Please help with the bifurcation diagram for the system and parameter values below
with(VectorCalculus)
[`&x`, `*`, `+`, `-`, `.`, `<,>`, `<|>`, About, AddCoordinates, ArcLength, BasisFormat, Binormal, ConvertVector, CrossProduct, Curl, Curvature, D, Del, DirectionalDiff, Divergence, DotProduct, Flux, GetCoordinateParameters, GetCoordinates, GetNames, GetPVDescription, GetRootPoint, GetSpace, Gradient, Hessian, IsPositionVector, IsRootedVector, IsVectorField, Jacobian, Laplacian, LineInt, MapToBasis, Nabla, Norm, Normalize, PathInt, PlotPositionVector, PlotVector, PositionVector, PrincipalNormal, RadiusOfCurvature, RootedVector, ScalarPotential, SetCoordinateParameters, SetCoordinates, SpaceCurve, SurfaceInt, TNBFrame, TangentLine, TangentPlane, TangentVector, Torsion, Vector, VectorField, VectorPotential, VectorSpace, Wronskian, diff, eval, evalVF, int, limit, series]
interface(imaginaryunit = F)
I
M := Pi*theta-S*c__1-S*lambda+S__v*v__2
Y := -S__v*c__2*lambda+Pi*b__1+S*v__1-S__v*c__3
P := S__v*alpha+`&rho;__A`*A+c__4*`&rho;__Q`*Q+I*`&rho;__I`-µ*V
Q*c__4*rho__Q+A*rho__A+I*rho__I+S__v*alpha-V*µ
R := S__v*c__2*lambda-E*c__5+S*lambda
U := E*a*delta+Q*k*`&rho;__Q`-A*c__6
E*a*delta+Q*k*rho__Q-A*c__6
L := c__7*E-I*c__8
E*c__7-I*c__8
X := q__E*E+I*q__I-c__9*Q
E*q__E+I*q__I-Q*c__9
solve({L = 0, M = 0, P = 0, R = 0, U = 0, X = 0, Y = 0}, {I, A, E, Q, S, S__v, V})
{A = (a*c__8*c__9*delta+c__7*k*q__I*rho__Q+c__8*k*q__E*rho__Q)*lambda*Pi*(b__1*c__1*c__2+b__1*c__2*lambda+c__2*lambda*theta+c__2*theta*v__1+b__1*v__2+c__3*theta)/(c__6*c__9*c__5*c__8*(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2)), E = lambda*Pi*(b__1*c__1*c__2+b__1*c__2*lambda+c__2*lambda*theta+c__2*theta*v__1+b__1*v__2+c__3*theta)/(c__5*(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2)), I = c__7*lambda*Pi*(b__1*c__1*c__2+b__1*c__2*lambda+c__2*lambda*theta+c__2*theta*v__1+b__1*v__2+c__3*theta)/(c__5*c__8*(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2)), Q = (c__7*q__I+c__8*q__E)*lambda*Pi*(b__1*c__1*c__2+b__1*c__2*lambda+c__2*lambda*theta+c__2*theta*v__1+b__1*v__2+c__3*theta)/(c__9*c__5*c__8*(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2)), S = Pi*(c__2*lambda*theta+b__1*v__2+c__3*theta)/(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2), S__v = Pi*(b__1*c__1+b__1*lambda+theta*v__1)/(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2), V = Pi*(a*b__1*c__1*c__2*c__8*c__9*delta*lambda*rho__A+a*b__1*c__2*c__8*c__9*delta*lambda^2*rho__A+a*c__2*c__8*c__9*delta*lambda^2*rho__A*theta+a*c__2*c__8*c__9*delta*lambda*rho__A*theta*v__1+b__1*c__1*c__2*c__4*c__6*c__7*lambda*q__I*rho__Q+b__1*c__1*c__2*c__4*c__6*c__8*lambda*q__E*rho__Q+b__1*c__1*c__2*c__7*k*lambda*q__I*rho__A*rho__Q+b__1*c__1*c__2*c__8*k*lambda*q__E*rho__A*rho__Q+b__1*c__2*c__4*c__6*c__7*lambda^2*q__I*rho__Q+b__1*c__2*c__4*c__6*c__8*lambda^2*q__E*rho__Q+b__1*c__2*c__7*k*lambda^2*q__I*rho__A*rho__Q+b__1*c__2*c__8*k*lambda^2*q__E*rho__A*rho__Q+c__2*c__4*c__6*c__7*lambda^2*q__I*rho__Q*theta+c__2*c__4*c__6*c__7*lambda*q__I*rho__Q*theta*v__1+c__2*c__4*c__6*c__8*lambda^2*q__E*rho__Q*theta+c__2*c__4*c__6*c__8*lambda*q__E*rho__Q*theta*v__1+c__2*c__7*k*lambda^2*q__I*rho__A*rho__Q*theta+c__2*c__7*k*lambda*q__I*rho__A*rho__Q*theta*v__1+c__2*c__8*k*