Simple question. I hope it has simple answer. I have always thought that what int() returns should match exactly what "default" result shows when using int() with the option _RETURNVERBOSE
I mean exact match. But this below shows that int() result underwent some simplification as it is not the same as default.
integrand:=sin(x)/(sin(x) + 1);
maple_result_1 :=int(integrand,x);
maple_result_2 := int(integrand,x,'method'=':-_RETURNVERBOSE')[1]
Ofcourse maple_result_2 can be made the same as maple_result_1
simplify(rhs(maple_result_2)) assuming 0<x and x<Pi;
But this is beside the point. Why is "default" is not excatly the same as int() result?  It seems that int() does something more after obtaining the :"default" result as shown.
Should default not match exactly result from int() ?
Maple 2024.
I put together the attached worksheet to help me determine the cheapest way to buy "refreshments" for a party by comparing price and volume of different bottle size options.  The spreadsheet works fine as is.  However, when I right click on the output of line (14) and format pct_difference as percent with 2 decimal places and execute the worksheet, Maple hangs on that line and progresses no further.  This doesn't happen in Maple 2018 but the problem does show up in Maple 2024.  Suggestions please?
cost_comparison_-_liquid_(v01MP).mw
This is still a  starting procedure and let's see what can be added?
# Define the procedure to draw a cylinder along the x-axis and a specifically positioned plane
CylinderAndPlane := proc(r, h, alpha_deg, beta_deg, P, axis_length)
    local alpha, beta, cylinder, plane, pointPlot, display, nx, ny, nz, px, py, pz, annotations, plane_type, titleStr, grafiek;  # Added: titleStr
    uses plots, LinearAlgebra;
    # Convert angles from degrees to radians
    alpha := alpha_deg * Pi / 180;
    beta := beta_deg * Pi / 180;
    # Determine the normal vector based on angles
    nx := cos(alpha) * sin(beta);
    ny := sin(alpha) * sin(beta);
    nz := cos(beta);
    # Point P is directly used as given coordinates
    px, py, pz := op(P);
    # Cylinder along the x-axis
    cylinder := plots:-implicitplot3d(y^2 + z^2 = r^2, x = 0 .. h, y = -r .. r, z = -r .. r, style = surface, color = "LightBlue", transparency = 0.5);
    # Determine the type of plane based on angles alpha and beta
    if beta_deg = 90 then
        plane_type := "yz";
        plane := plots:-implicitplot3d(x = px, x = px - 10 .. px + 10, y = -axis_length .. axis_length, z = -axis_length .. axis_length, style = surface, color = "Yellow", transparency = 0.5);
    elif alpha_deg = 90 and beta_deg = 0 then
        plane_type := "xz";
        plane := plots:-implicitplot3d(y = py, x = -axis_length .. axis_length, y = py - 10 .. py + 10, z = -axis_length .. axis_length, style = surface, color = "Green", transparency = 0.5);
    elif beta_deg = 0 then
        plane_type := "xy";
        plane := plots:-implicitplot3d(z = pz, x = -axis_length .. axis_length, y = -axis_length .. axis_length, z = pz - 10 .. pz + 10, style = surface, color = "Blue", transparency = 0.5);
        plane_type := "arbitrary";
        plane := plots:-implicitplot3d(nx * (x - px) + ny * (y - py) + nz * (z - pz) = 0, x = -axis_length .. axis_length, y = -axis_length .. axis_length, z = -axis_length .. axis_length, style = surface, color =            "Red", transparency = 0.7);
    # Mark point P
    pointPlot := plots:-pointplot3d([px, py, pz], symbol = solidcircle, symbolsize = 10, color = "Red");
    # Create dynamic title - New
    titleStr := cat("Plane: ", plane_type, "\nAlpha: ", sprintf("%.2f", alpha_deg), " deg\nBeta: ", sprintf("%.2f", beta_deg), " deg\nPoint: [", sprintf("%.2f", P[1]), ", ", sprintf("%.2f", P[2]), ", ", sprintf("%.2f", P[3]), "]");
    # Display everything together - Modified: titleStr added in the display function
    grafiek := plots:-display(cylinder, plane, pointPlot, axes = normal, scaling = constrained, labels = ["x", "y", "z"], title = titleStr);
    return grafiek;
# Example call to the procedure with coordinates of P and setting the axis length
# Alpha and Beta are now angles in degrees, P is a list of coordinates, axis_length is the length of the coordinate axes
CylinderAndPlane(15, 50, 0, 90, [15, 5, 5], 30);  # For yz-plane
#CylinderAndPlane(5, 15, 90, 0, [5, 5, 5], 10);  # For xz-plane
#CylinderAndPlane(5, 15, 0, 0, [5, 5, 5], 10);   # For xy-plane
#CylinderAndPlane(5, 55, 45, 45, [5, 5, 5], 10); # For arbitrary plane
Download maple_primes_-doorsnijdingsvlak_solids_procedureDEF.mw
sol := y = -3283/4253 - (3283*x)/4253, How can I determine the value of the coefficient of x?
