I've been using Maple Flow for awhile and generally pleased with its performance...until today.
Going through my normal workflow, the sheet stopped evaluating and a little troubleshooting later it seems that the issue is that once I use a keyboard shortcut to include units, the sheet will not evaluate anything going forward.
Once
Let a, b be arbitrary real parameters. I intend to compute something like: (with exact piecewise output)
Optimization:-Maximize(8*x + 7*y, {5*y <= 6 - 9*b, -6*x - 4*y <= 8 - 5*a - 7*b, -4*x + 7*y <= -1 - 2*a - 7*b, -x + y <= 6 + 4*a - 5*b, 7*x + 5*y <= a + 4*b}, variables = {x, y}): # Error
Optimization:-Minimize((x - 1)^2 + (2*y - 1)^2, {x - 2*y <= 2*a - b + 1, x + 2*y <= a + b, 2*x - y <= a - b + 1}, variables = {x, y}): # Error
Unfortunately, these Maple codes are virtually invalid, and the relevant commands minimize, maximize, extrema, and Student[MultivariateCalculus][LagrangeMultipliers] do not support general inequality constraints. Is it possible to tackle these small-scale constrained parametric problems in Maple?
Quite often, Maple freezes, and the file cannot be saved, and Maple cannot be closed.
Did you get the problem ?
Can someone give me an example for using
linear regressor function from deep learning package
By passing one dependent variable say Y
And a set of independent variables say X
As a matrix say
Can we be able to split data into train and test and use this linear regressor command on train and do validation
As I am not able to see some examples on the implementations using command kind help
Can i use Maple to do satellite image classification . by implement the satellite image so the software will do the math processing ?
Hope the resolution of the images which come via Plot3d and plot commands are atleast 300 dpi
If not how to make them
After a long hiatus I have come back to the issue of null tetrads in the physics package in light of the updates to  Maple in 2021. I have uploaded a document file to illustrate. See below. My first question concerns the labelling of elements of a null tetrad. After calling the metric 27,37 from Stephani et al, and using Setup to specify a null tetrad, Maple's choice is such that the elements labelled m and bar m are not complex. Rather, both these elements are in fact real, while the elements lablled l and n are complex, with one being the negative complex conjugate of the other. While these are just labels, they don't agree with the usual conventions for the Newman-Penrose formalism, which is disorienting. What convention is Maple using to label the elments of a null tetrad?
Next, I try to specify the null tetrad used by Stephani et al., first by converting it into covariant form (which I did by hand rather than in Maple). In Maple's default null tetrad, the order in which Maple listed the elements of the null tetrad is n, m, bar m, l (as rows in the matrix display for e_[ ]), so I followed that convention (in the conventions of Stephani et al., the first and fourh element should have scalar product -1, the second and third scalar product 1, and all other scalar products zero, which is the case). After entering the matrix and using Setup to specify the null tetrad by the matrix, I get an error message saying that the components of the metric with respect to my tetrad are not just 0, 1, and -1. Yet,  executing eta_[ ]  does not confirm this warning; nor does a computation by hand.
Finally, IsTetrad asserts the tetrad is not null, contrary to the fact that it is a null tetrad.
Since I have followed the conventions implicit in Maple's default null tetrad for this metric, I am puzzled as to what has gone wrong.SKMHH27_37_2021_New.mw
On the other hand, taking into account how Maple 2019 orders the coordinates in Stephani et al 27.37 and labels the null vectors in a null ttetrad, if I translate accordingly what I have in the 2021 Maple file, Maple 2019 confirms Stephani et al.'s null tetrad is indeed a null tetrad, as one would expect. See the following file.SKMHH27_37_2019_Var.mw.
Hello everybody.
My goal is to solve the following integro-functional equation:
(int(p^2/(f(p)-f(p+q)+omega), p = a .. b))/omega^2 = ln(omega^2+q^2)
where where is the unknown function and a, b are some numerical values as well as ω and q are real positive variables.
I would be grateful for any ideas.
Hello I cant sign in on my other MapleCloud account to view all my other Maple Documents.
It says "Oops an error stopped us, from verifying your account. Please sign in again or continue using public MapleCloud features maple" Any suggestions on how to fix it?
@nm I can see that working for a signal that has a starting point other than 0 and no other shifts involved, but I am wondering about signals built from shifted steps / ramps / etc.  If the forcing function is something like r(t) - u(t-1) - r(t-1) with u(t)=Heaviside(t) and r(t) = t Heaviside(t).  I won't have time to see if I can break Maple with that until this weekend, but I plan to try!
Streamlines, isotherms and microrotations for Re = 1, Pr = 7.2, Gr = 105 and (a) Ha = 0 (b) Ha = 30 (c) Ha = 60 (d) Ha = 100.
