Symbolic_integral.mw
I'm working on systems with discontinuities and need to define a finite state machine.
I tried to define one by myself and encountered some errors. The computation of initial conditions complains about either cycles and suggests using a pre-block - I am allready using one - or about inconsistent initial conditions and ignores some constraints. Does the initial condition computing algorithm loop insufficiently?
I also tried to use the modelica...
Friends,
I am very beginner of Maple softs, in order to proceed with my project i need to model a simple Human Knee joint and  to do its simulation, Somebody please help on this, otherwise i cant able to proceed with my project.
Waiting for a solution
Vinil
Hello, MaplePrimes!
I want to create a custom component to model dynamics of a movable pulley, which can rotate and move along some direction (translational motion). I’ve got dynamic system, which describes both motions of a pulley. Some information about this dynamic system:
Hey all you clever people
I have been leaning simulink in school today. The problem is that i like maple, and would like to solve all my problems in maple
The problem we solved i attached in a zip file.
Can anyone make a simulation in maplesim, that does the same, and mail it to me?
Looking forward to hear from you
Rune Behnk Eriksen
Is there a maple function that implements the semantics of the μ-recursive function (Wikipedia)?
Hey!
I'm really new on using maple 14 and I need help please.
I want to either connect maple 14 software with an oscilloscope for data acquisition or import the data captured by the oscilloscope to maple 14 and manipulate this data with the software for dynamic system analysis so I was wondering if anyone knows a programming code or a command to do this please =( I'm stuck
Thanks for your attention...
I would like to define the following exceptions:
0/0 should be equal with 0, but any other x/0 should be infinity, if x>0 or -infinity, if x<0.
In the following example, I show what I achieved, however, I also would like to have equation (8) to be infinity.
BR,
Zoltan Faigl
Hello!
I want to make a model with an inner moving circle touching a non-moving, stiff outer circle. 2 differential equations describe the movement of the inner circle, i already have modelled thisand i have the x and y coordinates of the most "exposed point" which will touch the outer circle, as output variables (i could also add the derivatives as output). When the 2 circles touch, i want to "tell" the differential equation model the 2 new derivatives for x and y...
I have got a question. I have an Hamiltonianfunctionand want to differentiate this function to all variables. There is no problem with most of the variables, but one doesn't work. The error above occures, when I use the button "execute the entire worksheet". When I just press Enter, the errror does not occure and the right results are presented. But I am not abel to use the results.
Has anyone an idea how I can solve this problem?
dear all,
          i have a simple optimization problem. the objective function is like A*X + B = E and the constraints are 100 <E < 8000 and 10<X<600. I want to find the Min and Max ranges of A and B such that Amin*Xmin+Bmin=Emin and analogous for maximum. I am not sure about the correctness of my modeling. Please guide me to proceed. Thanks.
How to interpolate in terms of any form of algebra in maple?
For example, to interpolate a time series in terms of exponential or mixed with cos and sin?
I would like to know how to find an extreme (max) point of function of two variables:
and how to manage with this error
"Warning, solutions may have been lost
How to solve a set or a system of differential equations in maple for motion with Schwarzchild metric?
************** Schwarzchild metric *****************
with(tensor):
coord := [t, r, theta, Phi]:
g_compts:=array(symmetric,sparse,1..4,1..4):
g_compts[1,1]:=1 - 2*G*M/(r*c^2):
g_compts[2,2]:=-(1 - 2*G*M/(r*c^2))^(-1):
g_compts[3,3]:=-r^2:
g_compts[4,4]:=-(r^2)*sin(theta)^2:
g1 := create([-1,-1], eval(g_compts)):
First 333 334 335 336 337 338 339 Last Page 335 of 371
