UncertaityofCalibrat.mw
within the attached document, is the idea that I would like to develop with the optimization package.
What's wrong?
I need to minimize (z-Z) T.E-1. (z-Z).
How can you see in the first Call to LSSolve worked. By introducing objectivejacobian I have problems
Recently, I submitted for publication to a peer-reviewed math journal
a formula for the n-th order implicit derivative given an implicit function G(z,w)=0.
i.e. dz/dw = - Gw/Gz where Gw and Gz are partial derivatives of G with respect to w and z, respectively. Anyway, I proved the general formula for d^n z/ dw^n.   I have since proved the generalization of this to implicit functions of several variables, G(z,w1,w2,...,w(N))=0. A good mathematician...
I had my traditional right-hand-side dock pannel in Maple 14 which
includes Greek, Components etc. Then I selected components
and droped it on the righ-hand side of the screen, which gave me
a dock on the right-hand-side of the screen.
Now the problem is when you want to remove such a right-hand side dock.
The arrows are extremely small which means that it is extremly difficult to
see them yet alone click on them. Most of the time when you have your mouse on them
 If you see my last question "use fsolve or matrix dissection"CCC.mw
I want to find C, i finally solve it and get My special C
Now , I Want tolve My problem in block mode,
CCCd.mw
this means that, My matrix elemnts are block matrix, and search for result,
I would like to ask either MAPLE is capable to solve >2 boundaries value problem.
Actually I'm solving a system of ODEs in a membrane divided electrochemical cell, basically a REDOX process.In 1 part I have 2 species reacting and in another part I have 3 species reacting , 2 of the species exist in both part.
At the end I wanted to coupled all the species together.
So basically I have 4 boundaries and I would like to solve it simultaneosly.
My Maple 13 puts small curly brackets to the left side of an expression and this causes several problem for me. What should I change to write good ones? (I mean normal, big brackets, not small brackets to index.) (I use the AltGr+b combination to write a left curly bracket.)
Compare the results of isdifferentiable on 3 piecewise defined expressions f, g, and h.
The first time the order of the asking is f, g, h. The second time (after a restart) the order is h,g,f.
The results are remarkably different! What is going on?
isdifferentiable was first brought to my attention within the last week or so, maybe it is not reliable?
If you remove all the lines with 'assuming' then the inconsistency remains.
I want to solve this Problem
Symbolic_Matrix.pdf
 in symbolic by maple, but i can`t.
is there any symbolic solution by maple or not,
if there is another solution please help me.
I don't quite understand about some parameters of flexible beam. Please introduce  briefly.
1. Truncation order of inertial terms
2. Truncation order of elastic coordinates
3. Number of elastic coordinates
help_for_maple_quest.docplease give a explain how to work for operations.
Does anybody know how to make Maple 14 work with Visual Studio 10.0 Professional (not the express version)?  I can't seem to make this happen.  The problem has to do with the PostLink command.
Hi, again, I am a physist. It is convenient to solve problems in presence of units. I have a equation (1-variable) including a erf function to solve. As I substute all the constants (with units) and then use 'solve'. It returns a warning without any result. I am not really familiar with the numeric package in maple. Could anyone give me some advice? Thank you.
There is a example "3D rigid slider crank" in the MapleSim examples. Replace the "crank" and the "rod" with flexible beam, turn it into a flexible system, how to do that?
Thank you very much!
I want to evaluate an integral over the Dirac function with basically the following assignments. (I had some troubles parsing here...) Then I want to plot function rho(epsilon). What I get is just an empty graph with nothing displayed although test has only values in the range -3...3. I am pretty new to maple and don't know how to compute this in another way.
> test(x,y,z) := .2686733768*x^2+.2686733768*z^2-.2178281566+.2686733768*y^2+(-1)*1.000000000*sqrt...
First 337 338 339 340 341 342 343 Last Page 339 of 371
