If I type the following:
a := 1
a2 := 1.5
a*a2
When I press enter
I want it to display the expression without evaluating and then the result:
(1)*(1.5)
By default the program displays  1.5.  Is it possible to display it this way?
x^4-1equivalent 0 mod 29
after find root of inverse?
Please have a visit of this qestion `http://math.stackexchange.com/q/574843/8581`. I did a very elementary attempt there for example for a function:
 > with(plots):
      h := x->piecewise(x < -2, x+3, x <= 2, 5-x^2, 3-x):
      t:=x->h(-x):
      a:= plot(h(x), x = 0 .. 10, color = red, thickness = 3):
      b:= plot(t(x), x = -10 .. 0, color = green, thickness = 3):
      display(a,b);
But  I am eager to know  the formal codes if they exists. Thanks for your time.
I was successful in getting the Maple add-in to load into Excel 2013 but the help file accessed in the Add-In Ribbon is not found.  Does anyone know where in Excel that file can be loaded?
Hi, I have encountered a difficult question.
My answer is A=151,B = 47.
Could anyone tell me whether this answer is correct?
The question is as follow:
Pi=∑((120n2+An+B)/(16n((512n4 + 1024n3 + 712n2 + 194n + 15))  (n starts from 0 to infinity)
Good morning sir.
I request your kind support to the above cited question.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
I am just getting started with Maple and would like to know the following:
When I input an equation, for example (3.4)^2x+3 = 8.5, right click and select “solve for x”, the software gives me a value x=0.6256295444, although this is the final answer I require I also want to see how we arrived at that answer, I bought the software to use as a learning tool so I really need to be guided through the whole process.
Hope you can help.
Hello hello...
Is there a way i can double underline and math answer i Maple 17 ?
Like when you write 2+2=4 and you want to double underline 4 ??
Many thanx in advance
Allan
Hi there..
I have a question on how to do a pointplot.
before plotting, I need to know the value of lambda[j] and  all the values of lambda already have.
so now I need to plot a graph with the values of lambda with different range and different colour,
Let say I have
> for j from 17 to 32 do k[j] := j+1;
x[j] := add(P[j, 1], j = j-1 .. j+2);
X[j] := add(P[j, 1]^2, j = j-1 .. j+2);
y[j] := add(P[j, 2], j = j-1 .. j+2);
Y[j] := add(P[j, 2]^2, j = j-1 .. j+2);
xy[j] := add(P[j, 1]*P[j, 2], j = j-1 .. j+2);
cx[j] := evalf(x[j]/k[j]);
cy[j] := evalf(y[j]/k[j]);
c11[j] := evalf(X[j]/k[j]-cx[j]^2);
c22[j] := evalf(Y[j]/k[j]-cy[j]^2);
c12[j] := evalf(xy[j]/k[j]-cx[j]*cy[j]);
C[j] := evalf(Matrix(2, 2, [[c11[j], c12[j]], [c12[j], c22[j]]]));
E[j] := simplify(fnormal(LinearAlgebra[Eigenvalues](C[j])));
if E[j][1] > E[j][2] then lambda[j] := E[j][2]/(E[j][1]+E[j][2]) else lambda[j] := E[j][1]/(E[j][1]+E[j][2])  end if;
lambda[j];
the range of lambda [j] are as follows:
 0.02< lambda [j]<0.06
 0.06< lambda [j]<0.12
 0.12< lambda [j]<0.18
for i from 17 to 32, do if   0.02< lambda [j]<0.06 then green[i]:=P[i,j]; j:=i+1 elif
 0.06< lambda [j]<0.12 then red[i]:=P[i,j];j:=i+1 ; elif 0.12< lambda [j]<0.18 then blue[i]:=P[i,j];j:=i+1 end if;end do
how to do a point plot with the above situation so that in my plotting all the information are on the same graph.
All help is greatly appreciated.
Im trying to plot the different values of shanks as points in this ] loop.
pp:=0.0:sumn:=0:sumnm1:=0:sumnp1:=0:
for i from 1 to 60 do
if(n>2) then sumnm1:=sumn fi;
if (n>1) then sumn:=sumnp1 fi; p:=1/evalf(2*beta*BesselJ(2,zeros[i])+epsilon*zeros[i]*BesselJ(0,zeros[i])+zeros[i]*BesselJ(1,zeros[i])); pp:=pp+p;
sumnp1:=pp;
if (n>2) then shanks:=(sumnp1*sumnm1-sumn*sumn)/(sumnp1-2*sumn+sumnm1) fi;
shanks;
od;
sumnp1: -2*sumn+sumnm1:
I have tried plotting it but it only plots the last value.
Many thanks James
I have 2nd order nonlinear ode I try to solve with Runge Kutta 4th order method in maple but all I get from the out is 1 and 0.This is the equation: theta_ode.mw . How do I do it Or how do I write the code to solve it with maple using  Runge Kutta 4th order method?
I am not that good at english, but i will try to tell you what my problem is.
I have a worksheet in maple where i can't find out to make the results appear.
Maybe it is easiere for you guys to help me if i can send you the document.
Looking forward to hear form you
Niclas
I have a Matrix whose entries are polynomials in several formal parameters (the matrix is sparse and the polynomials are rather simple, though inverses of the parameters may also arise).
Then, when I compute the kernel with LinearAlgebra-NullSpace, maple naturally gives a basis of solutions over the same ring of polynomials.
Now for some reason there are some parameters that I don't want to see in the solutions (all but two of them, actually).
How can I compute the part of the kernel that lives in $\mathbb{Z}[a,a^{-1}, b,b^{-1}]$, i.e. that involves only the first two parameters?
Thank you,
NoThik
Edit : the coefficients of the polynomials are integers, and I expect the kernel elements to have integer coefficients as well.
please help me with my problem. i have quite a big program all parts of which are distributed in the several code edit regions and in the main text. i'd like to find all occurenses of gven text in all open documents including code edit regions. i know how to do it manually by openening each code edit regiong and pressing Ctrl-F. however it is very time consuming and defocuses me apart from my main tasks. i'd prefer to use some combinations of 'hot keys' on the keybord or one or two mouse clicks as for example in MS Visual Studio.
4(x-7) =6
(2x+3)(2x2-5x-3)=0
First 288 289 290 291 292 293 294 Last Page 290 of 371
