I am creating a plot in Maple17 which will include many line segments and polygons.  I want the axes to be equally scaled, so that line segments that are perpendicular actually look perpendicular.  When I view what I have created so far, line segments that are perpendicular do not appear to be so in a plot, even though I used the "scaling=constrained" option several times.  I created a stripped-down file that isolates the problem.  Here it is:
segp := proc(pt1, pt2)
  description "plot of line segment between two points";
  local m;
 m:=Matrix([pt1,pt2]):
  polygonplot(m,thickness=1,scaling=constrained);
slope := proc(pt1, pt2)
  description "slope of line segment btwn two different points";
  (pt2[2]-pt1[2])/(pt2[1]-pt1[1])
pa9:=[0.1864032968, 0.9824733131];
[.1864032968, .9824733131]
pa16:=[0.6816387600, 0.7316888689];
[.6816387600, .7316888689]
pd9:=[0.05940746930, 0.7316888689];
[0.5940746930e-1, .7316888689]
slope(pa9,pa16)*slope(pa9,pd9);
-1.000000000
display({segp(pa9,pa16),segp(pa9,pd9)},scaling=constrained);
Download perp.mw
An angle that should be a right angle looks obtuse in the plot.  I used "scaling=constrained" in both the "display" command and the "segp" procedure.  I am using "polygonplot" to plot line segments (degenerate polygons) because the final plot will contain genuine polygons and this seemed like the easiest way to do it.  If this is a bad idea for some reason I can change it.
GS
according to this page  http://www.maplesoft.com/products/maple/new_features/codeeditor.aspx
it says "Maple 17 features a completely new editor for writing Maple code."  but for the last 15 minutes I've been looking in my Maple 17.02 for windows and not able to figure where this editor is or how to start it.
When I open Maple, I say File->New-> and nothing there for an editor.
I also looked in my Maple installation icons group, there is nothing there.
I also looked here http://www.maplesoft.com/support/help/Maple/view.aspx?path=updates/Maple17/CodeEditor
"Maple 17 features a completely new editor for writing Maple code.   The editor includes many features to make it easier to write, read, and debug Maple code, such as syntax highlighting, bracket matching, command completion, and automatic indenting. The new editor is available for managing startup code, inline code edit regions, and code attached to embedded components."
but again, does not say anything about how to START it ? Or is this editor a separate apps I need to buy?
x11 = [0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2];
y11 = [ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748];
z11 = [ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475];
filename = 'C:\Users\Hello\Desktop\testnew51.gif';
k = 10;
for n=1:length(x11)
plot3(x11(1:n),y11(1:n), z11(1:n));
%axis equal;
%axis([0,max(x11),0,max(y11)+10]);
xlabel('x (ft)');
ylabel('y11 (ft)');
title('Projectile Trajectory');
M(n)=getframe;
im = frame2im(M(n));
[imind,cm] = rgb2ind(im,256);
if n == 1;
imwrite(imind,cm,filename,'gif', 'Loopcount',inf);
imwrite(imind,cm,filename,'gif','WriteMode','append');
end;
end;
numtimes=3;
fps=1;
movie(M,numtimes,fps);
when i magnify the diagram in matlab, it is not a triangle, the diagram is changed,
would like to draw this and animate this in maple to see whether maple has this problem
x11 := Vector([0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]):
y11 := Vector([ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]):
z11 := Vector([ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]):
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t) + k4*u(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t) + k8*u(t);
c1 := Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t) + k12*u(t);
d1 := Diff(u(t), t) = 0;
ICS:=x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1];
sol:=dsolve({a1,b1,c1,d1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
ans:=proc(p1,p2,p3) sol(parameters=[a1=p1,b1=p2,c1=p3]); end proc:
