I read the article "ONEOptimal: A Maple Package for Generating One-Dimensional Optimal System of Finite Dimensional Lie Algebra", and also searched out in Maplesoft website, but couldn't found. Does anyone have the package?
I am trying to see if there is a way to submit maple code as a worksheet and get results back as worksheets in a cluster.
The following 2D integrals of 0 are seemingly trivial and one would expect them to evaluate to zero, but Maple evaluates them to undefined
int(0, x=0..infinity, y=0..1) # undefined
int(0, x=0..1, y=0..infinity) # undefined
When the 2D integral is split into two 1D integrals, it does evaluate to zero, as the following examples show
int(0,x=0..infinity) # 0
int(int(0,x=0..infinity), y=0..1) # 0
int(int(0,x=0..1),y=0..infinity) # 0
If infinity is replaced by a variable (say 'c'), the first two integrals are also evaluated to zero.
It may be connected by the following
int(a, x=0..infinity, y=0..1) # a*infinity
int(a, x=0..1, y=0..infinity) # a*infinity
int(a,x=0..infinity) # signum(a)*infinity
So for the 1D integrals the signum is applied to 'a' when the interval is infinite, but not for the 2D integrals. I'm not sure about this difference.
Is it possible to read in specific parts of a bmp image?
Given a constant gamma, gaussian random variables S[1] and S[2], and a linear combination of gaussian random variables Omega, I need to compute Exp[ Omega | S[1], S[2] ] - (gamma/2)*Var[ Omega | S[1], S[2] ]. I am not experienced in Maple. In the attached script I include many step-by-step details on what I need to do, as well as some notes where I get stuck:
150423_OptimizationProblem.mw
It would be convenient if you could directly fix this and share the working version. Thanks!
The conditional means and variance terms are calculated according to the 2D version of the script 3_gaussian_mmcdara.mw provided by @mmcdara.
As usual, I have a tricky question. There is an integral that Maple can take numerically
R0 := 1/(a-sqrt(b+c*cos(x)));
Now let's put the coefficients, e.g.
 a := 0.9; b := 4.5; c :=0.1
and take the integral from 0 to 2*Pi
R1 := evalf(int(R0, x = 0 .. 2*Pi));
Also, there is an exact analytical result that Maple gives (I give it after simplifying it to avoid division by zero for the limit x=0 and x=2*Pi)
R2:=-4*((a^2-b+c)*EllipticK(sqrt(-2*c/(b-c)))-a^2*EllipticPi(2*c/(a^2-b+c), sqrt(-2*c/(b-c))))/((a^2-b+c)*sqrt(b-c));
As it turns out, the results are completely different. In the first case -5.145818656, while for the second case -3.612771378+0.I
Moreover, If we change the coefficients to a := 0.9; b := 4.5; c := -4 then I obtain Float(undefined)+3.662506136*I and -2.362349457+3.662506117*I , respectively.
My question: how to avoid this descepancy?
According to this help page,
the transitive reduction of graph G, is the graph with the fewest edges that still shares the same reachability as G (but might contain new edges not present in G).
However, in Maple 2023, things become strange; different branches return distinct numbers of edges:
(33 arcs or 40 arcs?)
with(GraphTheory):
showstat(TransitiveReduction, 4)
GraphTheory:-TransitiveReduction := proc(G::GRAPHLN, $)
local D, V, T, i, j, k, A, M, n, flags, B;
   4   if _EnvDisableExt <> true then
       elif D <> (':-directed') then
G__0 := Digraph({[2, 8], [3, 1], [4, 9], [5, 10], [6, 19], [7, 12], [8, 13], [9, 3], [10, 4], [10, 14], [11, 5], [11, 15], [12, 6], [12, 16], [13, 7], [13, 17], [14, 9], [15, 10], [15, 18], [16, 19], [17, 12], [17, 20], [18, 14], [19, 11], [19, 21], [20, 22], [21, 18], [22, 16], [22, 23], [23, 19]})
G__0 := `Graph 1: a directed graph with 23 vertices and 30 arc(s)`
G__1 := TransitiveReduction(G__0)
G__1 := `Graph 2: a directed graph with 23 vertices and 33 arc(s)`
_EnvDisableExt := trueG__2 := TransitiveReduction(G__0)
G__2 := `Graph 3: a directed graph with 23 vertices and 40 arc(s)`
IsIsomorphic(G__1, G__2)
false
Download TransReduction.mw
Any bugs?
