I need your help to plot the phase portrait using DEtools[DEplot]  these are the lines of the code. But when I make RUN, there is an error. I need your help to fix the error. Many thinks.
r1:=1; r2:=1; q2:=2; q1=0.5;  a1:=1;
Sys1 := {diff(N(t),t) = r1*N*(1-N/q1)-P*N/(1+N), diff(P(t),t) = r2*P*(exp(-a1*P)-q2)+P*N/(1+N)};
DEtools[DEplot](Sys1,[N(t),P(t)],t=-10..10,N=0..2,P=0..2);
Many thinks
Hello, Maple wizards.
I have a problem with Tasks for parallel computations. In each task my programm should execute this command:
>B:=SignalProcessing:-DFT(A)
"A" and "B" are Arrays (1..m). "m" is integer. I have 8 tasks. Each task is a loop ("for i from 1 to n do..." n is integer), where my command is executing. "A" and "B" are local for each task. In this case each task should execute my command n times.
So, I obtain this:
"Error, (in SignalProcessing:-Engine:-DFT) attempting to assign to `FwdDFT` which is protected"
What is it? In Maple Help I read that ">SignalProcessing:-DFT" is Thread-Safe Function.
I have a characteristic equation. some times It has polar roots . sometimes It has real roots and sometimes both of them.
I want to extract real roots and extract polar roots if they are.
for instance:
q:=m3*r^3+m2*r^2+m1*r+m0:
rot:=solve(q=0,r);
I want to know how can I use if in this part ?
Can maple solve maximization problem like
q := proc (a, b, c) options operator, arrow; .2*b+.1*c end proc;
print(`output redirected...`); # input placeholder
(a, b, c) -> 0.2 b + 0.1 c
w := proc (a, b, c) options operator, arrow; .7*a+.1*c end proc;
(a, b, c) -> 0.7 ab + 0.1 c
e := proc (a, b, c) options operator, arrow; .7*a+.2*b*c end proc;
(a, b, c) -> 0.7 a + 0.2 b c
with(Optimization)
Maxmize(int(min(100+(.7*a+q)*(1/2), a), q)+int(min(100+(.2*b+w)*(1/2), b), w)+int(min(100+(.1*c+e)*(1/2), c), e)-a-b-c-ab-ac-bc)
Error, (in Optimization:-NLPSolve) cannot convert procedures to piecewise
Thanks alot if you can help me.Urgent! Really appreciate.
Hi there,
I used the following plot command in maple13.
implicitplot(abs(x)+abs(y)=2, x=-2..2, y=-2..2, scaling=constrained)
But the output(square) is not complete at vertices.In fact at the vertex the graph is like a trapezoid.
Any help will be appreciated.
Yegan
> restart;
> with(plots);
> Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-2*(diff(f(eta), eta))^2-M^2*(diff(f(eta), eta)) = 0;
/ d / d / d \\\ / d / d \\
|----- |----- |----- f(eta)||| + f(eta) |----- |----- f(eta)||
\ deta \ deta \ deta /// \ deta \ deta //
/ d \ 2 / d \
- 2 |----- f(eta)| - M |----- f(eta)| = 0
\ deta / \ deta /
> Eq2 := 1+(4/3)*R*(diff(theta(eta), eta, eta))+Pr*(f(eta)*(diff(theta(eta), eta))-(diff(f(eta), eta))*theta(eta)) = 0;
4 / d / d \\
1 + - R |----- |----- theta(eta)||
3 \ deta \ deta //
/ / d \ / d \ \
+ Pr |f(eta) |----- theta(eta)| - |----- f(eta)| theta(eta)| = 0
\ \ deta / \ deta / /
> bcs1 := f(0) = S, (D(f))(0) = 1+L*G, (D(D(f)))(0) = .1, f(6) = 0;
f(0) = S, D(f)(0) = 1 + L G, @@(D, 2)(f)(0) = 0.1, f(6) = 0
> fixedparameter := [S = .1, M = .1];
[S = 0.1, M = 0.1]
> Eq3 := eval(Eq1, fixedparameter);
/ d \ / d \
- 2 |----- f(eta)| - 0.01 |----- f(eta)| = 0
\ deta / \ deta /
> fixedparameter := [R = .1, Pr = .7];
[R = 0.1, Pr = 0.7]
