Let N be an integer.
For each pair of integers (n,m) where 1<= n,m <= N, we have a variable f_{n,m}(t).
Then for these we have a system of ODEs
d/dt f_{n,m}(t) = \sum_{n', m'} f_m'n' * f_m''n'' * (m'n'' - m''n')
where m''=m-m', n''=n=n', and the sum is simply over for all pairs (n',m').
I simply do not know how to put these set of equations into Maple in a nice way.
I will really appreciate any help!
Need to evaluate above summation in maple. For simplicity infinity can be replaced by some constant say 1000.
The value of parameters used are:
alpha=73.11
beta=76.11
E=4.75
help....
I have been trying to solve 2D Diffusion Equation with zero Neumann BC over the unit disk. If I use Gaussian type function with a sharp peak as initial condition, I get huge errors between initial values. Let's say u(r,phi,t) is the solution of the PDE and f(r,phi) is initial value function. The expectation is for the point (r*,phi*) ,  u(r*,phi*,0)=f(r*,phi*), but it is not.
Is Numerical integration in Maple not able to handle such sharp peak? I tried some of the built-in methods such as MonteCarlo,CubaVegas but no difference.
It might be a good idea to specify some nodes arround the peak. There is a command called "peaks", but I could not use it, error message says "invalid arguments".
Soln_2D_Gaussian.mw
Maple does not cancel out a variable.
Why is that?
Is there a way to solve this?
(I pasted my code on the bottom of this message)
Thanks for your help/advice,
Stephan
M(x):=piecewise(x<=l,1/2*(q*x^2)/(EI)-3/8*(q*l*x)/(EI),l<x,1/2*(q*x^2)/(EI)-13/8*(q*l*x)/(EI)+5/4*(q*l^2)/(EI)):
M(x):=M(x)*(-EI);
# simplify() does not work.....?
M(x):=simplify(%) assuming EI>0;
# Wiht EI cancelled out by hand it schould look like:
M(x):=piecewise(x<=l,1/2*(q*x^2)-3/8*(q*l*x),l<x,1/2*(q*x^2)-13/8*(q*l*x)+5/4*(q*l^2));
Please find my Maple-worksheet attached below.
How do I solve this problem? I can not drawn it.
I would really appriciate if somebody could help me.
I am quite new to Maple and have a problem I've been struggling with all day.
I have a spring pendulum and have to develop the equation of motion in the y-direction. The pendulum consist of a mass at the end of a elastic, unbendable and massless rod.
How do I solve the differential equation 2.9 for y(t)? As far as I can see the problem is that I have to differentiate y(t), which is not designated as a function, with respect to y (?)
Thank you in advance!
I am new to Maple and have a problem I've been struggling with all day.
I have a pendulum and need to find a equation of motion in the y-direction. Please find my code in the picture below.
I can see that my problem starts at Eqy where the differentiation deletes one of the right-hand-side parts because I don't have any function y(t), and Maple thinks y(t) a constant (?)
Can somebody please tell me what I'm doing wrong?
This is my code for the Extended Euclidean Algorthim which should return integer l, polynomials pi,ri,si,ti for 0<=i<=l+1. And polynomial qi for 1<=i<=l such that si(f)+ti(g) = ri and sl(f)+tl(g)=rl=GCD(f,g).
The problem is, I keep getting division by zero. Also it evaluates pi = lcoeff(ri-1 - qiri) to be zero, everytime. Even when I remove this it still says there is a division of zero, which must be coming from qi:=quo(ri-1,ri, x); however I do not know why considering the requirements for the loop are that r[i] not equal zero. I really could use a fresh pair of eyes to see what I've done wrong. Any help would be greatly appreciated!!
Hi there,
Is there a way in which i can solve the following optimal control problem numerically with Maple?
 dH/dt=λ-µ H-(1-u1)β H V+δ I,
dI/dt=(1-u1)β H V-σ I,
‎dV/dt=(1-u2)k I-γ‎V,
dλ1/dt=-1+λ1µ+β‎‎V(1-u1)(λ1-λ2),‎
dλ2/dt=λ1δ+λ2σ-λ3(1-u2)k‎,‎
‎dλ3/dt=β H(λ1-λ2)(1-u1)‎‎+λ3γ.
where
u1=βHV(λ1-λ2)/A1,
u2=-λ3kI/A2,
σ = α + δ,
H(0)=1.7*10^8,    I(0)=0,    V(0)=400.
λ=5*10^5,    µ=0.003,     β=4*10^(-10),    α=0.043,    δ= 0.2                  k=6.24,       γ‎=0.65.
A1=900, A2=1000.
Answers and advice are very appreciated.
Thank you all for reading.
Aylin
I got a problem with a difficult ode,the commands are below.
sys := 1.*(diff(x(t), t, t)) = piecewise(b(t) = 1, 0, 1003.0-1000.*x(t)-30.*(diff(x(t), t))-25.*signum(diff(x(t), t)-.1)-.3*signum(diff(x(t), t))*exp(-2*abs(diff(x(t), t)))), x(0) = 1, (D(x))(0) = 0;
mu := 100;
stick := [diff(x(t), t) = .1, b(t) = piecewise((1000.-1000.*x(t))^2 < 10000, 1, 0)];
slip := [[0, 10000 < (1000.-1000.*x(t))^2], b(t) = 0];
sol:=dsolve({sys,b(0)=0},numeric,discrete_variables=[b(t)::float],events=[stick,slip],event_maxiter=1000000,output=listprocedure,maxfun=0,range=0..8);
any advice is appreciated.
I have to calculate the data in JSON format and export the result back to JSON.
It would be greate if there is any JSON package for Maple.
Also, I use`ExportMatrix` to export the result to CSV format.
But there are some comma (`,`) in the result content and `ExportMatrix` does not handle it well.
Is there any solution for export data to CSV file in my situation?
I need to build a multibody model in MapleSim 6.4 in which with few global parameters I can describe all the other parameters. In other words the final user will enter this few parameters, that are coordinates of specific points, and then the model will calculate all the relative distances on the base of those coordinates.
The problem is that if I apply trigonometric function and square root (like in the screenshot) the model is not calculating any value. Is it possible to make those calculculations?
this is the model (don't worry about the nonsense plots, it's because it's not ultimated):
DWS.msim
a+c^2
5*a+b^5
2*a+b^2*c+3*c
assume system of polynomials are above, how to test whether inverse exist
and find inverse of them
Let a planar polygon P without selfintersections be given through the plottools:-polygon command.
How to find its triangulation as a set of triangles (The indication of common sides is desired too.) in an optimal way with Maple? This is used in the finite element method.
Triangulation
properties of operations on sets?
Example:
is((A minus B) intersect (A minus C) = A minus (B union C)) assuming A::set, B::set, C::set;
        FAIL
First 257 258 259 260 261 262 263 Last Page 259 of 371