How can I take the value of the coefficient of x? Thank you.
I am stuck this command works seemlessly in Maple:
ThermophysicalData:-CoolProp:-Property(D, T = 20*Unit('degC'), P = 760*Unit('mmHg'), water)
but it does not work in Maple Flow. Does anyone knows why? Thank you so much for your help in the matter.
Hello :)
I have a math problem, where I first need to use Linear regression to find the equation based on a set of data. I did that, no problem.
However, in the next part of the problem I need to check if the residuals are under "normal distribution". Usually, I check if a dataset is normally distributed via "QQ-plot", and there will be no problems. But this time, because I need to check the residuals, I need to use the "residualQQplot(data,LinReg)" command to make it happen. But when I read the mean-value, mu, it says "-0," and nothing else? I know it should be "-3,2752*10^-15.
The standard deviation is correct.
How do I fix this, so the residualQQplot shows me the right result?
I have attached the worksheet here. worksheet_-_linear_reg_and_residuals_for_normal_distribution.mw
Thank you!
I can't understand this behavior. Any idea why it happens?
Solve is able to solve equation   f(y)=x+A for y, but can't solve   f(y)=x for y.
This is unexpected for me. I do not see why it can solve it when RHS is x+A but not when RHS is just x.
21040
`Standard Worksheet Interface, Maple 2024.0, Windows 10, March 01 2024 Build ID 1794891`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1745. The version installed in this computer is 1744 created 2024, April 17, 19:33 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
sol:=int(1/sqrt(sin(y)),y);
solve(sol=x,y)
(sin(y)+1)^(1/2)*(-2*sin(y)+2)^(1/2)*(-sin(y))^(1/2)*EllipticF((sin(y)+1)^(1/2), (1/2)*2^(1/2))/(cos(y)*sin(y)^(1/2))
solve(sol=x+b,y):
{%}; #to eliminate duplicates
{arctan(JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))^2-1, -(1/2)*JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))*(4-2*JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))^2)^(1/2)*2^(1/2)), arctan(JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))^2-1, (1/2)*JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))*(4-2*JacobiSN(((1/2)*I)*2^(1/2)*(x+b), (1/2)*2^(1/2))^2)^(1/2)*2^(1/2))}
I can trick it to solve  f(y)=x for y  by asking it to solve f(y)=x+A for y and then set A=0 in the solution. But one should not have to do this. Is this a bug or Am I missing something?
Download why_solve_when_adding_term_only_may_22_2024.mw
I have a Prime Version Abo. On my iPhone works everyrhing fine. But on IPad there is a Limit of 5 step by step solutions. Same AppleID. What's the Problem?
I'm trying out the 2024 version of Maple and I'm getting the following warning message:
Warning, not a built-in function (`rtable_alias`)
which I didn´t get for the 2023 version. I have no clue where it is coming from since it happens even when I start a new worksheet:
I've also attached print outs of the same worksheets (from Maple help examples and from Maple Portal), one using Maple 2023 version and the other one using Maple 2024 version so youcould see the warning and some other problems.
I really appreciate if someone would have an idea of what is going on here. Thanks very much in advance.
interpolation_2023.pdf
interpolation_2024.pdf
optimization_2023.pdf
optimization_2024.pdf
Multiplaction "dot" in Maple 2022 is way too small - causes errors.
e.g. two variables multiplied s*m ends up being sm a new variable as I cannot really see that there is a missing multiplication operator between the variables. This causes huge unnecessary errors.
Maple 9.x e.g had nice clear and big operators and this kind of error was avoided.
How can I undo this unfortunate regression in Maple 2022 to increase the size of multiplication operator and other operators, so that they actually becom visible and not just a little dot almost a pixel in size.
If I was a falcon (20x20)^infinity then this would have been ok, but I am not, I am human.
So how do I change this unfortunate regression so that these errors can be avoided.?
See attached worksheet in Maple 2023.
This example is taken from the Maple help page. I want to 'zoom in' on a plot3d object. The only way I have found was from responses [1] on the maple primes forum. It uses InlinePlot and the scale option to perform the 'zoom in'. Since InlinePlot generates the plot in terms of XML there is no graphic out, only a text based output. In order to reconstitute the InlinePlot as a plot object I can view visually I need to use some additional commands from the DocumentTool package. This is all great but the output, which in our case is P3, is not a plot object and therefore cannot be exported as a png. Is there a way to convert the InlinePlot with the scaling applied back to a typical plot object so I can export it as a .png, using Export("output_plot.png",P3,base=worksheetdir)?
can_I_convert_InlinePlot(P3)_back_to_a_regular_plot_object_so_I_can_export_it_as_a_png.mw
When I try to contract the tensor with connection, maple encounters such promble:
Error, (in DifferentialGeometry:-Tensor:-ContractIndices) expected 2nd argument to be a tensor. Received: _DG([["connection", O, [["con_bas", "cov_bas", "cov_bas"], []]], [`...`]])
The expression is Cacd Hab
Don't see here the FunctionAdvisor , what is included for every choosen function.
How to obtain a clear plot of Zeta function
- via a total plot ?
