Heat equation
I want to parallel the following code.it is good that part1 solved by one thread and part2 solved by other thread.
please help me.it must be noted that part1 and part 2 are independent "at each" iteration.
dtheta[m](x):= theta[m-1](x)+phi[m-1](x);
dphi[m](x):= theta[m-1](x)-2*phi[m-1](x);
for i from 2 by 1 to 10 do;
# part1
theta[i](x):=subs(m=i,dtheta[m](x)):
theta[i](x):=value(%):
eval(-theta[i](x),x=0);
i want to write a program to simulate a walk of a drunken sailor who walks out of a bar at the centre of a city. the city has a regular pattern of 24\24 square blocks. the sailor doesnt know where he is going and how to exist teh city. the question is how many blocks will he have to walk to exit the city?
let him start at the centre of the city and assume that he exists the city when he reaches either north, east, south or western borders. it can happen that he wlks...
Consider a simple polymer , which consist of long chains of simple molecules attached to each other, e.g:
....-CH2-CH2-CH2-...
If the interaction energy between consecutive sections ca be ignored or is low enough, the chain can be bend around at varios places to form varios configurations. One can start by  fixing the first section to a particular co-ordinate and then add additional components by use of random walk with...
While I am getting more and more comfortable with the document mode, I have some questions regarding the document block feature:
- What is a document block good for anyway?
- Why not have the whole document in one block?
- Can one join two document blocks?
- when do I "remove the document block"
- How can I make sure that say an informational 2-D math expression inside a document block never gets executed?
-- Can I still...
Hello!  I am writing a Grassmann multiplication operator:
define('`&*`', 'multilinear', 'flat', 'identity' = 1)
So that it automatically constructs operators like &*(arg1, arg2,arg3 ...)
Now I want to teach Maple how to transforms &* with ARBITRARY number of arguments.
How to create a pattern for that?  (to be added to "define")
Can anyone explain these results?  I m trying to check on a more complicated form of this expression, but cannot proceed without understanding what is occurring in this case.
Does anyone know if you can schedual a task in maple ie at 12:00 add a number
to a matrix in a worksheet (Just an simple example to see if it is working)
In windows you can use the "Task Scheduler" to automate stuff that you need to repeat.
Also I dont want the actuall Maple software to actually launch at 12:00, I want everything to happend
in the background.
If you put the maple commands in the "start up code region" of the worksheet I guess it
what should i do to get display buttons in maplet as an input in TextField? so that everytime i click on a button in maplet, the value of that button will show up in TextField as an input, such as if i click on a  Button("1") , the number 1 will show up in the TextField. thanks in advance.
i am solving for a system of df eq's, but the eq's have these little tricky integrals inside them.....so it either retards operation or no solutoin can be found...They look like...
B_12:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(3/2)) * ((a_3^2+u)) )):
B_122:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(5/2)) * ((a_3^2+u)) )):
B_123:=(10*a_2*a_3)*(u/( ((10^2+u)^(3/2)) * ((a_2^2+u)^(3/2)) * ((a_3^2+u)^(3/2)) )):
B_23:=(10*a_2*a_3...
My problem looks as follows................pts1FIXED comes from dsolved solution......it plots a empty figure...and i checked that l(the data pairs looks fine)..
Energy:=array(1..450);
Time:=array(1..450);
for i from 1 to 450 do
Energy[i]:=-1*((32*G*Inertia^2*e^2)/(5*c^2))*pts1FIXED(i);
l := [[t,Energy[t]] $t=1..450]:
plot(l,style=point,symbol=circle,color=blue);
I need some help...i need a solver using the Runge-Kutta method adaptive size control, to solve a sytem of 5 diff eq's, all of them are interlinked...
And
Say that dsolve numeric produces a results, called Solution, Now ex  solution(0)=1, and in general solution(t) can be evaluated, now, i want to use this, in E(t)=2*solution(t), in a plot, thus...
plot(E(t),t=0..100,....), but returns the error....
hello everyone, this is my first time visit mapleprimes, i just started to use maplets programming, so there are a lot of things i still don't know about this maplet, if i ask some stupid questions please be patient with me.
so i've been trying to write a maplet that will calculate some simple functions such as addition, multiplication, division,...,it's kind of like a calculator.
i've been trying all day, and no luck so far. help please.
if i want to create a table which contain buttons label from 0-9 so when i calculate n! i can use the number buttons on the table? please help.
i found this program in mapleprimes
First 316 317 318 319 320 321 322 Last Page 318 of 371
