with(Groebner):
T := lexdeg([x1,x2,x3],[e1,e2,e3]);
hello1 := proc(xx,yy)
return MatrixMatrixMultiply(xx,yy);
hello2 := proc(xx,yy)
return xx+yy- MatrixMatrixMultiply(xx,yy);
m1 := Matrix(3, 3, {(1, 1) = -.737663975994461+0.*I, (1, 2) = -.588973463383001+0.*I, (1, 3) = .330094104689369+0.*I, (2, 1) = -.588012653178741+0.*I, (2, 2) = .320157823261769+0.*I, (2, 3) = -.742792089286083+0.*I, (3, 1) = -.331802619371428+0.*I, (3, 2) = .742030476217061+0.*I, (3, 3) = .582492741708719+0.*I});
m2 := Matrix(3, 3, {(1, 1) = -.742269137704830+0.*I, (1, 2) = -.590598631673326+0.*I, (1, 3) = .316590877121441+0.*I, (2, 1) = -.593533033362923+0.*I, (2, 2) = .360143915024171+0.*I, (2, 3) = -.719732518911068+0.*I, (3, 1) = -.311054762892221+0.*I, (3, 2) = .722142379823161+0.*I, (3, 3) = .617863510611693+0.*I});
m3 := Matrix(3, 3, {(1, 1) = -.751491355856820+0.*I, (1, 2) = -.574908634018322+0.*I, (1, 3) = .323636840615627+0.*I, (2, 1) = -.575794245520782+0.*I, (2, 2) = .332066412772496+0.*I, (2, 3) = -.747123071744916+0.*I, (3, 1) = -.322058579916187+0.*I, (3, 2) = .747804760642505+0.*I, (3, 3) = .580574121936877+0.*I});
AA := hello1(m1, m2);
BB := hello2(m1, m2);
GB := Basis([e1- AA,e2- BB],T):
NormalForm(m3, GB, T);
i have got alot of mixed and high degree derivatives. For example:
u[x]*u[x,t]*eta[x,t]+u[]^2*u[x]*eta[x]+kis(x,y)u[x,t]^2*u[]+eta(x, y)*u[]*u[x]^2+ksi[x,t]*u[x]^2*u[x,t]+......
like this alot of terms
my question is how can i solve divided by the derivative of the u(x,t) partial differential equations system and so  how can i find eta(x,t,u) and ksi(x,t,u)
what is the name of this decomposition?
Y = S^-1*X*S, where S is unitary fourier transform
do maple have function to solve this?
Hi MaplePrimers!
I have a simulation in MapleSIM, exported as a compiled procedure in maple using -LinkModel(), and -GetCompiledProc.
I'm trying to do parameter estimation on my MapleSIM model.  Within a optimization scheme, I call the MapleSIM model, and it will output a curve.  Using a least squares method, I compare this measurements to synthetic experimental data (I know the actual values), and generate an objective function.  The optimization algorithm will try different parameter values, and try to minimze the objective function.  When the curves are exactly the same, the objective function will be zero.
The problem I am having is certain parameter sets will cause the model to require very small steps.  I wish to put a timeout on these experiments, because speed is important.  However, I would also like to see the results up to the point of requiring very small steps.  For timeout, I was using code along the lines of:
out:= timelimit(30,cProc(params = PData)); #simulate with 30s limit
where PData are the parameter guessses, and cProc is the compiled MapleSim model.
I would like 'out' to be assigned whatever the results were after 30 seconds, even if the model had not finished integrating.
Thanks in advance for any help!
I want to define a band matrix using n vectors. Detial given maple sheet. please help me
Help.mw
I want to define a matrix of M by M which have some condition. detail given in maple file. please help me.
