi), xi))^2*mu*w-2*G(xi)*(diff(G(xi), xi))*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*mu*w+2*(diff(G(xi), xi))^4*w+2*(diff(G(xi), xi))^3*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*w)/((2*m*mu^2*(diff(G(xi), xi))*G(xi)^2-2*m*mu*(diff(G(xi), xi))^3*G(xi)+mu*(diff(G(xi), xi))*G(xi)*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)-(diff(G(xi), xi))^3*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)+mu^2*G(xi)^2-mu*(diff(G(xi), xi))^2*G(xi)-(diff(G(xi), xi))^4)*k), lambda = RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)/G(xi), mu = mu, a[1] = -(1/2)*(-G(xi)^4*gamma*k*e[-1]^2+G(xi)^4*k*sigma*e[-1]^2-4*G(xi)^2*(diff(G(xi), xi))*V*m*mu^2*a[2]+4*G(xi)*(diff(G(xi), xi))^3*V*m*mu*a[2]+G(xi)^4*b*e[-1]^2-2*G(xi)^2*V*mu^2*a[2]+2*G(xi)*(diff(G(xi), xi))^2*V*mu*a[2]-2*mu*G(xi)*(diff(G(xi), xi))*V*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*a[2]+2*(diff(G(xi), xi))^4*V*a[2]+2*(diff(G(xi), xi))^3*V*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)*a[2])/(2*m*mu^2*(diff(G(xi), xi))*G(xi)^2-2*m*mu*(diff(G(xi), xi))^3*G(xi)+mu*(diff(G(xi), xi))*G(xi)*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)-(diff(G(xi), xi))^3*RootOf(4*m^2*mu^2*(diff(G(xi), xi))*G(xi)^2+2*m*mu^2*G(xi)^2+6*m*mu*(diff(G(xi), xi))^2*G(xi)+3*mu*(diff(G(xi), xi))*G(xi)+2*(diff(G(xi), xi))^3+(4*m*mu*(diff(G(xi), xi))*G(xi)+mu*G(xi)+3*(diff(G(xi), xi))^2)*_Z+(diff(G(xi), xi))*_Z^2)+mu^2*G(xi)^2-mu*(diff(G(xi), xi))^2*G(xi)-(diff(G(xi), xi))^4), e[-1] = e[-1], e[0] = 0, e[1] = 0}
(17)
case1 := COEFFS[2]
(18)
F1 := subs(case1, F)
e[0]
(19)
F2 := subs(case1, ode)
(-a[2]*V-(gamma*k*e[0]^2-k*sigma*e[0]^2-b*e[0]^2-k*w*a[2]+alpha*k+w)/k^2)*(diff(diff(U(xi), xi), xi))+U(xi)*(((-gamma+sigma)*k+b)*U(xi)^2+k*e[0]^2*gamma-k*e[0]^2*sigma-b*e[0]^2-k*w*a[2]+k*alpha+(w*a[2]-alpha)*k) = 0
(20)
W := U(xi) = F1
U(xi) = e[0]
(21)
E := diff(G(xi), xi) = -(-2*m*mu-lambda)*exp(-(2*m*mu+lambda)*xi)*c__1/(2*m*mu+lambda)-mu/(2*m*mu+lambda)
(22)
W1 := subs(E, W)
U(xi) = e[0]
(23)
W2 := subs(case1, W1)
U(xi) = e[0]
(24)
W3 := rhs(U(xi) = e[0])
e[0]
(25)
W4 := convert(W3, trig)
e[0]
(26)
W5 := W4
e[0]
(27)
odetest(W2, F2)
(28)
Download G-factoring.mw
I’m trying to solve a stiff system 1-D PDEs numerically in Maple but I’m getting the following error:
“Error, (in pdsolve/numeric/match_PDEs_BCs) cannot handle systems with multiple PDE describing the time dependence of the same dependent variable, or having no time dependence”
I included a picture of the PDEs and their BCs in the attached maple file. For easy reading, the attached file includes highlighted sections for parameters and variables. You can skip those to PDEs, BCs and ICs sections at the end of the document to reach the error I’m facing.
For reference, I used another software to solve the system and I was able to get the results in few seconds, so I think it is solvable. However, personally I prefer to use Maple so any inputs, insights, workarounds that I could use to handle the system in Maple would be of great help to me. Thank you.
question.mw
Is there any other way to interrupt a MapleFlow (2024.2) evaluation, other then the red circled ! icon?
Sometimes MF gets stuck in an "Evaluating" state and the red circled ! icon doesn´t work.
Thanks very much in advance for any help.
I programmed a sequence a(n). Up to a(42) Maple had no problem to calculate the term, but when calculating a(43), after a while appears the message
`System error, `, "bad id"
What does that mean and what can I do?
