Hi everybody,
I already discussed my tasks with @Preben Alsholm. Therefore, I decided to share it with you and try to finalize solution.
Actually, I want to calculate heat dynamics transfer between one, two or more rooms. Hence, I used heat balance approach to set the system of differential equations:
In the following code, why is B returned unevaluated?
A:= a:  B:= 2:
F:= _a-> eval(`if`(A,B,C), a= _a):
F(true);
                               B
eval(B);
The "ExcelTools" seems can work based on Excel 2003 format,which can only support 2^16 rows.Excel 2010 format cantains much more rows and columns. So I want to know when maple can support Excel 2010?
Yesterday I’ve updated to the new Version 17.01 and now I’ve the problem that I cannot enter  ‚}‘ and another problem is an exponent e. g. x^2. To enter it I have to write x^22. The first number is not shown in the worksheet.
I hope someone can help me to solve this problem.
Are you in or near Berkeley, California?
Are you experienced with Maplesoft for academics?
Can you train a student to use it with the tutorials and your own knowledge?
This student is located at University of California, Berkeley and needs an immediate hands on private trainer.
He will be taking Calculus 1A next semester and needs to learn to use this program this summer.
He is a student who uses an eye control computer without the use of his hands and needs this
     I'm computing some difficult integrals, involving Spherical Harmonics. I've proved that the answer must be a real number, and yet Maple returns a complex number. Also Mathematica returns purely real numbers, so I wonder if there is a bug in Maple. I found if I break the integrand into real and imaginary parts, and add them I get the right answer...usually.  Anyway's here's the code and the proof, I suspect they could be a bug...
@acer My question is about highly oscillatory integral.I wanna integrate
int(int(f(x,y)*exp(i*w*g(x,y),y=0..1),x=0..1)) which is higly oscillatory integral in a triangle with vertices  (0,0),(1,0),(1,1) and with g(x,y)=x^2+y^2. Since g(x,y) has stationary  point at (0,0), I have to interpolate f(x,y) except (0,0) but also quite close to (0,0). The problem is that since...
hello, i'm using maple, in order to draw a graphic in wich, different functions are plotted,
these functions came from one with 4 variables, wich represents losses in a phenomenon (extraction) depending on diffenrent variables, so my objective is to varry only one parameter and then draw its curve, and this for each parameter ; i had 4 functions.
f1:=plot((n-1)/(-1+n*10^(6.77*((n-1)/n))), n=1.0537..1.2688):
f2:=plot(0.2365/(-1+1.2365*10^(0.0155*O)), O=76.42..99.92):...
I installed Maple 17 on Slackware Linux 14.0 today and everything seems to work except that when I want to search for something through Maple Help my mouse doesn't seem to activate the text search field. Is this happening with anyone else or is this just because I am running under Slackware?
Jovan
hi
I have some equations like these:
i have 6 non linear diff equation. for the quad copter i want to get its state space representation and its done in a master  but they didnot say how they did it ???
soo any one can help me?
In MapleSim, it is possible to constrain a rigid body in a multibody system to an arbitrary constraint?
Similarly to how a mass at the end of a simple pendulum can only move along a circle defined by the length of the pendulum, I was hoping to constrain one to a shape like an ellipse or sine wave.  I could then give it initial velocities and see how it would move along the shape over time.
I'd like to be able to define this constraint with an equation. ...
I am supposed to adjust the code my teacher gave us for a project. The only problem is I dont know anything about maple or much about what I am supposed to do. I tried copying and pasting the code but I couldn't.
The assignment says to adjust the code to incorporate variable window size. There is a place in the code where it says insert code here and the teacher said it shouldn't need more than like 8 lines of code.
If anybody thinks they they can help I will be more then happy to forward you the email.
How does one take the gradient of a expression involving sums in terms of a set of indexed variables.
I am trying to find the maxima for the satisfaction for a public good from a tax code. The sum represents the total revenue. The tax code is defined as a piecewise linear function of income and indexed variables. The indexed variables represent the points of the kinks and the marginal tax rate for each income bracket. (The set of indexed variables will vary...
The general formula of GHR (Gazis-Herman-Rothery), the most well known car following model, is given by
an - acceleration of vehicle n implemented at time t
v - speed of follower vehicle
deltax and deltav - relative spacing and speeds respectively between follower and leader vehicle at a
First 297 298 299 300 301 302 303 Last Page 299 of 371
