2024-12-20_Q_simplification_Question.mw
Solve the general cubic. Apply values and simplify.
Could someone show how Maple simplifies to the value of X=3? I tried doing it manually and I could not figure it out.
Also is there a Help assistant to see the setps?
X^3+a*X=b
X^3+X*a = b
sol:=solve(X^3+a*X=b,[X])
[[X = (1/6)*(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)-2*a/(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)], [X = -(1/12)*(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)+a/(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/6)*(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)+2*a/(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3))], [X = -(1/12)*(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)+a/(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/6)*(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3)+2*a/(108*b+12*(12*a^3+81*b^2)^(1/2))^(1/3))]]
vals:=[a=6,b=45]
[a = 6, b = 45]
Nans:=(map(eval,sol,vals))
[[X = (1/6)*(4860+12*166617^(1/2))^(1/3)-12/(4860+12*166617^(1/2))^(1/3)], [X = -(1/12)*(4860+12*166617^(1/2))^(1/3)+6/(4860+12*166617^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/6)*(4860+12*166617^(1/2))^(1/3)+12/(4860+12*166617^(1/2))^(1/3))], [X = -(1/12)*(4860+12*166617^(1/2))^(1/3)+6/(4860+12*166617^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/6)*(4860+12*166617^(1/2))^(1/3)+12/(4860+12*166617^(1/2))^(1/3))]]
simplify(Nans)
[[X = 3], [X = (1/4)*(I*3^(1/2)*(180+44*17^(1/2))^(2/3)+(8*I)*3^(1/2)-(180+44*17^(1/2))^(2/3)+8)/(180+44*17^(1/2))^(1/3)], [X = -3/2-((1/2)*I)*51^(1/2)]]
Download 2024-12-20_Q_simplification_Question.mw
This text is typed directly into the browser. I can now change the font size to something bigger. I can also change the font from Default to something else.
This text in Calibri 11 was pasted from Word. What do I have to do to change it to MaplePrimes default font (which I have used above)? Selecting default from
does not work because default is already selected when I put the cursor into the pasted text.
What is the default font type by the way? Can I change it permanetly?
All on Windows 10 and with Firefox.
If possible, please help me write the steps to solve the following equation.
By setting the coefficients of the same power (Yi) on both sides of equation equal, we solution get
This is my first time working with plotting data from a matrix. However, with the help of a friends on MaplePrimes, I learned how to plot the data in both Maple and MATLAB. Despite this, I am having trouble with visualization. When I change the delta value, my function experiences vibrations or noise, which is clearly visible in the plot. But when I change delta, I encounter errors with my matrix data. How can I fix this problem? and there is any way for get better visualization by Explore ? also How show this vibration or noise in 2D?
randomize():
local gamma;
gamma
currentdir(kernelopts(':-homedir'))
T3 := (B[1]*(tanh(2*n^2*(delta^2-w)*k*t/((k*n-1)*(k*n+1))+x)-1))^(1/(2*n))*exp(I*(-k*x+w*t+delta*W(t)-delta^2*t))
(B[1]*(tanh(2*n^2*(delta^2-w)*k*t/((k*n-1)*(k*n+1))+x)-1))^((1/2)/n)*exp(I*(-k*x+w*t+delta*W(t)-delta^2*t))
params := {B[1]=1,n=2,delta=1,w=1,k=3 };
{delta = 1, k = 3, n = 2, w = 1, B[1] = 1}
insert numerical values
solnum :=subs(params, T3);
(tanh(x)-1)^(1/4)*exp(I*(-3*x+W(t)))
CodeGeneration['Matlab']('(tanh(x)-1)^(1/4)*exp(I*(-3*x+W(t)))')
Warning, the function names {W} are not recognized in the target language
cg = ((tanh(x) - 0.1e1) ^ (0.1e1 / 0.4e1)) * exp(i * (-0.3e1 * x + W(t)));
N := 100:
use Finance in:
  Wiener := WienerProcess():
  P := PathPlot(Wiener(t), t = 0..10, timesteps = N, replications = 1):
end use:
W__points := plottools:-getdata(P)[1, -1]:
t_grid := convert(W__points[..,1], list):
x_grid := [seq(-2..2, 4/N)]:
T, X := map(mul, [selectremove(has, [op(expand(solnum))], t)])[]:
ST := unapply(eval(T, W(t)=w), w)~(W__points[.., 2]):
SX := evalf(unapply(X, x)~(x_grid)):
STX := Matrix(N$2, (it, ix) -> ST[it]*SX[ix]);
_rtable[36893490640185799852]
opts := axis[1]=[tickmarks=[seq(k=nprintf("%1.1f", t_grid[k]), k=1..N, 40)]],
        axis[2]=[tickmarks=[seq(k=nprintf("%1.1f", x_grid[k]), k=1..N, 40)]],
        style=surface:
DocumentTools:-Tabulate(
    plots:-matrixplot(Re~(STX), opts),
    plots:-matrixplot(Im~(STX), opts),
plots:-matrixplot(abs~(STX), opts)
  , width=60
"Tabulate"
MatlabFile := cat(currentdir(), "/ST2.txt"); ExportMatrix(MatlabFile, STX, target = MATLAB, format = rectangular, mode = ascii, format = entries)
421796
Download data-analysis.mw
After download MapleFlow 2024.2 "fsolve" return only one solution for a polynom of n-order.