Fig. 2
for Ra = 105Ha = 50, Pr = 0.025 and θ = 1 − Y
eqat := {M . (D(theta))(0)+2.*Pr . f(0) = 0, diff(phi(eta), eta, eta)+2.*Sc . f(eta) . (diff(phi(eta), eta))-(1/2)*S . Sc . eta . (diff(phi(eta), eta))+N[t]/N[b] . (diff(theta(eta), eta, eta)) = 0, diff(g(eta), eta, eta)-2.*(diff(f(eta), eta)) . g(eta)+2.*f(eta) . (diff(g(eta), eta))-S . (g(eta)+(1/2)*eta . (diff(g(eta), eta)))-1/(sigma . Re[r]) . ((1+d^%H . exp(-eta))/(1+d . exp(-eta))) . g(eta)-beta^%H . ((1+d^%H . exp(-eta))^2/sqrt(1+d . exp(-eta))) . g(eta) . sqrt((diff(f(eta), eta))^2+g(eta)^2) = 0, diff(theta(eta), eta, eta)+2.*Pr . f(eta) . (diff(theta(eta), eta))-(1/2)*S . Pr . eta . (diff(theta(eta), eta))+N[b] . Pr . ((diff(theta(eta), eta)) . (diff(phi(eta), eta)))+N[t] . Pr . ((diff(theta(eta), eta))^2)+4/3 . N . (diff((C[T]+theta(eta))^3 . (diff(theta(eta), eta)), eta)) = 0, diff(f(eta), eta, eta, eta)-(diff(f(eta), eta))^2+2.*f(eta) . (diff(f(eta), eta))+g(eta)^2-S . (diff(f(eta), eta)+(1/2)*eta . (diff(f(eta), eta, eta)))-1/(sigma . Re[r]) . ((1+d^%H . exp(-eta))/(1+d . exp(-eta))) . (diff(f(eta), eta))-beta^%H . ((1+d^%H . exp(-eta))^2/sqrt(1+d . exp(-eta))) . (diff(f(eta), eta)) . sqrt((diff(f(eta), eta))^2+g(eta)^2) = 0, g(0) = 1, g(6) = 0, phi(0) = 1, phi(6) = 0, theta(0) = 1, theta(6) = 0, (D(f))(0) = 1, (D(f))(6) = 0};
sys1 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys2 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys3 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys4 := eval(eqat, {M = 0, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys5 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys6 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys7 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys8 := eval(eqat, {M = .5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys9 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys10 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys11 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys12 := eval(eqat, {M = 1, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
sys13 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .2, d^%H = 1.5});
sys14 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .4, d^%H = 1.5});
sys15 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .6, d^%H = 1.5});
sys16 := eval(eqat, {M = 1.5, N = 2, Pr = .8, S = -2.5, Sc = .5, d = 2, sigma = .2, C[T] = .5, N[b] = .4, N[t] = .4, Re[r] = 1.1, beta^%H = .8, d^%H = 1.5});
I ploted the step response of a MIMO system in Maple using DynamicSystems object.
The plot is incorrect.
What am I doing wrong?
Thanks for your help
I have a system described by
I want to plot Y(s)/Z(s) = ((C . (1/((s . I) - A))) . B) + D with stepped inputs on both inputs
The system above evaluates to
My commands are
ss_a := A__m;
ss_b := B__m;
ss_c := C__m;
ss_d := D__m;
sys4 := StateSpace(ss_a, ss_b, ss_c, ss_d);
plots:-display([ResponsePlot(sys4, [Step(), Step()], 'duration' = 5, color = red)]);
Maple is returning the incorrect plot
The correct plot is
SYSTEM
Correct plot
I would like to solve this system of PDEs along the x-interval [0,1] in three different subintervals: from 0 to 0.35, from 0.35 to 0.6, and from 0.6 to 1. I tried to solve the system by setting these same subintervals as you might see in my script, however it is now what I need. Any help would be very appreciated.
d1 := 0.05;
d2 := 0.3;
AA := 0.2;
BB := 0.1;
PDE1 := diff(u(x, t), t) = d1*diff(u(x, t), x, x) + w(x, t)*exp(AA*u(x, t) - BB*v(x, t));
PDE2 := diff(v(x, t), t) = d2*diff(v(x, t), x, x) - w(x, t)*exp(AA*u(x, t) - BB*v(x, t));
PDE3 := 0.0001*diff(w(x, t), t) = diff(w(x, t), x) - 0.8*x + 3.3;
IBC1 := u(0, t) = 1, u(1, t) = 0, u(x, 0) = piecewise(x < 0.35, -(4*x)*x + 1, 0.35 < x and x < 0.65, 1.32958 - 1.29167*x, 0.65 < x, 4*(x - 1)^2);
IBC2 := v(0, t) = 0, v(1, t) = 1, v(x, 0) = piecewise(x < 0.35, (4*x)*x + 1, 0.35 < x and x < 0.65, 1.32958 - 1.29167*x, 0.65 < x, -4*(x - 1)^2);
IBC3 := w(0, t) = 0.5, w(x, 0) = 1 - (0.3*x)*x;
pds := pdsolve([PDE1, PDE2, PDE3], [IBC1, IBC2, IBC3], numeric, time = t, range = 0 .. 1);
p1 := pds:-plot(t = 0, numpoints = 50);
p2 := pds:-plot(t = 1/8, numpoints = 50, color = blue);
p3 := pds:-plot(t = 1/4, numpoints = 50, color = green);
(Deleted because not reproducible on a different PC)
With 1D
int(1/(sqrt(x__0 - x)*sqrt(-x^2 + 1)), x = 0 .. x__0)
Warning, unable to determine if -1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
Warning, unable to determine if 1 is between 0 and x__0; try to use assumptions or use the AllSolutions option
int(1/((x__0-x)^(1/2)*(-x^2+1)^(1/2)), x = 0 .. x__0)
With 2D
int(1/(sqrt(x__0-x)*sqrt(-x^2+1)), x = 0 .. x__0)
The root cause might be the same as for this open question.
int_warning_2D.mw
int_warning_1D.mw
How to insert pagebreak using code itself where I want as i run code
As if I get more lines of output difficut to run through output give ctrl+Enter each place later
Kind help
First 60 61 62 63 64 65 66 Last Page 62 of 371
