I have the following situation:
HB:=Bend(L,a,n);
Bend is a proc, that returns a Record with info based on its parameters. I would like to get access to the name I assign to (i.e. HB) in the proc. Any chance?
Mac Dude
PS: I can of course kludge things by adding an argument to the proc Bend. But I'd like to avoid that.
I'm trying to solve the following differential equation numerically with dsolve:
but dsolve gives me this error:
> res := dsolve(DGL, numeric, parameters = [y0, A, B, C, E]);
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
I think the problem is that I use the wrong solver. Does Maple provide a solver which is capable of solving this kind of equations (nonlinear ODE)?
Thanks in advance!
hello , to solve a differential euqations , maple gave me this error. please help me.
TG.mw
I`m new with the Physics package. I have a Hamiltonian in a lattice written in terms of creation and annihilation operators. The Question is, How can I label a Creation and an Annihiliation operator for each site in the Lattice. WIth this, I can compute mean values and other stuffs associated with the Hamiltonian.
Many thanks in advance
  Excuse me, I tried to substract in a series expansion. It works for Taylor-type expansion, but not Laurent-type ones
ffff:=1/(t-3);
ggg:=taylor(ffff,t=infinity,3);
coeff(ggg,t,-1);
ffff:=exp(t);
ggg:=taylor(ffff,t=0,3);
coeff(ggg,t,1);
Maple gives me
Error, unable to compute coeff
. My question is, why "coeff" does not work in the first case? how to make it work? Though I can copy the expansion part, assign it to another variable, and "coeff" will work
Excuse me,
  I have the following input
fff:=x1^k;
int(fff,x1=0..x2);
I would like to obtain
1/(k+1)* (x2^(k+1)), k<>-1
but maple gives me just the same integral. Is there any way to get the expression?
Thank you!
I am trying to make a plot3d on my Surface Pro  3 running Windows8.1.
The plot looks like a ghost.  Pale grey.  It looked nice and colourful when I executed the same command on an older computer a few hours ago.  (I know it was exactly the same command because I saved the file on my old computer and then opened in on the Surface Pro 3)
Is there a way to fix this?
plot3d(-x^2+y^2-3*x+2*y+100, x = -5 .. 8, y = -5 .. 5, transparency = 0, lightmodel = light1, glossiness = 1, filled = true, style = wireframeopaque, shading = zhue, view = [-5 .. 10, -5 .. 8, 0 .. 150]);
 OOPS!  Now the problem has corrected itself.
I'm getting worried about all the weird things Maple is doing on this Surface Pro 3.  I'm trying to make up a final exam tonight (the exam is tomorrow).
I have downloaded MaplePlayer on my iPad.   I see that it comes with a number of "pre-recorded" programs that it can run.  Is there a way to have it run a Maple worksheet that I have written?   If so, how do I use this app to open an existing worksheet?
Also, are there any plans for this app on the Android platform any time soon?
I have written a program and I would like to embed a check near the beginning to see if input data was entered correctly.  I have written an "if statement" to check on this and I would like the program to stop execution at this point if the "if statement" criteria are met.   I get an error saying that this command is disabled.   I have tried "stop", "end" and "quit," as I understand that they are all the same.
I have a simple transfer function like
I want to calculate the amplitude ratio and the phase shift.
Without maple I would set s=I*omega and solve for real and imaginary part to obtain the phase shift and amplitude ratio.
Is there any possibility to do that in Maple more easily?
When I run a maple program which take a long time (in command line), I have this kind of message every second:
"memory used=43867.3MB, alloc=147.3MB, time=856.28"
Does there exist any way to avoid this display ?
How would one in Maple solve this, which is an inequality equation in some variables, which can be nonlinear, with constraints on range of each variable. I.e. I want to find conditions on the variables to make the inequality satisfied.
In Mathematica, I use the Reduce command
Clear[x, y];
eq = 1/2 - x + x^2 - y + y^2;
Reduce[{eq > 0, 0 < x < 1 && 0 < y < 1}, {x, y}, Reals]
How would one do the same in Maple? I tried solve, but can't give constraints.
eq:=1/2 -x+x^2-y+y^2:
solve(eq>0 , {x1, x2});
So I need to do the same as in the Mathematica command, but in Maple. I do not want numerical solution, but algebraic as shown above.
Using Maple 18.2 on windows.
Hello people in mapleprimes,
I want to ask a question about modification of expression.
Basically, what I want to do is to change the expression of sqrt((-a)^2) to sqrt(a^2).
The expression I want to modify is this:
aa:=phi[n, j] = a[j, D]-a-sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
I want to change this to
phi[n, j] = a[j, D]-a-sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j])
To do this, I wrote as
subs(sqrt((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j]) = sqrt((a[j, D]-a-tau[n, j])^2+4*gamma*f[c, n, j]/L[j]), phi[n, j] = a[j, D]-a-((-a[j, D]+a+tau[n, j])^2+4*gamma*f[c, n, j]/L[j])^(1/2))
Or, I wrote as
subs(op([2,3,2,1,1],aa)=(a[j, D]-a-tau[n, j])^2,aa)
If there is better ways, please tell me them.
Best wishes.
taro
I would be grateful if anyone would comment on the compatibility of Maple 18 and MacOS 10.10 (Yosemite).
First 251 252 253 254 255 256 257 Last Page 253 of 371
