I'm encountering an issue with the "roots of complex number" message while running my Maple code. Maple seems unable to solve this problem for me.
I would greatly appreciate any ideas or suggestions that could help me resolve this error.
Vib-code.mw
Every last query I make in the AI Formula Assistant returns this message...
This happens even when I use a basic canned query shown in use-case examples (e.g., surface area, sphere).
I have accepted the Terms of Use.  Is there some other setting I need to enable? Thanks.
I want to solve a big system of equations. There are 32 equations and 32 variables. Furthermaore there are a few restrictions to 8 of those variables, for example 0<t, t<1. I put the restrictions into the set of equations I want to solve. Normaly its works quite well, but today, one of the solutions was t=-2.0000000000. But this does not fit to the inequalitys I gave into the programm. Why is that? Is there a diffrence if I mark a set of inequalitys as restrictions and put them as a further property into the solve command comparded to use those inequalitys as additional equations?
I am the administrator of Maple in my school, and all the students use Maple in part of their exams. Is it possible  to block the access to ChatGPT thru eg. the firewall or otherwise during exams.
The reason for this question is that the students must have access to some internet sources during exams, but definately not CharGPT.
Kind regards
Per Kirkegaard
Hello, I try to solve the equations of the odometric model with the Maple 2024 but I have not the answers as with the hands, can you help me to verify it ?
dsolve(diff(phi(t), t) = tan(10*t)/5)
dsolve(diff(x(t), t) = V*cos(ln(1 + tan(10*t)^2)/100))
dsolve(diff(y(t), t) = V*sin(ln(1 + tan(10*t)^2)/100))
Best regards, Edern Ollivier.
Hello Everyone;
I need to find the bifurcation point and further bifarcation diagram for the given model. But facing error. Can anybody help to do this? Can you refer some library for bifurcation analysis of ODE's? Code is attched. Thanks in Advance.
123.mw
C_m := 1.0; g_K := 36.0; I_inj := 0; g_L := .3; E_Na := 50.0; E_K := -77.0; E_L := -54.4
alpha_m := (.1*(V-25.0))/(1-exp(-(V-25.0)*(1/10))); beta_m := 4*exp(-V/(18.0)); alpha_h := 0.7e-1*exp(-V/(20.0)); beta_h := 1/(1+exp(-(V-30)*(1/10))); alpha_n := (0.1e-1*(V-10.0))/(1-exp(-(V-10.0)/(10.0))); beta_n := .125*exp(-V/(80.0)); I_Na := g_Na*m^3*h*(V-E_Na); I_K := g_K*n^4*(V-E_K); I_L := g_L*(V-E_L)
.125*exp(-0.1250000000e-1*V)
(1.1)
eq1 := (I_inj-I_Na-I_K-I_L)/C_m; m := alpha_m/(alpha_m+beta_m); n := alpha_n/(alpha_n+beta_n); h := alpha_h/(alpha_h+beta_h)
-16.32000000-1.000000000*g_Na*m^3*h*(V-50.0)-36.00000000*n^4*(V+77.0)-.3000000000*V
.1*(V-25.0)/((1-exp(-(1/10)*V+2.500000000))*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V)))
0.1e-1*(V-10.0)/((1-exp(-.1000000000*V+1.000000000))*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V)))
0.7e-1*exp(-0.5000000000e-1*V)/(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3)))
(1.2)
bif_eq1 := eq1 = 0;
-16.32000000-0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))-0.3600000000e-6*(V-10.0)^4*(V+77.0)/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)-.3000000000*V = 0
bif_eq2 := diff( eq1, V) = 0;