Can I unchain by an hidden order?
is(abs(x)=max(x,-x)) assuming real;
#  FAIL
I wonder if this will work in newer versions of Maple?
It's becoming increasingly common for questions to be deleted, the most frequently evoked argument being that they duplicate earlier questions.
Usually it's the author of the question who complains, in this case it's the one who provided an answer.
I've always found this self-given freedom on the part of moderators somewhat inappropriate, especially given that these deletions are done on the sly, without even the courage to be explicitly claimed by their authors.
Couldn't these latter take the time to leave a message indicating what they've just done (and why) and where the deleted question, and any exchanges associated with it, can be found?
Otherwise, this attitude is more akin to contempt and censorship than to real management of this blog.
A few years ago, when I came to this site, these deletions were the exception and I can only deplore the fact that they have become commonplace.
They say that life is better elsewhere, I don't know, but what I do know is that I've never come across this on any Scilab, R, SageMath or OpenTurns user's blog.
Anyway, here's the reply I sent to @salim-barzani :  Hirota_derivative_KdV_equation.mw
Is it possible to configure newer maple versions to use a different file extension ?
I have a lot of  Maple 9 files  with .mw extension. I dont want them opened and saved by a later version as they are valuable and actually work better than later maple versions which throws unneccesary signum errors. The results are verified so the signum errors are bogus in the recent maple versions running the same file.
Particularly, can I configure e.g. Maple 2022 to save to a different file extension say .mww or similar rather than .mw so I can avoid destroying to original 9.5 files?
What systematic methods can be used to determine the optimal parameters in a long equation involving two independent variables, and how do techniques like separation of variables, balancing principles, or dimensional analysis aid in simplifying and solving such equations?
parameters_x_t.mw
Some of the calculations mentioned here can be done in alternative programming languages, such as Python, C, and so on. However, I would like to reproduce exactly these graphs using Maple (without the need for programming commands, such as "if", "while", among others).
In the work I am trying to reproduce, we have "The evaluation of the influence of the inclusion of the broadband behavior of grounding systems in EMT-type programs in the evaluation of transients resulting from direct lightning strikes on transmission lines. The behavior of the grounding frequency is determined using an accurate electromagnetic model and included in the EMTP/ATP by means of an equivalent circuit derived from the Vector Fitting technique. In addition, the impact of the frequency dependence of soil parameters on the lightning performance of transmission lines is addressed." This may seem somewhat disconnected from reality for many, since it is a problem involving electrical engineering optimization.
Could someone help me reproduce these calculations? I have made little significant progress.
If you want to access the reference accounts, I'll send you the PDF
schroeder2017 [link to copyrighted material replaced by moderator]
I'm evaulating Maple Flow and wondered if any Mathcad users have transferred to Maple Flow?
What are the pros/cons of Maple Flow? It's different to what I'm used to so I need to spend time learning. But I'm liking what I see so far.
How can I simplify this relation(See uploaded .mw file)?
For example, the second term is simplified as:
deltae*(1-phi0/(kappa-3/2))^(-kappa+1/2)+(1/2)*deltab*(1-sqrt(2)*sqrt(1/(m*ub^2))*sqrt(-phi0));
di1.mw
Where can I found details about Statistics:-Sample(..., method=envelope).
It would be nice to have a link to a description of the envelope method Sample uses.
