When you use the slider without Do(%MathContainer1 = StandardError(Variance, R)):
everything works ok but when you add Do(%MathContainer1 = StandardError(Variance, R)):
Maple Crashes.....
Strange...
LL_102)_Covariance_M.mw
@Markiyan Hirnyk
First try, i change to
result1 := Optimization:-Minimize([ans>=0, ans<=0],initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003], feasibilitytolerance=0.01);
Error, (in Optimization:-Minimize) objective function must be an algebraic expression or procedure
Second try, i change to use ans for >=0, ans2 <=0
ans:=proc(k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12) sol(parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2>=0,i=1..N)
ans2:=proc(k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12) sol(parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2<=0,i=1..N)
ans(.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003);
result1 := Optimization:-Minimize([ans, ans2],initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003], feasibilitytolerance=0.01);
x11 := [0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]:
y11 := [ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]:
z11 := [ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]:
u11 := [7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7];
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t)+k4*u1(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t)+k8*u1(t);
c1 := Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t)+k12*u1(t);
d1 := Diff(u1(t),t) = 0;
ICS:=x1(1)=x11[1],y1(1)=y11[1],z1(1)=z11[1],u1(1)=u11[1];
sol:=dsolve({a1,b1,c1,d1, a2,b2,c2,d2,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12],output=listprocedure);
X,Y,Z,U:=op(subs(sol,[x1(t),y1(t),z1(t),u1(t)]));
tim := [seq(n, n=1..27)];
N:=nops(tim):
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2,i=1..N)
hi,
     there is a common  differential equation in my maple note,the solution of the eq. can be expressed by
associated Legendre function(s),but i get a result by hypergeometric representation.how i can translate the later into a  single Legendre fun?
 Thank you in advance
ode := 'sin(theta)*(diff(sin(theta)*(diff(Theta(theta), theta)), theta))'/Theta(theta)+l*(l+1)*sin(theta)^2 = m^2
sin(theta)*(diff(sin(theta)*(diff(Theta(theta), theta)), theta))/Theta(theta)+l*(l+1)*sin(theta)^2 = m^2
dsolve(ode)
Theta(theta) = _C1*((1/2)*cos(2*theta)-1/2)^((1/2)*m)*sin(2*theta)*hypergeom([(1/2)*m+(1/2)*l+1, (1/2)*m-(1/2)*l+1/2], [3/2], (1/2)*cos(2*theta)+1/2)/(1-cos(2*theta))^(1/2)+_C2*hypergeom([(1/2)*m-(1/2)*l, (1/2)*m+(1/2)*l+1/2], [1/2], (1/2)*cos(2*theta)+1/2)*(-2*cos(2*theta)+2)^(1/2)*((1/2)*cos(2*theta)-1/2)^((1/2)*m)/(1-cos(2*theta))^(1/2)
`assuming`([simplify(dsolve(ode))], [l::posint, m::integer, l >= m])
Theta(theta) = ((1/2)*cos(2*theta)-1/2)^((1/2)*m)*(sin(2*theta)*hypergeom([(1/2)*m+(1/2)*l+1, (1/2)*m-(1/2)*l+1/2], [3/2], (1/2)*cos(2*theta)+1/2)*_C1+2^(1/2)*(1-cos(2*theta))^(1/2)*hypergeom([(1/2)*m-(1/2)*l, (1/2)*m+(1/2)*l+1/2], [1/2], (1/2)*cos(2*theta)+1/2)*_C2)/(1-cos(2*theta))^(1/2)
convert(Theta(theta) = _C1*((1/2)*cos(2*theta)-1/2)^((1/2)*m)*sin(2*theta)*hypergeom([(1/2)*m+(1/2)*l+1, (1/2)*m-(1/2)*l+1/2], [3/2], (1/2)*cos(2*theta)+1/2)/(1-cos(2*theta))^(1/2)+_C2*hypergeom([(1/2)*m-(1/2)*l, (1/2)*m+(1/2)*l+1/2], [1/2], (1/2)*cos(2*theta)+1/2)*(-2*cos(2*theta)+2)^(1/2)*((1/2)*cos(2*theta)-1/2)^((1/2)*m)/(1-cos(2*theta))^(1/2), `2F1`)
Theta(theta) = (1/2)*_C1*((1/2)*cos(2*theta)-1/2)^((1/2)*m)*sin(2*theta)*Pi^(1/2)*GAMMA(-(1/2)*m-(1/2)*l)*JacobiP(-(1/2)*m-(1/2)*l-1, 1/2, m, -cos(2*theta))/((1-cos(2*theta))^(1/2)*GAMMA(1/2-(1/2)*m-(1/2)*l))+_C2*Pi^(1/2)*GAMMA(1-(1/2)*m+(1/2)*l)*JacobiP(-(1/2)*m+(1/2)*l, -1/2, m, -cos(2*theta))*(-2*cos(2*theta)+2)^(1/2)*((1/2)*cos(2*theta)-1/2)^((1/2)*m)/((1-cos(2*theta))^(1/2)*GAMMA(-(1/2)*m+(1/2)*l+1/2))
Download question_12.19.mw
Is there a way to play animations in maplets?