-0.2100000000e-3*g_Na*(V-25.0)^2*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.2100000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*exp(-(1/10)*V+2.500000000)/((1-exp(-(1/10)*V+2.500000000))^4*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.2100000000e-3*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*(.1/(1-exp(-(1/10)*V+2.500000000))-0.1000000000e-1*(V-25.0)*exp(-(1/10)*V+2.500000000)/(1-exp(-(1/10)*V+2.500000000))^2-.2222222222*exp(-0.5555555556e-1*V))/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^4*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.3500000000e-5*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*(-0.3500000000e-2*exp(-0.5000000000e-1*V)+(1/10)*exp(-(1/10)*V+3)/(1+exp(-(1/10)*V+3))^2)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3)))^2)-0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))-0.1440000000e-5*(V-10.0)^3*(V+77.0)/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)+0.1440000000e-6*(V-10.0)^4*(V+77.0)*exp(-.1000000000*V+1.000000000)/((1-exp(-.1000000000*V+1.000000000))^5*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)+0.1440000000e-5*(V-10.0)^4*(V+77.0)*(0.1e-1/(1-exp(-.1000000000*V+1.000000000))-0.1000000000e-2*(V-10.0)*exp(-.1000000000*V+1.000000000)/(1-exp(-.1000000000*V+1.000000000))^2-0.1562500000e-2*exp(-0.1250000000e-1*V))/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^5)-0.3600000000e-6*(V-10.0)^4/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)-.3000000000 = 0
bif_sol := solve({ bif_eq1,bif_eq2}, {V, g_Na});
as the solutions, which are then expressed as the points mu, y via
[Back to ODE Powertool Table of Contents]
I have solution to system of equations that results (I assign it to) in:
I2sol := -I*omega0*k*L*vin*1/(L^2*k^2*omega0^2 + R^2)
I then try to solve it for k by doing
solve(I2sol = I2, k)
but that doesn't work.  What is the "right" Maple way to rearrange I2 such that the expression is the solution(s) for k?
Hey! I need help ASAP, because my maple file has been corrupted and i dont know what to do. Do you guys know how to recover a file? i can save it again as_mw. but should i change it to xml? or how? i have the link to my maple file attached, so if someone can help me, it could be helpful! Because i have an upcoming exam. Thanks youu
I noticed tags on the post
https://mapleprimes.com/questions/238161-Why-Maple-Gives-Solution-To-Euler-Ode
keep disappearing.
I added tags "differential equation" and "dsolve" and so on.
Later on when I visit this site again I found the tags are all gone.
Why does Mapleprimes remove the tags on post?
Or is someone else removing the tags? If so, why? is something wrong with the tags I've added?
This happend twice on this one post. I noticed earlier today the tags were gone, so I added them again. And now I see the same thing. They are all gone.
I am new to Maple Flow and am constantly having issues like the one shown below. A cell will become corrupted somehow, and the kernel will crash or freeze. I can save and quit, but if I re-open the file, the crash will happen again before I can diable evaluation. My questions:
  1. Has anyone else had this issue? Was it solvable?
  2. Can evaluation be disabled by default? Its possible in Maple but I don't see how in Flow.
  3. Can the kernel be restarted and reconnected (like Jupyter Lab)?
I cant expand the cell in question because of the crash, but this cell isn't the issue. This is happening all the time.
I have noticed over a few questions I have asked recently.
I ask a question.                   It goes to top of active converstaions
Some  one answers                                            "
I Reply        *
A bit of time passes  so slides  of the top six/seven that show
Another Reply/Answer from someone                possibly does not show in active conversations.  I catch this by the orange flag or email notification
I reply                                 Does not appear in active conversations..
       This can kill the conversation chain.
I have even tried changing one of me replys to an answer but did not go to top active conversations again.
Has anyone else expperienced this?
If a type is not known, an error is thrown
type([],foo)
Error, type `foo` does not exist
Since no error is thrown, these types are known
type({},'{}');# why that output?
