In multibodies system, there exists many kind of coordinates namely joint (or relative) coordinates and absolute coordinates. Moreover, for the joint (or relative) coordinates, it is possible to choose strict, simplified, or complete coordinates.
For the moment, i only find in the tutorials system modeled with complete joint (or relative) coordinates. I will give the example of a 4 bars mechanism. The kinematic scheme with this complete joint coordinates is the following :
How do i "show region ranges" on mac. on windows you just press F9 but you cant on mac??
Let X be the random variable uniformly distributed in the disk centered at the origin O(0,0) with radius 1 and let Y be the random variable uniformly distributed in the square having its vertices A(6,-1), B(9,-2), C(8,-5), and E(5,-4). What is the PDF of the distance between X and Y? Is it possible to find that with Maple? The similar question in three dimensions, replacing a square by a cube and a disk by a solid sphere.
Aslam-u-Alikum... How are you? Hope you will be fine. I want to determine the eigenvalues of differential equation in Maple kindly help me... Problem.docx
i interpolate a function in some knots by BSplineCurve, the resulting function is parametric.
how i can convert this parametric function to a function?
thanks.
MapleSim already developed a Template for Linearization.
The code behind "Linearize" button in the Linearization template is as follows:
"MapleSim:-Templates:-Linearization:-Linearize();"
The results, namely A,B,C,D matrices in the state-space presentation, are shown in the text area "mcEqs".
How can I save these matrices to some variables for further analysis?
In addition, without the linearization template,
What I'm looking for is a good text for my Embedded Components interactive mathematical designs. I have several books of Maple but speak little of Embedded Components. MapleCloud community hope I post up a book. It is very poor on "The Maple Help System" so I need a good text.
how to use c# check whether maple is installed
I'm a new user of Maple. The pdsolve in Maple is quite an important function for me.
I can see how it works for PDES in the help:
http://www.maplesoft.com/support/help/Maple/view.aspx?path=pdsolve/numeric
However, I'm wondering if I could get the euqations of the discreted PDES forms (equations) rather than just the results, please?
Thanks in advance!
1.
Actually the goal is to output a numeric to c# variable after run a procedure
i use EvalMapleStatement to run the procedure body and then
use another EvalMapleStatement to call this procedure
it do not know the procedure or variable in last EvalMapleStatement
2.
then i think whether i can run it once with one EvalMapleStatment
however i got maple warning about declared local variables to procedure
so, the output...
i copy the example to run in a new project, it can run successfully
however, after copy part of code such as static class MapleEngine into my old console program, it return error unable to find maplec.dll when run at StartMaple
this old project is created with Visual Studio 2008 and migrated to 2010
then i do backward, i succeed when i copy old console code to new project which can run maple
this project is newly created in Visual Studio 2010
Hi, I’ve recently begun using Maple 16. I just discovered a problem when trying to open my saved files. I can’t open them directly form the folder where they are saved, I get a Message saying: File XXX.mw could not be found, please select another file. I can accsess the same file through the recent files form within the application.
It is not a shortcut, but the original file I'm trying to open.
If it matters, I'm using windows 8
I'm looking for any procedure to calculate orthogonal latin squares. I found this:
rOrt := proc (A, B, n)
local freq, i, j;
freq := Array(0 .. n^2-1);
for i to n do
for j to n do
freq[A[i][j]+n*B[i][j]] := 1
freq := convert(freq, list);
return numboccur(freq, 1)
But I don't know what I now have to write to see result, for example for n=3?
Aslam-ul-Alikum I need some help urgently. I want to compare the coefficients of like powers of Y_1*Y_2, please help how i compare it in maple
First 294 295 296 297 298 299 300 Last Page 296 of 371
