Hey Guys
I`m looking for a maplet that shuts down the entire program. A maplet that interrups the following steps and goes back to the beginning of the program.
Thanks for answers
Andrea
Hy,
I'm trying to display a list value in a maplet. But I can only manage to get textboxes, checkboxes and textfields. I know that in textfields I can display the evaluation of a function, but I tried many different ways and I still don't get the desired result.
I designed a maplet with a button and 6 rows with a checkbox at the end of each row. When clicking the button I would like that the values of a list ("lstx", 6 values) are displayed in the 6 rows. Can you help me? thanx!!
I am dealing with Fourier series, I have series of sin(nw) + cos (nw) for different  value of n . How can I put all sin together and all cos together equal to zero, when n=1000 for example.
I created a Maplet that calculates ODE (Ordinary Differential Equations) however I would like to create a button that can allow printing on paper
I am using an old package, Janet, I got from http://wwwb.math.rwth-aachen.de/Janet/janet.html with Maple 16.
I changed the libname to point to the directory where the package files are.
Few days ago I was able to call help(Janet); without any problems but now everytime I try to call help(Janet)
Maple front-end loses connection to the ihe Maple kernel.
The package loads fine...
I am trying to call the maple function fsolve in the matlab. I have used maple('fsolve(x^2-4)'). It worked.
Now in the matlab code I have defined another variable. let us say a = 10.  Now I am trying to call the fsolve as follows.
maple('fsolve(a*x^2-4)')
I ended up with the following error.
Error, (in fsolve) number of equations, 1, does not match number of variables, 2
Hi...
I need to solve the pde
eq := diff(diff(V(y, t), y, y)-alpha^2*V(y, t), t) = -I*alpha*U(y)*(diff(V(y, t), y, y)-alpha^2*V(y, t))-I*alpha*(diff(U(y), y, y))*V(y, t)-(diff(V(y, t), y, y))+alpha^2*V(y, t)
with U(y) as a known function
and boundary conditions as
bcs := {V(-1, t) = 0, V(1, t) = 0, (D[1](V))(-1, t) = 0, (D[1](V))(1, t) = 0}
and initial condition as
V(y,0)=phi(y);
both of phi(y) and U(y) can...
     Theres seems to be an error in the SphericalY function when the input is SphericalY( l, -l, theta, phi)
assume(phi, real):assume(theta, real):
for l from 1 to 2 do
   m:=-l;
   s:=SphericalY(l,m,theta, phi);
   f:=s*conjugate(s);
   plot3d(f, phi=0..2*Pi,theta=0..Pi,coords=spherical);#sphereplot(f, phi = 0 .. 2*Pi, theta = 0 ..Pi,  style...
Is there a chance to produce right looking pdf via LateX export using table inside a Maple worsheet?
Could you tip somone?
I encolose:
zip:
(tex file with two eps + pdf file without reqiured table structure)
Tex_export.zip
source workseet done with Maple 17
How to transform between permutation group and linear transformation matrix in maple
is there a command like gap
gap> i:=IsomorphismPermGroup(G);
to find permutation group which has isomorphism
Hellow,
 any one know how to solve the second order differential equation using finite element method (Using Linear shape functions)
if you have four teams a b c and d playing in a tournament and teams a and d have not played each other but all other teams have played .. typing this from my phone but its not too friendly ...  soccer scores how would you determine who would win and by what score
I'm trying to solve a pretty complex system of equations (a 3rd order DAE with 61 equations) using the MEBDFI numeric solver but I'm always getting the following error.
error in dsolve/dae/numeric/sm_intersect. numeric exception, division by zero
I have tried to find out what the sm_interesect command is but I haven't had luck neither in Internet nor in Maple help. I have looked for similar posts...
https://skydrive.live.com/redir?resid=E0ED7271C68BE47C!358
1/x!*subs(z=0,Diff(g(z)^x, x$(x-1))) = n*x
1/x!*subs(z=0,Diff(g(z)^x, z$(x-1))) = n*x
how to solve for g(z) ?
as i do not know what do this respect to which variable from a book. so i capture this diagram.
hope that can solve it
First 298 299 300 301 302 303 304 Last Page 300 of 371
