hello. before I used Mapple 15. But then I`ve run Mapple 16 and now I`ve a problem. I can`t use this program. I open the program, everthing is in the rule, but if I want to write any mathemathical function, or a letter, such as- x or x+2, the program does`t give any reaction. program only gives reaction the numbers.
Please, help me. (my english isn`t very good, and I don`t know I`ve explained my opinion).
a = c1*b + c2*c;
b = c3*a + c4*c;
where a, b, c are vector, a is linear combination of b and c, b is linear combination of a and c, and c1^2 + c2^2 = 1, c3^2 + c4^2 = 1
assume equation for a = c1*b + c2*c; is
Matrix([[y1],[y2]]) = Matrix([[x1,x2],[x3,x4]])*Matrix([[c1],[c2]]);
how to find c1 and c2 when c1^2 + c2^2 = 1
nothing return after solve({y1 = c1*x1 + c2*x2, y2 = c1*x3 + c2*x4, c1^2 + c2^2 = 1}, {c1,c2});
https://drive.google.com/file/d/0B2D69u2pweEvMV92SGhtRGZONFk/edit?usp=sharing
a error and code in this attachment mw
i can pdsolve it, but numeric pdsolve it get error
Hi -
    It is often useful useful to generate two procedures --- one to evaluate a function and one to evaluate its gradient.  The procedure codegen[GRADIENT] does not treat functions of array variables.  Why doesn't GRADIENT support array variables?  Would it be possible to replace the array variables by variables, apply GRADIENT, and then replace the array variables by variables again?
Best wishes,
David
> sol := pdsolve({ICS, sys1, sys2, sys3, sys4, sys5, sys6, sys7}, numeric, method = rkf45, parameters = [a, b, c, d, e, f, g, h, i, j, k, l, m, n, o, p], output = listprocedure);
Error, (in pdsolve) invalid input: `pdsolve/numeric` expects its 2nd argument, IBCs, to be of type {set, list}, but received method = rkf45
x11:=[1.05657970467127, .369307407127487, .400969917393968, .368036162749865, .280389875142339, .280523489139136, .283220960827744, .373941285224253, .378034013792196, .384412762008662, .358678988563716, .350625923673556, .852039817522304, .362240519978640, 1.03197080591829, .343650441408896, .982510654490390, .404544012440991, .422063867224247, 1.20938803285209, .455708586000668, 1.22503869712995, .388259397947667, .472188904769827, 1.31108028794286, 1.19746589728366, .572669348193002];
y11:= [.813920951682113, 10.3546712426210, 2.54581301217449, 10.2617298458172, 3.82022939508992, 3.81119683373741, 3.90918914917183, 10.5831132713329, 10.8700088489538, 11.0218056177585, 10.5857571473115, 9.89034057997145, .271497107157453, 9.77706473740146, 2.23955104698355, 4.16872072216206, .806710906391666, 11.9148193656260, 12.0521411908477, 2.52812993540440, 12.6348841508094, 2.72197067934160, 5.10891266728297, 13.3609183272238, 3.03572692234234, 1.07326033849793, 15.4268962507711];
z11:= [8.93290500985527, 8.96632856524217, 15.8861149154785, 9.16576669760908, 3.20341865536950, 3.11740291181539, 3.22328961317946, 8.71094047480794, 8.60596466961827, 9.15440788281943, 10.2935566768586, 10.5765776143026, 16.3469510439066, 9.36885507010739, 2.20434678689869, 3.88816077008078, 17.9816287534802, 10.1414228793737, 10.7356141216242, 4.00703203725441, 12.0105837616461, 3.77028605914906, 5.01411979976607, 12.7529165152417, 3.66800269682059, 21.2178824031985, 13.9148746721034];
u11 := [5.19, 5.37, 5.56, 5.46, 5.21, 5.55, 5.56, 5.61, 5.91, 5.93, 5.98, 6.28, 6.24, 6.44, 6.58, 6.75, 6.78, 6.81, 7.59, 7.73, 7.75, 7.69, 7.73, 7.79, 7.91, 7.96, 8.05];
u11 := [seq(close3(t+t3), t3=0..26)];
sys1:=Diff(a1(s,t),s) = a*a1(s,t)+ b*a2(s,t)+ c*a3(s,t)+ d*u(t);