lambda^2*q__E*rho__A*rho__Q*theta+c__2*c__8*k*lambda*q__E*rho__A*rho__Q*theta*v__1+a*b__1*c__8*c__9*delta*lambda*rho__A*v__2+a*c__3*c__8*c__9*delta*lambda*rho__A*theta+b__1*c__1*c__2*c__6*c__7*c__9*lambda*rho__I+b__1*c__2*c__6*c__7*c__9*lambda^2*rho__I+b__1*c__4*c__6*c__7*lambda*q__I*rho__Q*v__2+b__1*c__4*c__6*c__8*lambda*q__E*rho__Q*v__2+b__1*c__7*k*lambda*q__I*rho__A*rho__Q*v__2+b__1*c__8*k*lambda*q__E*rho__A*rho__Q*v__2+c__2*c__6*c__7*c__9*lambda^2*rho__I*theta+c__2*c__6*c__7*c__9*lambda*rho__I*theta*v__1+c__3*c__4*c__6*c__7*lambda*q__I*rho__Q*theta+c__3*c__4*c__6*c__8*lambda*q__E*rho__Q*theta+c__3*c__7*k*lambda*q__I*rho__A*rho__Q*theta+c__3*c__8*k*lambda*q__E*rho__A*rho__Q*theta+alpha*b__1*c__1*c__5*c__6*c__8*c__9+alpha*b__1*c__5*c__6*c__8*c__9*lambda+alpha*c__5*c__6*c__8*c__9*theta*v__1+b__1*c__6*c__7*c__9*lambda*rho__I*v__2+c__3*c__6*c__7*c__9*lambda*rho__I*theta)/(c__5*c__6*c__8*c__9*µ*(c__1*c__2*lambda+c__2*lambda^2+c__1*c__3+c__3*lambda-v__1*v__2))}
lambda := beta*(I+`&eta;__A`*A+`&eta;__Q`*Q)/N
beta*(I+eta__A*A+eta__Q*Q)/N
k := .15
.15
delta := .125
.125
mu := 0.464360344e-4
0.464360344e-4
pi := .464360344
.464360344
(15)
delta__Q := 0.6847e-3
0.6847e-3
(16)
beta := .1086
.1086
(17)
q__E := 0.18113e-3
0.18113e-3
(18)
rho__Q := 0.815e-1
0.815e-1
(19)
a := .16255
.16255
(20)
v__1 := 0.5e-1
0.5e-1
(21)
v__2 := 0.5e-1
0.5e-1
(22)
alpha := 0.57e-1
0.57e-1
(23)
lambda := 0.765e-2
0.765e-2
(24)
rho__A := 0.915e-1
0.915e-1
(25)
rho__I := 0.515e-1
0.515e-1
(26)
a := .16255
.16255
(27)
q__I := 0.1923e-2
0.1923e-2
(28)
q__A := 0.4013e-7
0.4013e-7
(29)
eta__A := .1213
.1213
(30)
eta__Q := 0.3808e-2
0.3808e-2
(31)
w := .5925
.5925
(32)
Download Bifurcation_Equation.mw
the graf that I want to generate is like this one
Dear experts
how can I numerically plot the following integral and have output as csv file.
in this relation, there is a list of omega1 and omega2 for each k1 and k2. for example,
k1 = [1,2,3,4,5]
omega11=[1,2,3,4,5], omega12= [1,2,3,4,5], omgega21= [1,2,3,4,5],omega22= [1,2,3,4,5],
all other coefficients would be calculated based on k values and corresponding omegas
thanks in advance
Given a pde (or a set of pdes) of multiple funcitons, is there a way to look for solutions when one of the functions is kept arbritary.
For example if I have a set of pdes with f1,f2,f3. Is there a way to see if there is a functional form for f2 and f3 such that the equation is satisfied for any f1?
It appears to me that "simplify/siderels" with two arguments is simply some special "simplify" procedure that just makes use of assumptions, but the results of experiments seem to tell an opposite story.
simplify(sqrt(x**2), [x = 0]);
simplify(sqrt(x**2), assume = [x = 0]);
simplify(ln(exp(x)), [x = 0]);
simplify(ln(exp(x)), assume = [x = 0]);
                               x
`assuming`(simplify(ln(exp(x))), [x = 0]);
                               x
simplify((1 - cos(x)**2 + sin(x)*cos(x))/(sin(x)*cos(x) + cos(x)**2), [sin(x)**2 + cos(x)**2 = 1]);
                  1 - cos(x)  + sin(x) cos(x)
                   cos(x) (cos(x) + sin(x))
simplify((1 - cos(x)**2 + sin(x)*cos(x))/(sin(x)*cos(x) + cos(x)**2), assume = [sin(x)**2 + cos(x)**2 = 1]);
                             tan(x)
How to explain these?