FitParams:=Statistics:-NonlinearFit(ans, x11, y11, z11, x1, y1, z1, initialvalues=<150e-9>, output=parametervalues);
Error, (in Statistics:-NonlinearFit) initial values Vector has incorrect dimension
sol:=dsolve({a1,b1,c1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
Error, (in DEtools/convertsys) the ODE system does not contain derivatives of the unknown function u
with(Optimization):
with(Statistics):
with(DEtools):
x11 := <0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2>;
y11 := <-21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748>;
z11 := <1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475>;
ICS:=[x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]];
N := Dimension(x11)-1:
sys1 := [Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t)];
SS := proc(k1,k2,k3,k5,k6,k7,k9,k10,k11)
local F, V;
if not type([k1,k2,k3,k5,k6,k7,k9,k10,k11],[numeric,numeric,numeric,numeric,numeric,numeric,numeric,numeric,numeric]) then return 'SS'(k1,k2,k3,k5,k6,k7,k9,k10,k11);
elif k1<0 or k2<0 or k3<0 or k5<0 or k6<0 or k7<0 or k9<0 or k10<0 or k11<0 then return 1e100;
F := dsolve(eval({Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t),x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]},{:-k1=k1,:-k2=k2,:-k3=k3,:-k5=k5,:-k6=k6,:-k7=k7,:-k9=k9,:-k10=k10,:-k11=k11}), [x1(t),y1(t),z1(t)], numeric, output=Array([seq(k,k=0..N)]));
V := convert(Column(F[2,1],2),Vector);
Norm(V-x11,2);
Norm(V-y11,2);
Norm(V-z11,2);
params := NLPSolve(SS(k1,k2,k3,k5,k6,k7,k9,k10,k11), method=nonlinearsimplex, initialpoint=[k1=.1, k2=.1, k3=.1, k5=.1, k6=.1, k7=.1, k9=.1, k10=.1, k11=.1],evaluationlimit=200):
Warning, limiting number of function evaluations reached
reference from
http://www.maplesoft.com/applications/view.aspx?SID=1667
when debug
k1=.1; k2=.1; k3=.1; k5=.1; k6=.1; k7=.1; k9=.1; k10=.1; k11=.1;
F := dsolve({Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t),x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]}, [x1(t),y1(t),z1(t)], numeric, output=Array([seq(k,k=0..N)]));
Warning, The use of global variables in numerical ODE problems is deprecated, and will be removed in a future release. Use the 'parameters' argument instead (see ?dsolve,numeric,parameters)
Error, (in dsolve/numeric) Array/array solutions cannot be obtained for ODE containing unassigned global variables {k1, k10, k11, k2, k3, k5, k6, k7, k9}
solL:=dsolve({a1,b1,c1,d1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
ans:=proc(p1,p2,p3) solL(parameters=[a1=p1,b1=p2,c1=p3]); end proc:
FitParams:=Statistics:-NonlinearFit(ans, x11, y11, z11, x1, y1, z1);
Error, (in Statistics:-NonlinearFit) unexpected parameters: Vector(27, {(1) = 1549.88755331800, (2) = -329.861725802688, (3) = 8.54200301129155, (4) = -283.381775745327, (5) = -54.5469129127573, (6) = 1875.94875597129, (7) = -16.2230517860850, (8) = 6084.82381954832, (9) = 1146.15489803104, (10) = -456.460512914647, (11) = 104.533252701641, (12) = 16.3998365630734, (13) = 11.5710907832054, (14) = -175.370276462696, (15) = 33.8045539958636, (16) = 2029.50029336951, (17) = 1387.92643570857, (18) = 9.54717543291120, (19) = -1999.09590358328, (20) = 29.7628085078953, (21) = 2582103.332, (22) = 57.7969622731082, (23) = -6.42551196941394, (24) = -...
So I am working on doing some trajectory simulations in Maple using standard Newton's Laws, some force expressions, and initial conditions.
Anyway, the numerical solution works fine if I let the initial conditions I specified (for z=-1) be actually for z=-0.9. To illustrate, when I give an initial condition like this:
x(-1) = x_0, D(x)(-1) = xd_0, Vz(-1) = v_0
the results don't make any sense. However, when using the same x_0, xd_0, and v_0 and I give initial conditions like this:
x(-.9) = x_0, D(x)(-.9) = xd_0, Vz(-0.9) = v_0,
the solutions at least make a bit of sense.
What's weird is that, when I let z -> 0.93 or so, the solution changes discontinuously. And this shouldn't happen. The initial conditions were calculated for and should work for z = -1. I don't understand why they aren't.