                             false
type([],'[]')
I would have expceted {} and [] to be listed as subtypes of set and list since their counterparts (nonemptylist and nonemptyset) exist. Technically the types {} and [] are not needed since negating
not(type([],nonemptylist));
not(type({},nonemptyset));
works.  However, the types exist, hence my question
_local(D, O);
with(Student:-MultivariateCalculus);
A := [0, 0, 0];
B := [a, 0, 0];
C := [a, b, 0];
D := [0, b, 0];
S := [0, 0, h];
O := [x, y, z];
lineSC := Line(S, C);
lineSD := Line(S, D);
H := Projection(A, lineSC);
K := Projection(A, lineSD);
OH := H - O;
OK := K - O;
OC := C - O;
M := Matrix([OH, OK, OC]);
O := eval(O, %);
R := simplify(Distance(O, H));
                               O
Student:-MultivariateCalculus:-LineApplyFunction([0,0,h],
  [Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(a,
  rowalign = "", columnalign = "", groupalign = "",
  rowspan = "1", columnspan = "1"), rowalign = "",
  columnalign = "", groupalign = ""), Typesetting:-mtr(
  Typesetting:-mtd(b, rowalign = "", columnalign = "",
  groupalign = "", rowspan = "1", columnspan = "1"),
  rowalign = "", columnalign = "", groupalign = ""),
  Typesetting:-mtr(Typesetting:-mtd(uminus0h, rowalign = "",
  columnalign = "", groupalign = "", rowspan = "1",
  columnspan = "1"), rowalign = "", columnalign = "",
  groupalign = ""), foreground = "[0,0,0]", readonly = "false",
  align = "axis", rowalign = "baseline", columnalign = "center",
  groupalign = "{left}", alignmentscope = "true",
  columnwidth = "auto", width = "auto", rowspacing = "1.0ex",
  columnspacing = "0.8em", rowlines = "none",
  columnlines = "none", frame = "none",
  framespacing = "0.4em 0.5ex", equalrows = "false",
  equalcolumns = "false", displaystyle = "false", side = "right",
  minlabelspacing = "0.8em")],variables=[x,y,z],parameter=t,id=1)
  [Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(0,
  minlabelspacing = "0.8em")],variables=[x,y,z],parameter=t,id=2)
               /     2            2         / 2    2\ /
               |    h  a         h  b     h \a  + b / |
        HAssign|------------,------------,------------|
               | 2    2    2  2    2    2  2    2    2|
               \a  + b  + h  a  + b  + h  a  + b  + h \
                          /    2         2  /
                          |   h  b    h b   |
                   KAssign|0,-------,-------|
                          |   2    2  2    2|
                          \  b  + h  b  + h \
        /                2                       2
        |               h  a                    h  b
OHAssign|uminus0x + ------------,uminus0y + ------------,uminus0z
        |            2    2    2             2    2    2
        \           a  + b  + h             a  + b  + h
       / 2    2\ /
     h \a  + b / |
      2    2    2|
     a  + b  + h \
            /                      2                    2  /
            |                     h  b               h b   |
    OKAssign|uminus0x,uminus0y + -------,uminus0z + -------|
            |                     2    2             2    2|
            \                    b  + h             b  + h \
          OCAssign(uminus0x + a,uminus0y + b,uminus0z)
M := Matrix(3, 3, {(1, 1) = Typesetting:-mrow(Typesetting:-mo("&\
  uminus0;"), Typesetting:-mi("x"), Typesetting:-mo("&plus;"),
   Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-msup(Typese\
  tting:-mi("h"), Typesetting:-mn("2")), Typesetting:-mo("&Invis\
  ibleTimes;"), Typesetting:-mi("a")), Typesetting:-mrow(Typeset\
  ting:-msup(Typesetting:-mi("a"), Typesetting:-mn("2")),
   Typesetting:-mo("&plus;"), Typesetting:-msup(Typesetting:-mi(\
  "b"), Typesetting:-mn("2")), Typesetting:-mo("&plus;"),
   Typesetting:-msup(Typesetting:-mi("h"), Typesetting:-mn("2"))\
  ))), (1, 2) = Typesetting:-mrow(Typesetting:-mo("&uminus0;"),
   Typesetting:-mi("y"), Typesetting:-mo("&plus;"), Typesetting:\