sys2:=Diff(a2(s,t),s) = e*a1(s,t)+ f*a2(s,t)+ g*a3(s,t)+ h*u(t);
sys3:=Diff(a3(s,t),s) = i*a1(s,t)+ j*a2(s,t)+ k*a3(s,t)+ l*u(t);
sys4:=Diff(y(t),t) = m*a1(s,t)+n*a2(s,t)+ o*a3(s,t)+ p*u(t);
sys5:= Diff(a1(s,t),t) = a1(s,t);
sys6:= Diff(a2(s,t),t) = a2(s,t);
sys7:= Diff(a3(s,t),t) = a3(s,t);
sol := pdsolve([sys1, sys2, sys3,sys4,sys5,sys6,sys7]);
t2 := [seq(i, i=1..27)];
xt1 := subs(_C1=1,sol[1]); # a1(t)
xt2 := subs(_C1=1,sol[2]); # a2(t)
xt3 := subs(_C1=1,sol[3]); # a3(t)
ut1 := subs(_C1=1,sol[4]); # u(t)
tim := [seq(n, n=1..27)];
N:=nops(tim):
ICS:=a1(1)=x11[1],a2(1)=y11[1],a3(1)=z11[1],u1(1)=u11[1];
sol:=pdsolve({sys1, sys2, sys3,sys4,sys5,sys6,sys7,ICS}, numeric, method=rkf45, parameters=[ a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p],output=listprocedure);
ans(.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003,.003,.003,.003,.003);
ans:=proc(a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p) sol(parameters=[ a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p]);
add((xt1(tim[i])-x11[i])^2,i=1..N)+add((xt2(tim[i])-y11[i])^2,i=1..N)+add((xt3(tim[i])-z11[i])^2,i=1..N)+add((ut1(tim[i])-u11[i])^2,i=1..N);
result1 := Optimization:-Minimize(ans,initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003,.003,.003,.003,.003]);
https://drive.google.com/file/d/0B2D69u2pweEvU3NpWWQwS3U1XzQ/edit?usp=sharing
https://drive.google.com/file/d/0B2D69u2pweEvMnFabkdiX1hpYVk/edit?usp=sharing
a1 := Diff(x1(s,t),s$2) = a*x1(s,t)+b*x2(s,t)+c*x3(s,t)+d*u(t);
a2 := Diff(x1(s,t),t)=x1(s,t);
b1 := Diff(x2(s,t),s$2) = e*x1(s,t)+f*x2(s,t)+g*x3(s,t)+h*u(t);
b2 := Diff(x2(s,t),t)=x2(s,t);
c1 := Diff(x3(s,t),s$2) = i*x1(s,t)+j*x2(s,t)+k*x3(s,t)+l*u(t);
c2 := Diff(x3(s,t),t)=x3(s,t);
sys := [a1, a2, b1, b2, c1, c2];
sol := pdsolve(sys);
length exceed limit
I get the error in the following code
gama1:=0.01:
zet:=0;
#phi0:=0.00789:
Phiavg:=0.02;
lambda:=0.01;
Ha:=1;
                              0.02
                              0.01
rhocu:=2/(1-zet^2)*int((1-eta)*rho(eta)*c(eta)*u(eta),eta=0..1-zet):
eq1:=diff(u(eta),eta,eta)+1/(mu(eta)/mu1[w])*(1-Ha^2*u(eta))+((1/(eta)+1/mu(eta)*(mu_phi*diff(phi(eta),eta)))*diff(u(eta),eta));
eq2:=diff(T(eta),eta,eta)+1/(k(eta)/k1[w])*(-2/(1-zet^2)*rho(eta)*c(eta)*u(eta)/(p2*10000)+( (a[k1]+2*b[k1]*phi(eta))/(1+a[k1]*phi1[w]+b[k1]*phi1[w]^2)*diff(phi(eta),eta)+k(eta)/k1[w]/(eta)*diff(T(eta),eta) ));
eq3:=diff(phi(eta),eta)+phi(eta)/(N[bt]*(1+gama1*T(eta))^2)*diff(T(eta),eta);
      /  d   /  d         \\   mu1[w] (1 - u(eta))
      |----- |----- u(eta)|| + -------------------
      \ deta \ deta       //         mu(eta)
           /             /  d           \\
           |      mu_phi |----- phi(eta)||
           | 1           \ deta         /| /  d         \
         + |--- + -----------------------| |----- u(eta)|
           \eta           mu(eta)        / \ deta       /
/  d   /  d         \\     1    |      |  rho(eta) c(eta) u(eta)
|----- |----- T(eta)|| + ------ |k1[w] |- ----------------------
\ deta \ deta       //   k(eta) |      |         5000 p2
                                /  d           \
     (a[k1] + 2 b[k1] phi(eta)) |----- phi(eta)|
                                \ deta         /
         1 + a[k1] phi1[w] + b[k1] phi1[w]
            /  d         \\\
     k(eta) |----- T(eta)|||
            \ deta       /||
           k1[w] eta      ||
                                      /  d         \
