I have theoretically 3(could eventually be more) layers with an incident wave with a wave equation for that wave.
It refracts into the 2nd layer from the first and now has a 2nd wave equation, then from the 2nd into the 3rd layer with a 3rd wave equation.
All the wave equations are of the form, Psi(z) = A_1psi_1(z) + B_1psi_2(z); this is just a general solution where psi_1&2 are linearly independant solutions that make up the general equation above and A_1 and B_1 are constant coefficients that would be A_2,B_2 and A_3,B_3 for the 2nd and 3rd layers respectively.
Transfer matrix method gives A_1,B_1 in terms of A_2,B_2(as it transfers from layer 1 to 2 they equate under boundary conditions so you can solve the simultaneous equations for results). You create a matrix of these results and multiply it with the respective matrix of the 2nd layer to 3rd layer to give you the overall transfer matrix from one side of the system to the other.
I think something to do with transfer function but not sure how to use it or set up the problem.
Thanks in advance for any pointers.
Bonjour,
Je veux savoir comment augmenter la mémoire du maple sachant que j'ai un calculateur puissant (4 CPU de 2G pour chacun+2 RAM de 146 G pour chacune).
En vérité, il s'agit de résoudre un système polynomial à 7 équations et 4 variables ; voici les deux messages du Maple après l'exécution : "Kernel connection has been lost" "execution stopped:memory allocation failed.please see ?alloc for more detail."
Quelles sont les paramètres ci-dessous de kernelopts qu'il faut modifier et comment :
> kernelopts(maxdigits);
                             38654705646
> kernelopts(wordsize);
                                  64
> kernelopts(dagtag=4);
                                FLOAT
> kernelopts(dagtag=SERIES);
                                  15
> kernelopts(cputime);
                               0.010998
> kernelopts(datalimit=64*Unit( megabyte )):
> kernelopts(datalimit=64*Unit( mebibyte ));
                                62500
> kernelopts(datalimit=10000*Unit( kibibyte ));
                                65536
> kernelopts(datalimit);
                                10000
> kernelopts(cpulimit=10*Unit( minute )):
> kernelopts(cpulimit);
                                 600
Avec mes plus vifs remerciements,
Gérard.
f(f(z,a),b) = f(z, a + b)
i googled this axiom is diff(x(t),t) = xi(f);
then i think
diff(x(t),t$2) = xi(f);
is it f(f(f(z,a),b),c) = f(z, a + b+c) ?
then think again
whether  f(f(f(z,a),b),c) + f(f(z,a),b) = f(z, a + b+c)  is diff(x(t),t$2)+diff(x(t),t)= xi(f);
however do not know how to construct right hand side  f(z, a + b+c), this is my guess
any books teaching this?
i think that if any matrix group be created from  f(f(f(z,a),b),c) + f(f(z,a),b)
that can help to convert to differential equations
hope that there is a solvable group which can represent solvable differential equation or differential system
if xi is Infinitesimal in maple,
how to find Infinitesimal from f(f(z,a),b) = f(z, a + b) ?
Is there an easy way, where I can generate a 3d cube when I have already defined a 3d polygon surface?
I would like to sweep my surface 20 cm in the z-axis, preferably without having to define the cube from it's 8 corners.
Is there a command I can use for this purpose?
