http://www.mapleprimes.com/questions/144384-Polynomials-Not-In-The-Correct-Indeterminates
above link's comment said eliminate will NOT generate a polynomial in all cases
make me think that eliminate in above link can not return correct one.
what is the correct way to convert groebner basis of kernel into kernel?
I sometimes like to work with worksheets in classic mode. However, I have just discovered that I cannot simply type "restart;" in the beginning of a worksheet in classic mode because it causes the worksheet window to freeze. However, if I click the "restart" button, then things go as normal. I really want to have each of my worksheets begin with the "restart;"  command. Need your assistant on a way out.
I use 64-bit windows 7 CORE i3 Dell Inspiron N4050.
having its diameter equal to three and its number of vertices equal to 32? Is it possible to find the one with Maple? The simpleminded approach
>with(GraphTheory):
>with(RandomGraphs):
> G := RandomRegularGraph(32, 4);
> Diameter(G);
produces 4 or 5.
What I know is http://www-ma4.upc.es/~comellas/delta-d/desc_g/desc_g3.html ( the second graph).
I mean not open these files, and ctrl+A select whole file and copy to one file.
I have been trying to find a solution to the following equation for ages!
Vt:=(a*t)+((1/(2*Pi))*((b*cos(2*Pi*t))-(c*sin(2*Pi*t))-b)-295);
I need to find what t converges to, I have solved the equation using a different method and I know the answer is around 0.787 but I need to find the result using the Newton Raphson method, or another iterative method. I am not allowed to use dsolve. or the Newton command.
Sorry if this is a bit vague...
I have a list.  I am applying a loop with a condition.  When the condition is met it stops (of course) but how do I get the condition to continue testing against the rest of the list without incrementing the next loop value?
I am trying to find the exact amplitude and phase angle for the signal, with values attached using MATLAB.  BUT the phase angles doesn't make sense.  Can you guys help me in doing the FFT of the signal and find the amplitude and phase using MAPLE.   I am interested in,  fundamental component, 5th , 7th , 11th, 13th 15th, 17th and 19th harmonics with their phases.
I shall be very thankful if anyone of you can actually solve the problem.
Hello, id like to find the analytic expression for the following sum.
Sum[Exp[-Sqrt[x]], {x, 1, infinity} ]
I can prove convergence, but i cant figure out a way to find the sum, i have tried maths programs (Maple, Mathematica), books on integrals (Gradshteyn, Prudnikov) and tried myself with no result so far.
Thanks for the Help in advance!
below code is calculate basis of kernel and kernel
i guess basis of image is
remove(has, Ga, [r,u,v,w]); if this correct, i eliminate this, i can get the image
however it include variable 'a'
is it correct? if not, how to calculate?
my final goal is to make unexact sequence into exact sequence
after union ideal I and J, how to remove the intersection of I and J in order to do primedecomposition?
I have a Matrix 'A' in maple with symbolic entries and I need to use that Matrix in matlab M file. The symbols with in 'A' are already initialized in M file.
How is this possible?
For Matrices 'A' of small dimension, I can use the codegeneration package to convert 'A' to Matlab Matrix and then copy paste.
But for matrices of 1000x1000, lets say, does not seem as a option.
Hello.
I have a workcheet, that is incompleete, when using
  > with(XMLTools);
  > ParseFile("FILE");
i get the wollowing error, but i cant seem to fix it by my selv in an xml editor.
Here you have the file:
9.mw
Hope you can help
I have two sets of data representing two function that depends on x with a parameter A.
I need to do a fit on both data series at the same time so to fit with the best parameter A.
Here is how I do a fit on one function
> f(x):=A*cos(x-B)^(2);
> g(x):=A*(cos(x-C)^(2)+ sin(x-C)^(2))^2;
> fit1 := Fit(f(x), r, x, parameternames = [A, B, C...
hey friends..
Am trying to solve 2d poission equation with finite difference method and using different scheme is got
ui-1,j -8ui,j + ui+1,j + 3ui,j-1 +3ui,j+1 = -h *16
and i have made code for this which is
> restart;
> with(LinearAlgebra);
> printf(`The lefthand endpoint on the X-axis is 0.\n`);
> OK := FALSE;
> while OK = FALSE do printf(`Input...
r-x^4
u-(x^3)*y
v-x*y^3
w-y^4
Step 1
with(Groebner):
K := {r-x^4,u-(x^3)*y,v-x*y^3,w-y^4};
G := Basis(K, 'tord', degrevlex(r,u,v,w));
Step 2
G intersect k[r,u,v,w]
G2 := Basis({w*G[1],w*G[2],w*G[3],w*G[4],w*G[5],w*G[6],w*G[7],w*G[8],w*G[9],w*G[10],w*G[11],w*G[12],w*G[13],w*G[14], (1-w)*K[1], (1-w)*K[2], (1-w)*K[3], (1-w)*K[4]}, 'tord', degrevlex(r,u,v,w));
G2 has too much though include the correct solution
correct solution...
First 304 305 306 307 308 309 310 Last Page 306 of 371
