I am to program a computation on maple.
But I get the message :
Error, unable to match delimiters
followed by the full sequence of command.
How can I do to fix this problem?
I want my graphic to be like this (file: Hansevi's Graphic.mw ):
instead of this (file: My graphic.mw):
Does anyone know why both graphics are different?
*The graphics were supposed to be similar -_-
Good afternoon sir.
I request your kind support to the above cited question.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
Lfh := proc(numoflevel, h, fx, var)
if numoflevel = 1 then
        hello := 0;
        for i from 1 to nops(var) do
                hello := hello + diff(h[i], var[i])*fx[i];
        od;
        return hello;
        hello := 0;
                hello := hello + diff(Lfh(numoflevel-1, h, fx, var), var[i])*fx[i];
        od;
        return hello;
f:=[x3-x2^3,-x2,x1^2-x3];
g:=[0,-1,1];
h:=[x1,0,0];
variables := [x1,x2,x3];
Lf1h := Lfh(1,h,f,variables);
Lgf1h := Lfh(1,[seq(Lf1h,n=1..nops(variables))],g,variables);
Lf2h := Lfh(2,h,f,variables);
Lgf2h := Lfh(1,[seq(Lf2h,n=1..nops(variables))],g,variables);
Lf3h := Lfh(3,h,f,variables);
Lgf3h := Lfh(1,[seq(Lf3h,n=1..nops(variables))],g,variables);
i doubt that my book example is wrong
it said relative rank is 2, but i can not find any zero when Lgf3h
if i continue to Lgf4h, Lgf5h, Lgf6h...etc, still no zero what does it mean?
Example
Diff(x1,t) = x2^2,
Diff(x2,t) = u,
y = x1
result in
Diff(y,t$2)-4*u^2*Diff(y,t) = 0
2*u*x2 - Diff(y,t^2) = 0
x1 - y = 0
is it possible a general and generic method to apply some steps on system below
Diff(u1, t) = u1*u2-u1*u3,
Diff(u2, t) = -u1*u2+u2*u3-(1/2)*(conjugate(u2-u3)*(u1*u2-u1*u3)+conjugate(u1)*(-u1*u2+u2*u3)-conjugate(u1)*(u1*u3-u2*u3))/conjugate(u1),
Diff(u3, t) = u1*u3-u2*u3+(1/2)*(conjugate(u2-u3)*(u1*u2-u1*u3)+conjugate(u1)*(-u1*u2+u2*u3)-conjugate(u1)*(u1*u3-u2*u3))/conjugate(u1),
y = u1
Here is the question:Prior to this question I was given f(z)=z^2+1, N(z)=(z^2-1)/(2z), T(z)=z-I/z+I such that T(N^k (z))=(T(z))^2^k. And L is a set of number on the real axis. Now the question is that given we have two regions of the complext plane as follow:
R+ = {z : Nk{z) -> i as k -> ∞}; R- = {z : Nk(z) -> -i as k -> ∞}.
Draw a diagram to illustrate these regions, the line L and the roots i and -i. We call R+ the basin of attractionfor the root +i, and similarly R-is the basin of attraction for the root -i.
 Show that if z is on the set L (the common boundary of the two regions R+ and R_, then Nk(z) stays on L for all values of k. (This is easy once you identify what L is.) So in this case iteration does not produce a root at all.
So basically my problem is that the fact I'm not very familar with the commands to draw such diagram, and I don't know much about Newton's method to compute complex roots. It would be appreciated if anyone can help me how to get start with the question. Thanks.
when a user liked a particular photo for the first launch of a mobile app, and the time different where by the event started and stoped was k seconds which is at constant (does not change). At this constant thus triggered the like application operation or function that was connected to the application server. Then later the user unlike the photo and the same event and operation was carried out at of (k + 2) seconds. The time variation that was carried out during the sequential or running loop event carried out by 2 seconds.
check if this derived equation is correct first f(Xn) = en(Xn + Xn+ 1) . if its correct do the second question.
what is the rate at which the operation will be finish given an equation f(Xn) = en(Xn + Xn+ 1)
The dot product of vector v and u= ||v|| ||u||fosters also vector u*v=XvXu+Yv=A, v=<2,5>, u=<4,9>.
Assume that |T(z)| < 1. Why does it follow that (T(z))r → 0 as r → ∞?
(Hint |(T(z))r| = |T(z)|r.) Deduce from the above that, as k→∞, we have T(Nk(z)) → 0. Why does it follow that Nk(z)→i ?
What is the corresponding result when |T(z)| > 1 ?
(Hint: Let l/T(z) = U(z)so that |U(z)| < 1, then apply the same argument (check U(N(z)) = (U(z))2noting that U-1(0) = -i).
Now consider the two regions of the plane:
R+ = {Nk{z) → as k → ∞}; R- {Nk(z) → -i as k → ∞}.