For instance does it share some features of the Cuba library for numeric integration? Does it use the same envelope method evalf/Int(..., method=_CubaSuave)) uses?
I'm trying to transform a partial differential equation (PDE) into an ordinary differential equation (ODE) as demonstrated in the paper. However, I find some steps confusing and difficult to follow. The process often feels chaotic, and managing the complexity of the equations is overwhelming. Could you suggest an effective and systematic method to handle such transformations more easily?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(Omega(x, t)); declare(U(xi))
Omega(x, t)*`will now be displayed as`*Omega
U(xi)*`will now be displayed as`*U
tr := {t = tau, x = tau*c[0]+xi, Omega(x, t) = U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))}
P1 := diff(Omega(x, t)^m, t)
Omega(x, t)^m*m*(diff(Omega(x, t), t))/Omega(x, t)
L1 := PDEtools:-dchange(tr, P1, [xi, tau, U])
(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*(-((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))*c[0]+I*U(xi)*(-k*c[0]+w+delta*(diff(W(tau), tau))-delta^2)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))/(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))
pde1 := I*(diff(Omega(x, t)^m, t))+alpha*(diff(Omega(x, t)^m, `$`(x, 2)))+I*beta*(diff(abs(Omega(x, t))^(2*n)*Omega(x, t)^m, x))+m*sigma*Omega(x, t)^m*(diff(W(t), t)) = I*gamma*abs(Omega(x, t))^(2*n)*(diff(Omega(x, t)^m, x))+delta*abs(Omega(x, t))^(4*n)*Omega(x, t)^m
I*Omega(x, t)^m*m*(diff(Omega(x, t), t))/Omega(x, t)+alpha*(Omega(x, t)^m*m^2*(diff(Omega(x, t), x))^2/Omega(x, t)^2+Omega(x, t)^m*m*(diff(diff(Omega(x, t), x), x))/Omega(x, t)-Omega(x, t)^m*m*(diff(Omega(x, t), x))^2/Omega(x, t)^2)+I*beta*(2*abs(Omega(x, t))^(2*n)*n*(diff(Omega(x, t), x))*abs(1, Omega(x, t))*Omega(x, t)^m/abs(Omega(x, t))+abs(Omega(x, t))^(2*n)*Omega(x, t)^m*m*(diff(Omega(x, t), x))/Omega(x, t))+m*sigma*Omega(x, t)^m*(diff(W(t), t)) = I*gamma*abs(Omega(x, t))^(2*n)*Omega(x, t)^m*m*(diff(Omega(x, t), x))/Omega(x, t)+delta*abs(Omega(x, t))^(4*n)*Omega(x, t)^m
L1 := PDEtools:-dchange(tr, pde1, [xi, tau, U])
I*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*(-((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))*c[0]+I*U(xi)*(-k*c[0]+w+delta*(diff(W(tau), tau))-delta^2)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))/(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))+alpha*((U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m^2*((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^2/(U(xi)^2*(exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^2)+(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*((diff(diff(U(xi), xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-(2*I)*(diff(U(xi), xi))*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-U(xi)*k^2*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))/(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))-(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^2/(U(xi)^2*(exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^2))+I*beta*(2*(abs(U(xi))*exp(-Im(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^(2*n)*n*((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))*abs(1, U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m/(abs(U(xi))*exp(-Im(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))+(abs(U(xi))*exp(-Im(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^(2*n)*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))/(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))))+m*sigma*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*(diff(W(tau), tau)) = I*gamma*(abs(U(xi))*exp(-Im(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^(2*n)*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m*m*((diff(U(xi), xi))*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau))-I*U(xi)*k*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))/(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))+delta*(abs(U(xi))*exp(-Im(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^(4*n)*(U(xi)*exp(I*(-k*(tau*c[0]+xi)+w*tau+delta*W(tau)-delta^2*tau)))^m
Download transform-pde-to-ode-hard_example.mw
I tried the latest Maple flow upgrade (2024.2) and noticed some strange behavior. When I enter units such as L/min or m/s^2, the program states: "invalid unit(s) Units:-Simple:-*" However, to my surprise, if I start the canvas by stating with(Units) everything works as it should. In the user manual however it is stated that the with() commands do not work within Flow. If someone would be so kind to explain what I am doing wrong.
First 20 21 22 23 24 25 26 Last Page 22 of 371