Using edit -> Find/Replace (or crtl-f) it is possible to earch for text composed of alpha numeric-characters. Maple finds all occurences in input an output.
For greek letters this works only for 1D Math input. Is there a way to find/search for greek symbols displayed on the GUI in 2D Math input and output like lambda in the below
This is probaby more of a software request and I think it would be useful.
You can obviously open two worksheets of maple and tile them vertically to give the effect of a split screen but then all the icons of each worksheet reduce the visible on screen real estate in which you can work.
It should work similar to how Excel does it when you split cells.  It would work nicely in situations where you have a diagram or picture you are referring to during the creation of your worksheet.
Anyways just a request, I'm sure some people would find that functionality welcome.
In the attached model I have tried (among other things) to simulate a disk pendulum without friction.
The simulation shows bouncing and angular lock.
There are also 3 warnings and an initialization problem that I could not fix.
How can the model be improved?
Disk_pendulum.msim
P.S.:
Rolling without friction worked fine here.
I do not remember if I reported this before or not. Can't find it. Just in case, I am posting this.
If someone find it is duplicate, feel free to delete this. But this is in latest Maple 2024.2. May be this can be fixed in time by Maple 2025 version.
`Standard Worksheet Interface, Maple 2024.2, Windows 10, October 29 2024 Build ID 1872373`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1840 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
libname;
"C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib", "C:\Program Files\Maple 2024\lib"
ode := diff(y(x),x)/y(x)-(3*(4*x^2+y(x)^2+1))/(2*x*(4*x^2+y(x)^2-2-2*x))=0;
(diff(y(x), x))/y(x)-(3/2)*(4*x^2+y(x)^2+1)/(x*(4*x^2+y(x)^2-2-2*x)) = 0
DEtools:-odeadvisor(ode);
[_rational]
dsolve(ode,y(x));
Error, (in dsolve) invalid subscript selector
infolevel[dsolve]:=5;
ode := diff(y(x),x)/y(x)-(3*(4*x^2+y(x)^2+1))/(2*x*(4*x^2+y(x)^2-2-2*x))=0:
dsolve(ode,y(x));
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
Looking for potential symmetries
trying inverse_Riccati
trying an equivalence to an Abel ODE
equivalence obtained to this Abel ODE: diff(y(x),x) = 3/2*(4*x^2+1)/x/(2*x^2-x-1)*y(x)-(x^2+2*x+3)/x/(2*x^2-x-1)^2*y(x)^2+3/8*(2*x+3)/(2*x^2-x-1)^3/x*y(x)^3
trying to solve the Abel ODE ...
The relative invariant s3 is: -1/432*(8*x^4+40*x^3+45*x^2-270*x+135)/x^3/(x-1)^6/(2*x+1)^4
The first absolute invariant s5^3/s3^5 is: 729/16*(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)^3/(2*x+1)^4/(8*x^4+40*x^3+45*x^2-270*x+135)^5
The second absolute invariant s3*s7/s5^2 is: 1/3*(8*x^4+40*x^3+45*x^2-270*x+135)*(10240*x^12+133120*x^11+697600*x^10+1710080*x^9+3358592*x^8-1701568*x^7+6692592*x^6-18182448*x^5+2088072*x^4-7938000*x^3+2525985*x^2+1786050*x+2679075)/(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)^2
...checking Abel class AIL (45)
...checking Abel class AIL (310)
...checking Abel class AIR (36)
...checking Abel class AIL (301)
...checking Abel class AIL (1000)
...checking Abel class AIL (42)
...checking Abel class AIL (185)
...checking Abel class AIA (by Halphen)
...checking Abel class AIL (205)
...checking Abel class AIA (147)
...checking Abel class AIL (581)
...checking Abel class AIL (200)
...checking Abel class AIL (257)
...checking Abel class AIL (400)
...checking Abel class AIA (515)
...checking Abel class AIR (1001)
...checking Abel class AIA (201)
...checking Abel class AIA (815)
... changing x -> 1/x, trying again
The third absolute invariant s5*s7/s3^4 is: 243/16*(10240*x^12+133120*x^11+697600*x^10+1710080*x^9+3358592*x^8-1701568*x^7+6692592*x^6-18182448*x^5+2088072*x^4-7938000*x^3+2525985*x^2+1786050*x+2679075)/(2*x+1)^4*(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)/(8*x^4+40*x^3+45*x^2-270*x+135)^4
 ->             ...checking Abel class D (by Appell)
 -> Step 1: checking for a disqualifying factor on F after evaluating x at a number
Trying x = 2
*** No disqualifying factor on F was found ***
 -> Step 2: calculating resultants to eliminate F and get candidates for C
*** Candidates for C are {4/27} ***
 -> Step 3: looking for a solution F depending on x
*** No solution F of x was found ***
 ->             ...checking Abel class B (by Liouville)
Trying x = 2
*** Candidates for C are {1, 4, 1/4} ***
 ->             ...checking Abel class A (by Abel)
Trying x = 2
*** Candidates for C are {0, -1/4} ***
 ->             ...checking Abel class C (by Abel)
Trying x = 2