                             phi(eta) |----- T(eta)|
          /  d           \            \ deta       /
          |----- phi(eta)| + ------------------------
          \ deta         /                          2
                             N[bt] (1 + 0.01 T(eta))
mu:=unapply(mu1[bf]*(1+a[mu1]*phi(eta)+b[mu1]*phi(eta)^2),eta):
k:=unapply(k1[bf]*(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2),eta):
rhop:=3880:
rhobf:=998.2:
cp:=773:
cbf:=4182:
rho:=unapply(  phi(eta)*rhop+(1-phi(eta))*rhobf ,eta):
c:=unapply(  (phi(eta)*rhop*cp+(1-phi(eta))*rhobf*cbf )/rho(eta) ,eta):
mu_phi:=mu1[bf]*(a[mu1]+2*b[mu1]*phi(eta)):
a[mu1]:=39.11:
b[mu1]:=533.9:
mu1[bf]:=9.93/10000:
a[k1]:=7.47:
b[k1]:=0:
k1[bf]:=0.597:
zet:=0.5:
#phi(0):=1:
#u(0):=0:
phi1[w]:=phi0:
N[bt]:=0.2:
mu1[w]:=mu(0):
k1[w]:=k(0):
eq1:=subs(phi(0)=phi0,eq1):
eq2:=subs(phi(0)=phi0,eq2):
eq3:=subs(phi(0)=phi0,eq3):
#A somewhat speedier version uses the fact that you really need only compute 2 integrals not 3, since one of the integrals can be written as a linear combination of the other 2:
Q:=proc(pp2,fi0) local res,F0,F1,F2,a,INT0,INT10,B;
global Q1,Q2;
print(pp2,fi0);
if not type([pp2,fi0],list(numeric)) then return 'procname(_passed)' end if:
res := dsolve(subs(p2=pp2,phi0=fi0,{eq1=0,eq2=0,eq3=0,u(1)=lambda/(phi(1)*rhop/rhobf+(1-phi(1)))*D(u)(1),D(u)(0)=0,phi(1)=phi0,T(1)=0,D(T)(1)=1}), numeric,output=listprocedure):
F0,F1,F2:=op(subs(res,[u(eta),phi(eta),T(eta)])):
INT0:=evalf(Int((1-eta)*F0(eta),eta=0..1-zet));
INT10:=evalf(Int((1-eta)*F0(eta)*F1(eta),eta=0..1-zet));
B:=(-cbf*rhobf+cp*rhop)*INT10+ rhobf*cbf*INT0;
a[1]:=2/(1-zet^2)*B-10000*pp2;
a[2]:=INT10/INT0-Phiavg;
Q1(_passed):=a[1];
Q2(_passed):=a[2];
if type(procname,indexed) then a[op(procname)] else a[1],a[2] end if
#The result agrees very well with the fsolve result.
#Now I did use a better initial point. But if I start with the same as in fsolve I get the same result in just about 2 minutes, i.e. more than 20 times as fast as fsolve:
Q1:=proc(pp2,fi0) Q[1](_passed) end proc;
Q2:=proc(pp2,fi0) Q[2](_passed) end proc;
Optimization:-LSSolve([Q1,Q2],initialpoint=[6.5,exp(-1/N[bt])]);
proc(pp2, fi0)  ...  end;
              HFloat(6.5), HFloat(0.006737946999)
the error is :
Error, (in Optimization:-LSSolve) system is singular at left endpoint, use midpoint method instead
how can I fix it.
Amir
I have exported Maple code as a Maplet file.  When I click on the file Maplet Launcher opens but nothing "runs".  It looks like it's trying because the icon flashes, but no window opens.  The Maple worksheet from which the Maplet was generated runs fine.
Any suggestions as to how to get Maplet Launcher to run my Maplets?
Rollie
In a mechanical problem, i have to deal with a system with trigonometric expression. The variables are gamma[1](t), psi[1](t), phi[1](t), alpha(t), beta(t), x(t). The orthers are parameters.
I would like to have a explicit relations between  gamma[1](t), psi[1](t), phi[1](t) and alpha(t), beta(t), x(t).
In orthers words, i would like to have
alpha(t)= f(gamma[1](t), psi[1](t), phi[1](t)).
beta(t)= f(gamma[1](t), psi[1](t), phi[1](t)).
 x(t) = f( gamma[1](t), psi[1](t), phi[1](t)).
Of course, the expresions of alpha(t), beta(t), and x(t) should be complex. Nevertheless, it will avoid me to have to solve Newton Raphson algorithm to solve these constraints equations.
Normally, it should be feasible.
When i have only one equation and not a system, isolate function is helpful.
