Can you help me how to program about the interference of wave on the water surface in Maple ?
I've bought NAG C Library for my mac in order to use it in Maple.
However, it seems that Maple doesn't know where to search for it.
Indeed, it returns
Error, (in NAG:-h03abc) external linking: error loading external library libnagc_nag.dylib: dlopen(libnagc_nag.dylib, 129): image not found
I've installed NAG C Library in usr/Library
Thank you very much for your help
Further tags : implicit form, Matlab codegen for GPOPS purposes
Hi there,
I would like to introduce my self and ask you for an advice.
I have a four linked robot that i would really like to control by the meaning of the optimal control theory. The arm has 4 actuators (giving torques U) in corrispondence of 4 rotational joints. P parameters describe the system.
I got ht edynamic system with the Lagrangian method and now I have 4 2nd order...
So currently i am trying to programm a game. for that i would need a Textbox that is updating once the player makes an input. I have a textbox TB1 and a button with the action linked. the action that the button should make is calling an external procedure which in turn updates the textbox. But i currently i keep getting the following error expresion:
Error, (in Maplets:-Tools:-Set) invalid argument(s): [TB1]::string = [7, 8, 9]
So what die i do wrong.
Dear Maple experts
I want to find the co-efficient for z^k of G(t,z)=sum_i=1^infty a_i(t) z^i where z is a function of t.
I got this error message while attempting to compute Inverse matrix of symbolic function.
Error, (in Normalizer) unable to allocate enough memory, computation aborted
I have managed to download data for Nasdaq, NYSE and Amex in Maple. However,
my problem is how do I store the data in a txt file on my desktop in the most optimal way.
I want an mpl file so I can schedul the task manager to run the file each day in the background.
This is as far as I have come:
with(StringTools):
CSV := proc (Url) local theDLL, URLDownloadToFile, myDirectory, myFile, Destination, DL;
theDLL...
    IS THERE ANY MAPLE CODE FOR SOLVING SYSTEMS OF ODEs using IMPLICIT RUNGE KUTTA SUCH AS LOBATTOIIIA,LOBATTOIIIB and LOBATTOIIIC.THANKS
I have a polynomial system that I'd like to find ONE solution of (there may be many, so I want the program to terminate after 1 is found, since I only need to know that there IS a solution). In this system, the unknown variables are a_i, b_i, c_i, d_i, s_i, t_i, r_i, l_i, for i = 1, 2, 3, 4. Thus I want the solution in terms of these variables. The system is given below.
\begin{align*}
q & = \sum_{i = 1}^4 a_i s_i, \\
w & = \sum_{i = 1}^4 a_i t_i, \\
Hallo Guys,
This questions was asked 7 years ago and I hope now there is some knowldege how to do it ( else Maple sucks that in 7 years they havent figured out it yet ) ...
So basically How do you change the inline plot size window in the worksheet itself by command line ( For Noobs please do not show off your "Skills" by saying that you can do it b Mouse : I know that much else wont be here :P  and those who want to tell me how to do it in a jpeg/etc also Shut up ! ...
I am trying to obtain an inverse of a symbolical 4 by 4 matrix in order to diagonalize it. I have noticed that the command 'Inverse' seems to find a matrix inverse almost instantaneously, whereas the Matrix Inverse command from the Linear Algebra package takes far longer - on the order of hours. Can anyone explain the difference between them? It seems like 'Inverse' is roughly speaking, an approximation to 'Matrix Inverse', however I have not been able to find...
I'm using Maple to come up with equations, and then I'm substituting in variable names for functions which I can then output to Matlab.
I haven't had any problems until I ran into partial derivates described by the D[] operator.  For example, if i have a function f described by f(x(t),y(t)) and I differentiate it wrt t, I get
D[1](f)(x(t),y(t))*(x(t)_dot) + D[2](f)(x(t),y(t))*(y(t)_dot)
I want to make a substitution for D[1](f)(x(t),y(t)) and D[2...
     I have a a matrix with one symbol and all others are numbers. I got this from doing
   M := (1-x)*N + x*A :
 So my parameter is x, and N, A are numeric (real, symmetric) matricies. I want to plot the eigenvalues as x=0..1, but for a large matrix, say 25x25. Eigenvalues(M) only returns 17 eigenvalues, and more so, it doesnt keep them in the same order when plotting!
My issue is when Maple computes the...
The equation
solve(surd(-2*x+4,3)+surd(x+2,3)+surd(x -6> ,3)=0);
has three different integer solutions.
I want to choose the integer number a, b, c, d, e, f to the equation
(a*x + b)^(1/3) + (c*x + d)^(1/3) + (e*x + f)^(1/3) =0
I tried
L:=[]:
for a from -10 to -1  do
First 299 300 301 302 303 304 305 Last Page 301 of 371
