     So I'm trying to animate a ball moving around in a moving circle. I can do a sequence of points, and a sequence of static circles which works okay but I'd like a continuous animation. Here is the points where the ball hits the circle (x,y) position and the times (t).  and the animation of the circle
with(plots);
x1 := [.9, -0.6953537244e-1, .5084436548, .5084436548, -.5253004431, -.4186356935,
     -.8180728424, -.8180728424,...
Here is , seemingly simple task:
In the Euclidean plane are given two sets, each with 4 points. It is known that all possible pairwise distances between the points of the first set coincide with all possible pairwise distances between the points of the second set, ie we obtain two sets of numbers, in each of which six numbers. Of course, the numbers in each numeric set can be repeated (such sets are called multisets).  Can we say that there is an isometry of...
Having read the above I decided to try it on a substitution problem I had last year on a set of equations. Work sheet containe an example. I successifuly applied algsubs to the problem. It can be slow and their is no easy way I see to know when the substitution is complete. so what I did go round the loop 2, 3, 4, 5 times. Crude!
Decided to try "side relations" with simplify here but it comes out with a totally different answer (not correct).
Could somebody explain why?
I'm not sure this topic has ever come up.  I cannot find a way to output strikethrough characters.  Underline and subscript will get you strikethrough characters.  Is there a way to produce strikethrough output?
Question.doc
Can you make geometric figures that hold a particular area within a given perimeter of 12 matches
My attempt was to start at origin 0,0 and move up 1 unit (a,b) and then 1 unit up or to the right (c,d) etc ... until you enclose the required area (defined by linear spline) s.t. perimeter =12. but it doesn't really work
I recently get a new macbook pro with retina display. Unfortunately Maple 16 seems to be not retina ready. Searching the net I found a tool called retinizer. Using it Maple 16 seems to be displaying a little better, but still the outputs of calculations looks blured. however, whenever certain texts are selected, the whole Maple window display becomes very sharp, so I guess Maple is somehow retina ready but this functionality is disabled by default. Checking the "Get Info" window...
I've several versions behind but I getting a strange behavior. I created an assignment using the eco0 question bank. Later this assignment was passed to a class a semester later. The question bank eco0 was updated. As the instructor, using the review button on the assignment shows the new version of the question bank. As a student, the assignments are getting the old question bank question.  The students didn't start the assignment until after the questionbank change.(I think I'm using version 4.0.)
I need the button that will change the content (list) of a ListBox. When I create such Maplet, ListBox behaves very strange! The ListBox sometimes shows the list after the button click, but sometimes the list disappears.
The code below reproduces this strange behavior. Just click the button several times.
with(Maplets[Elements]):
getObjects := proc()
local testList;
use Maplets:-Tools in
testList := ["YAHOO", "YAHOO", "YAHOO", "YAHOO", "YAHOO", "YAHOO"];...
i'am using maplet shortcut in maple
but it did not show in table form, it only gives final answer.
use DocumentTools in
with(LinearAlgebra):with(VectorCalculus):with(linalg):
# F1,F2,F3 are my equations
F1:=Do(%f1);
F2:=Do(%f2);
F3:=Do(%f3);
# these is my initial point
X1:=Do(%x1);
X2:=Do(%x2);
X3:=Do(%x3);
# the whole operation
F := Matrix(1 .. 3, 1 .. 1, [[F1], [F2], [F3]]);
J := Jacobian([F1, F2, F3], [x1, x2, x3]);
How to solve attached equation in Maple?
Is there a possiblity to solve using units?
wzel
PS
Solution was done in Mathcad
I am new to Maple. I need to measure the time complexity of computing the GCD for a set of 1024-bit numbers. I have an equation as:
O(nm × log^2 m × log log m). Where n is the number of bits in the numbers in my set (say, 1024-bit) and m is the number of times I am going to do a computation. How can I perform this computation in Maple ?
helo
i want an exaact answer(numeral) of an equation but I can't maple answer a realation that include sin,cos,root,z how can i simplify that to a number
Is there a way of importing data in NetCDF format into Maple 15? This format is very widely used in atmospheric sciences as a data standard for experimental data such as satellite-derived data.
if rsolve is solving difference equation for L(x) in summation(L*z^n, n=0..infinity)
can i use double encapsulation to solve for summation(L*z^n/n!, n=0..finity)
step 1 use rsolved result of a given classic difference equation times z^n/n! * t^n
step 2 then summation step 1 and use celine method to change into difference equation again
step 3 solve this new difference equation
then i imagine L should be L*z^n/n!
but i am not sure...
with(SumTools):
an := -n+L;
bn := -x+L;
gen := Summation(Product(an, L=0..k-1)*Product(bn, L=0..k-1)/k!*(-1/a)^k, k=0..infinity);
genfun1 := subs(a=z,simplify(gen));
genfun2 := exp(z)*(1-(z/mu))^x;
correct is genfun2
but using famous hypergeom of charlier written in many books and papers, it can not summation to a correct generating function
First 306 307 308 309 310 311 312 Last Page 308 of 371