But in this case, i don't manage to have my relations.
Have you some ideas to expression these relations ?
Here the code of the equations :
with(Student[MultivariateCalculus]):
constants:= ({constants} minus {gamma})[]:
`evalf/gamma`:= proc() end proc:
`evalf/constant/gamma`:= proc() end proc:
unprotect(gamma);
unprotect(gamma);
eq_liai[1]:= rF[1]*cos(a[1])-cos(a[1])*cos(gamma[1](t))*e[1]-l[1]*(cos(phi[1](t))*cos(a[1])*cos(gamma[1](t))*cos(psi[1](t))-cos(phi[1](t))*cos(a[1])*sin(gamma[1](t))*sin(psi[1](t))-sin(a[1])*sin(phi[1](t)))-cos(alpha(t))*rBTP[1]*cos(a[1])-sin(alpha(t))*sin(beta(t))*rBTP[1]*sin(a[1])-sin(alpha(t))*cos(beta(t))*h = 0;
eq_liai[2]:= rF[1]*sin(a[1])-sin(a[1])*cos(gamma[1](t))*e[1]-l[1]*(cos(phi[1](t))*sin(a[1])*cos(gamma[1](t))*cos(psi[1](t))-cos(phi[1](t))*sin(a[1])*sin(gamma[1](t))*sin(psi[1](t))+cos(a[1])*sin(phi[1](t)))-cos(beta(t))*rBTP[1]*sin(a[1])+sin(beta(t))*h = 0;
eq_liai[3] := h[1]+sin(gamma[1](t))*e[1]+l[1]*(sin(gamma[1](t))*cos(psi[1](t))+cos(gamma[1](t))*sin(psi[1](t)))*cos(phi[1](t))+sin(alpha(t))*rBTP[1]*cos(a[1])-cos(alpha(t))*sin(beta(t))*rBTP[1]*sin(a[1])-cos(alpha(t))*cos(beta(t))*h-z(t) = 0;
or directly a maple file
constraints.mw
Thanks a lot for your help
Does Maplesim allow hardware integration such as a joystick so that I can feed in joystick commands (via USB or serial) from the computer and then control my Maplesim model in the virtual space? Suggestions?
I'm currently working on a manipulator model in Maplesim and will import CAD attachments to each of the links. The Solidworks model, once imported to Maplesim, is not located in the same position as the Maplesim part but is offset by X,Y,Z. The scaling is also off. Is there some way to align the CAD to the component instead of trial and error?
Maple Player seems like it could be an outstanding piece of software, yet with the new operating system for Ipad, the program crashes immediately. I am unable to find any solutions. I also stumbled across a post in which Maplesoft is no longer providing support for the APP. Is this true?
@Markiyan Hirnyk
First try, i change to
result1 := Optimization:-Minimize([ans>=0, ans<=0],initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003], feasibilitytolerance=0.01);
Error, (in Optimization:-Minimize) objective function must be an algebraic expression or procedure
Second try, i change to use ans for >=0, ans2 <=0
ans:=proc(k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12) sol(parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2>=0,i=1..N)
ans2:=proc(k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12) sol(parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2<=0,i=1..N)
ans(.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003);
result1 := Optimization:-Minimize([ans, ans2],initialpoint=[.001,.002,.003,.001,.002,.003,.001,.002,.003,.003,.003,.003], feasibilitytolerance=0.01);
x11 := [0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]:
y11 := [ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]:
z11 := [ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]:
u11 := [7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7];
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t)+k4*u1(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t)+k8*u1(t);
c1 := Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t)+k12*u1(t);
d1 := Diff(u1(t),t) = 0;
ICS:=x1(1)=x11[1],y1(1)=y11[1],z1(1)=z11[1],u1(1)=u11[1];
sol:=dsolve({a1,b1,c1,d1, a2,b2,c2,d2,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12],output=listprocedure);
X,Y,Z,U:=op(subs(sol,[x1(t),y1(t),z1(t),u1(t)]));
N:=nops(tim):
add((X(tim[i])-x11[i])^2,i=1..N)+add((Y(tim[i])-y11[i])^2,i=1..N)+add((Z(tim[i])-z11[i])^2,i=1..N)+add((U(tim[i])-u11[i])^2,i=1..N)
In my research a I need to solve the linear equation (getting its null space) under some constraints.
The matrix is given below:
The constraints shall be (x[1]...x[16]>0, x[17]...x[20] arbitary...)
The solutions shall actually be a canonical combination of a lot of vectors, (canonical combination means possitive sums of vectors). And I wish to get those vectors. is there a way that I could achieve this by Maple?
First 283 284 285 286 287 288 289 Last Page 285 of 371
