with the information in the page
http://aw.twi.tudelft.nl/~koekoek/askey/ch3/par28/par28.html
what should do?
i guess to use Hn directly and use sum(Hn*z^m/m!)
is it possible in Maple?
I have a third order system with nonconstant coefficients I would like to solve in Maple.  I have found a solution  but, I need a general solution.  I have attached the worksheet.  In the worksheet I have commented the system and the known solution.  AllCalculationsPertu.mw
Is there some way to construct the general solution from known solutions like a variation of parameters?
Any other method besides rsolve to solve genfun?
i discover it can solve variable coefficient and n coefficient too.
but sometimes n*P(n+1) make it can not solve, i have to remove n to P(n+1)
any paper describing the mechanism of rsolve, where it store the maple code of rsolve in maple 15?
In status box between "Evaluating..." and "Memory, Time, Mode" there is enough space. Would be nice to have there smth like "user-defined status" of ~100 symbols (or so). Instead of long printed log you could see status of current stage of long-term process.
Thanks for the previous support and help.
I am trying to solve a poisson equation, but I am getting Bessel function in the solution. Derivation of this equation with respect to 'r' gives more complex form of Bessel function.
Actually I am not sure should I continue with the problem and Maple will take care of everything or I have to modify in the solution.
Equation 9 and Equation 11 needs to...
Maple gives me the complete solution to the attached PDE. This solution is expressed in terms of KummerU and KummerM. What I want is to obtain the solution for real numbers only, i.e. I want to get rid of the possible imaginary numbers in the solution. This implies that the separation constant, _c1, must be less or equal to 2r.
How can I do this?
Furthermore, the four arbitrary constants will need to be determined through boundary conditions....
Is there a way to create an interactive plot, and put it in a Maplet, so I could get onclick coordinates and display some points there on my plot ? I checked Maple help and I didn't find any onclick event for plot or Maplets,Elements,Plotter but I found something called PlotComponent and there are some options like clickx, clicky. Can I use it somehow in Maplet, or maybe there's another solution ?
Hi, below is what I have. I am trying to change elenum:=Array([2,4,6,8,16])
Then I changed my E0:=evalf((map(c->c*((map(int,((B^%T).(B1).J),eta=0..1))),L))
I also changed my E2:=evalf(map(c->c*map(int,((B2^%T).(B2).J),eta=0..1)),(1/(2*L))))
My E0M:=Matrix(nodes), which I am not sure if it is correct.
Then I tried to use the for do statements, it would not allow me to do so. What i'm trying to get is the first one to be a 5x5 matrix, followed...
Some time ago I asked a question concerning the algorythm for numerical dsolve and related issues here.
I got a nice answer from pagan and implemented the algorythm.
However, since my system is big, the iterations take long time.
Here is the code itself:
sys1:=[TRIC[1],TRIC[2],TRIC[3],TRIC[7],TRIC[8],TRIC[9]]:
> sys2:=[TRIC[4],TRIC[5],TRIC[6],TRIC[10],TRIC[11],TRIC[12]]:
> GRAD:=subs(u=FF[1](t),a=FF[2](t),k=k(t),tau=tau(t),psi[1...
Problem. write the equation of the line cut the two lines d1: x = 2*t, y= -t+1, z = t-2, d2: x = -1+2*m, y = 1+m, z = 3 and perpendicular to the plane 7*x+y-4*z=0.
This is my code.
> restart;with(geom3d):
a:=[2*t,-t+1,t-2]:
b:=[-1+2*m,1+m,3]:
line(d1,a,t):
line(d2,b,m):
i tried to plot a differential equation with piecewise.
h:=piecewise(0 <= t and t <= 1, 1, 1 < t and t <= 2, 2, 2 <= t and t <= 3, 0, 3 < t and t <= 4, 2, 4 < t, 1.5):
g3:=diff(y(t),t)=((800-y(t))*y(t)/*(100+y(t)))-E*h
ivs6:=[y(0)=100,y(0)=500,y(0)=1500]:
with(DETools):
DEplot(g3,y(t),t=0..10,ivs6);
I have 12 equations with 12 unknowns.  I trying to solve using the following:
solve({s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12},{c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c11,c12});
but my problem is MAPLE doesn't solve for C10, C11, C12.
Is there any format for writng s10,s11,s12  and c10,c11,c12.
Your help will be really appreciated.
Write the equation of the sphere passing through the point B(-1,-1,0) and tangent to the line x = t + 1, y = 2*t + 1, z = -t + 2 at the point A(1, 3, 2) so that its radius obtain minimum value.
This is my code.
> restart:with(geom3d):
point(B,-1,-1,0):
point(A,1,3,2):
a:=[t+1,2*t+3,-t+2]:
line(Delta,a,t):
dsegment(AB,[A,B]):
Problem 1. Write the equation of the sphere passing through three points A(2, 3, -2), B(-2, 3, 4), C(0, -1, 2) and  tangent to the plane (P): x+5*y+z-33=0.
This is my code
point(A,2,3,-2):
point(B,-2,3,4):
point(C,0,-1,2):
plane(P,x+5*y+z-33=0,[x,y,z]):
point(T,x,y,z):
I tried to use control+C and control+V to copy and paste equations from maple to MS word under windows 7, it works fine. But when it comes to the Mac OS, it generate some meaningless codes. Is there any way to do it under Mac OS?
First 320 321 322 323 324 325 326 Last Page 322 of 371