got error when draw root locus
and would like to know how to set feasibility tolerance, less than 0.1 is also ok
with(DynamicSystems):
x11 := [1.05657970467127, .369307407127487, .400969917393968, .368036162749865, .280389875142339, .280523489139136, .283220960827744, .373941285224253, .378034013792196, .384412762008662, .358678988563716, .350625923673556, .852039817522304, .362240519978640, 1.03197080591829, .343650441408896, .982510654490390, .404544012440991, .422063867224247, 1.20938803285209, .455708586000668, 1.22503869712995, .388259397947667, .472188904769827, 1.31108028794286, 1.19746589728366, .572669348193002];
y11 := [.813920951682113, 10.3546712426210, 2.54581301217449, 10.2617298458172, 3.82022939508992, 3.81119683373741, 3.90918914917183, 10.5831132713329, 10.8700088489538, 11.0218056177585, 10.5857571473115, 9.89034057997145, .271497107157453, 9.77706473740146, 2.23955104698355, 4.16872072216206, .806710906391666, 11.9148193656260, 12.0521411908477, 2.52812993540440, 12.6348841508094, 2.72197067934160, 5.10891266728297, 13.3609183272238, 3.03572692234234, 1.07326033849793, 15.4268962507711];
z11 := [8.93290500985527, 8.96632856524217, 15.8861149154785, 9.16576669760908, 3.20341865536950, 3.11740291181539, 3.22328961317946, 8.71094047480794, 8.60596466961827, 9.15440788281943, 10.2935566768586, 10.5765776143026, 16.3469510439066, 9.36885507010739, 2.20434678689869, 3.88816077008078, 17.9816287534802, 10.1414228793737, 10.7356141216242, 4.00703203725441, 12.0105837616461, 3.77028605914906, 5.01411979976607, 12.7529165152417, 3.66800269682059, 21.2178824031985, 13.9148746721034];
u11 := [5.59, 5.74, 5.49, 5.19, 5.37, 5.56, 5.46, 5.21, 5.55, 5.56, 5.61, 5.91, 5.93, 5.98, 6.28, 6.24, 6.44, 6.58, 6.75, 6.78, 6.81, 7.59, 7.73, 7.75, 7.69, 7.73, 7.79];
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t)+k4*u1(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t)+k8*u1(t);
c1 := Diff(z1(t),t) = k8*x1(t)+ k9*y1(t)+ k10*z1(t)+k12*u1(t);
d1 := Diff(u1(t),t) = 0;
ICS:=x1(1)=x11[1],y1(1)=y11[1],z1(1)=z11[1],u1(1)=u11[27];
sol:=dsolve({a1,b1,c1,d1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12],output=listprocedure);
X,Y,Z,U:=op(subs(sol,[x1(t),y1(t),z1(t),u1(t)]));
tim := [seq(n, n=1..27)];
N:=nops(tim):
ans:=proc(k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12) sol(parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
 add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2,i=1..N)
ans(.001,.002,.003,.001,.002,.003,.001,.002,.003,.001,.002,.003);
result1 := Optimization:-Minimize(ans,initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.001,.002,.003]);
k1 := result1[2][1];
k2 := result1[2][2];
k3 := result1[2][3];
k4 := result1[2][4];
k5 := result1[2][5];
k6 := result1[2][6];
k7 := result1[2][7];
k8 := result1[2][8];
k9 := result1[2][9];
k10 := result1[2][10];
k11 := result1[2][11];
k12 := result1[2][12];
diff_eq := [a1, b1, c1, d1];
sys6 := DiffEquation(diff_eq, [x1(t), y1(t), z1(t), u1(t)], [x1(t), y1(t), z1(t), u1(t)]);
sys6 := DiffEquation(diff_eq, [x1(t), y1(t), z1(t)], [x1(t), y1(t), z1(t), u1(t)]);
ResponsePlot(sys6, Step(), parameters = params);
RootLocusPlot(sys6);
> sys6 := DiffEquation(diff_eq, [], [x1(t), y1(t), z1(t), u1(t)]);
Error, (in DynamicSystems:-DiffEquation) unrecognized diff-equation type: 9
> sys6 := DiffEquation(diff_eq, [x1(t), y1(t), z1(t), u1(t)], [x1(t), y1(t), z1(t), u1(t)]); sys6 := DiffEquation(diff_eq, [x1(t), y1(t), z1(t)], [x1(t), y1(t), z1(t), u1(t)]);
> ResponsePlot(sys6, Step(), parameters = params); RootLocusPlot(sys6);
Error, invalid input: DynamicSystems:-ResponsePlot expects value for keyword parameter parameters to be of type ({set, list})(name = complexcons), but received params
Error, (in Verify:-CommonExports) system object is not a module
Bonjour,
Merci d'avance,
Gérard.