> Eq4 := eval(Eq2, fixedparameter);
/ d / d \\ / d \
1 + 0.1333333333 |----- |----- theta(eta)|| + 0.7 f(eta) |----- theta(eta)|
\ deta \ deta // \ deta /
/ d \
- 0.7 |----- f(eta)| theta(eta) = 0
\ deta /
> bcs2 := theta(0) = 1+T*B, (D(theta))(6) = B, theta(6) = 0;
theta(0) = 1 + T B, D(theta)(6) = B, theta(6) = 0
> T := .1; B := .1;
0.1
0.1
> L := [0., .1, .2, .3];
[0., 0.1, 0.2, 0.3]
> for k to 4 do R := dsolve(eval({Eq3, Eq4, bcs1, bcs2}, L = L[k]), [f(eta), theta(eta)], numeric, output = listprocedure); Y || k := rhs(R[2]); YL || k := rhs(R[3]) end do;
Error, (in dsolve/numeric/bvp/convertsys) too many boundary conditions: expected 6, got 7
> plot([YL || (1 .. 4)], 0 .. 6, 1 .. -.2, labels = [eta, diff(f(eta), eta)]);
Dear all;
I need your help to get all the solution of this nonlinear  system  with four parameters: r1, r2, q1, q2  assumed to be positives. Let the system:
the first equation is: r1*x*(1-x/q1)=x*y/(1+x)
the second equation: r2*y*(exp(-y)-q2)=-x*y/(1+x)
How can get the positive solution ( x, y) of the previous system.
Consider the function
The above definition may result in four cases depening on r and x.
Can Maple calculate automatically all possible cases and the corresponding Maxima, Minima and Values at intervals limits?
I have an ode in the form:
diff(u(x),x)-f(x)=u(x)^3+B(X)*u(x)+g(x)
how to extaract and name the different coefficients of the equation?
Hamada
Having a little trouble getting data from openstreetmap from export here
http://www.openstreetmap.org/export#map=17/43.4763/-80.5459
The system :
I am trying to recreate journal work for validating using another computer program so I am trying to use maple to solve the ODE, based on further research I found using laplace might be the best but I am having some trouble.
eq8:=d*(n(t)+C(t))/drho = -rho(t)/(l*alpha*K_c)
given the initial conditions of:
ICs:= n(0) = n_0, rho(0) = rho_0, C(0) = (beta-rho_0)*n_0/(l*lambda)
therefore:
equation9 := dsolve({equation8, ICs}, {C(t), n(t)}, method = laplace)
Following this process I get the error:
Error, (in dsolve) invalid initial condition
According to the journal work the solution I am looking for is:
C(t)=-n(t)+(rho_0^2+rho(t)^2)/(2*l*alpha*K_c)+((Beta+l*lambda-rho_0)*n_0)/(l*lambda)
is there something that I'm doing wrong or missing?
Any help would be greatly Appreciated!
I want to simulate Inelastic collision
There has 2 ball which I can change  Quality and Radius.
one ball  move to another stirless ball with diferent angle
I need your help .. I solve a system and I get the error Warning, solutions may have been lost.
The maple code is attached.
testerror.mw
hi everyone , i need your point of view in my question,any help would be appreciated in advance .
we have a discrete function named g(t) and a continous function f(t) in in convolution integral just like this :
int(f(t-x)*g(x),x=0..t) ;
we have just g(x) in some special points int the interval (0..t) , thus i need to convert this integral to a series.
how should i do this ? can anyone help or any idea ? i need at first a mathematical solution or idea about how to do this and then, how to do this in a software ?
tnx again.
First 253 254 255 256 257 258 259 Last Page 255 of 371
