I have a multivariable function, F(n, g(1,0),g(0,1),g(0,2),g(1,1),g(2,1),...,g(n,1),g(n-1,2),...,g(1,n)), of indeterminates g(i,j) (omitting g(0,0) - in other words - let L = set of all pairs of nonnegative integers, (i,j), which satsify 1<= i+j <=n) of the following form F = product over all the (i,j) in L of g(i,j)^h(i,j) / ((i!
I want  to calculate the derivative of Bessel, I do
why dont any of maples 11, 12, or 13 work properly in windows seven? for example: when i click on "open a file" or "save" botton, and then it opens a window, the respective window dont show "up one level" or "create new folder" and "details" bottons above it.
How can add the values of a list with the list as an argument of a function. As exmaple:
f([1,2,3,4,5]);
                              15
Thanks for any help,
Dat
I am running Maple 13.0 on Ubuntu 9.04 and I'm having Maple give me some strange outputs.
In this first block of code, I define an expression f which I try to evaluate (unsuccessfully) at a partiuclar value of t and g.   If I expand first, then I get an answer, which is not correct.
These are the steps that I need to do
determine the domain and range of the functioon
determine the intercepts and asymptotes of the graph
locate the x-values where f'(x) and f''(x) are zero or undefined
then i need to determine where the relative extrema and the points of inflection occur (this i should be able to do if I can get the graph)
i have to know how to do this for two kind of function for a test tomorrow I missed all week because i was sick and we are allowed to use the software on the test.
here are the functions
I have a system which is below:
X6-n4-n2, -n3+n1, -n4*X17t+n2*X9t, n3*X17t^2-n4*X17tt-n1*X9t^2+n2*X9tt, 130*X9tt-60*X17tt*n2*n4+60*X17tt*n1*n3-40*n2*X11+981*n2+60*n2*n3*X17t^2+60*n1*n4*X17t^2, -1500*X9tt*n2*n4+1500*X9tt*n1*n3+2250*X17tt+1000*n4*X11-14715*n4+1500*n4*X9t^2*n1+1500*n3*X9t^2*n2, n1^2+n2^2-1, n3^2+n4^2-1
I need to do primedecomposition for it. Maple could not do this for me kernel was lost. However system is not very big.
With version 10, I did this:
gammadist:=(x^(alpha-1)*exp(-x/theta))/(GAMMA(alpha)*theta^alpha);
simplify(int(gammadist,x=0..infinity),symbolic);
The result of the integral is 1.
When I do this exact same thing in version 12, I get an integral without any symbolic computation.
If I use assum(alpha>0): additionally(theta>0): then it will give me the same result.  However, in version 10 I also did
mgf:=simplify(int(exp(t*x)*gammadist,x=0..infinity),symbolic);
I'm trying to make a FFT from a 2s long input file by using the obsolete FFT-procedure, but strange thing is: No matter what first argument they receive (3, 2, 1, 0 even!) the result is always the same; even more strange is: Writing out the signal after the FFT it's exactly the same as before as if the FFT never would've happened.
What am I doing wrong?
Hi, I'm working on the Smoluchowski equation (essentially the diffusion eqn with an extra derivative) diff(u(x,t),t)=k*diff(u(x,t),x)+D*diff(u(x,t),x,x) k is piecewise so the function has to be solved numerically, the boundary values are specified u(0,t)=u(1,t)=0 but i need the derivative at the boundaries D[1](0,t) and D[1](1,t). It seems to be simple to evaluate a numeric derivative of an ODE but I can't see how to do it for a PDE. Any help welcome, even some sort of brute force method if necessary. Thanks, Ryan
I tried to find the limit of the following equation using l'hopital's rule, when sigma approches to zero find i couldn't find it.
Now i want to use Taylor series to find the limit of the following equation, when sigma approches zero.
hey do u know a website where i can find information about gravel pacing and screen of a bore hole..i really can't find anything
Hello everyone
I have a cost function I would like to minimize. It is a fairly simple function that only contains multiplications and additions.
Only problem is, this function has about a hundred variables, but they can only be between the interval [0,1] so I guess it makes the problem easier.
Is it possible to write a little program in maple that can be ran as much as I want it to run and that could try to find an approximation of the actual solution? (By trying random numbers between 0 and 1)
Thank you very much
Does anyone know a way of quantizing sensor data in MapleSim?
First 341 342 343 344 345 346 347 Last Page 343 of 371
