I am using Maple 13 under Windows 7. I have been using Maple for quite a while now, and all of a sudden Maple has decided to start playing funny games.
Whenever I go into the Maple Portal and click on one of the hyperlinks, the Maple session locks up. The first time this had happened, I had been in the Maple Portal for half an hour.
It doesnt respond to any clicks, including trying to close the Maple window. The only way to close it at this point is to crash it via the Task Manager....
Hello everyone
i forgot to add, subtract, divid and multiple all infinties (∞) together and with any number and i want to know the indetermanite forms.
if anyone know, please try to respond quickly.
thank you all.
Up until now, I have been using lists instead of sets in solve() in order to ensure the first equation is solved for the first variable, the second for the second, etc.  However, I have run into a case for which using an equation list and a variable list does not work, but the equation list alone is fine, and sets of both are fine, etc.  I would be grateful if somebody can explain why the first statement below does not produce a solution.
> soln := solve([foc1 = 0, foc2 = 0, foc3 = 0...
Let NULL
old version define use
'homalg/default':=RPI;
in maple 15
libname := "D:/homoalg/10_homalg.lib",libname:
with(homalg):
> define(homalg, RPI, 'default');
Error, (in define) homalg is assigned
> hom2 := Hom(L, K, var);
Error, (in homalg/tablename) Since homalg/default is not defined, the last argument must be a table containing the (minimum) homalg conversions or an unassigned symbol pointing to such a table!
> define(homalg, 'RPI', 'default');
I want to solve numerically the nonlinear problem
a*(diff(y(x), x, x))+2*(diff(y(x), x))+exp(y(x)) = 0, y(0) = 0, y(1) = 0
by defining my own method defined as
yn+1=yn+2*h*(-2*yn+2*ln(2/(1+x))-(1/2)*a)^2/(a*(-4*yn+4*ln(2/(1+x))-a-h*(4*yn-4*ln(2/(1+x))+a+x+1)/a))
where h is the step-size. Please help me by letting me know how can I do this using Maple 11.
Hi evryone.
Does anyone have experience on what is the best format to export an entire worksheet (code and graphics) out of Maple. I tried all different formats but none comes even close to being publication quality.
thanks a lot
I have an array [1..2503] y-axis for different values,  x-axis [0..180],
when I plot these two arrays its not possible.   but if I change x-axis [1..2503] then plot is ok... I want to plot x-axis [0..180] and y-axis [1..2503]
A.Q   Soton
Find the value of the integral I=∫√(tanx)dx
I want to compare two signals where intersections between the two signals represent the instant of command (like boolean pulse) of a thyristor. The two signals are volatges and command of thyristor is boolean. A conversion of voltage to boolean signal should also done, I think ?
See image below.
I am really stuck in one more bit thats the least square problem.  leastsquare1.mw
Hope someone can help me to solve this bit and get me out of this problem :(.
Least square method is successfuly implemented in MATLAB code (WRITTEN IN THIS MESSAGE AT THE END), but I couldn't do it in Maple.  I am having problem in the for loop section,  I am attaching Matlab code and  maple code ...
I guess the question I am asking is quite common, however I am still not able to figure it out. I have several (right now three) non-linear inequalities. Given these inequalities, I try to plot them in one graph and then color the different areas with different colors. It would be also ok, if just the area where all inequalities hold is plotted. To do this I have already tried several things. With implicitplot and transparency it is generally working, but...
So basically I'm trying to slice a tesseract, with a 3D surface but first want to be able to slice a cube, with a 2D plane. so I have a 3D plot of a polygon of a face (of a cube) and I want to find the intersection of that with a plane. intersectplot doesn't seem to be working for me, and I'm unsure of how to represent a finite face of a cube as a plane
I tried to solve the following system of equations with Maple 15:
You can copy paste the commands below to get the equations
pde1 := [diff(`#msub(mi("n"),mo("&uminus0;"))`(x, t), t) =
diff(`#msub(mi("n"),mo("&uminus0;"))`(x, t), x)+n[o](x, t)-`#msub(mi("n"),mo("&uminus0;"))`(x, t)]
pde2 := [diff(n[o](x, t), t) = 0.3139e-2*(diff(n[o](x, t), x, x))-2*n[o](x, t)+`#msub(mi("n"...
I am really struggeling with these 2 questions..
need to plot this in maple
Fourier:
This is my last 2 questions on my school report that i need to deliver tomorrow
First 318 319 320 321 322 323 324 Last Page 320 of 371