Help_Maple-1.mw
I wan to define a square matrix for M and r detial given in Maple sheet. Please Help....Help_Maple.mwHelp_Maple.mw
FirstEigenVector := Matrix(3, 1, {(1, 1) = -.736895432967255+0.*I, (2, 1) = -.588906969844997+0.*I, (3, 1) = -.331924240964690+0.*I});
SecondEigenVector := Matrix(3, 1, {(1, 1) = -.589856901397123+0.*I, (2, 1) = .320280857681335+0.*I, (3, 1) = .741275257969058+0.*I});
ThirdEigenVector := Matrix(3, 1, {(1, 1) = .330233185410229+0.*I, (2, 1) = -.742030156443046+0.*I, (3, 1) = .583384341736151+0.*I});
LHS := ProjOfEigenVector;
LHS := Matrix(3, 3, {(1, 1) = -.736895432967255+0.*I, (1, 2) = -.589856901397123+0.*I, (1, 3) = .330233185410229+0.*I, (2, 1) = -.588906969844997+0.*I, (2, 2) = .320280857681335+0.*I, (2, 3) = -.742030156443046+0.*I, (3, 1) = -.331924240964690+0.*I, (3, 2) = .741275257969058+0.*I, (3, 3) = .583384341736151+0.*I});
RHS := c1*FirstEigenVector+c2*SecondEigenVector+c3*ThirdEigenVector;
RHS := Matrix(3, 1, {(1, 1) = (-.736895432967255+0.*I)*c1+(-.589856901397123+0.*I)*c2+(.330233185410229+0.*I)*c3, (2, 1) = (-.588906969844997+0.*I)*c1+(.320280857681335+0.*I)*c2+(-.742030156443046+0.*I)*c3, (3, 1) = (-.331924240964690+0.*I)*c1+(.741275257969058+0.*I)*c2+(.583384341736151+0.*I)*c3});
solve([LHS[1][1] = RHS[1][1], LHS[2][2] = RHS[2][1], c1^2+c2^2+c3^2 = 1], [c1, c2, c3]);
after calculated the projection matrix,
it is a 3*3 matrix on left hand side
however, combination of eigenvectors on right hand side is 3*1 matrix
when calculated c1,c2,c3 under the condition c1^2+c2^2+c3^2 = 1
how to know whether LHS[1][1] = RHS[1][1], or LHS[1][2] = RHS[1][1] or
LHS[1][3] = RHS[1][1]
How to create a borel set from a list of decimal
if i interpolate three decimal number and solve it,
if any number substitute into this result which is a inverse function, can the results be said borel set?
When i look into 'maple help' for Pade approximation, it only show a code for solving equation involving 1 variable only..what is the code for equation involving 2 or more variable for pade approximation?
In his article “Subscripts as Partial Differentiation Operatuuors , rlopez 1228 showed us a way to denote partial derivatives by repeat subscripts. For example, the sixth derivative of u(x,y) with respect to x will be denoted by u_{x,x,x,x,x,x}.
Is there a way to make the notation u_{x,x,x,x,x,x} even shorter by u_{6x}?
In the same way mixed derivatives u_{x,x,x,y,y,y,y} will be denoted as u_{3x,4y}, etc.
Thank you very much!
superposition said that a vector is a linear combination of other vectors
but even if i calculated the coefficient, i do not know which vector is which other vectors's linear combination
how to prove?
InputMatrix3 := Matrix([[close3(t), close3(t+1) , close3(t+2) , close3(t+3) , close3(t+4) , close3(t+5)],
[close3(t+1) , close3(t+2) , close3(t+3) , close3(t+4) , close3(t+5) , close3(t+6)],
[close3(t+2) , close3(t+3) , close3(t+4) , close3(t+5) , close3(t+6) , 0],
[close3(t+3) , close3(t+4) , close3(t+5) , close3(t+6) , 0 , 0],
[close3(t+4) , close3(t+5) , close3(t+6) , 0 , 0 , 0],
[close3(t+5) , close3(t+6) , 0 , 0 , 0, 0],
[close3(t+6) , 0 , 0 , 0, 0, 0]]):
EigenValue1 := Eigenvalues(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3)):
Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3)):
AEigenVector[tt+1] := Asso_eigenvector;