I can send an animation to a plotter, but don't know how to play it.
Thanks, Rollie
I have a linear space spanned by the column vectors of:
I want to know its exact intersection of the first quadrant in 16 dimensional space (meaning Sum(a[i]*e[i]),i=1..16), how could I accomplish it? The output could possibly be the vectors defining the convex cone in higher dimensional space...
I have an ipad air 16G running ios 7.0.4 and downloaded the MaplePlayer APP.  t seems to crash on several of the routines for example, "Approximaing Sphere" and "Linear System Tutor". The app was last updated in 2011.  Do you have plans to any upgrades plan in the near future?
Hi MaplePrimers,
I'm trying to solve a system of algebraic equations using 'solve' [float].  I'd prefer to use 'solve' over 'fsolve', as 'solve' solves my system in about 0.05s, whereas fsolve takes about 5 seconds.  I need to solve the system repeatedly at a different points, so time is important.  I don't know why there is such a large difference in time ...
I have a few piecewise functions of order 3 to 5.  It solves fine with the other (piecewise) equations, but adding one piecewise function which gives me an error while trying to solve:
Error, (in RootOf) _Z occurs but is not the dependent variable.
I think this is due to solve finding multiple solutions.  Is there a way to limit solve to only real solutions?
Thanks in advance!
Hello, please i would like someone to please explain Hermite Polynomial for me. I have zero knowledge of this and if possible give examples and references. Also, on how to Normalize Hermite Polynomial and Ortogonarity of Hermite Polynomial. Thanks
Hello, I have quite a complex thing to solve, but would simplify it here. I would like to solve the unknown in a matrix, how can I use the 'solve' function? For example
A:=Matrix(3,1,4)
B:=Matrix(3,1,[2,7,9])
The relation between them is A=B*y
How can I use the below function?
solve(A=B*y,y)
I have a programme which examine how well a particular set of data fits a theoretical function.
In fact, I faced a problem : the programme returns only one solution and I guess in an arbitrary way.
I would like to find a way to define an interval in which the programme seeks solutions .
How can I do so?
with (Optimization)
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve,QPSolve];
data := [[2.954488^2, 1.644900e-5], [3.132092^2,1.614900e-5], [3.307416^2, 1.594200e-5], [3.471311^2, 1.550700e-5], [3.559775^2, 1.450200e-5], [3.669332^2, 1.499400e-5], [3.825572^2, 1.476900e-5], [3.962449^2, 4.133000e-8], [4.200714^2, 1.320900e-5],
[4.434636^2, 1.433400e-5], [4.638319^2, 1.259100e-5], [4.832908^2, 1.258500e-5], [5.078484^2,
1.216200e-5], [5.315167^2, 1.164300e-5], [5.662155^2, 1.131000e-5], [5.916080^2, 1.082400e-5],
[6.208865^2, 1.054800e-5], [6.526868^2, 1.002600e-5], [6.880407^2, 1.006200e-5], [7.243618^2, 9.594000e-6], [7.607233^2,
9.288000e-6], [7.916439^2, 8.958000e-6], [8.320457^2, 8.664000e-6], [8.721812^2, 8.439000e-6], [9.007774^2, 8.325000e-6], [8.721812^2, 8.439000e-6], [9.007774^2,8.325000e-6], [9.393083^2, 7.878000e-6], [9.668506^2, 7.755000e-6], [9.988994^2,7.623000e-6], [10.40192^2, 7.367000e-6], [10.94532^2, 6.928000e-6], [11.38244^2,6.812000e-6], [11.85200^2, 6.720000e-6], [12.18811^2, 6.422000e-6], [12.67281^2, 6.403000e-6], [12.96341^2,6.514000e-6], [13.49185^2, 6.032000e-6], [13.76590^2, 6.103000e-6], [14.4072^2,6.143000e-6], [14.45476^2, 6.095000e-6], [14.76313^2, 5.758000e-6], [15.09868^2,6.965000e-6]]:
