How can I create a new object from a stanrd, defined in a given metric? For example I want to define an object by convolution of two indices of the Christoffel symbols? I cannot even to see components of such object.
Many thans for an explanation
Leonid
Hi, there i want to basically plot the graph attached. It is basically the graph y= 2x^2 transformed to y = x^2. I can plot them, but how do they get the arrows showing the transformation and the arrows on the axis. Any help would be appreciated.
Composite1:=proc(g,f)
Flist := indets(f): Glist := indets(g): gof:=g:
Subslist1 := [seq( Flist[i]=q, i=1.. nops(Flist))]:
return subs(q=f,subs(Subslist1, gof)): # g(f)
#F(g o f) = F(g) o F(f) = F o g o f = (F o g) o (F o f)
Functor := (1/2)*(-y*t2-x*t1-y*t3+sqrt(y^2*t2^2+2*y*t2*x*t1+2*y^2*t2*t3+x^2*t1^2+2*x*t1*y*t3+y^2*t3^2-4*x*t4*y*t9-4*x*t4*y*t8-4*x^2*t4*t7-4*y^2*t5*t9-4*y^2*t5*t8-4*y*t5*x*t7-4*y^2*t6*t9-4*y^2*t6*t8-4*y*t6*x*t7))/(x*t4+y*t5+y*t6);
F1:=x+2;
G1:=3*x+5;
gof:=subs(x=F1, G1);
osys := Composite1(gof, Functor) = Composite1(Composite1(G1, Functor),Composite1(F1, Functor));
sys1 := subs(x=3,subs(y=2, osys));sys2 := subs(x=5,subs(y=1, osys));
sys3 := subs(x=1,subs(y=5, osys));sys4 := subs(x=1,subs(y=2, osys));
sys5 := subs(x=2,subs(y=5, osys));sys6 := subs(x=5,subs(y=2, osys));
sys7 := subs(x=2,subs(y=1, osys));sys8 := subs(x=3,subs(y=5, osys));
sys9 := subs(x=5,subs(y=3, osys));
res:=solve([sys1, sys2, sys3, sys4, sys5, sys6, sys7, sys8, sys9], {t1,t2,t3,t4,t5,t6,t7,t8,t9});
simplify(%);
`~`[lhs](select(evalb, res));
alpha:= (1/2)*(-y*t2-x*t1-y*t3+sqrt(y^2*t2^2+2*y*t2*x*t1+2*y^2*t2*t3+x^2*t1^2+2*x*t1*y*t3+y^2*t3^2-4*x*t4*y*t9-4*x*t4*y*t8-4*x^2*t4*t7-4*y^2*t5*t9-4*y^2*t5*t8-4*y*t5*x*t7-4*y^2*t6*t9-4*y^2*t6*t8-4*y*t6*x*t7))/(x*t4+y*t5+y*t6);
g := -y/x;
f := (-x+sqrt(x^2-x*y-2*y^2))/(2*y+x);
subs(p=f,subs(q=f,subs(x=p,subs(y=q,g))));
g := (1/2)*(-x+sqrt(x^2-4*y*x-4*y^2))/(x+y);
f := x*y;
gof := subs(p=f,subs(q=f,subs(x=p,subs(y=q,g))));
lhsgofoalpha := subs(q= alpha,subs(p=alpha, subs(x=p,subs(y=q,gof))));
foalpha := subs(p= alpha,subs(q=alpha,subs(x=p,subs(y=q,f))));
rhsgofoalpha := subs(x= foalpha,subs(y= foalpha, g));
osys := lhsgofoalpha = rhsgofoalpha;
res:=solve([Re(sys1)=0, Re(sys2) =0, Re(sys3) =0, Re(sys4) =0, Re(sys5) =0, Re(sys6) =0, Re(sys7) =0, Re(sys8) =0, Re(sys9) =0], {t1,t2,t3,t4,t5,t6,t7,t8,t9});
Hi! I can't answer the following two simple questions.
1) Why do use different font sizes every other  files created by the attached worksheet?
2) What happens when we uncomment some (all) of the #restart lines, and execute the commands (execution groups)  in the original order? How many files should we get?