I was wondering if I can call Matlab R2012b with maple 14 on my macos 10.7.5.
When I try to do this:
> Matlab[setvar]("x", 3.14);
I get this:
Error, (in Matlab:-setvar) there was a problem finding or loading matlink.so. Refer to ?Matlab,setup for help configuring your system to work with the Matlab-link.
I read that I may have to change a script. Where are those scripts located?
delete this post, not maple related
apologies
how to make a table of newton raphson ?
working is below
printf("No           root                   x[i+1]                 abs(x[i+1]-x[i])\n"); for i to n do y[i] := evalf(x[i]+(-D1(x[i])+sqrt(D1(x[i])^2-2*f(x[i])*D2(x[i])))/D2(x[i])); x[i+1] := evalf(y[i]-f(y[i])/sqrt(D1(x[i])^2-2*f(x[i])*D2(x[i]))); printf("%d         %10.10f     %10.10f       %10.10e \n", i+1, x[i+1], f(x[i+1]), abs(x[i+1]-x[i])); if abs(x[i+1]-x[i]) < tol then print("approximate solution" = x[i+1]); print("No of iterations" = i+1); break end if end do
please help me
expect to export a series of graphs, but no diagram,
then i debug to export one diagram, it is success, why in this case not export
https://drive.google.com/file/d/0B2D69u2pweEvcDZVZ0tsRTc2dTg/edit?usp=sharing
with(combinat):
list1 := permute([a, b, a, b, a, b], 3);
list1a := subs(b=1,subs(a=0, list1));
n := 3;
list1a := permute([seq(seq(k,k=0..1),k2=1..n)], n);
list2 := permute([a, b, c, d, e, f, g, h, a, b, c, d, e, f, g, h, a, b, c, d, e, f, g, h], 3);
list3 := subs(h=18,subs(g=17,subs(f=16,subs(e=15,subs(d=14,subs(c=13,subs(b=12,subs(a=11,list2))))))));
list3 := permute([seq(seq(k,k=11..18),k2=1..3)], 3);
Iter:= iterstructs(Permutation([seq(seq(k,k=11..(10+nops(list1a))),k2=1..3)]), size=3):
list3b := [];
while not Iter[finished] do
p:= Iter[nextvalue]();
list3b := [p, op(list3b)];
list5 := Matrix(nops(list1a)*nops(list3), 1);
count := 1;
for n from 1 to nops(list3) do
temp1 := subs(1=list1a[1],list3[n]);
for k from 11 to nops(list1a)+10 do
temp1 := subs(k=list1a[k-10],temp1);
od;
list5[count] := temp1;
count := count + 1;
od;
Lfh := proc(numoflevel, hx, fx, varx)
if numoflevel = 1 then
hello := 0;
for kk from 1 to nops(var) do
hello := hello + diff(hx[kk], varx[kk])*fx[kk];
od;
return hello;
hello := 0;
hello := hello + diff(Lfh(numoflevel-1, hx, fx, varx), varx[kk])*fx[kk];
od;
return hello;
CheckRelativeRankZero := proc(h1, f1, g1,variables1,Count)
IsFinish := 0;
Result := 0;
for ii from 1 to 8 do
if IsFinish = 0 then
Lf2h := Lfh(ii,h1,f1,variables1);
Print(“Lf2h=”);
Print(Lf2h);
Lgf2h := Lfh(1,[seq(Lf2h,n=1..nops(variables1))],g1,variables1);
if Lgf2h = 0 then
print(“Lgf2h = 0”)
print(f1);
print(Lf2h);
print("find at ", ii);
IsFinish := 1;
Result :=Lf2h;
od;
return Result;
IsZeroMatrix := proc(h1)
Iszero := 1;
for ii from 1 to 3 do
for jj from 1 to 3 do
if h1[ii][jj] <> 0 then
Iszero := 0;
end if
od;
od;
return Iszero;
with(combstruct):
list6:= convert(list5, list):
list7 := [];
for ii from 1 to nops(list6) do
if list6[ii] <> 0 then
list7 := [list6[ii], op(list7)];
od;
with(VectorCalculus):
varlist := [x1, x2, x3];
Iter:= iterstructs(Permutation(list7), size=2):
Count := 1;