f:= x -> abs(((2*(c*exp(-b*1.5e-6)/(2*150*(c^2-((1+I)*(sqrt(3.14*x/8.5e-5)))^2)))*(2*(((1-I)*c/(2*(sqrt(3.14*x/8.5e-5))))-((0.026/150)*sqrt(8.5e-5/2e-5)))*exp(-c*0.5e-3)+((1+((0.026/150)*sqrt(8.5e-5/2e-5)))*(1-((1-I)*c/(2*(sqrt(3.14*x/8.5e-5)))))*exp(((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3))-((1-((0.026/150)*sqrt(8.5e-5/2e-5)))*(1+((1-I)*c/(2*(sqrt(3.14*x/8.5e-5)))))*exp(-((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3)))+(b/(2*a*(b^2-((1+I)*(sqrt(3.14*x/9e-6)))^2)*((2*(1-((0.026/150)*sqrt(8.5e-5/2e-5)))*(1+((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150)))*exp(-((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3-b*1.5e-6))-(2*(1+((0.026/150)*sqrt(8.5e-5/2e-5)))*(1-((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150)))*exp(((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3-b*1.5e-6))-((1-((0.026/150)*sqrt(8.5e-5/2e-5)))*(1-((a/150)*sqrt(8.5e-5/9e-6)))*(1-((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(-((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3+((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))-((1-((0.026/150)*sqrt(8.5e-5/2e-5)))*(1+((a/150)*sqrt(8.5e-5/9e-6)))*(1+((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(-((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3-((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))+((1+((0.026/150)*sqrt(8.5e-5/2e-5)))*(1+((a/150)*sqrt(8.5e-5/9e-6)))*(1-((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3+((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))+((1+((0.026/150)*sqrt(8.5e-5/2e-5)))*(1-((a/150)*sqrt(8.5e-5/9e-6)))*(1+((1-I)*b*a/(2*(sqrt(3.14*x/8.5e-5))*150))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3-((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))))/(((1-((0.026/150)*sqrt(8.5e-5/2e-5)))*exp(-((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3))*(((1-((a/150)*sqrt(8.5e-5/9e-6)))*(1+((0.026/150)*sqrt(8.5e-5/2e-5))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))+((1+((a/150)*sqrt(8.5e-5/9e-6)))*(1-((0.026/150)*sqrt(8.5e-5/2e-5))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(-((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6)))-((1+((0.026/150)*sqrt(8.5e-5/2e-5)))*exp(((1+I)*(sqrt(3.14*x/8.5e-5)))*0.5e-3))*(((1+((a/150)*sqrt(8.5e-5/9e-6)))*(1+((0.026/150)*sqrt(8.5e-5/2e-5))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6))+((1-((a/150)*sqrt(8.5e-5/9e-6)))*(1-((0.026/150)*sqrt(8.5e-5/2e-5))/((a/150)*sqrt(8.5e-5/9e-6)))*exp(-((1+I)*(sqrt(3.14*x/9e-6)))*1.5e-6)))))))*((1+I)*(sqrt(3.14*x/2e-5)))*exp(-190e-6*((1+I)*(sqrt(3.14*x/2e-5))))):
residuals := map(p -> (f(p[1])-p[2]), data):
R:= LSSolve(residuals);
¿Que tipos de programas ayudan en  el desarrollo de problemas geometricos?
¿como puedo resolver problemas en maple17?
I have a TextArea component on the worksheet. Is it possible to create on the worksheet some number of Sliders, where the number of sliders is defined by the number entered in the TextArea?
Hello, how can i solve these equations
eq[1]:=a'[1](t)*p[1](x)+b*a[1](t)*p[1](x)
eq[2]:=a'[2](t)*p[2](x)+b*a[2](t)*p[2](x)
eq[3]:=a'[3](t)*p[3](x)+b*a[3](t)*p[3](x)
eq[4]:=c[1]*a[1](t)+c[2]a[2](t)+c[3]a[3](t)-q(t)
eq[5]:=d[1]*a[1](t)+d[2]a[2](t)+d[3]a[3](t)-p(t),
where p[i](x) , c[i] , d[i] , q(t) and p(t) are known functions?
Why does the following statement not evaluate, or better yet, how can I make it do so?
A:=value(floor(p)) assuming p>0,p<1,p::real;
or
A:=simplify(floor(p)) assuming p>0,p<1,p::real;
or any one of a lot of different attempts along the above lines, all of which seem (to me) that they should yield
A:=0
rather than
A:=floor(p)
which is what I get.
First 284 285 286 287 288 289 290 Last Page 286 of 371