Here is my Maple document. ics1 are the problem.
dsolve_field_traject.mw
Do you guys have any idea what could be going on?
Hello, everyone!
Last week I’ve encountered problems with integration of Maple 17 in Microsoft Office Excel 2013. The Maplesoft note on the point (http://www.maplesoft.com/support/faqs/detail.aspx?sid=32651) offers some ways of fixing it up, though I’ve run all of them the problem is the same:
While the connection is established, after entering the formula “=Maple(“x+x”)”, the Excel returns “Critical Error in Formula”
Before contacting the Maplesoft Technical Support, I want to ask here whether someone had the same case and managed to solve it.
Many thanks in advance.
the question is as follow:
1)receive two integers p and q
2)declare two local p1 and q1 and give them intial values and q
3)check if p o q are equal or less to zero print works only with positive integers
4)while p1 not equal to q1 then p1-a1 otherwise q1-p1
5)whenever p1=q1 we have the GCD
note:must use procedure and call it for different values of p and q after the procedure is written
-by following the instruction above this is what i got
GCD:=proc(p,q)
local p1,q1;
p1:=p;
q1:=q;
if p<=0 OR Q<=0 then 'works only with positive integers'
else while p1<>q1 do if q1<p1 then p1-q1 else q1-p1
but when I call two integers eg:p=2, q=6 -> GCD(2,6) maple just freeze...evaluating....forever. is it because i got the procedure wrong etc? it would be helpful if anyone can help me with this. thanks
A square has 36 sub-squares in it. How to Number each sub squares from 1 to 36, to make the sum of vertical, the sum of horizontal, and the sum of cross line are the same .Describe in general if possible.
Bonjour
Comment se calcul le résidue d'une fonction f(x,y) ?
Si par exemple f(x,y)=1/x+1/y+5/(x*y), alors le residue de f en (0,0) est défini comme étant (1/2*Pi)^2*int(f(x,y)) avec intégrale est sur une sphère qui contient l'origine.
Est ce qu'il est égal au coefficient 5 de 1/(x*y) dans le developpement de laurent en deux variables ??
Merci d'avance,
Gérard.
n := 31;
h := 0;
c1 := Array(1 .. 100);
c2 := Array(1 .. 100);
c3 := Array(1 .. 100);
for tt from 0 to n-4 do
c1[tt+1] := ...
c2[tt+1] := ...
c3[tt+1] := ...
od;
plot3d([c1[x],c2[x],c3[x]], x=1..27, y=1..27);
Does N variables caylay table have N permutation group so that can generate N functions?
for exmaple 3 variables cayley table have 3 permutation group, for 1, it has a permutation group , for 2 has a permutation group etc.
then does it mean that it has 3 functions, do it need to composite 3 functions in order to get a function belong to this cayley table?
1 1 1
1 2 2
1 2 3
Hello, everyone!
Last day I’ve discovered a strange behavior of the “optimization” tool:
Mostly it copes with the task – but there are cases (the data are the same) when the tool doesn’t return the opt. value: instead it returns the parameter name.
BUT if some of the previous calculations are re-evaluated (and the same input values are received) the “optimization” tools works quite well.
The question is: how to tackle the problem?
P.S. The way to force re-evaluation of previous functions in the body of this procedure (if the optimization failed) doesn’t help: it returns the optimizing parameter name once more.
Windows 8 (64-bit)
Maple 17.00
Hi, I am trying to plot these two curves:
I tried:
with(plots);  A := Array(1..2)  A[1] :=plot (0.199563349672261+0.0178636902277546 x^1.14406289706794-0.0182070811144750 x^(1.13867380551454),x=50..2050,  color=red);  A[2]  := plot(0.298910542599302+0.0117459591500434 x^1.00390277106937-0.0137065176395662 x^0.970667551759677, x = 50..2050, color = blue);  display (A);
and I got:
Error, (in plot) unexpected option: .298910542599302+0.117459591500434e-1*x^1.00390277106937-0.137065176395662e-1*x^.970667551759677
so I tried
so I am not sure how I would graph these two functions...
First 289 290 291 292 293 294 295 Last Page 291 of 371
