The model that i uploaded (EqQui.msim) has a component with severall output and 4 inputs, but 2 of the inputs (LgKph2o and Lgkpco2) depends on one of the outputs. The 2 interpolation tables transfor the output variable (temperature) in this two inputs. All components works fine independtly (first "model", the one on the top), but if i link the exit of both interpolation tables mapleSim say it cant solve a lot of variables.
I need program of multiple shooting method with maple or algorithm?
Thanks alot.
When I use ImportMatrix to import a MATLAB mat file, I get a list of names and values. Should I write a "for" loop to assign them in Maple or there is an easier way to do it?
I am working over F_p, where p is prime. When p = 2, the number of 2x2x2 arrays (aka hypermatrices or tensors) over this field is 2^(2*2*2) = 256. Of those 256 arrays, I only want the symmetric ones: that is, if x_{ijk} is the ijk-th element of the array X, then x_{ijk} = x_{ikj} = x_{jik} = x_{jki} = x_{kij} = x_{kji}. Is there a quick loop that does this?
how to solve this partial differential equation  :
d/dx[(1+e*T)dT/dx]+P*dT/dx-B*T=0
e ,p ,b are constants and t is temperature.
plz help in finding a solution for this differential...or the closest method to simplifying it...
Question 1. After googled, x*diff(F,t)+t*diff(F,x) for two variables, how about three variables or general ?
Question 2.
if deal with on variables case using the example in
http://demonstrations.wolfram.com/AFunctionInvariantUnderAGroupOfTransformations/
F := (x^2-x+1)^3/((x^2)*(x-1)^2)-y;
G:=y*diff(F,x)=0;
sol:=solve(G,y);
F(H)-F = 0
sol:=solve(F,x);
H := simplify(subs(y=F, sol[1]));
all above code can...
I need to get inverse kinematics model of a double inverted pendulum. I got a model but it gives error when I run. It seems to me that the inverse kinematics model is not quite right. If you are able to help me, I will be very pleased.DoublePendulumI.msim
Thanks for your help....
I would appreciate a hint why Maple 16 Classic under Win XP 32 bit crashes due to the following sequence of commands
> dir1:="C:\\Maple16\\P16\\test1\\";
> path:=cat("dir ",dir1);
> ssystem(path);
with the lasst ssystem command doing the crashing while the same sequence of commands under Maple 13 Classic does not: Instead, system returns to Maple 13 worksheet the content of the directory "dir1" as expected.
Is there another way to issue that ssystem command?
hello,
after defining N_1 N_2 and N_3 with long numbers, and defining M by N_1*N_2*N_3 i tried to step backwards.
By entering something like: M/N_1 (what is exactly like N_2*N_3) it does not show me full numbers, but instead 1/something*M.
After refreshing M and afterwards refreshing M/N_1 it totally worked out and showed me the product of N_2*N_3
Now my question is: how can i prevent this odd display format without refreshing everytime? (i tried...
similar to
http://www.singular.uni-kl.de/Manual/html/sing_951.htm
http://www.singular.uni-kl.de/Manual/html/sing_753.htm
i would like to find all modules in the complex
for example
0 -> A -> B -> C -> 0
would like to find B and C if know A
which book describe this algorithm for polynomial system
I have to design a wheeled mobile robot for my bachelor-thesis. the robot should be controlled in Simulink. Therefore, I have to use the Simulink Component Block Generator. Outputs are: yaw angle/rate, absolute position in x/z and its derivatives, wheel angle and its derivative,steering angle. Inputs are one torque for steering and one torque for actuatuating for each wheel. -->6 torques (3 wheels). When I click on the "Generate and Compile...
Dear All
I want to solve a set of two ordinary differential equations by means of Maple. I can not unfortunately perform it as a non-numeric method. It is worth mentioning that by the following commands, Maple returns a solution presented as a DESol form, which is not useful for me. Note that functions C2_U0[i](theta) and C2_V0[i](theta) are obtained in terms of  C1_U0[i](theta) and C1_V0[i](theta) by using boundary conditions bc1_U0[i] and bc1_V0[i...
How can we re-initialize a multi-body system, for example a three link pendulum, based on measurements obtained from various sensors? Can we generate a modelica custom component which has inputs from various sensors and the output is the re-initialized states for the multi-body system?
First 313 314 315 316 317 318 319 Last Page 315 of 371