G__0 := GraphTheory:-Digraph({[3, 1], [9, 3], [4, 9], [14, 9], [10, 4], [5, 10], [15, 10], [11, 5], [19, 11], [12, 6], [7, 12], [17, 12], [13, 7], [8, 13], [2, 8], [10, 14], [18, 14], [11, 15], [6, 19], [16, 19], [23, 19], [13, 17], [15, 18], [21, 18], [12, 16], [22, 16], [22, 23], [20, 22], [19, 21], [17, 20]}):
How to find the similarity matrix that applies A in N, B in P, C in C and B in M;
with(geometry):
_EnvHorizontalName = 'x':  _EnvVerticalName = 'y':
#Vdot := proc(U, V) local i; add(U[i]*V[i], i = 1 .. 2); end proc
point(A, 0, 1);
point(B, 1, 1);
point(C, 1, 0);
point(E, 0, 0);
square(Sq, [A, B, C, E]);
Phi := (1 + sqrt(5))/2;
point(N, (2 - Phi)/(Phi - 1), 1);
line(BE, [B, E]);
MakeSquare(s1, [N, C, 'diagonal']);
point(M, (3 - sqrt(5))/(2*sqrt(5) - 2), (3 - sqrt(5))/(2*sqrt(5) - 2));
point(P, (1 + sqrt(5))/(2*sqrt(5) - 2), (3*sqrt(5) - 5)/(2*sqrt(5) - 2));
                               A
                               B
                               C
                               E
                               Sq
                             1   1  (1/2)
                      Phi := - + - 5
                             2   2
                               N
                               BE
                               s1
                               M
                               P
 display(draw([
A(color = black, symbol = solidcircle, symbolsize = 12),
B(color = black, symbol = solidcircle, symbolsize = 12),
C(color = black, symbol = solidcircle, symbolsize = 12),
E(color = black, symbol = solidcircle, symbolsize = 12),
N(color = black, symbol = solidcircle, symbolsize = 12 ),
Sq(color=red),BE(color=green),
s1(color = blue)]),
textplot([[coordinates(A)[], "A"],
[coordinates(B)[], "B"],
[coordinates(E)[], "E"],
[coordinates(N)[], "N"],
[coordinates(P)[], "P"],
[coordinates(M)[], "M"],
[coordinates(C)[], "C"]], align = [above, right]), axes = none); Thank you.
I can derive a symbolic solution by hand for the following ODE, but cannot get Maple to do it for me.  Any tricks?
Velocity field, -infinity < x and x < infinity,  t > 0.
v := (x,t) -> piecewise(x <= -t, 0, x < t, 1 - 1/2*(1 - x/t));
v := proc (x, t) options operator, arrow; piecewise(x <= -t, 0, x < t, 1/2+(1/2)*x/t) end proc
Position x(t):
de := diff(x(t),t) = v(x(t),t);
de := diff(x(t), t) = piecewise(x(t) <= -t, 0, x(t) < t, 1/2+x(t)/(2*t))
Initial condition, assuming a > 0
ic := x(0) = -a;
x(0) = -a
Symbolic solution, calculated by hand:
x__exact := t -> piecewise(t < a, -a, t - 2*sqrt(t)*sqrt(a));
x__exact := proc (t) options operator, arrow; piecewise(t < a, -a, t-2*sqrt(t)*sqrt(a)) end proc
Verify exact solution by comparing it against the numeric solution for some a > 0:
a := 3;  # any a>0 should do
dsol := dsolve({de,ic}, numeric):
plots:-odeplot(dsol, t=0..5);   # dsolve solution
plot(x__exact(t), t=0..5);      # symbolic solution (calculated by hand)
a := 'a';
a
Can Maple's dsolve find the exact solution?  This one returns empty in Maple 2022:
dsolve({de, ic}) assuming a > 0, t > 0;
Download ode-piecewise.mw
I need your help....
I want to use the maple 2023 kernel in jupyter lab. I followed, to knowledge, the maple installation in windows10 and could not get it to work
after numerous attempts. Maybe it is a path issue that I am getting wrong.
I decided to use it with EndeavourOS distro for Linux as Sagemath interest me. Here it recognizes the kernel but gives syntax errors when
running code; it does not understand ‘:-’ for example.
Again I used maple suggested installation to no avail.
I used the alternative following comands and it recognizes Maple2023 in the kernels menu but to repeat does not run code, simply gives errors.
sudo pacman -S python-jupyterlab
python -m venv maple2023
source maple2023/bin/activate
pip install jupyter ipykernel
python -m ipykernel install --user --name=maple2023
jupyter kernelspec list
Often, in response to a question without code, the suggestion is made to upload a Maple file using the button with the green arrow .
This happens so often that I get the impression that new users don't recognize this as the best and most efficient way to get their question analyzed and answered. Or they just don't know how to do it.
So why not adding a hint to consider uploading code just before "Suggested Tags"?
If I have a pde with multiple constants (for example a and b) in them such that some are fixed constants (say k) and some terms are undetermined constants , how do I put that in a PDE such that Maple knows to solve the equation not for arbritary k (in case no solution exists), but any k such that k is not a function of the differentiating variable.
I put this command and It keep saying  plot(f(x), x = -0.667 .. 1.71, y = -5 .. 20, gridlines); Error, (in plot) unexpected options: [1.71 = -.667 .. 1.71, y = -5 .. 20] . How can I fix this
First 57 58 59 60 61 62 63 Last Page 59 of 372