with(DEtools):
Count := 1;
list8 := [];
I1 := 0;
I2 := 0;
if IsZeroMatrix(p[1]) = 0 and IsZeroMatrix(p[2]) = 0 then
group1 := Matrix(p[1]);
if group1[ii][jj] = 1 then
I1 := I1 + varlist[ii]*varlist[jj];
od;
od;
group2 := Matrix(p[2]);
if group2[ii][jj] = 1 then
I2 := I2 + varlist[ii]*varlist[jj];
od;
od;
f2:=[I1, I2];
g2:=[0,-1,1];
h2:=[x1,0,0];
Lf2h := CheckRelativeRankZero(h2,f2, g2, varlist, Count);
print(“Lf2h=”);
print(Lf2h);
RightSide := MatrixMatrixMultiply(Matrix([[0,diff(I2, varlist[3]),-diff(I2,varlist[2])],[-diff(I2, varlist[3]),0,diff(I2, varlist[1])],[diff(I2, varlist[2]),-diff(I2, varlist[1]),0]]), Matrix([[diff(I1, varlist[1])],[diff(I1, varlist[2])],[diff(I1, varlist[3])]]));
print(“RightSide”);
print(RightSide);
Lf2_h := Lfh(1, Lf2h, f2, varlist);
LgLf_h := Lfh(1,Lfh(1,h2,f2,varlist),g2, varlist);
if LgLf_h = 0 then
u:=0;
u := -Lf2_h/LgLf_h;
newsys := [Diff(x1(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[1][1]))) + g[1]*u,
Diff(x2(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[2][1]))) + g[2]*u,
Diff(x3(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[3][1]))) + g[3]*u];
eval(plotsetup):
`plotsetup/devices`[jpeg]:=[jpeg,`plot.jpg`,[],[],``]:
plotsetup(jpeg, plotoutput=cat(cat(`testhamiplot`, Count),`.jpg`),plotoptions=`height=700,width=800`);
DEplot3d(value(newsys), [x1(t), x2(t), x3(t)], t = 0..1,[[x1(0) = 1, x2(0) = 1, x3(0) = 1]]);
Count := Count +1;
Hello.
I am novice here and I have an question about export animations frames into sequence of postscript files. I don't googled nothing about this theme.
Here is my question:
Is there an option to convert the animated picture into  sequence of separate images and then (eg using the program cycle) save this images as separate PostScript images? I know the possibility of exporting to GIF file and then converting them into PS file. But I do not have a PS file with a sequence of bitmap images. I would sufficed for me to be able to see a separate frame of animation (through any index).
Thanx Jaroslav Hajtmar
Using the fsolve commmand how does one solve for just the positive solutions and remove the dublicate values?
when i got this error, i am confused i guess t is independant variable, x1,y1,z1 are dependant variables
x11 := [0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]:
y11 := [ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]:
z11 := [ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]:
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t);
b1 := Diff(y1(t),t) = k4*x1(t)+ k5*y1(t)+ k6*z1(t);
c1 := Diff(z1(t),t) = k7*x1(t)+ k8*y1(t)+ k9*z1(t);
ICS:=x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1];
sol:=dsolve({a1,b1,c1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
ans:=proc(p1,p2,p3) sol(parameters=[x1=p1,y1=p2,z1=p3]); end proc:
FitParams:=Statistics:-NonlinearFit(ans, [x11, y11, z11], tim, initialvalues=<0.5,0.5,0.5>, output=parametervalues);
4th_order.mw Is it possible to solve this ODE with perturbation method using maple? If yes, please give the procedure.
First 285 286 287 288 289 290 291 Last Page 287 of 371
