Egor has two parents, four grandparents, and so on.
Write an explicit formula and a recursive formula for the number of ancestors Egor has if we go back n generations.
what would be the figure back to 25 generations ?
Hej everyone,
I am trying to run a Maple script for multiple parameters on our cluster, so far so good. I found that I can pass for example a:=1 and b:=2 to a Maple script using
maple -c "a:=1;" -c "b:=2;" < script.mpl
Is that the best/only way? For convenience I would like to read the parameters from a file, my first idea was to work with sed, so I tried
maple $(sed -n 1'p' data) < script.mpl
This should take the first line from data (which is -c "a:=1;" -c "b:=2;"), so that I would expect to get the same result.
Unfortunately, this is not the case, only the first parameter a:=1 is passed correctly and non of the further parameters.
I've appended the files, I used.
This may be not a Maple problem but rather me making a mistake using sed, but maybe you can see where I made a mistake.
Thanks in advance,
Sören
a
b
c
Download script.mw
The mw-file has to be exported as an mpl-file first. In my case data just contains one line: -c "a:=1;" -c "b:=2;" -c "c:=3;" (I couldn't upload either)
I'm brand new to Maple and was assigned a problem to modify a code provided by my professor to incorporate variable window size. However, I don't know where to begin or what I'm doing. I've attached the link to the problem below. Plz help.  NA1_Project_IDW_01.2014_Fall.pdf
Let (G, ·) be a group and X any set. Let F be the set of functions with domain
X and range G. Define a binary operation ∗ on F by (f ∗ g)(x) := f(x) · g(x). Is
prove that this is so.
Yes, (F, ∗) is a group.
prove it.
Exercise Prove that (-1)u = - u in any vector space. Note that (-1)u means the number -1 is multiplied to the vector u, and - u means the negative vector in the fourth property of the definition of vector spaces.
Answer
Exercise Prove that (a1u1 + a2u2) + (b1u1 + b2u2) = (a1 + b1)u1 + (a2 + b2)u2 in any vector space.
Answer
Exercise Give a detailed reason why, in any vector space,
  • u + v = 0 ⇒ u = - v.
  • 3u + 2v - 4w = 0 ⇒ v = - 3/2 u + 2w.
error in( dsolve/numeric/bvp) unable to achieve the requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.22e-4), consider increasing `maxmesh` or using larger `abserr`
The above is the error message displayed by maple 17. How do I correct this.
Adeniyi Michael
Mytest:=module()
    option package;
    export
        mymain
    # local a,b,c;
    uses LinearAlgebra;
    interface(rtablesize=infinity);
    mymain:=proc(n::integer)
        local ans;
        ans:=Vector(n);
        return ans;
end module;
Here is a short piece of code to create a Maple package. It runs fine. Is that possible to hide the code from print() ?
with(Mytest);
print(mymain); # which displays the source code
Could I hide some of the code? Say I want to use the function mymain() for debugging purpose, but I dont want to make it local to the package. Instead I keep it in "export", but I dont want users to see its code.
Hello I am a Maple 15 user and I am using the command fsolve to solve for the intersection of two curves over a specified interval in x, namely from 0 to the lim defined in the Maple document. The specified interval contains asymptotes and when I specify the full interval only one of the three solutions is returned even if I can see that there are three distinct solutions by looking at the plot of RHS and LHS. Should I use another technique to find the solution or is my implementation of fsolve command wrong?
