A small glitch
pointplot3d({[2,3,4],[1,2,3],[4,5,6]},symbol=box,axes=boxed)
The third point is missing from the plot however if I use axes=normal all three points are displayed but when the boxed option is enabled the point [4,5,6] is not displayed.
It seems the autoscaling undercuts the last point and so is out of view of the plot.  In order to have the 3rd point visible (it is there) we need to use the view=[ xmin..xmax,ymin..ymax,zmin..zmax ] option.
I've bought a new computer recently and was disappointed, because Maple uses only 25% of that processor (my old computer used 99% of CPU).
I have Intel Core i5 750 processor (it has 4 kernels).
From the Screenshot you can see that It uses only 25%, but not because it uses only one kernel (it uses all 4 kernels).
If I open two Maple instances and run the same program on all of them at once then I get 50% of CPU used.
The question is:
how to force to use Multi-Kernel processor to work at 90% (if needed) with one single Maple program?
It seems that this isn't a limitation to Maple, but for all other programs as well.
For example,
the equation is like the pic below:
int(sqrt(1+16*a^2*y^6+24*a*y^5*b+16*a*y^4*c+8*a*y^3*d+9*b^2*y^4+12*b*y^3*c+6*b*y^2*d+4*c^2*y^2+4*c*y*d+d^2), y = 0 .. .2)
i try it by Maple ..but did not get any answer of it ! anyone can help me with this ??or there is no real answer for it ?
since the equation got 4 unknown constants which are a,b,c,d ...so how to use maple to solve it ???
any idea and comment will be much appreciated ...thx
I have a multivariable function, F(n, g(1,0),g(0,1),g(0,2),g(1,1),g(2,1),...,g(n,1),g(n-1,2),...,g(1,n)), of indeterminates g(i,j) (omitting g(0,0) - in other words - let L = set of all pairs of nonnegative integers, (i,j), which satsify 1<= i+j <=n) of the following form F = product over all the (i,j) in L of g(i,j)^h(i,j) / ((i!
I want  to calculate the derivative of Bessel, I do
why dont any of maples 11, 12, or 13 work properly in windows seven? for example: when i click on "open a file" or "save" botton, and then it opens a window, the respective window dont show "up one level" or "create new folder" and "details" bottons above it.
How can add the values of a list with the list as an argument of a function. As exmaple:
f([1,2,3,4,5]);
                              15
Thanks for any help,
Dat
I am running Maple 13.0 on Ubuntu 9.04 and I'm having Maple give me some strange outputs.
In this first block of code, I define an expression f which I try to evaluate (unsuccessfully) at a partiuclar value of t and g.   If I expand first, then I get an answer, which is not correct.
These are the steps that I need to do
determine the domain and range of the functioon
determine the intercepts and asymptotes of the graph
locate the x-values where f'(x) and f''(x) are zero or undefined
then i need to determine where the relative extrema and the points of inflection occur (this i should be able to do if I can get the graph)
i have to know how to do this for two kind of function for a test tomorrow I missed all week because i was sick and we are allowed to use the software on the test.
here are the functions
I have a system which is below:
X6-n4-n2, -n3+n1, -n4*X17t+n2*X9t, n3*X17t^2-n4*X17tt-n1*X9t^2+n2*X9tt, 130*X9tt-60*X17tt*n2*n4+60*X17tt*n1*n3-40*n2*X11+981*n2+60*n2*n3*X17t^2+60*n1*n4*X17t^2, -1500*X9tt*n2*n4+1500*X9tt*n1*n3+2250*X17tt+1000*n4*X11-14715*n4+1500*n4*X9t^2*n1+1500*n3*X9t^2*n2, n1^2+n2^2-1, n3^2+n4^2-1
I need to do primedecomposition for it. Maple could not do this for me kernel was lost. However system is not very big.
With version 10, I did this:
gammadist:=(x^(alpha-1)*exp(-x/theta))/(GAMMA(alpha)*theta^alpha);
simplify(int(gammadist,x=0..infinity),symbolic);
The result of the integral is 1.
When I do this exact same thing in version 12, I get an integral without any symbolic computation.
If I use assum(alpha>0): additionally(theta>0): then it will give me the same result.  However, in version 10 I also did
mgf:=simplify(int(exp(t*x)*gammadist,x=0..infinity),symbolic);
I'm trying to make a FFT from a 2s long input file by using the obsolete FFT-procedure, but strange thing is: No matter what first argument they receive (3, 2, 1, 0 even!) the result is always the same; even more strange is: Writing out the signal after the FFT it's exactly the same as before as if the FFT never would've happened.
What am I doing wrong?
Hi, I'm working on the Smoluchowski equation (essentially the diffusion eqn with an extra derivative) diff(u(x,t),t)=k*diff(u(x,t),x)+D*diff(u(x,t),x,x) k is piecewise so the function has to be solved numerically, the boundary values are specified u(0,t)=u(1,t)=0 but i need the derivative at the boundaries D[1](0,t) and D[1](1,t). It seems to be simple to evaluate a numeric derivative of an ODE but I can't see how to do it for a PDE. Any help welcome, even some sort of brute force method if necessary. Thanks, Ryan
I tried to find the limit of the following equation using l'hopital's rule, when sigma approches to zero find i couldn't find it.
Now i want to use Taylor series to find the limit of the following equation, when sigma approches zero.
First 340 341 342 343 344 345 346 Last Page 342 of 371