  -mfrac(Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi("h"\
  ), Typesetting:-mn("2")), Typesetting:-mo("&InvisibleTimes;"),\
   Typesetting:-mi("b")), Typesetting:-mrow(Typesetting:-msup(Ty\
  pesetting:-mi("a"), Typesetting:-mn("2")), Typesetting:-mo("&p\
  lus;"), Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-m\
  n("2")), Typesetting:-mo("&plus;"), Typesetting:-msup(Typesett\
  ing:-mi("h"), Typesetting:-mn("2"))))), (1, 3) = Typesetting:-\
  mrow(Typesetting:-mo("&uminus0;"), Typesetting:-mi("z"),
   Typesetting:-mo("&plus;"), Typesetting:-mfrac(Typesetting:-mr\
  ow(Typesetting:-mi("h"), Typesetting:-mo("&InvisibleTimes;"),
   Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-msup(Type\
  setting:-mi("a"), Typesetting:-mn("2")), Typesetting:-mo("&plu\
  s;"), Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-mn(\
  "2"))))), Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi(\
  "a"), Typesetting:-mn("2")), Typesetting:-mo("&plus;"),
   Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-mn("2"))\
  , Typesetting:-mo("&plus;"), Typesetting:-msup(Typesetting:-mi\
  ("h"), Typesetting:-mn("2"))))), (2, 1) = Typesetting:-mrow(Ty\
  pesetting:-mo("&uminus0;"), Typesetting:-mi("x")), (2, 2) =
   Typesetting:-mrow(Typesetting:-mo("&uminus0;"), Typesetting:-\
  mi("y"), Typesetting:-mo("&plus;"), Typesetting:-mfrac(Typeset\
  ting:-mrow(Typesetting:-msup(Typesetting:-mi("h"),
  pesetting:-mi("b"), Typesetting:-mn("2")), Typesetting:-mo("&p\
  lus;"), Typesetting:-msup(Typesetting:-mi("h"), Typesetting:-m\
  n("2"))))), (2, 3) = Typesetting:-mrow(Typesetting:-mo("&uminu\
  s0;"), Typesetting:-mi("z"), Typesetting:-mo("&plus;"),
   Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-mi("h"),
   Typesetting:-mo("&InvisibleTimes;"), Typesetting:-msup(Typese\
  tting:-mi("b"), Typesetting:-mn("2"))), Typesetting:-mrow(Type\
  setting:-msup(Typesetting:-mi("b"), Typesetting:-mn("2")),
  "h"), Typesetting:-mn("2"))))), (3, 1) = Typesetting:-mrow(Typ\
  esetting:-mo("&uminus0;"), Typesetting:-mi("x"), Typesetting:-\
  mo("&plus;"), Typesetting:-mi("a")), (3, 2) = Typesetting:-mro\
  w(Typesetting:-mo("&uminus0;"), Typesetting:-mi("y"),
   Typesetting:-mo("&plus;"), Typesetting:-mi("b")), (3, 3) =
  mi("z"))})
Error, invalid input: eval received Matrix(3, 3, {(1, 1) = -x+h^2*a/(a^2+b^2+h^2), (1, 2) = -y+h^2*b/(a^2+b^2+h^2), (1, 3) = -z+h*(a^2+b^2)/(a^2+b^2+h^2), (2, 1) = -x, (2, 2) = -y+h^2*b/(b^2+h^2), (2, 3) = -z+h*b^2/(b^2+h^2), (3, 1) = -x+a, (3, 2) = -y+b, (3, 3) = -z}), which is not valid for its 2nd argument, eqns
       /     1       / 2  2      2        2  2    2  2    2  2
  R := |------------ \a  h  - 2 a  h z + a  x  + a  y  + a  z
       | 2    2    2
       \a  + b  + h
            2      2  2      2        2  2    2  2    2  2
     - 2 a h  x + b  h  - 2 b  h z + b  x  + b  y  + b  z
            2      2  2    2  2    2  2\\
     - 2 b h  y + h  x  + h  y  + h  z /|^(1/2)
Why this error ? Thank you.
I keep getting an error: invalid subscript selector on specifically this part of my code:
MuligIndgange := subsop(RemoveList\[i\]=NULL, MuligIndgange).
Whenever I comment out the MuligIndgange := part it works.
I can't for the life of me see why it's happening, and whenever I use this code outside my proc it works aswell.
Any help is appreciated, and if you need more context I'll be happy to give it.
for i to numelems(MuligIndgange) do
     if M1[MuligIndgange[i][1], MuligIndgange[i][2]] =/= 0 then
         RemoveList := [op(RemoveList), i];
for i from numelems(RemoveList) by -1 to 1 do
    MuligIndgange := subsop(RemoveList[i] = NULL, MuligIndgange);
I have seen this quite a bit in blocks of code. The `>` symbol seems to appear erratically. I don't know how to specifically reproduce this. Does it mean something? I would post the worksheet but it will not run without the package.
First 35 36 37 38 39 40 41 Last Page 37 of 371
