Does anyone know a way of quantizing sensor data in MapleSim?
When using Threshold on an image that has been converted to grayscale is it not the same as this loop?
a:=ToGrayscale(img);
for i from 1 to Width(a) do
  for j from 1 to Height(a) do
    a[i,j] := round(a):
I know it is possible to change the "Look and Feel" of Java applications, and i was wondering if there was any way to do this on Maple? (Maple 13 for Linux, to be exact.)
I have been using MapleNet for several years mainly on Linux.
But I usually use Mac for daily research and education.
I wonder why MapleNet is not compatible with Mac OS X.
MapleNet runs on Tomcat since ver. 11 and it should be run
on Mac OS X with Tomcat. However, there is no installer
for Mac !
I would love to ask Maplesoft to support Mac OS X for MapleNet.
webMathematica is fully compatible with Snow Leopard !
http://support.wolfram.com/technotes/snowleopard.en.html
Please...
I was playing around with loops and came up with this simple while loop that is reacting different than I am expecting
a:=rand(1..10):
while a() <> 4 do print(a()); od:
the output includes 4's ??
I'm trying to pointplot two arrays (vectors) but no matter what I change in the listing below Maple 11 keeps considering the second vector as an option.
Can Maple embed ActiveX objects ?
such as discussed here www.quaccess.com/index.html
Hello, I've already posted a similar Problem, but didn't get any answers. Now I think I got the solution, but now there pops up another problem.
I try to run the openMaple sample java code from the samples folder in Maple. I'm running Windows 7 with Maple 13.
When I run test.java, a Popup appears with:
"Error launching OpenMaple splash screen"
with an OK button.
After this, a Popup appears with
"Fatal Error, unable to open C:\Program Files\ Maple 13\bin.win\libgmp-3.dll. This library is required for Maple to run."
Hi, MY problem below is basically like this: I have a grid and need to plot points on it. The color of points depend on another parameter x. So, if x=
i got some problems trying to run the example test.java. I have Maple 13 on a ubuntu machine.
for your info:
$MAPLE=/home/thomas/maple13
$LD_LIBRARY_PATH=/home/thomas/maple13/bin.IBM_INTEL_LINUX
Now the problem:
Compiling the java file works, but when I try
java -classpath "$MAPLE/java/externalcall.jar:$MAPLE/java/jopenmaple.jar:." test
this exception appears:
Error loading libraries: java.lang.UnsatisfiedLinkError: no jopenmaple in java.library.path
My goal: given G(z,w), find the polynomial, P(n), in the partial derivatives of G(z,w) over the integer such that
d^n z/ dw^n = P(n) / Gz^(2n-1)    where Gz= partial derivative of G with respect to z.
Step 1. Differentiate G(z(w),w) w.r.t w n times. Formulae are known for doing that (Mishkov, Tsoy-Wo Ma),
Dear Maple Users
I am trying to minimize a cost function C subject to conditions t1>0 , t2>0 and t1< t2 by using maple 10
It seems a picture inserted or plot command generated is not movable in a document ?
If I shrink the picture,that will be in the center of the page,but this is not good when I should print the document.
can't be dragged to anywhere?
What keyboard configuration must have the Win XP to use the keyboard shortcut "Shortcut Keys" and not the key combination "International" to introduce 2-D math expressions. I refer to the help "2-D Math Shortcut Keys and Hints".
The configuration I have enabled is:
Input Device Language: Spanish.
Keyboard layout / IME: United States International.
Gracias
HerClau
Hi, I am wandering whether are some functions to compute all irreducible polynomial and prmitive polynomial over Galois field. For example, I want to all the irreducible and prmitive polynomials of GF(2^5). are there such commands to perform that? thanks
First 342 343 344 345 346 347 348 Last Page 344 of 372