Update: sorry, I can't see the uploaded worksheet, but here it is as plain text:
#### on Fedora 18 Linux, Maple 17.01:
#restart;
currentdir(kernelopts(homedir)):
currentdir();
#restart;
plotsetup(ps,plotoutput= `sinplot1`, plotoptions = `width=500,height=500, font=[TIMES, BOLD, 16]`);
plot(sin(x), x=-Pi..Pi, title="Output: sinplot1.eps");
#restart;
plotsetup(ps,plotoutput= `sinplot2`, plotoptions = `width=500,height=500`);
plot(sin(x), x=-Pi..Pi, font=[TIMES, BOLD, 16], title="Output: sinplot2.eps");
#### Restart in the same execution group as the plot statements - no output file?
#restart;
plotsetup(ps,plotoutput= `sinplot3`, plotoptions = `width=500,height=500, font=[TIMES, BOLD, 16]`);
plot(sin(x), x=-Pi..Pi, title="Output: sinplot3.eps");
#restart;
plotsetup(ps,plotoutput= `sinplot4`, plotoptions = `width=500,height=500`);
plot(sin(x), x=-Pi..Pi, font=[TIMES, BOLD, 16], title="Output: sinplot4.eps");
restart:with(plots):
L1 := (1/2)*(S+sqrt(S^2+4*a*b))/b;
L2 := (1/2)*(S-sqrt(S^2+4*a*b))/b;
solve(L1=L2,S);
         2*sqrt(-a*b), -2*sqrt(-a*b)
solve(L1=L2,a);
             -(1/4)*S^2/b
solve(L1=L2,b);
                -(1/4)*S^2/a
Here is my question.
Now plotting L1, L2
a:=1:b:=1: # say
plot({L1,L2},S=0..1);
Is there a way to utilize the conditions which we can get through solve and use it while plotting (not 3d plotting) for any given choice of the values of a, b, S?
and  x have range=(0 to 2),the y have range = (2,3),follow when the x=(3 to 4),so the y=(3 to -3) how to implement the title's function
still the x and y have variability value and variability number
i assign
seta := [x+1, x^2]
setb := [x^3, 2*x+5]
does morphism mean that
i use card_prod
to get
(x+1, x^3)
(x+1, 2*x+5)
(x^2, x^3)
(x^2, 2*x+5)
such that i composite each of 4 sets still satisfy F(f o g) = f o g
example
subs(x=x^3, x+1)
(A o C) o Colimit = (B o C) o Colimit
if known A, B, C and framework of Colimit
can it be said colimit?
Bonus, what are A,B,C? <- this can be not answered
after integration,
result is x^2
f := x^2
we know in the range 5..-5 = 5^2 - (-5)^2 = 0
this example is not good enough, as i can be any number x, -x
if in another example, i use a and b to represent that would like to find
3*a^2 - 3*b^2 = 0, how to find possible a and b?
my example is not good, is there example that a and b are different number, not only in sign
Notepad displays alt+1, alt+2 and alt+3 as ☺☻♥
Just wondering why Maple displays them as square boxes?  Shouldn't it have the font capability to display them as well?
I tried to create the*.exe file by C and call the kernel of maple for calculation.
To understand the OpenMaple, I ran the OpenMaple C code sample, “simple.c” in “<Maple>\ samples\OpenMaple\simple” through Microsoft Visual C++ 2008 but got the incorrect result:
It’s seems that the error is happen due to the wrong maple directory. But according to the description of "kernelopts" in help, the value of mapledir cannot be set.
Refer to the description of  "OpenMaple,Examples" in help , both header file path and library file path had been set:
O/S: Windows (32-bit)
Header file Directories: "C:\Program Files\Maple 17\extern\include"
Library Directories: "C:\Program Files\Maple 17\bin.win"
Environment Variable: "C:\program files\Maple 17\bin.win"
I'd appreciate any help on this topic. Thank a lot.
Has anyone used Maple for Empirical Mode Decomposition ? Any tips, Maple docs ? I can't seem to find anything when searching Maple sites.
I have recently written a maple program to deconvolute gamma-ray spectra using the Richardson-Lucy algrithm. Although this method works well I would prefer to use a method based on the Maximum Entropy algorithm, and would like to know if anyone has tried to write a Maple program to deconvolute 1 dimensional data?
In ode solve command i generated a large array data. The output shows a large order matrix of this form
[110001x6 Matrix
Datatype:Anything
Storage:rectangular
order:Fortran_order].
I want to export this matrix into a notepad. Which can then be used for plotting in TecPlot.
Looking for good response
First 279 280 281 282 283 284 285 Last Page 281 of 371