Matrix(6, 6, {(1, 1) = .514973850028629+0.*I, (1, 2) = .510603608194333+0.*I, (1, 3) = .469094659512372+0.*I, (1, 4) = .389872713818831+0.*I, (1, 5) = .279479324327359+0.*I, (1, 6) = -.154682461176604+0.*I, (2, 1) = .493994413154560+0.*I, (2, 2) = .306651336822139+0.*I, (2, 3) = -0.583656699197969e-1+0.*I, (2, 4) = -.417550308930506+0.*I, (2, 5) = -.566122865008542+0.*I, (2, 6) = .404579494288380+0.*I, (3, 1) = .449581541124671+0.*I, (3, 2) = -0.266751368453398e-1+0.*I, (3, 3) = -.529663398913996+0.*I, (3, 4) = -.359719616523673+0.*I, (3, 5) = .313717798014566+0.*I, (3, 6) = -.537405340038665+0.*I, (4, 1) = .386952162293470+0.*I, (4, 2) = -.351332186748244+0.*I, (4, 3) = -.390816901794187+0.*I, (4, 4) = .470032416161955+0.*I, (4, 5) = .231969182174424+0.*I, (4, 6) = .547134073332474+0.*I, (5, 1) = .306149178348317+0.*I, (5, 2) = -.530611390076568+0.*I, (5, 3) = .192717713961280+0.*I, (5, 4) = .291213691618787+0.*I, (5, 5) = -.562991429686901+0.*I, (5, 6) = -.431067688369314+0.*I, (6, 1) = .212576094920847+0.*I, (6, 2) = -.489443150196337+0.*I, (6, 3) = .553283259136031+0.*I, (6, 4) = -.488381938231088+0.*I, (6, 5) = .363604594054259+0.*I, (6, 6) = .195982711855368+0.*I})
Matrix(6, 6, {(1, 1) = .515428842592397+0.*I, (1, 2) = .515531996615269+0.*I, (1, 3) = .468108280940919+0.*I, (1, 4) = -.392394120975052+0.*I, (1, 5) = -.280467124908196+0.*I, (1, 6) = -.129613084502380+0.*I, (2, 1) = .494563493180197+0.*I, (2, 2) = .301273494494509+0.*I, (2, 3) = -0.622136916501293e-1+0.*I, (2, 4) = .438383262732459+0.*I, (2, 5) = .571041594120088+0.*I, (2, 6) = .377494770878435+0.*I, (3, 1) = .450886315308369+0.*I, (3, 2) = -0.323387895921418e-1+0.*I, (3, 3) = -.527636820417566+0.*I, (3, 4) = .332744872607714+0.*I, (3, 5) = -.322934536375586+0.*I, (3, 6) = -.549772001891837+0.*I, (4, 1) = .385916641681991+0.*I, (4, 2) = -.352066020655722+0.*I, (4, 3) = -.389655495441319+0.*I, (4, 4) = -.450049711766943+0.*I, (4, 5) = -.221529986447276+0.*I, (4, 6) = .568916672007495+0.*I, (5, 1) = .305485655770791+0.*I, (5, 2) = -.528766119966973+0.*I, (5, 3) = .201065789602278+0.*I, (5, 4) = -.310329356773806+0.*I, (5, 5) = .555973984740943+0.*I, (5, 6) = -.425730045170186+0.*I, (6, 1) = .210210489500614+0.*I, (6, 2) = -.488744465076970+0.*I, (6, 3) = .553484076328700+0.*I, (6, 4) = .494245653290329+0.*I, (6, 5) = -.364390406353340+0.*I, (6, 6) = .183130120876843+0.*I})
mm1 := 1;
solve(
[AEigenVector[mm1][2][1][6] = m1*AEigenVector[mm1][2][1][1]+m2*AEigenVector[mm1][2][1][2]+m3*AEigenVector[mm1][2][1][3]+m4*AEigenVector[mm1][2][1][4]+m5*AEigenVector[mm1][2][1][5],
AEigenVector[mm1][2][2][6] = m1*AEigenVector[mm1][2][2][1]+m2*AEigenVector[mm1][2][2][2]+m3*AEigenVector[mm1][2][2][3]+m4*AEigenVector[mm1][2][2][4]+m5*AEigenVector[mm1][2][2][5],
AEigenVector[mm1][2][3][6] = m1*AEigenVector[mm1][2][3][1]+m2*AEigenVector[mm1][2][3][2]+m3*AEigenVector[mm1][2][3][3]+m4*AEigenVector[mm1][2][3][4]+m5*AEigenVector[mm1][2][3][5],
AEigenVector[mm1][2][4][6] = m1*AEigenVector[mm1][2][4][1]+m2*AEigenVector[mm1][2][4][2]+m3*AEigenVector[mm1][2][4][3]+m4*AEigenVector[mm1][2][4][4]+m5*AEigenVector[mm1][2][4][5],
m1^2 + m2^2 + m3^2 + m4^2 + m5^2 = 1], [m1, m2, m3, m4, m5]);
[m1 = .4027576723+.5022235499*I, m2 = -.5922841426-1.043213223*I, m3 = -.1130969773+.9150300317*I, m4 = .9867039883-.5082455178*I, m5 = -1.400123192+.1536850673*I], [m1 = .4027576723-.5022235499*I, m2 = -.5922841426+1.043213223*I, m3 = -.1130969773-.9150300317*I, m4 = .9867039883+.5082455178*I, m5 = -1.400123192-.1536850673*I]
mm1 := 2;
solve(
[m1 = .4262845394-.5114193433*I, m2 = -.6313720018+1.072185334*I, m3 = -0.7337582213e-1-.9580760394*I, m4 = -1.036525681-.5400714113*I, m5 = 1.412710014+.1874839516*I], [m1 = .4262845394+.5114193433*I, m2 = -.6313720018-1.072185334*I, m3 = -0.7337582213e-1+.9580760394*I, m4 = -1.036525681+.5400714113*I, m5 = 1.412710014-.1874839516*I]
any user of the community has material ppt or pdf on presentation of clickable math popup and maple in computaconal applied to mathematics.
any help on the origin of math clickable popup;? place the link if they were so friendly!
First 282 283 284 285 286 287 288 Last Page 284 of 371