*** Candidates for C are {2, -11676447873119/75975070592769, 9/5, 15632211369872/75439744512117, 46273613050865/52325357771027, 75312059745574/25138886548531} ***
_____________________________
C = 9/5 leads to a useless solution (F does not depend on x)
 ->             ...checking Abel class AIL 1.6
Trying x = 2
*** Candidates for C are {-4, 16} ***
 ->             ...checking Abel class AIL 1.8
Trying x = 2
*** Candidates for C are {0, -116457391291688/45108305127449, -96869842492381/35485755507516, -36964550865207/94238117721032, -32286830321303/11596568583712, 32286830321303/11596568583712, 36964550865207/94238117721032, 96869842492381/35485755507516, 116457391291688/45108305127449} ***
 ->             ...checking Abel class AIL 1.9
Trying x = 2
*** Candidates for C are {-2/9, -1/9} ***
 ->             ...checking Abel class AIA 1.51
Trying x = 2
*** Candidates for C are {0, -94917840318055/84247876515289, -85939756880989/51399391393709, -82210125508529/36853933366676, -74381886667083/82545981233858, -41168492684238/33804146399567, -15658703496425/19275443365317, -9175348901453/101481647952193, 3/4, 15/4, 5568553686203/113599855351490, 12774469621703/63437040534358, 17836021821409/102823494563886, 39657708622139/74009717243016, 82495450887526/27663991325651, 86656182727564/45157560524183, 90074893410229/54954593917906, 100200889070747/32282555481919, 113612565327585/103754255779069} ***
C = 15/4 leads to a useless solution (F does not depend on x)
Trying x = 2
*** Candidates for C are {-1, 1, -113553630998996/78694251194667, -112790344818825/35834119404842, -104905620984375/18860524785743, -95409943222181/78810323073434, -77648002983645/31218435062578, -67259194033608/9576982470445, -46892223838816/86694928762723, -45901561561111/29768419326991, -34674701564566/6522678435631, 26154715634141/21099761863911, 42841215778132/81925179545457, 52638927823233/15127919203723, 54069389554571/5444364811188, 54445812264368/10328928623117, 56815569067370/40738034746481, 75614540760757/62881656939350, 76459718737483/64786816765621, 85896394925571/88677987470966, 90623073438172/24246571690325, 103628692054633/17857341616628, 117754725919014/60191028908095} ***
C = -1 leads to a useless solution (F does not depend on x)
C = -113553630998996/78694251194667 leads to a useless solution (F does not depend on x)
C = -112790344818825/35834119404842 leads to a useless solution (F does not depend on x)
C = -104905620984375/18860524785743 leads to a useless solution (F does not depend on x)
C = -95409943222181/78810323073434 leads to a useless solution (F does not depend on x)
C = -77648002983645/31218435062578 leads to a useless solution (F does not depend on x)
C = -67259194033608/9576982470445 leads to a useless solution (F does not depend on x)
C = -46892223838816/86694928762723 leads to a useless solution (F does not depend on x)
C = -45901561561111/29768419326991 leads to a useless solution (F does not depend on x)
C = -34674701564566/6522678435631 leads to a useless solution (F does not depend on x)
C = 26154715634141/21099761863911 leads to a useless solution (F does not depend on x)
C = 42841215778132/81925179545457 leads to a useless solution (F does not depend on x)
C = 52638927823233/15127919203723 leads to a useless solution (F does not depend on x)
C = 54069389554571/5444364811188 leads to a useless solution (F does not depend on x)
C = 54445812264368/10328928623117 leads to a useless solution (F does not depend on x)
C = 56815569067370/40738034746481 leads to a useless solution (F does not depend on x)
C = 75614540760757/62881656939350 leads to a useless solution (F does not depend on x)
C = 76459718737483/64786816765621 leads to a useless solution (F does not depend on x)
C = 85896394925571/88677987470966 leads to a useless solution (F does not depend on x)
C = 90623073438172/24246571690325 leads to a useless solution (F does not depend on x)
C = 103628692054633/17857341616628 leads to a useless solution (F does not depend on x)
C = 117754725919014/60191028908095 leads to a useless solution (F does not depend on x)
 ->             ...checking Abel class AIA 1.52
Trying x = 2
*** Candidates for C are {-5, -4, -3, 0, 1, 2, -3/2} ***
 ->             ...checking Abel class AIA 1.53
Trying x = 2
*** Candidates for C are {-3, -1, 1, 2, -3/2, -2/3, -1/2} ***
C = -3 leads to a useless solution (F does not depend on x)
C = -3/2 leads to a useless solution (F does not depend on x)
trying to map the Abel into a solvable 2nd order ODE
...checking Abel class AIA 2-parameter, reducible to Riccati
dsolve(ode,y(x));
tracelast;
Download dsolve_invalid_subscript_dec_27_2024.mw
I did a lot  of time but this time i don't know why not run any one have idea?
