Can one solve nonlinear ODE with perturbation method in maple? If yes, please the procedure.
x11 := Vector([0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]):
y11 := Vector([ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]):
z11 := Vector([ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]):
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t)+k4*u(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t)+k8*u(t);
c1 := Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t)+k12*u(t);
ICS:=x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1],u(0)=7;
Zt := rhs(dsolve({a1,b1,c1,ICS},[x1(t),y1(t),z1(t),u(t)]));
Params := NonlinearFit(Re(Zt),<seq(k,k=0..N)>, C, [t], parameternames=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12], output=parametervalues):
A := eval(a, Params):
B := eval(b, Params):
a = A;
b = B;
i wait for a long time for dsolve still evaluating
Greetings to all.
I have run into a curious numeric event while computing Master theorem recurrences at this math.stackexchange.com link.
I do have to say that this one has me worried. I am referring to Maple 15 (X86 64 LINUX).
Try the following program in a new Maple session.
T := proc(n)
option remember;
    if n = 0 then return 0 end if; 9*T(floor(1/3*n)) + n*(1 + ilog[3](n))^3
T_ex := proc(n)
local m, d;
option remember;
    d := convert(n, base, 3);
    m := ilog[3](n);
    add(3^j*(1 + m - j)^3*add(d[k + 1]*3^k, k = j .. m), j = 0 .. m)
T(3^22-1)-T_ex(3^22-1);
The result is the following error message:
Error, (in T_ex) invalid subscript selector
Now try it again, in a new Maple session, but enter the following command first.
Digits := 50;
Now the result is
Consider the following program:
T := proc(n)
option remember;
T_upper := proc(n)
local m;
option remember;
    m := ilog[3](n); 3^(2*m + 2)*sum(3^(-j)*j^3*(1 - 3^(-j)), j = 1 .. m + 1)
T(3^22-1)-T_upper(3^22-1);
The result is
-30454808964204479209326
But if you precede the program with the command
Digits:=50;
the result is once more
This is reproducible (restart Maple every time) and quite frankly, seems rather serious to me. Could someone please look into this.
Marko Riedel
Hi. I'd like to find the solution closest to zero for sum(abs(f(k, m, n)+g(k, m, n)), n = i .. j) , when a < m, n < b .
Have trouble wrapping my head around how to do that and would appreciate any help.
Even better would be to find a solution where the maximum absolute value of f(k, m, n) + g(k, m, n) is minimized for n = i .. j) and when a < m, n < b , but I'm guessing the sum would be easier, and close enough.
Maybe I'm barking up the wrong tree getting this done with Maple, but I'm hopeful.
Thank you for looking
Hi every one,
Q1:
I tried to get the max $ min of a following function:
l:=1:alpha:=1:b:=100:k:=20:
eq1 := (alpha+(l+alpha)*u+alpha*k*u^2)*a =
u*(alpha+(l+alpha)*u+alpha*k*u^2)*(1+l*alpha*b/((alpha+(l+alpha)*u+alpha*k*u^2))):
I did this code but it seems it didnt work for this equation
maximize(eq, u=1..12, location);
minimize(eq, u=1..12, location);
Also, I think about solving the cubic i feel i'm so close to the solve but couldn't
factor((rhs-lhs)(eq1));
eq:=collect(%,u);
Q:=(a,u)->eq;sol:=evalf(solve(Q(a,u),u)): S:=array([],1..3): S[1]:=sol[1]:S[2]:=sol[2]:S[3]:=sol[3]:
Q2:
the same thing wanted to get the maximum and the minimum of the function v
here the code
eq1:=(alpha+(l+alpha)*u+alpha*k*u^2)*a=
u*(alpha+(l+alpha)*u+alpha*k*u^2)*(1+l*alpha*b/((alpha+(l+alpha)*u+alpha*k*u^2)));
eq2:=v=alpha*b*(1+u+k*u^2)/(alpha+(l+alpha)*u+alpha*k*u^2);
eq1:=collect(%,u);
params:={l=10,alpha=0.5,b=100,k=20};
U:=[solve(eval(eq1,params),u)]; #3 solutions for u
#plots:-complexplot(U,a=0..20,style=point); #plot in the complex u-plane
vua:=eval(solve(eq2,v),params): #v expressed in terms of u and a
V:=eval~(vua,u=~U): #the 3 solutions for v in terms of a
## PLOT the function V
plot(V,a=0..75,v=0..100,color=black,labels=[a,v],axes=boxed,numpoints=90,linestyle=1,font=[1,1,18],thickness=2,tickmarks=[4,4],view=[0..65,25..100]);
I do appricaited any advises
function [y g] = ques5
% using Simpson Formula to approximate the integration
% input:
% f(x): [a b]
end
% use Euler formula to compute function y
for i = 1:N
    if i ==1
legend('numerical y','exact y','numerical g','exact g')
function g = f2g(a,b)
% f(x) = x
g = (b-a)/6*(a + 4*(a+b)/2 + b);
ican use matlab to solve this problem but not maple
please help
http://homepages.lboro.ac.uk/~makk/MathRev_Lie.pdf
ode1 := Diff(f(x),x$2)+2*Diff(f(x),x)+f(x);
with(DEtools):
with(PDETools):
gen1 := symgen(ode1);
with(PDEtools):
DepVars := ([f])(t);
NewVars := ([g])(r);
SymmetryTransformation(gen1, DepVars, NewVars);
Error, invalid input: too many and/or wrong type of arguments passed to PDEtools:-SymmetryTransformation; first unused argument is [_xi = -x, _eta = f*x]
generator1 := rhs(sym1[3][1])*Diff(g, x)+ rhs(sym1[3][2])*Diff(g, b)
what is X1 and X2 so that [X1, X2] = X1*X2 - X2*X1 = (X1(e2)-X2(e1))*Diff(g, z) ?