with(ListTools):
n1 := 1:
n2 := 1.50:
n3 := 1.40:
lambda := 1.3:
k0 := 2*Pi/lambda:
d := 3:
x0 := k0*d:
arg1 := sqrt(x0^2*(n2^2-n1^2)):
arg2 := sqrt(x0^2*(n2^2-n3^2)):
lim := FindMinimalElement([arg1, arg2]):
sqr1 := sqrt(x0^2*(n2^2-n1^2)-x^2):
sqr2 := sqrt(x0^2*(n2^2-n3^2)-x^2):
LHS := tan(x):
RHS := (sqr1+sqr2)/(x*(1-sqr1*sqr2/x^2)):
plot([LHS, RHS], x = 0 .. lim, y = -6 .. 6)
fsolve(RHS = LHS, x = (1/2)*Pi .. 3*Pi*(1/2))
2.634254816
fsolve(RHS = LHS, x = 3*Pi*(1/2) .. 9*Pi*(1/4))
5.222527128
fsolve(RHS = LHS, x = 9*Pi*(1/4) .. lim)
7.598486053
Download HW4Q2.mw
Hey guys,
i'd like to create a custom component for maplesim. I opened the template in maple18 and defined the following equations:
eq := [p(t) = p__0+rho*g*h(t), Q(t) = A*(diff(h(t), t)), L(t) = 100*h(t)/h(0)]
These equations describes a tank with a liquid in it. Now I tried to define a function L(t) (above) that gives the level of the tank in percentage. Therefore I need the initial height value at t=0. The function defined above (h(0)) does not work, cause maple tells me that the function does not exist.
Any hint how to get an initial value or a value at t=0? Or maybe another way to solve my problem?
Hopefully I described right. :-)
Best regards
Christian
I am numerically solving a nonlinear system of nine equations. How long can I expect it to take?
I have run it for 30 minutes and it has not solved yet.
Here is the system of equations:
0=Lambda-mu.*S-beta.*(H+C+C1+C2).*(S./N)-tau.*(T+C).*(S./N);
0=tau.*(T+C).*(S./N)-beta.*(H+C+C1+C2).*(T./N)-(mu+mu_T).*T;
0=beta.*(H+C+C1+C2).*(S./N)-tau.*(T+C).*(H./N)-(mu+mu_A).*H;
0=beta.*(H+C+C1+C2).*(T./N)+tau.*(T+C).*(H./N)-(mu+psi.*mu_A+mu_T+lambda_T).*C;
0=lambda_T.*C-(mu+mu_A+rho_1+eta_1).*C1;
0=rho_1.*C1-(mu+mu_A+rho_2+eta_2).*C2;
0=eta_1.*C1-(mu+rho_1+gamma).*CT1;
0=eta_2.*C2-(mu+rho_2+gamma.*(rho_1)./(rho_1+rho_2)).*CT2+(rho_1).*CT1;
0 = N - S - T - H - C - C1 - C2 - CT1 - CT2;
and I have numeric values for Lambda, beta, tau, mu, mu_T, mu_A, rho_1, rho_2, psi, gamma. The only parameters left are eta_1, eta_2.
Hi everyone.
I wrote simple program with several functions. I would like to obtain parallel computing of my functions. I can't understand how to use nodes.
My programm.
Simple_example.mw
Solve, using 4000 miles for the radius of the earth.
A space shuttle is in circular orbit 150 miles above the surface of the earth. Approximate
  1. the speed
  2. the time required for one revolution.
I'm trying to solve a series of equations and then graph them. I'm trying to solve for the variables involved:
values := solve({eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9,
eq10, eq11, eq12, eq13, eq14, eq15, eq16}, {a, b, b, c, d, e, f,
g, h, i, j, k, l, m, n, o, p});
. . . but it gives me this:
Warning, solving for expressions other than names or functions is not recommended.
values :=
A major-league pitcher releases a ball at a point 6 feet above the ground and 58 feet from home plate at a speed of 100 mi/hr ,
If gravity had no effect, the ball would travel along a line and cross home plate 4 feet off the ground. Find the drop D caused by gravity.
NB: in this problem the angle alpha is the angle between the horizontal and the direction of the released ball. Since the ball is dropping, alpha will be negative.
ADIABATIC FREE EXPANSION
Suppose an ideal gas expands to four times its initial volume. From experience for this process, the initial and final
temperature are the same.
  1. Using a macroscopic approach, calculate the entropy change for the gas
  2. Using statistical considerations, calculate the change in entropy for the gas and show that it agrees with the answer
    you obtained in part 1.
First 256 257 258 259 260 261 262 Last Page 258 of 371