- via partial plots ?
- further take circle in complex domain : complex plane ( riemann surface) , to be continued..
ComplexSurface := proc(complex_function, x_range, y_range, view_opt, orient_opt, grid_opt)
    local f, plot, combined_plot;
    # Define the complex function f(z)
    f := unapply(complex_function, z);
    # Call the FunctionAdvisor to provide plot recommendations
    FunctionAdvisor(f(z), z = x + I*y, 'view' = view_opt, 'orientation' = orient_opt, 'grid' = grid_opt);
    # Plot the complex surface
    plot := plot3d([evalc(Re(f(x + I*y))), evalc(Im(f(x + I*y)))], x = x_range, y = y_range, view = view_opt, orientation = orient_opt, grid = grid_opt, style = surface, title = sprintf("Plot of %a", complex_function));
    # Print the combined plot
    combined_plot := plot;
    #printf("Plot of the complex surface:\n");
    print(combined_plot);
    # Display additional messages
    printf("Procedure input:\n");
    printf("ComplexSurface(complex_function, x_range, y_range, view_opt, orient_opt, grid_opt)\n");
    printf("complex_function: The complex function to be plotted\n");
    printf("x_range: Range of the real axis\n");
    printf("y_range: Range of the imaginary axis\n");
    printf("view_opt: List of the form [x_min..x_max, y_min..y_max, z_min..z_max], determines the visible region\n");
    printf("orient_opt: List of the form [angle_x, angle_y], determines the viewing angle\n");
    printf("grid_opt: List of the form [x_grid, y_grid], determines the grid resolution\n");
    printf("\n");
    printf("Example usage:\n");
    printf("ComplexSurface(Zeta(z), -50..5, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);\n");
    printf("\n");
    printf("Where Zeta(z) is the complex function to be plotted, and the ranges, view options, orientation options, and grid options are specified accordingly.\n");
ComplexSurface(Zeta(z), -50..50, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);
Procedure input:
Example usage:
ComplexSurface(ln(z), -50..50, -5..5, [-50..50, -5..5, 0..15], [120, 60], [50, 50]);
Procedure input:
Example usage:
Download complex_oppervlak_zeta_functie_maple_primes.mw
This is new:
Maple 2024 frozen on opening recent files
Maple 2023 frozen on opening
Maple 2022 frozen on opening start page
Maple 2021 blinking
Maple 2020 opening start page
The above system state is constant for about 30 min. Maple sessions without start page are working. I can enter code but file opeing and saving does not work. The fact that Maple 2020 is also not working makes it unlikely that the Java environement is part of the problem.
I have several times restarted the system. The rest of the system is working.
Something happened to the system and I have no clue what is was and what I can do about it.
Any ideas or suggestions what I could try? Windows 10.
How can I get the evaluation of integration inside if-statement?
Thanks for your help in advance,
#L:=1:sigma:=0.01:beta:=0.2:k0:=-100:
#For Free particle
Projectile := proc({L:=1,sigma:=0.01,beta:=0.2,k0:=-100},n_max) local x0,g,c:
 x0:= beta*L;
 g := unapply(exp(-(x-x0)^2/2/sigma^2),x);
 #c := int(g(x)^2,x=-L/2..L/2,numeric=true);
 ub := (L/2-x0)/sqrt(2)/sigma;
 lb := (-L/2-x0)/sqrt(2)/sigma;
 a := Pi*sqrt(2)*sigma/L;
 b := sqrt(2)*k0*sigma;
 c := Pi*x/L;
 d := k0*x0;
 eq1 := [cos(a*n*z)*cos(b*z)/e^(z^2),cos(a*n*z)*sin(b*z)/e^(z^2),sin(a*n*z)*cos(b*z)/e^(z^2),sin(a*n*z)*sin(b*z)/e^(z^2)];
 eq1 := map(f->unapply(f,n,z),eq1);
 eq2 := [cos(n*c)*cos(d),cos(n*c)*sin(d),sin(n*c)*cos(d),sin(n*c)*sin(d)];
 eq2 := map(f->unapply(f,n,z),eq2);
 for j from 1 to n_max do:
   if (is(j,odd)) then eq11 := int(eq1[1](j,z),z=lb..ub,numeric=true);
   else 0;
Warning, (in Projectile) `ub` is implicitly declared local
Warning, (in Projectile) `lb` is implicitly declared local
Warning, (in Projectile) `a` is implicitly declared local
Warning, (in Projectile) `b` is implicitly declared local
Warning, (in Projectile) `d` is implicitly declared local
Warning, (in Projectile) `eq1` is implicitly declared local
Warning, (in Projectile) `eq2` is implicitly declared local
Warning, (in Projectile) `j` is implicitly declared local
Warning, (in Projectile) `eq11` is implicitly declared local
Projectile(1);
int(cos(0.4442882938e-1*z)*cos(1.414213562*z)/e^(z^2), z = -49.49747467 .. 21.21320343)
Download SolnforProjectile_v3_3.mw
First 33 34 35 36 37 38 39 Last Page 35 of 371
