Find a(n)of sequence:5, 7, 7, 2, 1, 5, 6, 6, 4, ...............
I have a system of PDEs
restart:with(PDEtools):with(plots,implicitplot):
Pr:=1:A:=1:lambda:=1:Omega:=1:epsilon:=1:C1:=1:N:=5:b:=1:fw:=1:a:=1:
Eq1:=diff(f(eta,tau),eta,eta,eta)-diff(theta(eta,tau),eta)*diff(f(eta,tau),eta,eta)+
f(eta,tau)*diff(f(eta,tau),eta,eta)-(diff(f(eta,tau),eta))^2-(1+A*(1-theta(eta,tau)))*diff(f(eta,tau),eta)
+lambda*(1+epsilon*cos(Pi*tau))*theta(eta,tau)-Omega*diff(diff(f(eta,tau),tau),eta);
I am dealing with an Eigen value problem, the equations are
restart:with(plots):
Eq1:=diff(f(y),y$2)-a^2*f(y)+a*(h(y)+R*q(y))=0;
Eq2:=diff(h(y),y$2)-a^2*h(y)+a*Z*y*f(y)=0;
Eq3:=diff(q(y),y$2)-a^2*q(y)+a*f(y)=0;
ic:=f(0)=0,f(1)=0,D(h)(0)=0,q(0)=0,h(1)=0,q(1)=0;
where f,h,q are Eigen functions, R, Z are dimensionless...
I am using Maple 13, I am working on Optimtimization package (worksheet mode) in command-line
LPSolve(-x-y, {y <= -5*x+2, y <= 3*x+1/2}, assume = nonnegative)
I have equations in microsoft word file and I have to copy the...
I saw a question on a different forum related to the stability of the numerical solution of a coupled ode system. The original question was about the convergence of the far field condition (infinity) for some specific values of the different parameters involved.  For the details please see the link below
http://mathematica...
Hi,I want to compute some expressions as binomial(d-2,r)*binomial(v-d-1,r-1) and something like that. In the process, there are many such expressions but with differernt parameters. Some of them can pass successfully, but some of them will generate a mistake. That is: Error, (in gcd/LinZip) variable in input expression must be in either the evaluate or retained variables.Could you please what happened to it? Thanks.
 I wish to solve nonlinear PDE equation numerically  in u & v coordinate . where u=t-x, v=t+x . we note x=(v-u)/2..
pde := diff(u(t,x),t,t) - diff(u(t,x),x,x) + x^2*u(t,x);
 We need only initial condition let f(u)=sech(u) & g(v)=sech(v). So u((i,0)=f(ih), u(0,j)=g(jh)
we summe step size of time j =  step size of spatial i .
the stencil we use ,
Bonjour,
Je cherche une méthode éfficace pour résoudre le système d'équations polynomiales suivant :
with(SolveTools):
> PolynomialSystem({f0,f1,f2,f3,f4,f5,f6},{alpha,lambda,mu,nu});
# avec les fi ci-dessous :
f0:= (1+mu+nu+lambda)*alpha^3*(1+mu+nu)*(mu^2-2*mu*alpha+2*nu*alpha*mu+2*mu-2*nu*alpha+2*nu*alpha^2+alpha^2-2*alpha+1+alpha^2*nu^2)*(-lambda*alpha^3+3*mu*nu+alpha^2*lambda-lambda+3*nu*mu^2+3*nu*mu^2*lambda+l...
I want to use Maple (dsolve command) to solve this problem, how do I input the command? Part (a) is enought.
I have tried the command, but Maple says "Warning, for {u(t)} arbitrary the system is inconsistent".
Thank you very much for your help.
Hello everyone!
I am very new to the maplesoft community but am very impressed with everything I have learned in the last few days.  I'm having an issue using force probes on a double wishbone suspension that I'm hoping someone can help me with.  I am trying to measure the forces in each link to gather quantitative solutions for the forces at the chassis connection points.  However, I keep getting one of the links measuring no value at all.  The...
Hello All
I looking to write Maple code procedure to solve this equation
with(PDEtools):
pde := diff(psi(t,x),t,t) - diff(psi(t,x),x,x) + V(x)*psi(t,x);
where V(x)->x^2;
I have to use this stencil
u[i+1,j]=-u[i-1,j1]+(1-1/8*h^2*v[i-1])*u[i,j-1]+(1-1/8*h^2*v[i+1])*u[i,j+1]; where i is spatial step and j is time step
int(y^2/2 - lambda*(u*diff(y,t)-diff(u,t)-a), t);
with(Physics):
diff(y(t)^2/2 - lambda(t)*(u(t)*diff(y(t),t)-diff(u(t),t)-a), u(t)); # u -> something
diff(lambda(t),t) disappear
should be
diff(lambda(t),t)+Physics[`*`](lambda(t), diff(y(t), t))
diff(y(t)^2/2 - lambda(t)*(u(t)*diff(y(t),t)-diff(u(t),t)-a), y(t)); # y -> something
u*diff(lambda(t...
Hi, I want to know how to change the rectangular form to polar form, and how to manipulate the operation of them, for example the picture below. The angle of polar form contain radian and degree, how to represent them in Maple?Thank you.
First 292 293 294 295 296 297 298 Last Page 294 of 371