Today, I trried to enter an equation into a text region using Ctrl+R (In Maple Flow 2023.1), like I have always done in previous releases of Maple Flow. Well, today it did not work. I tried to enter the equation Q=W+mCv(T2-T1). When I tried to enter the equal sign after the Q, the program would not allow me to do it. I would press the equal sign and nothing happened. I tried :=, but it would only enter the :, it would not let me enter the =. Any help will be appreciated.
(While using Maple 2015 this question concerns any other Maple versions)
I hesitated on the title to write and my first idea was to write "How to modify a built-in functions without making a mess?".
I finally changed my mind in order not to orient the answers in a wrong way.
So this question is about the construction of multi-variate distributions and concerns only the Statistics package.
Here are some of the attributes of a univariate random variable that Maple recognizes, and it is quite normal to expect that the construction of a multi-variate random variable (MVRV for short) distribution should get, at least, some of them.
X := RandomVariable(Normal(a, b)):
map(a -> printf("%a\n", a), [exports(attributes(X)[3])]):
Conditions
ParentName
Parameters
CharacteristicFunction
CDF
CGF
HodgesLehmann
Mean
Median
MGF
Mode
PDF
RousseeuwCrouxSn
StandardDeviation
Support
Variance
CDFNumeric
QuantileNumeric
RandomSample
RandomSampleSetup
RandomVariate
MaximumLikelihoodEstimate
If the distribution is continuous the PDF is fundamental in the sense it enables constructs all the other statistics (=attributes) of a MVRV.
But it is nice to use integrated functions, such as Mean, Support, PDF, and so on, to get the expressions or values of these statistics instead of computing them from this PDF.
Let's that I prefer doing this
MyNormal := proc(m, v)
  description "Reparameterized Normal randomvariable, m=mean, v=variance":
  Distribution(
    PDF = (t -> exp(-1/2*(x-m)^2/v)/sqrt(2*Pi*v))
    , Conditions = [Sigma > 0]
    , Mean =m
X := RandomVariable(MyNormal(mu, Sigma)):
Mean(X)
                              m
than doing this
  Distribution(
Mean(X);  # of course undefined
mean := int(PDF(X, x), x=-infinity..+infinity) assuming Sigma > 0
                           undefined
                           mean := 1
So, while all the statistics can be recover from the CDF (provided it exists), it's nicer to define these statistics within the Distribution structure (as in the first construction above).
Now some problems appear when you want to construct the Distribution structure for a MVRV.
The attached file contains the construction of MVRV whose ecah components are mutually independent (to keep the things simple) and both have a Unifom distribution.
MV_Uniform.mw
Here are some observations:
  • Defining a multi-variate PDF goes without problems.
  • Defining the Mean (or many other algebraic or numeric statistics) presents a difficulty related to the type of the arguments the build-in function Mean is aimed to recieve.
    But a workaround, not very elegant, can be found.
  • The case of the Support seems unsolvable: I wasn't able to find any workaround to define the support of a MVRV.
  • I did not consider the Conditions attribute, but I'm not sure that, in the case of, let's say, a bi-gaussian random variable I would be capable to set that the variance is a symmetric positive-definite matrix?
I feel like the main restriction to define such MVRV distributions is the types used in the buid-in functions used in the Distribution structure.
Does anyone have an idea to tackle this problem?
  • Are we doomed to use workarounds like the one I used for defining the MVRV mean?
  • Can we modify the calling sequence of some build-in functions without making a mess and keep them working on build-in distributions?
  • Must we overload the construction of these build-in functions?
    Doing for instance:
    with(Statistics):
    local Mean:
    Mean := proc(...) ... end proc
Thanks in advance for any suggestion and help.
 For the command LieAlgebras[RootSpaceDecomposition] I don't understand what the command return, I read the help and see the examples but still not understanding.
for example it returns:
RSD := RootSpaceDecomposition(CSA);
RSD := table([[-2, -1] = E31, [2, 1] = E13, [1, 2] = E23, [1, -1] = E12, [-1, 1] = E21, [-1, -2] = E32])
I don't understand what means [-2, -1] even they said that is the root but I know that a root is in h* so it must be only a number not a vector.
