I've a problem with the buttons. It's not a problem to make a line break, but if I reload or change the text into my button (while the program ist running) maple/maplets ignores all line breaks.
Here is an small example (maybe not the best):
with(StringTools):
with(Maplets[Elements]): ToGreen := proc()
Maplets:-Tools:-Set(B(caption) = "blue\nhallo");
maplet := Maplet([
hallo guys,
my goal: i wanna create some buttons and scale and position them individualy. like i can do in any visual IDE.
Could some one help me with some example code, showing how to create a button on a specific position, maybe load a picture on the button if it gets pressed?
thx in advance
Are There  options to solve this problem?
I solved a PDE system and got module() export plot,plot3d,animate,value,settings; ... end module (Got ui(x,t) and ur(x,t))
And after it I try to solve the task
Xs := [0, .175, .789, 1.818, 3.287, 5.183];
n := 1;
interface(prettyprint = 1);
for t1 from 0 by 50 to 50 do
k1 := sol:-value(t1, output = listprocedure);
maple 17 does not calculate the definite integral  (?):
f(x):=sin(sin(x)); int(f(x), x = 0 .. 1).
Trying evalf leads to the correct  numerical result.
for my mechanical engineering studies we have to optimize an engine during a workshop. Therefore we have to use a numerical dsolve to solve the equation of motion. I have to get the maximum bearing reaction for a constant rpm. In order to get this I can't think of anything else but use the dsolve solution and use it in maximize.
ysk_2 := t -> -rc*cos(phi(t))-lp*cos(alpha(t))-lkb-y(t);
ysp_2 := t -> -rc*cos(phi(t))-lp2*cos(alpha(t))-y(t);
i have 12 second order non linear coupled partial differential equations (Euler-Lagrange Equations) in 12 variables {u1a(x1+l/2),u2a(x1+l/2),u3a(x1+l/2),theta1a(x1+l/2),theta2a(x1+l/2),theta3a(x1+l/2), u1p(x1,x2),u2p(x1,x2),u3p(x1,x2),theta1p(x1,x2),theta2p,theta3p}
also there are 17 lagrange multipliers in these equations which are also to be solved, using 17 constraints equations.
along with 48 boundary conditions. These have emerged out of variational formulations
I've been trying to manipulate the equations of a mechanism that I've exported from MapleSIM.  The system equations contain 4 differential ordinary equations, and 6 algebraic equations.  In MapleSIM it simulates fine, but I'm having problems simulating it in maple alone (without multibody exports).
I've tried solving the initial value problem by replacing all the time dependant variables with constants, (and as this is a dynamics problem) I supplied...
I need help about this equation.
what is the maple coding for the function, f(t)=-1-(epsilon)v(t) with the initial condition v(0)=1 for the 10 term?
i had did it but i don't know how to come up with the expansion series in the maple coding
Hi Everyone:)
I'm doing a mini project at the moment and I'm pretty stuck with how to go about something on Maple...
My aim is to get the catenoid from an initial cylinder by use of an iterative method.
To find the minimal surface r=g(θ,z) - the catenoid - I want to minimise the Dirichlet integral (in cylindrical polar coordinates)
assume i have a number 26 and assume a prime number not greater than a value, let it be 5
then it is like a division and factor into 5^2 + 1
if prime number set to 17, then it will output 17 + 3^2,
the output will be in terms of prime number, such as  a^3+b^2 + c  where a and b are prime number
it should start from greatest prime number given as a parameter in function
Good morning,
my name is Agnieszka Dymek, I'm a Polish student and I have a question or request. I'm looking for a quite difficult, interesting problems to solve it on Maple. I need this for presentation on lecture, for my friends - it have to be exercies with application different, special function of Maple programme. I was looking for it on Polish websites and I didn't find anything interesting and complicated.
If You have something in database or somewhere,...
I have a large sheet containing about three proc(). Four symbolic matrices of though small order but with complex values are being imported. There are also some other statements other than mentioned above. I have writing them in text mode.
What could be the possible reasons for connnection lost with maple though I have 4 GB of ram.
Thankyou!!!
Hello!!
I have modeled a 3DOF manipulator with crank-arm type actuators in maplesim!!!
It simulates the model... but when I "Create Attachement>Equations" and when I click on "load selected subsystem"... it starts evaluating but never gives me equation... I have waited for almost 2 hours but no luck!!!!
Any idea what should I do to get equations for this model???
P.s. I have attached the moel!!!
First 302 303 304 305 306 307 308 Last Page 304 of 371