Draw a diagram to illustrate these regions, the line L and the roots and -i. We call R+ the basin of attraction for the root +i, and similarly R-is the basin of attraction for the root -i.
Show that if is on the set (the common boundary of the two regions R+ and R_, then Nk(z) stays on L for all values of k. (This is easy once you identify what is). So in this case iteration does not produce a root at all.
It would be appreciated if any one could help me with clear up my confusion with questions.
Thanks a lot.
Dear users
A friend of of mine has a problem with an integral and since it's for his thesis, it's pretty important.
That's why I ask it here cause I don't know where to ask it elsewhere, so if it's wrong posted, completely my bad.
l:=(y*o)/(v);
R:=(Phi*o)/v;
A:=5*(a*ln(R)+b);
P:=sqrt(1+4*k^2*l^2*(1-exp^(-l/a)));
M:=int((2)/(1+P),o);
With other words, I want to integrate the wole thing to the variable o, who appears in the variables l and R.
Somehow, when I put this in Maple, it won't solve it. Probably it's just a stupid fault or i just forget something, but i don't find it. Does anyone knows how to solve it?
Already a lot of thanks!
Is there a way to tell Maple to expand a complex function in Laurent series around a point, and have it show the series expansion that are valid for different regions? Either by the user telling it which region to use, or it automatically shows all regions?
For example, given
f(z):= z-> (3*z+1)/((z-1)*(z+1))
This has a pole at z=1 and at z=-1. I want to expand this around z=1. Hence it will have Laurent series in the annulus between z=1 and z=-1, but there is also region outside z=-1 that goes to infinity. So there are two regions.
When I do
with(numapprox);
laurent((3*z+1)/(z^2-1),z=1);
Maple gives the correct Laurent series for the region in the annulus |Z-1|<2, i.e. the first region (the one inside the two singularities).
But I want to see the expansion for different region, for |z-1|>2 (to check if I did it ok). This is what I get btw
3/(z-1) - 2/(z-1)^2 + 4/(z-1)^3 - 8/(z-1)^4 +....
Do I need a special package for this?
Fyi, I found this question here but it does not really answer my question. I want to speficy both the point of expansion, and also the region itself.
[> restart;
[> OPTIMAL:=proc(f,Condition::set)
local vars,L,S,SS,k,m,K,Fmax,Fmin,sol_min,sol_MIN,sol_max,sol_MAX;
vars:=indets(f,name) union indets(Condition,name);
L:=map(convert,Condition,equality);
K:=combinat[choose](L);
S:=NULL:
for k to nops(k) do if solve(K[k])<>NULL then
extrema(f,K[k],vars,'s||k'):S:=S,a||values(s||k):fi od:
SS:={}
for k to nops([s]) do
if type(s[k],set) then SS:=SS union evalc(s[k]) fi od;
SS:=remove(has,SS,l);
S:=NULL:
for k to nops(ss) do if type(SS[k],set(equation)) and
map(evalb,evalf(simplify(subs(SS[k],Condition))))={true}
then S:=S,vatue(ss[k]) fi od;
SS =[s];
Fmax:=-infinity:
for k to nops(SS) do
if evalf(simplify(subs(ss[k],f)))>evalf(Fmax)
then Fmax:=simplify(value(subs(SS[k],f)));sol_max:=SS[k]; fi;od;
sol_MAX:=sol_max:
if Fmax=simplify(value(subs(SS[k],f)))
and (SS[k] minus sol_max)<>{} then
sol_MAX:=sol_MAX,Ss[k] fi od;
‘Fmax'=simplify(expand(Fmax)),sol_MAX:
Fmin:=infinity:
if evalf(simplify((subs(SS[k],f))))<evalf(Fmin)
then Fmin:=simplify((subs(SS[k],f)));sol_min:=SS[k]; fi;od;
sol_MIN:=sol_min:
if Fmin=simplify(value(subs(SS[k],f)))
and (SS[k] minus sol_min)<>{} then
sol_MIN:=sol_MlN,SS[k] fi od;
RETURN('F[min]'=simplify(expand(Fmin)),sol_MlN,
'F[max]'=simplify(expand(Fmax)),sol_max);
end: ↵
" Error, unable to match delimiters"
  Please, help me.
I don't understand. Thank you, thank you.
Does someone know how to ask Maple to compute intersection and union of ranges (for that matter Realrange)?
if I find fourier intergra solution if 1/pi∫ (form infintiy to 0)(a*cos(u*x)+u*sin(u*x))/a^2+u^2 du. can you polt the function to the integral converges? and can you plot the fourier intergral on a=1 and -1<=x<=3 with 0<=u<=20?
Is there any way to program a button component to stop current calculations and restart maple server?
First 287 288 289 290 291 292 293 Last Page 289 of 371
