https://en.wikipedia.org/wiki/Coproduct
would like to do a sheaf which is a mapping from subset of prime ideal to coproduct of ring Ap where p belong to Prime ideal of A
I have two general 4x4 matrices S and R subject to the given contraints (eq1, eq2, respectively). First of all, I was trying
to see if there are any specific matrices T such that the equation S.R=T (subject to the constraints of eq1 and eq2)
does NOT exist (i.e. there are no matrices S and R such that the equation holds). I tried many examples but couldn't find
any so now I suspect that any possible T has a solution.
So firstly, I...
Previously I got some great help from Markiyan Hirnyk who introduced me to the DirectSearch package. I am having a little trouble implementing it for this function:
y := proc (E) options operator, arrow; -_C4*MathieuS(-a, -q, E)*(Int(MathieuC(-a, -q, E)*(-a+2*q*cos(2*E)), E))+_C4*(Int(MathieuS(-a, -q, E)*(-a+2*q*cos(2*E)), E))*MathieuC(-a, -q, E)-_C2*MathieuC(-a, -q, E)-_C3*MathieuS(-a, -q, E)-_C4*MathieuS(-a, -q, E)*MathieuCPrime(-a, -q, E)+_C4*MathieuSPrime(-a, -q, E...
I'm preparing for GRE and i came across this question from 800score.com while reviewing concepts for probability.
In a deck of 52 standard playing cards, what is the probability that pulling a single card from the deck
will produce a black card?
http://www.800score.com/content/gre/guidec7dview1a.html
Please...
I like to plot the Bode diagram of function transfer. For that purpose, i use Dynamicsystem package.
I obtain my transfer function by 2 different methods :
- direct method
- state space method.
The issue is the fact that i don't obtain the same results with the 2 methods.
 state_space_metho.pdf
restart;with(Statistics):
MartinPoisson := (p/((p+2*q*T)/(1+p*T+q*T^2)-(p*T+q*T^2)*(p+2*q*T)/(1+p*T+q*T^2)^2))^r*r^2*T^n/factorial(n);
Dist := subs(T=t,MartinPoisson) assuming t > 0;
MartinDist := Distribution(CDF = unapply(piecewise(t>1,Dist,0),t));
MartinDist := Distribution(CDF = unapply(Dist, t)) assuming t > 0; #Change 2
X:=RandomVariable(MartinDist);
MartinDensity := PDF(X,t);
MartinDensity := subs(t=x, MartinDensity);
DOES ANYONES HAS THE SLIGHTEST IDEA OF HOW I COULD MODEL AND SUMILATE THE WAVE PATTERN OF A REGISTERED EARTHQUAKE??? FOR INSTANCE I AM STUDYING THE EARTHQUAKE EFFECTS OF THE NOVEMBER QUAKE IN GUATEMALA OF LAST YEAR. I WOULD LIKE TO MODEL THE MOVEMENT OF THAT QUAKE OVER A GIVEN AREA NEAR THE EPICENTER.
ANY HINTS OF HOW I COULD EVEN START TO MAKE THE MODEL AND SIMULATE??
Hi there, i want to write a procedure which can initiat the sexond procedure accodingly. For example, f1(a,b,c,d,e,f) where a,b,c,d,e,f is set of different atoms. say, Here I only need to deal with a and d type atoms to calculate energy values through f2 procedure.
f1:=proc(a,b,c,d,e,f)
How i can write a procedure to assign values, like f1(yes,no,no,yes,no,no) or with number as f1(1,0,0,1,0,0) to show i only need a and d results.
I am trying to pass the caption of a Button named A1 with
i want to adding new maple package file extension with .lib  .ind  .eps.
i didnt find where to copy this.
I know this has to be an easy on, but I simply cannot figure out how to calculate the probability of a dice roll or a card pick. I want to calculate the probability of rolling four sixes in a row, or picking three kings in a pack of playing cards. I know how to to the math by hand, but I want maple to calculate it for me.
I've tried google my problem, but with no useful results (they were all a lot more advanced then what I could figure out). I'm guessing it's because...
I wonder if you could help me. I'm trying to calculate the eigenvalues of a complicated 3x3 matrix in Maple, but I'm not very familiar with Maple syntax. The answer maple has provided me with is in the form,
(&*(sin(pi*q/P),P/T,3x3 matrix))
How do I interpret this result? The eigenvalues are scalars.
Thanks for your help,
Sian
I am new to Maple (converting from Mathcad) and I am having trouble with plot3d in Maple 17.  Even in the help examples the scale numbers next to tickmarks appear blurred.   In addition after a couple of rotations of the 3D plot, my computer freezes and has to be manually reset.   I'm using Windows XP with 4 GB of physical memory.
Would appreciate any help.
First 300 301 302 303 304 305 306 Last Page 302 of 371
