I have been messing around with MapleSim for a while now, and I cannot find a good way to model something such as a spiderweb. I want to be able to model a spiderweb (using something like cables), and then measure the tension in the cables, and also vibrations as they travel through the cables. Is this something that I can accomplish using MapleSim? If so, what is the best way to approach this problem? Any suggestions or comments would be helpful. Thanks.
can i distrubute some random particle with an arbitrarity function in maple, for example p(r,theta,phi)=p0*sin(theta)/r, 0.01<r<1, 0< theta<pi, 0<phi< 2*pi. For such distribution we expect many particle in equator.
many thanks
After a few steps and derived out a formula include a hypergeometric expression
hypergeom(....)
in this hypergeometric expression, there are more than two parameters in maple for example
hypergeom(X,Y,Z...)
from some paper said G(z*q; q^f)
i am not familiar with hypergeometric series
how to substitute z*q and q^f into a formula include a hypergeometric expression.
I'm currently working on the modelling of a thermodynamic process.
Briefly, I cool down a solution (water + polymer) from -5°C to -15°C to induce a phase separation. At the end (and after removing of the water by lyophilisation) I obtain a porous sponge like material.
The process uses a home made cooling system which can be described like this:
- A Peltier module
- An aluminium layer recovered by teflon (And also a layer of ethanol)
Hi, there, maple built-in help just has an example of Brusselator model in 1D case. But how can I intepreter the diffusion terms that Brusselator has in 2D case? Could you please give me an example of the code to run Brusselator simulation in 2D case?
Brusselator model:
http://hopf.chem.brandeis.edu/yanglingfa/pattern/bruss/index.html
Kyle
Hi, i am trying to create a breakpoint on my worksheet. But i cannot press the debug current operation icon. Is there some other settings that i must press before using the button? Please help. Thanks.
Hi all. I am trying to use the Weyl character formula to evaluate some traces of Hecke operators on algebraic modular forms. This involves me having to substitute certain eigenvalues of 4x4 matrices into a polynomial of arbitrary degree (my choice).
I have created procedures that do this given the eigenvalues. Unfortunately I am having problems generating the eigenvalues.
The problem is that the matrices I am using are formed from products of matrices from two...
Hello every one,
I got an error while trying to solve numerically a nonlinear system of odes using
the dsolve command. This error is very common,
"Error, (in dsolve/numeric/bvp) initial Newton iteration is not converging".
I tried the different technique explained in
http://www.maplesoft.com/support/help/Maple/view...
restart:with(plots): a := 1; b := .5; d := 1; omega := .4; h1 := 1+a*cos(x); h2 := -d-b*cos(x+omega); F := Q-1-d; de:={alpha*(diff(f(y), y, y, y, y))+G*(diff(theta(y), y, y))+B*(diff(phi(y), y, y)) +6*beta*(diff(f(y), y, y))*(diff(f(y), y, y, y))^2+3*beta*(diff(f(y), y, y, y, y))* (diff(f(y), y, y))^2 = 0, diff(theta(y), y, y)+Nb*(diff(theta(y), y))*(diff(phi(y), y))+Nt*(diff(theta(y), y))^2 = 0' diff(phi(y), y, y)+Nb*(diff(theta(y), y, y))/Nt = 0, f(1+cos(x)) = (1/2)*Q-1, f(-1-.5*cos(x+.4...
This question was asked before but because of the curiosity, I
bring it in the light again. We have a system of odes
F := Q-1-d;
Find the definition Of the word juxtaposition in a dictionary and explain its meaning in the context of the tutorial?
I created a triangle whose length of the medians are integral numbers. Please comment to me about my code.
> resrart:
ListTools[Categorize]:
N:=5:
L:=[]:
for x1 from -N to N do
for y1 from x1 to N do
for z1 from y1 to N do
for x2 from -N to N do
for y2 from -N to N do
Hi people!
I'm experiencing lags of about 45 seconds on the interface when trying to manipulate the blocks of my model. MapleSim becomes totally unresponsible when, for example, I make a new connection. It just happens with this model.
Curiously, when I disable an specific connection, I can manipulate the model with reduced (but yet present) lags.
For instance, my processor is an Intel Core i5.
Could someone take a look at it? I will upload the model on demand.
Hi there!
Is there a way to implement a fixed delay (not the Padé approximation)? I'm using MapleSim 5.
I tried importing the Modelica's fixed delay block, but it seems that MapleSim doesn't support the implementation...
First 310 311 312 313 314 315 316 Last Page 312 of 371
