Maple crashed while saving and now there is nothing in my file. Lost a bunch of work, any way to fix it?
EquationSheet357.mw
(x+y)(x2+y2) = 5500
(x-y)(x2-y2) = 352
hi,i want to take differential with respect to another differential using physics package,but using D instead of diff,could anyone help me do that ? for example :
restart; with(Physics):
A1 := -(1/24)*1*rho*((diff(phi[1](x, t), t))^2)*(h^3)-(1/2)*1*rho*((diff(u[ref](x, t), t))^2)*h-(1/2)*rho*((diff(w(x, t), t))^2)*h+(1/24)*1*1*((diff(phi[1](x, t), x))^2)*(h^3)+(1/2)*1*(1*((diff(u[ref](x, t), x)+(1/2)*(diff(w(x, t), x))^2)^2)+K*1*((diff(w(x, t), x)+phi[1](x, t))^2))*h-1*q*w(x, t):
A2:=-diff(diff(A1,diff(u[ref](x,t),x)),x);
here i want to compute A2 using D command,not diff and i do not want use convert command ! i just need to calculate A2 directly using D command. tnx for your help.
how to transform
Matrix([[1,0,0],[1,0,0],[0,0,0]])
to
Matrix([[0,0,0],[0,0,1],[0,0,1]])
(a) Design your own 3-stage explicit Runge-Kutta method with one-step error O(h4).
(b) Test your method by solving y= −y. Confirm that the global error in your numerical solution
is O(h3).
Write a Maple procedure that solves for y(1) in the initial value problem
                     y= f(y),     y(0) = 1,
using a numerical stencil based on the nth order Taylor series expansion of y. The procedure’s arguments should include an arbitrary function f, an integer n representing the accuracy of the Taylor series expansion, another integer N representing the number of steps between x = 0 and x = 1. Pick a test problem and compare your results with the output of dsolve/numeric.
Eq1:=S*diff(f(x,t),x,t)+diff(f(x,t),x)^2-f(x,t)*diff(f(x,t),x$2)=diff(f(x,t),x$3);
BCs := {D[1](f)(0,t)=cos(t), f(0,t)=0,D[1](f)(L,t)=0};
ICs := {f(x,0)=0};
S:=10:L:=5:
smod3:= pdsolve(Eq1,ICs union BCs,numeric,range=0..L);
smod3:-plot(t=0,  color=red):
it seems to me that the problem is due to the mixed bcs. Any way around?
Cheers!
1.which rules or theorems can guide to generate relations for words in group theory?
2.Is topological method such as complexes the direction to answer Question 1?
I am running a set of diffrential equation , but i receive below error
"Error, (in LL) cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up"
I can't understand the problem
I suppose you would have to programme this, because I couldn't find anything relating to vector spaces in my Maplesoft Linear Algebra tutor or package.
My question really is, you have a problem like, the set of all pairs of real numbers of the form (1,x) with the operations (1,y)+(1,y')=(1,y+y') and k(1,y)=(1,ky)
( ^ taken straight out of my homework haha)
and you run through the 10 vecctor space axioms to determine whether it fails and it not a vector space, or it passes all and it is a vector space.
Is there a way to do this in Maplesoft?
which method i input a series of random number it output a periodic waveform
Hello dear all,
I use maple 16, x64. When I run this code:
Student[Calculus1][ApproximateInt](cos(y/(-1+y)), y = 0 .. 1, method = lower, iterations = 1)
it results in "0.0667344650", exactly equal with the result of executing
Student[Calculus1][ApproximateInt](cos(y/(-1+y)), y = 0 .. 1, method = lower, iterations = 10000000000)
Any idea?
Best regards
How to do composition for finite group?
is the composition like permutation group ?
if express finite group like permutation group,
if so, can elements in first row duplicate? can the second row duplicate?
however, do not know how to map when there are more than or equal two choices
my guess is that
if finite group can be expressed into permutation group
for example 3*3 matrx, each column is a permutation group
then there will be 3 permutation groups, when do composition , first column's permutation group composite with first column's permutation group , second composite with second etc
is it right?
i understand quotient group is
G/(normal subgroup)
= G composite with inverse permutation group of normal subrgoup
is this understanding correct?
If do not have subgroup or normal subgroup, how to do quotient group?
if i shift second row many times in order to find Subgroup satisfy G*Subgroup = Subgroup*G
after find Subgroup then test
inverse(g)*Subgroup*g = Subgroup
how to test whether inverse(g)*Subgroup*g belong to Subgroup?
or just use equal in inverse(g)*Subgroup*g = Subgroup?
a*b - b*a    where a , b are permutation group
how to minus this?
if a + b , then how to plus permutation group
First 277 278 279 280 281 282 283 Last Page 279 of 371
