Whenever I have 2 instances of the rotational move block in a model, mserver.exe crashes when I try to run the simulation. Why is this?
Hey everyone,
I've been using nonisomorphicgraphs for a while now, and my professor would really like to know if there is a pattern in the order in which it spits out the graphs. I've noticed that they pair them up in complements of each other(or as close as possible), but has anyone found the order in which they come out, and what the reason for this order is?
Who knows how to model a brushless dc motor?  Can I use a synchronous machine and some circuits? Brushless dc motors do require rotor position information in order to select the appropriate commutation angle. Using three Hall sensors? But how to model a hall sensor or something which can specify the rotor's position and send out a signal? I am looking forward to your answer. If you have some experiences of modeling a double closed-loop dc machine using maplesim, please tell me too.
Can anyone explain the below printscreen in simple terms ?
It is taken from http://www.lgt.com/export/sites/inta_lgtcom/fr/institutionelle_kunden/kompetenzen/traditionelle_anlagen/lgt_and_science/aktuelle-projekte/quantitative-finance/Projekt_EfeAksueyek_en.pdf
on pages 24. Why do we have such a ratio (second formula) ?
I can't seem to find anything on cluster anlaysis (kmean etc...) in Maple's help.  I thought graph theory might contain something close but not really.  I haven't tried but I suppose it shouldn't be too hard to create a few procedures for such things?  Can someone provide a few examples?
Of the 3 M's Maple seems to have left this one out?
There is a proper function of Maple to perform matrix left division?
This procedure is right for the calculation of the uncertainties of the coefficients?
There are large these uncertainties?
Comment?
How to change this general form to solve :
How to calculate with Maple Fourier coefficients on some numerical valued functions and how to calculate and plot the 3 partial sums :
Function B : on the interval [-phi, phi]
f(x)= NUMERICAL (x – phi/2) + NUMERICAL (x+phi/2)
Function C : on the interval [-phi, phi]
f(x) =  NUMERICAL (x+phi/2)
I enclose Maple general solution to the PDF heat equation in 1 dimention.
I need corrections of it to enable me to calculate the heat equation in certain conditions :
 du(x,t)/dt - d^2/x,t)/dx^2 = ;   t>0, x belongs to interval [0,phi[
with boundary conditions :
u(x,0) = sin(x)cos^2(x) ; x belongs to interval [0, phi)
u(0,t) = 0
u(phi,t) = 0  ;  t is still t>0
I want to solve several systems of equations and force Maple to account for the assumptions which were made for the used parameters.
For example I tried the following:
with(Statistics):
Y1 := RandomVariable(Beta(nu, omega)):
assume(0 < nu, 0 < omega):
c1:=solve({mu = Mean(Y1), sigma^2 = Variance(Y1)},{nu,omega}, UseAssumptions);
Now the problem is, that UseAssumptions makes a distinction of cases, even if -like in this case- the results do not differ from each other.
i would like to modify plot curves with different coloration in the optimization template coming from a maplesim document.
in the startup code of the maple 13 template i tried  to modify code in order to get the plot form with my custom design every time i open it, without the necessity to change again settings after each simulation.
The problem is that in the help section i don't find any examples about changing different expression curve propriety in a list of list and don't understand how to proceed.
Hello, in the attached graph I have scheduled some inequalities, but it shows error, you would know what is that?
I try to plot the deflection of a skyscraper. Therefore I need a very long calculation and the constants c_1 to c_14.
In View 16983_skyscraper.mw on MapleNet or Download 16983_skyscraper.mw
View file details
you can see my calculation.
I try to solve the folowing task:
Simulate the behaviour of a skyscraper with eight floors during an earthquake. (assumption: cosinus stimulation). Determine the resonance frequency of the skyscraper. When does it collapse. Ignore damping.
Hi everyone.
I have a loop in which initial data of ODE is found on every iteration and is substituted to find new solution. The system is striking 1 or -1 and x'(t) changes its sign, to -x'(t)
I do it this way (k[i] stands for the values of time t):
Hi, I was trying to define a function defined as a Fourier transform. In the plot, there are several pieces of the curve missing.
First 338 339 340 341 342 343 344 Last Page 340 of 371