with(PDEtools)
with(LinearAlgebra)
with(Physics)
with(SolveTools)
undeclare(prime)
declare(u(x, t)); declare(U(xi)); declare(G(xi))
u(x, t)*`will now be displayed as`*u
G(xi)*`will now be displayed as`*G
T := xi = -V*t+x; T1 := u(x, t) = U(-V*t+x)*exp(I*(-k*x+t*w+theta))
xi = -V*t+x
P3 := diff(u(x, t), x, t)
P33 := diff(u(x, t), x)
diff(u(x, t), x)
P333 := diff(P33, t)
Download why.mw
I am trying to see if I can get speed up by using dsolve inside thread.
I made very simple example of global list of two differential equations to start with.
Next, created two threads where each picks one ode from the global list to process. So they should in theory run in parallel. The list of ode's is a global list in the worksheet for now.
But I keep getting error when calling dsolve
               Error, (in dsolve) type `System` does not exist
I tried also passing the actual ode to the thread, still, same error.
Next, I did not pass anything, but called dsolve directly from inside thread proc on same ode. The ode is local variable inside the proc. I still get same error.
                        Does this mean dsolve is not supported by threads?
But when I searched this subject, AI says it works in threads:
Everything works OK when I run dsolve in worksheet outside thread (i.e. normally).
I will show below worksheet showing these cases. I must not be doing something right. But what? Can one not pass data from global worksheet to the thread this way? Or does one needs to load something in each thread to make this work?
Physics:-Version();
libname;
Example 1. Passing index of list to thread
g_list:=[sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0,
         diff(y(x),x)=lambda*sin(lambda*x)*y(x)^2+a*cos(lambda*x)^n*y(x)-a*cos(lambda*x)^(n-1)]:
work_func:=proc(i::posint)
  :-dsolve(g_list[i]):
Threads:-Wait(  seq( Threads:-Create( work_func(i)), i=1..2) );
Example 2. Passing actual ode itself to thread
work_func:=proc(ode::`=`)
  :-dsolve(ode):
Threads:-Wait(  seq( Threads:-Create( work_func(g_list[i])), i=1..2) );
Example 3. Normal processing. No threads
  :-dsolve(ode):
for item in g_list do
    work_func(item);
#no error
Example 4. do not pass anything. Just call dsolve
  local x,t;
  local ode:=sin(t)*diff(x(t),t$2)+cos(t)*diff(x(t),t)+2*x(t)=0;
  :-dsolve(ode):
Download error_dsolve_using_threads_dec_26_2024.mw
Here are the graphs of a parabola and a straight line:
plots:-display(
        plot(x^2, x=-1..1),
        plot((x+1)/2, x=-1..1),
color=["Red","Green"]);
Suppose I want to plot the part of the parabola that lies below
the straight line, and suppose, just to be nasty, I choose to do it
with implicitplot:
plots:-implicitplot(y=x^2, x=-1..1, y=0..(x+1)/2);
That is not a parabola at all.  [And where does the "ynew" label come from?]
This behavior was introduced in Maple 2022.
In Maple 2021 we get the expected result:
Download mw.mw
I cannot find any examples of how to raise the software memory limits to maximum with the mentioned  -T switch in the manual to avoid memory allocation error popup.
Neither are there any examples posted on the web.
It cannot be a hardware allocation error, as the system memory is large.
So how is the -T switch implimented
I'm quite new to Maple Flow and I really like it. However, since the 2024.2 update, Flow sometimes does not let me save a worksheet. Just nothing happens when I click Save or Save As or press Ctrl+S. Same thing when I click "Yes" in the dialogue (which asks me if I want to save the changes) after I close the worksheet.
As a workaround in these cases, I copy the whole content of the worksheet, close Flow altogether and open a new worksheet into which I paste the previously copied contents. Am I the only one experiencing this behaviour? Am I doing something wrong?
First 19 20 21 22 23 24 25 Last Page 21 of 371