is it possible to use lie group to represent a differential equation, and convert this group back to differential equation ? how do it do?
how to find symmetry z + 2*t*a, when you do not know before taylor calcaulation?
fza := z + 2*t*a;
fza := x;
fza := z + subs(a=0, diff(fza,a))*a;
Two questions:
The algortihms that Groebner[Basis] uses at each step computes some "tentative" or "pseudo-basis". The "tentative" basis is not a Groebner basis but it is in the ideal generated by the original system of polynomial eq.
1) Is this correct ? Provided this is correct, then
2) How can one retrive the last "tentative" basis?
 If I just use timelimit I can abort the computations but how can one retrive the last computation?
Please respond me by email, thanks.
wingwatson7@gmail.com
Good evening, dear experts.
I want to solve the system of PDEs, but i get a mistake:
"Error, (in pdsolve/numeric/xprofile) unable to compute solution for t>HFloat(0.0):
solution becomes undefined, problem may be ill posed or method may be ill suited to solution"
How  can I determine the method for pdsolve?
Thanks for answers.
It's my file with the functions:
alias(X = x(t, tau), Y = y(t, tau));
xt, yt := map(diff, [X, Y], t)[];
xtau, ytau := map(diff, [X, Y], tau)[];
M := (xtau*(-Y+.1*X)+ytau*X)/(xtau^2+ytau^2);
pde1 := xt = -Y+.1*X-xtau*M;
pde2 := yt = -M*ytau+X;
cond := {x(0, tau) = 1, x(t, 0) = 1, y(0, tau) = 1, y(t, 0) = 1};
Sol := pdsolve({pde1, pde2}, cond, numeric, time = t, range = 0 .. 1);
Sol:-value(t = 1);
I have  AX=B , I want to find X , A is 3*3 matrix  <.9,-.3,-.6>|<-.2,.6,-.4>|<-.4,-.4,.8>   B=matrix(3, 1, [600, 600, 600]) ? I using  linearslove, but it is not work.
Hello, I am trying to do a fourier transfrom using the package < DiscreteTransfroms >.
The function is an gaussian function for now,
Here is the code I tried
with(DiscreteTransform):
> X := Vector(1000, proc (k) options operator, arrow; (1/200)*k-5/2 end proc);
> Y := Vector(1000, proc (k) options operator, arrow; evalf(exp(-10*((1/100)*k-5)^2)) end proc);
> X2, Y2 := FourierTransform(X, Y);
Vector[column](%id = 18446744080244879358),
Vector[column](%id = 18446744080244879478)
> plot(X2, Re(Y2));
The program returns two vector, X2 and Y2 who are supposed to be the fourier transforme of a gaussian so.. a gausian but when I plot the result X2 on the horizontal and Y2 on vertical, the graph doesn't resemble a gaussian function or any function at all.
Please help!!
Alex
Good afternoon sir.
I request your kind support to the above cited query.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
My attempt to export array data using the Browse>Export option when looking at the data fails to work as needed.
The exported data always start in cell A1 of the Excel worksheet even a different starting cell is entered into the Matrix Browser export window.
In summary, my experience is that the Matrix Browser matrix export in Maple 16 and Maple 17 ignores the information about the intended starting destination cell in the Excel file.
Does anyone find that the Matrix Browser exports to a starting Microsoft Excel cell other than A1?
This exporting with Matrix Browser worked find in Maple 15.  It has been broken in Maple 16 and 17, including Maple 17.02.
so i am trying to plot some limit cycles and it won't plot. I don't know what's wrong.
> restart;
with (DEtools);
> L := -4.80; MU := 0.1e-1;
DE13 := {(D(x))(t) =
y(t)*(1-y(t)*y(t))+MU*x(t)*(x(t)*x(t)-3*y(t)*y(t)-L), (D(y))(t) = -x(t)*(1-2*x(t)*x(t))+MU*y(t)*(x(t)*x(t)-3*y(t)*y(t)-L)};
DEplot(DE13, [x(t), y(t)], t = 0 .. 20, [[x(0) = 0.1e-1, y(0) = .99], [x(0) = -.1, y(0) = -.9], [x(0) = 1.1, y(0) = 0], [x(0) = 0, y(0) = .2], [x(0) = 0, y(0) = .6], [x(0) = .6, y(0) = 0], [x(0) = .75, y(0) = 1], [x(0) = .1, y(0) = .1], [x(0) = .5, y(0) = 1.0], [x(0) = -.5, y(0) = 1], [x(0) = .5, y(0) = -1], [x(0) = -.5, y(0) = -1], [x(0) = -0.1e-1, y(0) = .99], [x(0) = 0.1e-1, y(0) = -.99], [x(0) = -0.1e-1, y(0) = -.99], [x(0) = .5, y(0) = -1], [x(0) = -.5, y(0) = -1], [x(0) = 0.1e-1, y(0) = .9]], stepsize = 0.1e-1, scene = [x(t), y(t)], title = "Phaseplane 3 Prime Plot", linecolor = black, thickness = 1);
First 286 287 288 289 290 291 292 Last Page 288 of 371