I am trying to convert from MapleSim to Simulink Matlab by using the S-function code Generation connector, but I got the above message when I uploaded the selected subsystem and I have no idea how can I fix it. Please help.
eta/2*diff(f, eta) + (diff(f, eta, eta) + lambda*diff(g, eta)/g)*g^lambda=0,
g*diff(g, eta) + sigma*eta*diff(g, eta)=0,here lambda,sigma positive parameters initial conditions f'(0)=0,g'(0)=0,f' goes to 1 at eta goes to infinity ,g' goes to 1 at eta goes to infinity
can you solve this coupled nonlinear differential equations  using homotopy analysis method
I cannot view 3d graphics with my version of Ubuntu 20.04. I've updated all my computer's graphics card drivers and the problem persists. If I run without hardware acceleration, nothing changes; no visualization and no production possible.
Do you have any ideas for solving this problem? Maple uses OpenGL libraries for 3D production and visualization, and these libraries are installed on my computer. Would installing mesa solve the problem, for example?
A very easy example:
solve({a > 0, ln(a) + ln(1 + a) >= 0}, a);
                        /    2         \
                        |---------- < a|
                       <  (1/2)         >
                        |5      + 1    |
The output is . Clearly,  is also a solution to this inequality, so the solutions have been lost. But there is no warning message. Why?
I would like if we can solve a problem of a  field homomorphism between two fields.
Please, if possible a code that help me to define the homomorphism between finite field.
homomorphism_finite_field.mw
I found another big problem.
In 2022, I get Error, (in SolveTools:-Polynomial) too many levels of recursion when using alias(seq(c[k] = _C||k, k = 0..10)); at the top of my code and the solution to the ode has c[2],c[3] etc.. as constants of integration.
This solution was given by Kitonum in this answer
I had this for years in the code (i.e. the alias) code.
In Maple 2022 the following gives the above exception error from odetest. I am using 2022, because in 2023 it just hangs on the same code.
If I remove the alias code, no error shows. (solution is wrong, but that is different story).
Also, If I remove the alias code, 2023 no long hangs!
#kernelopts('assertlevel'=2):
c[0], c[1], c[2], c[3], c[4], c[5], c[6], c[7], c[8], c[9], c[10]
ode:=diff(diff(y(x),x),x)+4*diff(y(x),x)+12*y(x) = 80*sin(2*x);
sol:=y(x) = -10*exp(-1/2*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*((-1/10*exp(4*I*2^(1/2)*x)+1/10)*c[2]-1/10*I*c[3]*exp(4*I*2^(1/2)*x)-1/10*I*c[3])/((exp(4*I*2^(1/2)*x)-1)*c[2]+I*c[3]*exp(4*I*2^(1/2)*x)+I*c[3])*c[1]-10*I*exp(-1/2*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*(cos(2*x)-sin(2*x))*exp(2*I*2^(1/2)*x)*exp(2*I*2^(1/2)*x)^(-1/2*I*2^(1/2))/((exp(4*I*2^(1/2)*x)-1)*c[2]+I*c[3]*exp(4*I*2^(1/2)*x)+I*c[3]);
odetest(sol,ode);
diff(diff(y(x), x), x)+4*(diff(y(x), x))+12*y(x) = 80*sin(2*x)
y(x) = -10*exp(-(1/2)*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*((-(1/10)*exp((4*I)*2^(1/2)*x)+1/10)*c[2]-((1/10)*I)*c[3]*exp((4*I)*2^(1/2)*x)-((1/10)*I)*c[3])*c[1]/((exp((4*I)*2^(1/2)*x)-1)*c[2]+I*c[3]*exp((4*I)*2^(1/2)*x)+I*c[3])-(10*I)*exp(-(1/2)*2^(1/2)*arctan(sin(2*2^(1/2)*x)/cos(2*2^(1/2)*x)))*(c[3]*cos(2*2^(1/2)*x)+c[2]*sin(2*2^(1/2)*x))*(cos(2*x)-sin(2*x))*exp((2*I)*2^(1/2)*x)*(exp((2*I)*2^(1/2)*x))^(-((1/2)*I)*2^(1/2))/((exp((4*I)*2^(1/2)*x)-1)*c[2]+I*c[3]*exp((4*I)*2^(1/2)*x)+I*c[3])
Download odetest_error_june_15_2023.mw
Why using the alias line above causes this error?  If you remove the alias line, you will see it completes with no error.
But it hangs in 2023. I am no longer using 2023 but went back to 2022 due to too many hangs in 2023. I wonder now if it because of this alias line I had there all the time.  I will remove now and see if this solves some of the hangs I had in 2023.
Anyone can shed some more light on what is going on?
Windows 10.
  Can someone guide me on how to write the code for this program?
sh.docx
First 53 54 55 56 57 58 59 Last Page 55 of 372
